    请教D1S MPIP屏显示异常
    5785
      JerryChen LV 4 最后由 编辑
      之前买了两款屏,一款是480480 2Lane MIPI,点屏显示正常(此贴:D1S新增一款MIPI屏[480480] ST7701S)
      这一款是720*720, 4Lane MIPI的,测试了较多参数,还是显示有点异常,看看各位友友有没有遇到类似的情况过, 请各位帮忙支招,谢谢。
      规格书:
      YX40005A.pdf
      驱动IC:ST7703
      卖家给的时序参数:
      测试现象:
      1、按照参数,时钟lcd_dclk_freq配置为36M,黑屏无显示。
      2、降频为16M测试,可以显示画面,但拖影比较严重,显示也不清晰。
      3、调节各个HBP/HFP等参数,好像无好转的迹象。
      硬件上面应该没有烧坏或者其它问题。
      dts:
      &lcd0 {
      	lcd_used            = <1>;
              lcd_driver_name     = "st7701s";
      	lcd_backlight       = <100>;
      	lcd_if              = <4>;
              lcd_pwm_used        = <0>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_freq        = <1000>;
      	lcd_pwm_pol         = <0>;
      	lcd_pwm_max_limit   = <255>;
              lcd_x               = <720>;
      	lcd_y               = <720>;
      	lcd_width           = <72>;
      	lcd_height          = <72>;
      	lcd_dclk_freq       = <20>;     // lcd_ht * lcd_vt * 60
              lcd_dsi_lane        = <4>;
              pinctrl-0           = <&dsi4lane_pins_a>;
      	pinctrl-1           = <&dsi4lane_pins_b>;
              lcd_hbp             = <30>;     // hsync back porch(pixel) + hsync plus width(pixel);
      	lcd_ht              = <790>;    // hsync total cycle(pixel)
      	lcd_hspw            = <4>;      // hsync plus width(pixel)
      	lcd_vbp             = <26>;     // vsync back porch(line) + vysnc plus width(line)
      	lcd_vt              = <776>;    // vysnc total cycle(line)
      	lcd_vspw            = <6>;      // vysnc plus width(pixel)
              lcd_dsi_if          = <0>;
      	lcd_lvds_if         = <0>;
      	lcd_lvds_colordepth = <0>;
      	lcd_lvds_mode       = <0>;
      	lcd_frm             = <0>;
      	lcd_hv_clk_phase    = <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_gamma_en        = <0>;
      	lcd_bright_curve_en = <0>;
      	lcd_cmap_en         = <0>;
      	lcd_fsync_en        = <0>;
      	lcd_fsync_act_time  = <1000>;
      	lcd_fsync_dis_time  = <1000>;
      	lcd_fsync_pol       = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	lcd_gpio_0 =  <&pio PB 2 GPIO_ACTIVE_HIGH>;
      初始化参数:
      static struct LCM_setting_table lcm_initialization_setting[] = {
      	// {0x11, 1, {0x00} },
      	{REGFLAG_DELAY, 500, {} },
          {0xB9, 3, {0xF1, 0x12, 0x83}},
          {0xBA, 27, {0x33, 0x81, 0x05, 0xF9, 0x0E, 0x0E, 0x20, 0x00, 0x00, 0x00,
                      0x00, 0x00, 0x00, 0x00, 0x44, 0x25, 0x00, 0x91, 0x0A, 0x00,
                      0x00, 0x02, 0x4F, 0xD1, 0x00, 0x00, 0x37}},
          {0xB8, 4,  {0x25, 0x22, 0x20, 0x03}},
          {0xBF, 3,  {0x02, 0x11, 0x00}},
          // set rgb()
          // {0xB3, 10, {0x10, 0x10, 0x0A, 0x50, 0x03, 0xFF, 0x00, 0x00, 0x00, 0x00}},
          {0xC0, 9,  {0x73, 0x73, 0x50, 0x50, 0x00, 0x00, 0x08, 0x70, 0x00}},
          {0xBC, 1,  {0x46}},
          {0xCC, 1,  {0x0B}},
          {0xB4, 1,  {0x80}},
          {0xB2, 3,  {0x3C, 0x12, 0x30}},
          {0xE3, 14, {0x07, 0x07, 0x0B, 0x0B, 0x03, 0x0B, 0x00, 0x00, 0x00, 0x00,
                      0xFF, 0x00, 0x40, 0x10}},
          {0xC1, 12, {0x65, 0x00, 0x32, 0x32, 0x77, 0xF1, 0xCC, 0xCC, 0x77, 0x77,
                      0x33, 0x33}},
          {0xB5, 2,  {0x0A, 0x0A}},
          {0xB6, 2,  {0xB7, 0xB7}},
          {0xE9, 63, {0x88, 0x10, 0x0A, 0x10, 0x0F, 0xA1, 0x80, 0x12, 0x31, 0x23,
                      0x47, 0x86, 0xA1, 0x80, 0x47, 0x08, 0x04, 0x44, 0x00, 0x00,
                      0x00, 0x00, 0x04, 0x44, 0x00, 0x00, 0x00, 0x00, 0x75, 0x31,
                      0x88, 0x88, 0x88, 0x1F, 0x88, 0x38, 0xFF, 0x58, 0x88, 0x64,
                      0x20, 0x88, 0x88, 0x88, 0x0F, 0x88, 0x28, 0xFF, 0x48, 0x88,
                      0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
                      0x00, 0x00, 0x00}},
          {0xEA, 61, {0x00, 0x1A, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
                      0x00, 0x00, 0x02, 0x46, 0x88, 0x88, 0x88, 0x28, 0x8F, 0x08,
                      0xFF, 0x48, 0x88, 0x13, 0x57, 0x88, 0x88, 0x88, 0x38, 0x8F,
                      0x18, 0xFF, 0x58, 0x88, 0x23, 0x00, 0x00, 0x01, 0x02, 0x00,
                      0x00, 0x00, 0x00, 0x00, 0x40, 0xA1, 0x80, 0x00, 0x00, 0x00,
                      0x00}},
          {0xE0, 34, {0x00, 0x03, 0x06, 0x2D, 0x3E, 0x3F, 0x34, 0x32, 0x08, 0x0C,
                      0x0D, 0x10, 0x12, 0x11, 0x12, 0x10, 0x15, 0x00, 0x03, 0x06,
                      0x2D, 0x3E, 0x3F, 0x34, 0x32, 0x08, 0x0C, 0x0D, 0x10, 0x12,
                      0x11, 0x12, 0x10, 0x15}},
          {0x11, 1, {0x00} },
      	{REGFLAG_DELAY, 300, {} },
      	{0x29, 1, {0x00} },
          {REGFLAG_DELAY, 100, {} },
      	{REGFLAG_END_OF_TABLE, 0x00, {}}
      附几张异常现象的照片:
      S 1 条回复 最后回复 回复 引用 分享 0
        soso90 LV 7 @JerryChen 最后由 编辑
        @jerrychen 在 请教D1S MPIP屏显示异常 中说:
        看来这个mipi还是比较麻烦。我的是圆屏,7701s,症状就是黑屏无显示。看来可以试试 你的这个时钟lcd_dclk_freq~~~ 板子和驱动都改好,就是没反应。看过你上一个贴。还没试试你那些参数~~
          Maihuanyi LV 5 最后由 编辑
          你有调试好st7703的mipi显示屏了吗
          J 1 条回复 最后回复 回复 引用 分享 0
            JerryChen LV 4 @Maihuanyi 最后由 编辑
            @maihuanyi 还没有,最近忙,没太多时间玩
              @whycan 晕哥请问可以帮忙指教下吗?感谢
