    [<ffffffe0000293ce>] walk_stackframe+0x0/0xa0
      cfxcfx LV 5 最后由 编辑
      721654ea-8e05-43cb-b43c-ad73e3342b16-image.png procd: Failed to open hotplug socket: Function not implemented
      求教怎么解决,或应该怎么去解决
        cfxcfx LV 5 @cfxcfx 最后由 编辑
        [231]HELLO! BOOT0 is starting!
        [234]BOOT0 commit : 27369ab
        [237]set pll start
        [239]periph0 has been enabled
        [242]set pll end
        [243][pmu]: bus read error
        [246]board init ok
        [248]ZQ value = 0x2f***********
        [251]get_pmu_exist() = -1
        [253]ddr_efuse_type: 0xa
        [256][AUTO DEBUG] single rank and full DQ!
        [260]ddr_efuse_type: 0xa
        [263][AUTO DEBUG] rank 0 row = 13
        [266][AUTO DEBUG] rank 0 bank = 4
        [269][AUTO DEBUG] rank 0 page size = 2 KB
        [273]DRAM BOOT DRIVE INFO: V0.24
        [276]DRAM CLK = 528 MHz
        [278]DRAM Type = 2 (2:DDR2,3:DDR3)
        [282]DRAMC read ODT off.
        [284]DRAM ODT off.
        [286]ddr_efuse_type: 0xa
        [289]DRAM SIZE =64 M
        [292]DRAM simple test OK.
        [295]dram size =64
        [297]card no is 0
        [298]sdcard 0 line count 4
        [301][mmc]: mmc driver ver 2021-04-2 16:45
        [310][mmc]: Wrong media type 0x0
        [313][mmc]: Try SD card 0
        [323][mmc]: HSSDR52/SDR25 4 bit
        [326][mmc]: 50000000 Hz
        [328][mmc]: 122 MB
        [330][mmc]: SD/MMC 0 init OK!!!
        [377]Loading boot-pkg Succeed(index=0).
        [381]Entry_name = opensbi
        [384]Entry_name = u-boot
        [387]Entry_name = dtb
        [390]mmc not para
        [391]Jump to second Boot.
        OpenSBI v0.6
        / __ \ / | _ _ |
        __ ___ _ __ | (
        | | | | '_ \ / _ \ '_ \ ___ | _ < | |
        | || | |) | __/ | | |) | |) || |
        _
        /| ./ _|| ||/|____/|
        |_|
        Platform Name : T-HEAD Xuantie Platform
        Platform Max HARTs : 1
        Current Hart : 0
        Firmware Base : 0x40000400
        Firmware Size : 75 KB
        Runtime SBI Version : 0.2
        MIDELEG : 0x0000000000000222
        MEDELEG : 0x000000000000b1ff
        PMP0 : 0x0000000040000000-0x000000004001ffff (A)
        PMP1 : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
        PMP2 : 0x0000000000000000-0x0000000007ffffff (A,R,W)
        PMP3 : 0x0000000009000000-0x000000000901ffff (
        U-Boot 2018.05-g0a88ac9-dirty (Mar 09 2023 - 14:34:22 +0800) Allwinner Technology
        [00.474]DRAM: 64 MiB
        [00.476]Relocation Offset is: 01f30000
        [00.481]secure enable bit: 0
        [00.483]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
        [00.489]flash init start
        [00.492]workmode = 0,storage type = 1
        [00.495][mmc]: mmc driver ver uboot2018:2021-04-16 14:23:00-1
        [00.501][mmc]: get sdc_type fail and use default host:tm1.
        [00.507][mmc]: can't find node "mmc0",will add new node
        [00.512][mmc]: fdt err returned <no error>
        [00.516][mmc]: Using default timing para
        [00.519][mmc]: SUNXI SDMMC Controller Version:0x50310
        [00.538][mmc]: card_caps:0x3000000a
        [00.541][mmc]: host_caps:0x3000003f
        [00.545]sunxi flash init ok
        [00.547]line:714 init_clocks
        __clk_init: clk pll_periph0x2 already initialized
        register fix_factor clk error
        [00.563]Loading Environment from SUNXI_FLASH... OK
        [00.586]out of usb burn from boot: not need burn key
        root_partition is rootfs
        set root to /dev/mmcblk0p5
        [00.595]update part info
        [00.598]update bootcmd
        [00.601]change working_fdt 0x42aefda8 to 0x42acfda8
        [00.620]update dts
        Android's image name: d1-mangopi_mq_rg
        [01.049]
        Starting kernel ...
