    v853 RTSP 推流遇到问题
    • I
      igbt70 LV 4 最后由 whycan 编辑
      				*		AW RTSP LIB VERSION: 				*
      				*		BUILD BY WHO: 										*
      				*		BUILD TIME: 						*
         rtsp://192.168.0.22:8554/ch0
      I0101 01:29:16.964546  1497 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[1] Comp StateExecuting
      I0101 01:29:16.964726  1510 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 01:29:16.964919  1510 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[152000]bytes
      I0101 01:29:16.965001  1510 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[24000]bytes
      I0101 01:29:16.965067  1510 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
      I0101 01:29:16.965139  1510 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[1], EncppEnable=1
      I0101 01:29:16.965202  1510 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
      I0101 01:29:16.965298  1510 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
      I0101 01:29:16.965370  1510 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=0, ShareBufNum=0, OnlineEnableFlag=0
      I0101 01:29:16.965430  1510 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
      WARNING: cedarc <LDC_K_Adjust:45>: calib_w&h[0 x 0] is valid, force setup to 1920x1080
      [ISP_ERR]isp_stat_process_buffer, line: 268,AEWB: stats error, skipping buffer.
      [ISP_WARN]gc2053_mipi get sensor_temp failed: Invalid argument (22).
      [ISP]video device name is vin_video12
      [ISP]open video device[12], detect isp0 success!
      [ISP]---------   LDCI Video12 Init OK   ---------
      [ISP]--------- LDCI Video12 Streamon OK ---------
      I0101 01:29:17.691264  1508 videoInputHw.c:4882]            <VideoInputHw_CapThread> vipp[4] drop 10 frames done!
      I0101 01:29:17.741546  1509 VideoEnc_Component.c:6308]      <VideoEncEmptyThisBuffer> send frame when venc state[0x2] is not executing
      I0101 01:29:17.741717  1509 VideoEnc_Component.c:6383]      <VideoEncEmptyThisBuffer> VencChn[1]: first video frame pts[1665461569]us,tm1[1665461914]us, vSize[640x368], frmId[1,12]
      W0101 01:29:17.971324  1514 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      ERROR  : cedarc <updateOnlineParam:567>: ve_addr is null: 0x0
      Aborted (core dumped)
      I 1 条回复 最后回复 回复 引用 分享 0
      • I
        igbt70 LV 4 @igbt70 最后由 编辑
        @igbt70
        关闭了了主码流就正常了
        S 1 条回复 最后回复 回复 引用 分享 0
          sergpenshin LV 4 @igbt70 最后由 编辑
          Hi.
          I have the same problem: when I run sample_rtsp, I get error: fatal error! vencChn[0] get frame failed! check code!
          root@TinaLinux:/mnt# ./sample_rtsp -path sample_rtsp.conf
          I0101 00:07:30.651708  1030 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
          I0101 00:07:30.677710  1030 sample_rtsp.c:95]               <ParseCmdLine> sample virvi2venc path:[./sample_rtsp], arg number is [3]
          I0101 00:07:30.680299  1030 confparser.c:60]                <createConfParser> load conf file sample_rtsp.conf ok!
          I0101 00:07:30.680776  1030 sample_rtsp.c:292]              <loadSampleConfig> IspAndVeLinkage config: Enable=1, StreamChn=0
          Committed_AS:       4088 kB
          I0101 00:07:30.691137  1030 mpi_sys.c:840]                  <A[   76.511060] VE: before freq=300000000
          W_MPI_SYS_SetConf> kfctmpdir is [   76.517758] VE: real freq=300000000
          [/tmp]
          >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
          modName : MPP-Platform
          tag   : V1.0 Release
          branch: v5-dev
          commit: 4eed413532ad87725895a8cb1ba75e22fc328233
          date  : 20170725
          author: jenkins
          iniparser: cannot open /etc/cedarx.conf
          iniparser: cannot open /vendor/etc/cedarx.conf
          I0101 00:07:30.712703  1030 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
          [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
          IPCORE: ISP600
          branch: libisp-dev
          commit: 14df8348718d093707641fea73eba7db962885f5
          date  : Thu Jul 14 15:40:38 2022 +0800
          I0101 00:07:30.713672  1030 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
          INFO   : cedarc <VeInitialize:1185>: *** ic_version = 0x1302000023010,
          I0101 00:07:30.734337  1030 hwdisplay.c:84]                 <hw_display_init>
          I0101 00:07:30.734595  1030 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
          I0101 00:07:30.734808  1030 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
          I0101 00:07:30.738925  1030 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:0
          I0101 00:07:30.823111  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
          I0101 00:07:30.823324  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 volume
          I0101 00:07:30.823427  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC2 volume
          I0101 00:07:30.823508  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCDRC
          I0101 00:07:30.823584  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCHPF
          I0101 00:07:30.823657  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DAC volume
