    make 出現 snd_sunxi_dmic 錯誤 !
      JerryLiu LV 2 最后由 WhycanService 编辑
        CC      sound/soc/sunxi_v2/snd_sunxi_pcm.o
        CC      sound/soc/sunxi_v2/snd_sunxi_dmic.o
      In file included from sound/soc/sunxi_v2/snd_sunxi_dmic.c:32:
      sound/soc/sunxi_v2/snd_sunxi_dmic.h:173:24: error: field 'clk' has incomplete type
        struct sunxi_dmic_clk clk;
      sound/soc/sunxi_v2/snd_sunxi_dmic.c: In function 'sunxi_dmic_dai_set_pll':
      sound/soc/sunxi_v2/snd_sunxi_dmic.c:107:6: error: implicit declaration of function 'snd_sunxi_clk_rate'; did you mean 'snd_sunxi_echo_reg'? [-Werror=implicit-function-declaration]
        if (snd_sunxi_clk_rate(clk, freq_in, freq_out)) {
            snd_sunxi_echo_reg
      sound/soc/sunxi_v2/snd_sunxi_dmic.c: In function 'sunxi_dmic_component_suspend':
      sound/soc/sunxi_v2/snd_sunxi_dmic.c:490:2: error: implicit declaration of function 'snd_sunxi_clk_disable'; did you mean 'clk_bulk_disable'? [-Werror=implicit-function-declaration]
        snd_sunxi_clk_disable(clk);
        clk_bulk_disable
      sound/soc/sunxi_v2/snd_sunxi_dmic.c: In function 'sunxi_dmic_component_resume':
      sound/soc/sunxi_v2/snd_sunxi_dmic.c:504:8: error: implicit declaration of function 'snd_sunxi_clk_enable'; did you mean 'snd_sunxi_echo_reg'? [-Werror=implicit-function-declaration]
        ret = snd_sunxi_clk_enable(clk);
              snd_sunxi_echo_reg
      sound/soc/sunxi_v2/snd_sunxi_dmic.c: In function 'sunxi_dmic_dev_probe':
      sound/soc/sunxi_v2/snd_sunxi_dmic.c:878:8: error: implicit declaration of function 'snd_sunxi_clk_init'; did you mean 'snd_sunxi_pin_init'? [-Werror=implicit-function-declaration]
        ret = snd_sunxi_clk_init(pdev, clk);
              snd_sunxi_pin_init
      sound/soc/sunxi_v2/snd_sunxi_dmic.c:922:2: error: implicit declaration of function 'snd_sunxi_clk_exit'; did you mean 'snd_sunxi_mem_exit'? [-Werror=implicit-function-declaration]
        snd_sunxi_clk_exit(clk);
        snd_sunxi_mem_exit
      cc1: some warnings being treated as errors
      make[9]: *** [sound/soc/sunxi_v2/snd_sunxi_dmic.o] Error 1
      J 1 条回复 最后回复 回复 引用 分享 1
        JerryLiu LV 2 @JerryLiu 最后由 编辑
        @jerryliu
        發現在 snd_sunxi_dmic.h 中,少了宣告 struct sunxi_dmic_clk ??
        struct sunxi_dmic_mem {
        struct resource res;
        void __iomem *membase;
        struct resource *memregion;
        struct regmap *regmap;
        struct sunxi_dmic_pinctl {
        struct pinctrl *pinctrl;
        struct pinctrl_state *pinstate;
        struct pinctrl_state *pinstate_sleep;
        bool pinctrl_used;
        struct sunxi_dmic_dts {
        /* value must be (2^n)Kbyte */
        size_t capture_cma;
        size_t capture_fifo_size;
        unsigned int rx_chmap;
        unsigned int data_vol;
        unsigned int rx_dtime;
        /* components func -> rx_sync */
        bool rx_sync_en;	/* read from dts */
        bool rx_sync_ctl;
        int rx_sync_id;
        rx_sync_domain_t rx_sync_domain;
        struct sunxi_dmic {
        struct platform_device *pdev;
        struct sunxi_dmic_mem mem;
        struct sunxi_dmic_pinctl pin;
        struct sunxi_dmic_dts dts;
        struct sunxi_dma_params capture_dma_param;