        [01.052][mmc]: MMC Device 2 not found
        [01.055][mmc]: mmc 2 not find, so not exit
        [ 0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
        [ 0.000000] Linux version 5.4.61 (root@c-VirtualBox) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #465 PREEMPT Wed May 17 10:49:22 UTC 2023
        [ 0.000000] cma: Reserved 8 MiB at 0x0000000043800000
        [ 0.000000] Zone ranges:
        [ 0.000000] DMA32 [mem 0x0000000040200000-0x0000000043ffffff]
        [ 0.000000] Normal empty
        [ 0.000000] Movable zone start for each node
        [ 0.000000] Early memory node ranges
        [ 0.000000] node 0: [mem 0x0000000040200000-0x0000000043ffffff]
        [ 0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x0000000043ffffff]
        [ 0.000000] On node 0 totalpages: 15872
        [ 0.000000] DMA32 zone: 217 pages used for memmap
        [ 0.000000] DMA32 zone: 0 pages reserved
        [ 0.000000] DMA32 zone: 15872 pages, LIFO batch:3
        [ 0.000000] elf_hwcap is 0x20112d
        [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
        [ 0.000000] pcpu-alloc: [0] 0
        [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 15655
        [ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g0a88ac9-dirty(03/09/2023-14:34:22) mbr_off
        [ 0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [ 0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
        [ 0.000000] Sorting __ex_table...
        [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
        [ 0.000000] Memory: 45780K/63488K available (4548K kernel code, 588K rwdata, 1714K rodata, 156K init, 211K bss, 9516K reserved, 8192K cma-reserved)
        [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
        [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
        [ 0.000000] Tasks RCU enabled.
        [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [ 0.000000] NR_IRQS: 0, nr_irqs: 0, preallocated irqs: 0
        [ 0.000000] plic: mapped 200 interrupts with 1 handlers for 2 contexts.
        [ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
        [ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
        [ 0.000005] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
        [ 0.000025] riscv_timer_clockevent depends on broadcast, but no broadcast function available
        [ 0.000355] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
        [ 0.000959] Console: colour dummy device 80x25
        [ 0.001008] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
        [ 0.001026] pid_max: default: 32768 minimum: 301
        [ 0.001201] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
        [ 0.001219] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
        [ 0.003265] ASID allocator initialised with 65536 entries
        [ 0.003468] rcu: Hierarchical SRCU implementation.
        [ 0.004186] devtmpfs: initialized
        [ 0.018530] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
        [ 0.019441] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [ 0.019475] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
        [ 0.019996] pinctrl core: initialized pinctrl subsystem
        [ 0.023015] DMA: preallocated 256 KiB pool for atomic allocations
        [ 0.023796] cpuidle: using governor menu
        [ 0.066502] rtc_ccu: sunxi ccu init OK
        [ 0.074011] clock: sunxi ccu init OK
        [ 0.075020] clock: sunxi ccu init OK
        [ 0.115550] iommu: Default domain type: Translated
        [ 0.115752] sunxi iommu: irq = 4
        [ 0.116975] SCSI subsystem initialized
        [ 0.117221] usbcore: registered new interface driver usbfs
        [ 0.117335] usbcore: registered new interface driver hub
        [ 0.117461] usbcore: registered new device driver usb
        [ 0.117678] mc: Linux media interface: v0.10
        [ 0.117765] videodev: Linux video capture interface: v2.00
        [ 0.119062] sunxi-msgbox-amp 3003000.msgbox: invalid resource
        [ 0.119834] Advanced Linux Sound Architecture Driver Initialized.
        [ 0.119848] pwm module init!