          I0101 00:07:30.823727  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACDRC
          I0101 00:07:30.823795  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACHPF
          I0101 00:07:30.823862  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEIN
          I0101 00:07:30.823935  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
          I0101 00:07:30.824171  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
          I0101 00:07:30.824295  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT
          I0101 00:07:30.824598  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
          I0101 00:07:30.824882  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT volume
          I0101 00:07:30.825078  1030 alsa_interface.c:756]           <alsaOpenMixer> set playback vol_val to value: 27
          I0101 00:07:30.825188  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1
          I0101 00:07:30.825411  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
          I0101 00:07:30.825529  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
          I0101 00:07:30.825618  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2
          I0101 00:07:30.825698  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
          I0101 00:07:30.825774  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
          I0101 00:07:30.825846  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:SPK
          I0101 00:07:30.826088  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:digital volume
          I0101 00:07:30.826204  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
          I0101 00:07:30.826293  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
          E0101 00:07:30.826389  1030 alsa_interface.c:970]           <alsaMixerSetAudioCodecHubMode> aec_elem_audio_codec_hub_mode:tx hub mode-1
          E0101 00:07:30.826518  1030 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
          I0101 00:07:30.826638  1030 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:1
          I0101 00:07:30.827539  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:loopback debug
          I0101 00:07:30.827712  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
          I0101 00:07:30.827824  1030 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
          E0101 00:07:30.827917  1030 alsa_interface.c:993]           <alsaMixerSetDAudio0HubMode> aec_elem_daudio0_hub_mode:tx hub mode-1
          E0101 00:07:30.828066  1030 alsa_interface.c:1016]          <alsaMixerSetDAudio0LoopBackEn> aec_elem_daudio0_loopback_en:loopback debug-1
          E0101 00:07:30.828214  1030 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
          I0101 00:07:30.828348  1030 sample_rtsp.c:490]              <configMainStream> main vipp0 ve_online_en:1, dma_buf_num:2, venc ch0 OnlineEnable:1, OnlineShareBufNum:2
          I0101 00:07:30.828444  1030 sample_rtsp.c:517]              <configMainStream> main EncppSharpAttenCoefPer: 100%
          I0101 00:07:30.828522  1030 sample_rtsp.c:527]              <configMainStream> main vbvThreshSize: 147450, vbvBufSize: 933882
          [ISP]video device name is vin_video0
          [ISP]open video device[0], detect isp0 success!
          I0101 00:07:31.160279  1030 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
          I0101 00:07:31.160840  1030 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[0] update width:1920(1920), height:1080(1088)
          I0101 00:07:31.160999  1030 videoInputHw.c:957]             <videoInputHw_SetChnAttr> ViCh[0] LBC pix:0x3132434c, line_tar_bits[0]:9216, line_tar_bits[1]:13824
          I0101 00:07:31.161826  1030 videoInputHw.c:977]             <videoInputHw_SetChnAttr> bs_len:61440, frm_bit:11520
          [ISP]video0 fd[10] ve_online_en=[   77.201400] [VIN]ve_online open, buffer_num is 2
          1, dma_buf_num=2
          open /dev/sunxi_soc_info failed![ISP]open isp device[0] success!
          [ISP_WARN]sdcard is not mounted!!!
          [ISP]prefer isp config: [gc2053_mipi], 1920x1088, 20, 0, 0
          [ISP]find gc2053_mipi_1920_1088_20_0 [gc2053_mipi_isp600_20220511_164617_vlc4_day] isp config
          [ISP]create isp0[   77.259044] [VIN]video0:buffer count is invalid, set to 2
           server thread!
             77.307974] VE: before freq=300000000Component.c:1160]
          60C<VideoViComponentInit> VideoV[   77.314952] VE: real freq=300000000
          irvi component Init! thread_id[0xb6889d50]
          I0101 00:07:31.509229  1030 VideoEnc_Component.c:704[   77.328301] VE: before freq=300000000
          2]                                                          <VideoEncComponentI[   77.334152] VE: real freq=300000000
          nit> create VideoEnc threadId:0xb6866d50
          I0101 00:07:31.509516  1030 VideoEnc_Component.c:2663]      <VideoEncSetChnAttr> vencChn[0] enable online!
          I0101 00:07:31.509650  1030 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[0] Comp StateIdle
          I0101 00:07:31.509840  1036 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 0, buf_num=2.
