    V853 OpenWrt编译报错,求大佬指点
    4568
      lhw_uestc LV 4 最后由 whycan 编辑
      removed '/home/xm/tina-v853/out/v853/vision/openwrt/.board.dtb.d.dtc.tmp'
      removed '/home/xm/tina-v853/out/v853/vision/openwrt/.board.dtb.dts.tmp'
      '/home/xm/tina-v853/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.d.dtc.tmp' -> '/home/xm/tina-v853/out/v853/vision/openwrt/.board.dtb.d.dtc.tmp'
      '/home/xm/tina-v853/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.dts.tmp' -> '/home/xm/tina-v853/out/v853/vision/openwrt/.board.dtb.dts.tmp'
      INFO: build rootfs ...
      ==mkcmd.sh: build_openwrt_rootfs ==
      make: Entering directory '/home/xm/tina-v853/openwrt/openwrt'
      make[1]: Entering directory '/home/xm/tina-v853/openwrt/openwrt'
      CreateSoftLink  /home/xm/tina-v853/openwrt/openwrt/tmp link to  /home/xm/tina-v853/out/v853/vision/openwrt/tmp
      CreateSoftLink  /home/xm/tina-v853/openwrt/openwrt/staging_dir link to  /home/xm/tina-v853/out/v853/vision/openwrt/staging_dir
      make[2]: Entering directory '/home/xm/tina-v853/openwrt/openwrt'
      make[2]: Leaving directory '/home/xm/tina-v853/openwrt/openwrt'
      Check Vendor Package...
      CreateSoftLink  /home/xm/tina-v853/openwrt/openwrt/package/subpackage link to  /home/xm/tina-v853/openwrt/package
      end
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile' has a dependency on 'libgst1gl', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-good', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland-protocols', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'opencv', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1badvideo', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1gl', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-base/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/kernel/linux/Makefile' has a dependency on 'kmod-sunxi-rf-wlan', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'weston', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'wayland', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'qt5-multimediawidgets', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a build dependency on 'libstdcpp', which does not exist
      copy from /home/xm/tina-v853/openwrt/target/v853/v853-vision/defconfig
      target/linux/generic/image/Config.in:12:warning: choice default symbol 'uImage' is not contained in the choice
      target/linux/generic/image/Config.in:47:warning: choice default symbol 'uImage' is not contained in the choice
      target/linux/generic/image/Config.in:72:warning: choice default symbol 'CONFIG_BOOT_IMAGE_NAME_SUFFIX_NONE' is not contained in the choice
      target/linux/generic/image/Config.in:89:warning: choice default symbol 'CONFIG_ROOTFS_IMAGE_NAME_SUFFIX_NONE' is not contained in the choice
      # No change to .config
      copy to /home/xm/tina-v853/openwrt/target/v853/v853-vision/defconfig
      Makefile:29: "NOTE: Will skip kernel build."
      The command image-prereq(include/kernel-build.mk) execute.
      time: target/linux/prereq#0.10#0.02#0.12
      make[1]: Leaving directory '/home/xm/tina-v853/openwrt/openwrt'
       make[1] world
       make[2] -C /home/xm/tina-v853/openwrt/target/v853 check
       make[2] tools/compile
       make[3] -C tools/flock compile
       make[3] -C tools/xz compile
       make[3] -C tools/sed compile
       make[3] -C tools/tar compile
       make[3] -C tools/patch compile
       make[3] -C tools/m4 compile
       make[3] -C tools/autoconf compile
       make[3] -C tools/autoconf-archive compile
       make[3] -C tools/pkgconf compile
       make[3] -C tools/automake compile
       make[3] -C tools/missing-macros compile
       make[3] -C tools/libtool compile
       make[3] -C tools/flex compile
       make[3] -C tools/bison compile
       make[3] -C tools/bc compile
       make[3] -C tools/libressl compile
       make[3] -C tools/cmake compile
          ERROR: tools/cmake failed to build.
      make -r world: build failed. Please re-run make with -j1 V=s or V=sc for a higher verbosity level to see what's going on
      /home/xm/tina-v853/openwrt/openwrt/include/toplevel.mk:236: recipe for target 'world' failed
      make: *** [world] Error 1
      make: Leaving directory '/home/xm/tina-v853/openwrt/openwrt'
      INFO: build_openwrt_rootfs failed
      whycan I 2 条回复 最后回复 回复 引用 分享 0
        whycan晕哥 LV 9 @lhw_uestc 最后由 编辑
        @lhw_uestc 在 V853 OpenWrt编译报错,求大佬指点 中说:
        -j1 V=s
        make -j1 V=s
        会打印具体的出错信息。
        • I
          igbt70 LV 4 @lhw_uestc 最后由 编辑
          @lhw_uestc 环境没有配置好
            lhw_uestc LV 4 @igbt70 最后由 编辑
            @igbt70 感谢感谢