        [ 0.121630] g2d 5410000.g2d: Adding to iommu group 0
        [ 0.122172] G2D: rcq version initialized.major:250
        [ 0.123593] clocksource: Switched to clocksource riscv_clocksource
        [ 0.138885] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
        [ 0.157978] thermal_sys: Registered thermal governor 'step_wise'
        [ 0.157985] thermal_sys: Registered thermal governor 'user_space'
        [ 0.159095] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
        [ 0.159719] spi spi1: spi1 supply spi not found, using dummy regulator
        [ 0.160037] sunxi_spi_resource_get()2062 - [spi1] SPI MASTER MODE
        [ 0.160152] sunxi_spi_clk_init()2138 - [spi1] mclk 100000000
        [ 0.160971] sunxi_spi_probe()2542 - [spi1]: driver probe succeed, base ffffffd00405e000, irq 32
        [ 0.162917] Initialise system trusted keyrings
        [ 0.163181] workingset: timestamp_bits=62 max_order=14 bucket_order=0
        [ 0.172087] squashfs: version 4.0 (2009/01/31) Phillip Lougher
        [ 0.193461] Key type asymmetric registered
        [ 0.193479] Asymmetric key parser 'x509' registered
        [ 0.193518] io scheduler mq-deadline registered
        [ 0.193529] io scheduler kyber registered
        [ 0.193552] atomic64_test: passed
        [ 0.195167] [DISP]disp_module_init
        [ 0.195809] disp 5000000.disp: Adding to iommu group 0
        [ 0.235122] [DISP] disp_init_hdmi,line:1047:
        [ 0.235127] dont support hdmi
        [ 0.235552] display_fb_request,fb_id:0
        [ 0.249435] [DISP] Fb_copy_boot_fb,line:1444:
        [ 0.249440] no boot_fb0
        [ 0.249987] disp_al_manager_apply ouput_type:0
        [ 0.250397] [DISP] lcd_clk_config,line:731:
        [ 0.250412] disp 0, clk: pll(198000000),clk(198000000),dclk(33000000) dsi_rate(198000000)
        [ 0.250412] clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
        [ 0.251209] [DISP]disp_module_init finish
        [ 0.252136] sunxi_sid_init()506 - insmod ok
        [ 0.260444] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
        [ 0.260881] uart uart0: get regulator failed
        [ 0.260914] uart uart0: uart0 supply uart not found, using dummy regulator
        [ 0.261361] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
        [ 0.261391] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
        [ 0.466277] [DISP] disp_sys_gpio_request,line:276:
        [ 0.466287] disp_sys_gpio_request failed, gpio_name=lcd_bl_en, gpio=123, value=0, ret=-517
        [ 0.466303] [DISP] disp_device_attached_and_enable,line:233:
        [ 0.466307] attached ok, mgr0<-->dev0
        [ 0.466311] [DISP] disp_device_attached_and_enable,line:236:
        [ 0.466320] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
        [ 0.994686] printk: console [ttyS0] enabled
        [ 1.000409] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
        [ 1.011946] uart uart1: get regulator failed
        [ 1.016846] uart uart1: uart1 supply uart not found, using dummy regulator
        [ 1.024981] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
        [ 1.035101] misc dump reg init
        [ 1.040160] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
        [ 1.047503] sunxi-ehci: EHCI SUNXI driver
        [ 1.052562] get ehci0-controller wakeup-source is fail.
        [ 1.058561] sunxi ehci0-controller don't init wakeup source
        [ 1.064886] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000704330, 0x:ffffffd004070000, irq_no:2e
        [ 1.078438] [sunxi-ehci0]: Not init ehci0
        [ 1.083366] get ehci1-controller wakeup-source is fail.
        [ 1.089374] sunxi ehci1-controller don't init wakeup source
        [ 1.095694] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0007046f0, 0x:ffffffd004074000, irq_no:31
        [ 1.109277] hci: sunxi_insmod_ehci()600 WARN: get supply failed
        [ 1.115960] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
        [ 1.123240] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
        [ 1.133176] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
        [ 1.163646] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
        [ 1.172630] hub 1-0:1.0: USB hub found
        [ 1.177016] hub 1-0:1.0: 1 port detected
        [ 1.182353] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
        [ 1.189430] sunxi-ohci: OHCI SUNXI driver
        [ 1.194541] get ohci0-controller wakeup-source is fail.
        [ 1.200538] sunxi ohci0-controller don't init wakeup source
        [ 1.206814] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000704e70
        [ 1.217276] [sunxi-ohci0]: Not init ohci0
        [ 1.222202] get ohci1-controller wakeup-source is fail.
