    用TF卡启动时,报MMC的错
    H/F/TV Series
      Jasper LV 2 最后由 编辑
      系统烧写进TF后,连接电脑,核心亮蓝灯,但是Xshell串口连接无法输入指令,且只在刚插电的时候输出如下信息:
      U-Boot SPL 2021.10-orangepi (Apr 15 2023 - 13:11:01 +0800)
      pmic id is 0x4b
      DRAM: 1024 MiB
      Trying to boot from MMC1
      NOTICE:  BL31: v2.7(debug):ea7aee20
      NOTICE:  BL31: Built : 04:47:26, Oct  3 2022
      NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
      NOTICE:  BL31: Found U-Boot DTB at 0x4a082610, model: OrangePi Zero2
      INFO:    ARM GICv2 driver initialized
      INFO:    Configuring SPC Controller
      INFO:    PMIC: Probing AXP305 on RSB
      ERROR:   RSB: set run-time address: 0x10003
      INFO:    Could not init RSB: -65539
      INFO:    BL31: Platform setup done
      INFO:    BL31: Initializing runtime services
      INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
      INFO:    BL31: cortex_a53: CPU workaround for 1530924 was applied
      INFO:    PSCI: Suspend is unavailable
      INFO:    BL31: Preparing for EL3 exit to normal world
      INFO:    Entry point address = 0x4a000000
      INFO:    SPSR = 0x3c9
      INFO:    Changed devicetree.
      U-Boot 2021.10-orangepi (Apr 15 2023 - 13:11:01 +0800) Allwinner Technology
      CPU:   Allwinner H616 (SUN50I)
      Model: OrangePi Zero2
      I2C:   ready
      DRAM:  1 GiB
      MMC:   mmc@4020000: 0
      Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@5000000
      Out:   serial@5000000
      Err:   serial@5000000
      Net:   phy interface7
      请问我该怎么做?
      Y 1 条回复 最后回复 回复 引用 分享 0
        YiXinTai LV 5 @Jasper 最后由 编辑
        @jasper 换一张卡试试?