          I0101 00:07:31.510058  1038 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
          I0101 00:07:31.510327  1038 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[0] Create VeType=265
          iniparser: cannot open /tmp/libcedarc_dynamic_log_level
          INFO   : cedarc <cdc_log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
          WARNING: cedarc <LogVersionInfo:44>:
          >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cedar Codec <<<<<<<<<<<<<<<<<<<<<<<<<<<<
          tag   :
          branch: tina-v853-dev
          commit: ee230a47e5a2392ec315795121c2d112492fac1c
          date  : Fri Jul 22 10:37:50 2022 +0800
          author: wuguanjian
          change-id : I28fe0c31c718f097d61ad6bdbcb4cb5df0bd3575
          release_author : lichaopdc
          patch :
          I0101 00:07:31.549682  1030 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[0] set new framerate:20
          I0101 00:07:31.549916  1030 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[0] enable and set 2DFilter param
          I0101 00:07:31.550035  1030 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[0] enable and set 3DFilter param
          I0101 00:07:31.550131  1030 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[0] SuperFrm Mode:0, IfrmSize:1638400 bits, PfrmSize:546133 bits
          I0101 00:07:31.550240  1030 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
          I0101 00:07:31.550363  1030 sample_rtsp.c:638]              <configSubStream> vipp[4] crop en:1 X:0 Y:0 W:1888 H:1072
          I0101 00:07:31.550454  1030 sample_rtsp.c:651]              <configSubStream> sub EncppSharpAttenCoefPer: 33%
          I0101 00:07:31.550533  1030 sample_rtsp.c:661]              <configSubStream> sub vbvThreshSize: 24000, vbvBufSize: 152000
          [ISP]video device name is vin_video4
          [ISP]open video device[4], detect isp0 success!
          I0101 00:07:31.550897  1030 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
          I0101 00:07:31.551151  1030 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[4] update width:640(640), height:360(368)
          I0101 00:07:31[   77.557037] VE: before freq=300000000
          .551265  1030 videoInputHw.c:957[   77.564098] VE: real freq=300000000
          ]                                                           <videoInputHw_SetChnAttr> ViCh[4] LBC pix:0x3132434c, line_tar_bits[0]:3072, line_tar_bits[1]:4608
          I0101 00:07:31.551685  1030 videoInputHw.c:977] [   77.581688] VE: before freq=300000000
        <videoInputHw_SetChnAt[   77.588627] VE: real freq=300000000
          tr> bs_len:20480, frm_bit:3840
          I0101 00:07:31.754989  1030 videoInputHw.c:1254]            <videoInputHw_SetCrop> vipp[4] set crop X:0, Y:0, Width:1888, Height:1072
          I0101 00:07:31.757969  1030 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb679cd50]
          I0101 00:07:31.758928  1030 VideoEnc_Component.c:7042]      <VideoEncComponentInit> create VideoEnc threadId:0xb6779d50
          I0101 00:07:31.759148  1030 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[1] Comp StateIdle
          I0101 00:07:31.759365  1039 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 4, buf_num=3.
          I0101 00:07:31.759614  1041 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
          I0101 00:07:31.759869  1041 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[1] Create VeType=96
          open /dev/sunxi_soc_info failed!WARNING: cedarc <LogVersionInfo:44>:
          tag   :
          author: wuguanjian
          patch :
          I0101 00:07:31.781457  1030 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[1] set new framerate:20
          I0101 00:07:31.781702  1030 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[1] enable and set 2DFilter param
          I0101 00:07:31.781827  1030 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[1] enable and set 3DFilter param
          I0101 00:07:31.781924  1030 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[1] SuperFrm Mode:0, IfrmSize:266666 bits, PfrmSize:88888 bits
          I0101 00:07:31.782041  1030 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
          I0101 00:07:31.782179  1030 sample_rtsp.c:772]              <configSubLapseStream> subLapse EncppSharpAttenCoefPer: 33%
          I0101 00:07:31.782277  1030 sample_rtsp.c:782]              <configSubLapseStream> SubLapse vbvThreshSize: 24000, vbvBufSize: 152000
          I0101 00:07:31.782692  1030 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb6756d50]
          I0101 00:07:31.783620  1030 VideoEnc_Component.c:7042]      <VideoEncComponentInit> create VideoEnc threadId:0xb6733d50
          I0101 00:07:31.783836  1030 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[2] Comp StateIdle
          I0101 00:07:31.784219  1043 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
          I0101 00:07:31.784520  1043 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[2] Create VeType=96
          tag   :
          author: wuguanjian
          patch :
          I0101 00:07:31.799049  1030 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[2] set new framerate:20
          I0101 00:07:31.799257  1030 sample_rtsp.c:1464]             <main> Lapse set TimeLapse 1000000 us
