    系统有时出现无法启动的情况,提示如下
      lingeasy LV 5 最后由 编辑
      系统启动的时候会出现如下提示,然后系统就停止了。
      [53]HELLO! BOOT0 is starting!
      [56]BOOT0 commit : 88480af
      [59]set pll start
      [61]periph0 has been enabled
      [64]set pll end
      [65][pmu]: bus read error
      [67]board init ok
      [69]ZQ value = 0x2e
      [71]get_pmu_exist() = -1
      [73]DRAM BOOT DRIVE INFO: V0.33
      [76]DRAM CLK = 528 MHz
      [78]DRAM Type = 2 (2:DDR2,3:DDR3)
      [81]DRAMC read ODT  off.
      [84]DRAM ODT off.
      [86]ddr_efuse_type: 0xa
      [88]DRAM SIZE =64 M
      [90]dram_tpr4:0x0
      [92]PLL_DDR_CTRL_REG:0xf8002b00
      [95]DRAM_CLK_REG:0xc0000000
      [97][TIMING DEBUG] MR2= 0x0
      [102]DRAM simple test OK.
      [104]dram size =64
      [106]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [111]block from 8 to 32
      [168]Check is correct.
      [170]dma 0x301a8 int is not used yet
      [174]dma 0x301a8 int is free, you do not need to free it again
      [180]Entry_name        = opensbi
      [183]Entry_name        = u-boot
      [187]Entry_name        = dtb
      [189]Jump to second Boot.
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP0    : 0x0000000041fc0000-0▒
      U-Boot 2018.07-ge987def-dirty (Apr 20 2023 - 11:37:55 +0800) Allwinner Technology
      [00.258]DRAM:  64 MiB
      [00.260]Relocation Offset is: 01ee9000
      [00.265]secure enable bit: 0
      can't support chip type 24064
      [00.271]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      sunxi flash map init
      SPI ALL:   ready
      [00.282]flash init start
      [00.284]workmode = 0,storage type = 0
      [00.292]sunxi-spinand-phy: spinand sample_mode:2 sample_delay:2
      defaults:
      mtdids  : nand0=nand
      [00.409]ubi0: attaching mtd4
      [00.526]ubi0: scanning is finished
      [00.533]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [00.538]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.544]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.550]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.557]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [00.562]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [00.569]ubi0: max/mean erase counter: 4/1, WL threshold: 4096, image sequence number: 0
      [00.576]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [00.588]sunxi flash init ok
      [00.591]line:703 init_clocks
      [00.594]drv_disp_init
      [00.615]drv_disp_init finish
      [00.720]Loading Environment from SUNXI_FLASH... OK
      [00.743]boot_gui_init:start
      [00.746]set disp.dev2_output_type fail. using defval=0
      ====LCD_power_on=====!!!!!!![00.755]set disp.fb0_rot_used fail. using defval=0
      [00.759]set disp.fb0_rot_degree fail. using defval=0
      [00.765]boot_gui_init:finish
      [00.783]bmp_name=b====----=====!!!!!!!ootlogo.bmp size 51798
      [00.795]out of usb burn from boot: not need burn key
      [00.800]Item0 (Map) magic is bad
      [00.829]update bootcmd
      [00.842]change working_fdt 0x42aa8da0 to 0x42a88da0
      [00.877]update dts
      Hit any key to stop autoboot:  1 ====LCD_bl_open=====!!!!!!!FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
      [00.951]LCD open finish
