    ubuntu18.04 d1 dependency install failed
      Jason95599 LV 2 最后由 编辑
      Hi guys,
      I have met a issue on ubuntu 18.04.
      sudo apt-get install libc6:i386 libstdc++6:i386  lib32z1
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      The following packages have unmet dependencies:
       lib32z1 : Depends: libc6-i386 (>= 2.4) but it is not going to be installed
       libc6:i386 : Depends: libgcc1:i386 but it is not going to be installed
       libstdc++6:i386 : Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed
      E: Unable to correct problems, you have held broken packages.
      First time to use linux system, please help give some advise.
        https://stackoverflow.com/questions/43769395/trying-to-install-the-package-libstdc6i386-or-ia32-libs-in-ubuntu-16-04-1-lts
        I found a solution,hope it works for others as well
        visit this website -> https://repogen.simplylinux.ch/ and choose your 'country' and 'release' along with necessary 'branches' and 'updates' and go to end of the page till 'Generate list' button and click it to get your new sources.list
        copy the text in 'sources list' text field and open sources.list file in /etc/apt/ in local file system and open in editable mode i.e., in sudo mode to edit, replace the current data with newly copy data and save it
        open terminal enter these commands : sudo apt-get update sudo apt-get install lib32stdc++6
        you are done. Now, just check if the problem with making AVD is gone or not.
        Share
        Improve this answer
        Follow
        • Moved from RISC-V(English) by  xiaowenge xiaowenge