          I0101 00:07:31.799384  1030 VideoEnc_Component.c:4036]      <VideoEncSetTimeLapse> SetTimeLapse: captureIntervalUs=1000000.000000, dstFrameIntervalUs=50000.000000, recType=1
          I0101 00:07:31.799493  1030 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[2] enable and set 2DFilter param
          I0101 00:07:31.799584  1030 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[2] enable and set 3DFilter param
          I0101 00:07:31.799669  1030 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[2] SuperFrm Mode:0, IfrmSize:266666 bits, PfrmSize:88888 bits
          I0101 00:07:32.131591  1030 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
          I0101 00:07:32.133689  1030 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[0] Comp StateExecuting
          I0101 00:07:32.133983  1038 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
          I0101 00:07:32.134416  1038 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[933882]bytes
          I0101 00:07:32.134570  1038 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[147450]bytes
          I0101 00:07:32.134675  1038 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 1536Kb, set encode vbv size 933888, frame length threshold 147450
          I0101 00:07:32.134785  1038 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[0], EncppEnable=1
          I0101 00:07:32.134877  1038 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
          I0101 00:07:32.134956  1038 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
          I0101 00:07:32.135042  1038 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=1, ShareBufNum=2, OnlineEnableFlag=1
          I0101 00:07:32.135118  1038 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
          [ISP_ERR]isp_sync_debug_info, line: 747,VIDIOC_VIN_ISP_GET_INFO error!
          I0101 00:07:32.165899  1038 VideoEnc_Component.c:2059]      <CedarvVideoEncInit> Venc Init success
          I0101 00:07:32.166132  1038 VideoEnc_Component.c:2068]      <CedarvVideoEncInit> Venc SetCallbacks success
          I0101 00:07:32.166314  1038 VideoEnc_Component.c:2078]      <CedarvVideoEncInit> Venc Start success
          I0101 00:07:32.166576  1038 VideoEnc_Component.c:2121]      <CedarvVideoEncInit> set Color2Grey [0], in Venchn[0]
          I0101 00:07:32.166719  1038 VideoEnc_Component.c:2128]      <CedarvVideoEncInit> vencChn[0] had init!
          I0101 00:07:32.166825  1038 VideoEnc_Component.c:8042]      <ComponentThread> VencChn[0]: idle/pause[0x2]->executing ...
          wlan0 ip:192.168.43.210
                                          *               BUILD BY WHO:        *
                                          *               BUILD TIME:                                             *
             rtsp://192.168.43.210:8554/ch0
          I0101 00:07:32.168219  1030 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[1] Comp StateExecuting
          I0101 00:07:32.168500  1041 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
          I0101 00:07:32.168834  1041 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[152000]bytes
          I0101 00:07:32.168966  1041 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[24000]bytes
          I0101 00:07:32.169068  1041 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
          I0101 00:07:32.169181  1041 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[1], EncppEnable=1
          I0101 00:07:32.169272  1041 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
          I0101 00:07:32.169354  1041 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
          I0101 00:07:32.169442  1041 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=0, ShareBufNum=0, OnlineEnableFlag=0
          I0101 00:07:32.169520  1041 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
          I0101 00:07:32.276325  1039 videoInputHw.c:4882]            <VideoInputHw_CapThread> vipp[4] drop 10 frames done!
          I0101 00:07:32.326668  1040 VideoEnc_Component.c:6308]      <VideoEncEmptyThisBuffer> send frame when venc state[0x2] is not executing
          I0101 00:07:32.326909  1040 VideoEnc_Component.c:6383]      <VideoEncEmptyThisBuffer> VencChn[1]: first video frame pts[78122322]us,tm1[78122879]us, vSize[640x368], frmId[1,12]
          open /dev/sunxi_soc_info failed![ISP]---------   LDCI Video12 Init OK   ---------
          W0101 00:07:33.180080  1045 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
          W0101 00:07:34.180485  1045 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
          I0101 00:07:34.327179  1040 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-0] has no frame input?
          [ISP_ERR]video_wait_buffer, line: 488,video4 select timeout!
          W0101 00:07:34.327568  1039 videoInputHw.c:4945]            <VideoInputHw_CapThread> vipp[4] get frame fail! frameBufId[1] is not release
          W0101 00:07:34.327719  1039 videoInputHw.c:4949]            <VideoInputHw_CapThread> vipp[4] get frame fail! [1]frames are not release
          W0101 00:07:35.180979  1045 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
          I tried turning off the main channel, but it did not work. I don’t understand what caused this error, would be thanks for any advice
          • Referenced by  kanken6174 kanken6174
