    请各位大佬帮忙Debug,自己做的D1-H板子启动会卡死,目前用的D1-H mini固件
      l874818045 LV 3 最后由 编辑
      启动日志如下,DDR已经降频,目前使用PhoenixCard 启动卡烧录。
      [32]HELLO! BOOT0 is starting!
      [35]BOOT0 commit : 88480af
      [37]set pll start
      [39]periph0 has been enabled
      [42]set pll end
      [44][pmu]: bus read error
      [46]board init ok
      [48]get_pmu_exist() = -1
      [50]ddr_efuse_type: 0x0
      [53]trefi:7.8ms
      [55][AUTO DEBUG] single rank and full DQ!
      [59]ddr_efuse_type: 0x0
      [61]trefi:7.8ms
      [63][AUTO DEBUG] rank 0 row = 15
      [66][AUTO DEBUG] rank 0 bank = 8
      [69][AUTO DEBUG] rank 0 page size = 2 KB
      [73]DRAM BOOT DRIVE INFO: V0.33
      [76]DRAM CLK = 672 MHz
      [78]DRAM Type = 3 (2:DDR2,3:DDR3)
      [81]DRAMC ZQ value: 0x7b7bfb
      [84]DRAM ODT value: 0x42.
      [87]ddr_efuse_type: 0x0
      [90]DRAM SIZE =512 M
      [92]dram_tpr4:0x0
      [93]PLL_DDR_CTRL_REG:0xf8003700
      [96]DRAM_CLK_REG:0xc0000000
      [99][TIMING DEBUG] MR2= 0x18
      [103]DRAM simple test OK.
      [105]dram size =512
      [107]card no is 0
      [109]sdcard 0 line count 4
      [111][mmc]: mmc driver ver 2021-04-2 16:45
      [121][mmc]: Wrong media type 0x0
      [124][mmc]: ***Try SD card 0***
      [133][mmc]: DS26/SDR12 4 bit
      [136][mmc]: 25000000 Hz
      [138][mmc]: 14922 MB
      [140][mmc]: ***SD/MMC 0 init OK!!!***
      [233]Loading boot-pkg Succeed(index=0).
      [237]Entry_name        = opensbi
      [240]Entry_name        = u-boot
      [244]Entry_name        = dtb
      [247]mmc not para
      [248]Jump to second Boot.
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒[00.329][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.334][mmc]: get sdc_type fail and use default host:tm1.
      [00.340][mmc]: can't find node "mmc0",will add new node
      [00.345][mmc]: fdt err returned <no error>
      [00.349][mmc]: Using default timing para
      [00.352][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.370][mmc]: card_caps:0x3000000a
      [00.373][mmc]: host_caps:0x3000003f
      [00.377][mmc]: sd set card speed failed
      [00.381][mmc]: sd set card speed failed
      [00.436]set disp.dev2_output_type fail. using defval=0
      [00.463]set disp.fb0_rot_used fail. using defval=0
      [00.467]set disp.fb0_rot_degree fail. using defval=0
      [00.651]out of usb burn from boot: not need burn key
      [00.656]Item0 (Map) magic is bad
      [00.659]the secure storage item0 copy0 magic is bad
      [00.665]Item0 (Map) magic is bad
      [00.667]the secure storage item0 copy1 magic is bad
      [00.672]Item0 (Map) magic is bad
      [00.684]The storage not support sample function
      [00.758]dts_get_dsp_memory: no /reserved-memory/dsp0 in fdt
      [00.763]dts_get_dsp_memory fail
      [01.109]no vendor_boot partition is found
      [01.310]
      Starting kernel ...
      [01.312][mmc]: MMC Device 2 not found
      [01.316][mmc]: mmc 2 not find, so not exit
      [    0.184186] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    0.191571] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    0.269231] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    0.276901] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    0.290879] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    0.298430] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    0.306034] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    0.313640] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    0.402182] sunxi-i2c sunxi-i2c2: Bus error
      [    0.406855] sunxi-i2c sunxi-i2c2: engine mode: I2C BUS error state is 0x0
      [    0.414489] sunxi-i2c sunxi-i2c2: engine-mode: bus state: 0x0, isn't idle
      [    0.422055] sunxi-i2c sunxi-i2c2: STOP failed!
      [    0.427048] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
      formating /dev/by-name/UDISK to ext4
      /etc/preinit: line 1: mkfs.ext4: not found
      [    7.274902] block: extroot: cannot find device UDISK
      [    9.099871] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [   11.612226] ======== XRADIO WIFI OPEN ========
      [   11.628926] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [   11.635685] [XRADIO] Allocated hw_priv @ (____ptrval____)
      [   11.929343] [XRADIO] Detect SDIO card 1
      [   11.955359] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   11.963127] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   11.975337] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   11.983044] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   11.990732] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   11.998349] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   14.109073] [XRADIO] Remove SDIO card 1
      [   14.123353] [SBUS_ERR] sdio probe timeout!
      [   14.127922] [XRADIO_ERR] sbus_sdio_init failed
      [   14.133754] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   14.140953] xradio_core_init failed (-110)!
      [   14.145642] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   14.157885] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   14.165500] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   14.173138] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   14.180756] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      kmodloader done