        [ 1.228214] sunxi ohci1-controller don't init wakeup source
        [ 1.234537] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe000705230
        [ 1.245053] hci: sunxi_insmod_ohci()265 WARN: get supply failed
        [ 1.251702] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
        [ 1.259023] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
        [ 1.268923] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
        [ 1.348909] hub 2-0:1.0: USB hub found
        [ 1.353174] hub 2-0:1.0: 1 port detected
        [ 1.358896] usbcore: registered new interface driver uas
        [ 1.365171] usbcore: registered new interface driver usb-storage
        [ 1.372038] usbcore: registered new interface driver ums-alauda
        [ 1.378824] usbcore: registered new interface driver ums-cypress
        [ 1.385721] usbcore: registered new interface driver ums-datafab
        [ 1.392508] usbcore: registered new interface driver ums_eneub6250
        [ 1.399594] usbcore: registered new interface driver ums-freecom
        [ 1.406519] usbcore: registered new interface driver ums-isd200
        [ 1.413186] usbcore: registered new interface driver ums-jumpshot
        [ 1.420168] usbcore: registered new interface driver ums-karma
        [ 1.426801] usbcore: registered new interface driver ums-onetouch
        [ 1.433811] usbcore: registered new interface driver ums-realtek
        [ 1.440601] usbcore: registered new interface driver ums-sddr09
        [ 1.447411] usbcore: registered new interface driver ums-sddr55
        [ 1.454210] usbcore: registered new interface driver ums-usbat
        [ 1.461198] mousedev: PS/2 mouse device common for all mice
        [ 1.468390] ts probe start
        [ 1.468830] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input0
        [ 1.481596] ts probe success
        [ 1.482002] sunxi_gpadc_init,1968, success
        [ 1.490209] sunxi_key_init: get key count failed
        [ 1.490227] sunxi_gpadc_setup: get channel scan data failed
        [ 1.501994] input: sunxi-gpadc0 as /devices/virtual/input/input1
        [ 1.509286] input: sunxi-gpadc1 as /devices/virtual/input/input2
        [ 1.517218] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
        [ 1.529790] sunxi-rtc 7090000.rtc: registered as rtc0
        [ 1.535661] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:02 UTC (2)
        [ 1.544639] sunxi-rtc 7090000.rtc: sunxi rtc probed
        [ 1.550509] i2c /dev entries driver
        [ 1.554608] IR NEC protocol handler initialized
        [ 1.559709] IR RC5(x/sz) protocol handler initialized
        [ 1.565398] IR RC6 protocol handler initialized
        [ 1.570478] IR JVC protocol handler initialized
        [ 1.575569] IR Sony protocol handler initialized
        [ 1.580752] IR SANYO protocol handler initialized
        [ 1.586036] IR Sharp protocol handler initialized
        [ 1.591308] IR MCE Keyboard/mouse protocol handler initialized
        [ 1.597853] IR XMP protocol handler initialized
        [ 1.602938] ir_imon_decoder: IR iMON protocol handler initialized
        [ 1.609779] IR RCMM protocol handler initialized
        [ 1.615746] sunxi cedar version 1.1
        [ 1.620003] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
        [ 1.626394] VE: install start!!!
        [ 1.626394]
        [ 1.631997] VE: cedar-ve the get irq is 6
        [ 1.631997]
        [ 1.638510] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
        [ 1.638510]
        [ 1.650181] VE: install end!!!
        [ 1.650181]
        [ 1.656853] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
        [ 1.669030] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
        [ 1.679149] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
        [ 1.685452] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
        [ 1.691794] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
        [ 1.698289] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
        [ 1.704751] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
        [ 1.711296] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
        [ 1.717911] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
        [ 1.724471] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
        [ 1.732019] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1.743261] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
        [ 1.763454] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1.787759] sunxi-mmc 4020000.sdmmc: detmode:manually by software
        [ 1.787815] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1.807035] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
        [ 1.817130] sunxi-mmc 4021000.sdmmc: ctl-spec-caps 8
        [ 1.823365] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
        [ 1.829891] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
        [ 1.836435] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
        [ 1.842905] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
        [ 1.849507] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1.861145] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
        [ 1.867790] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
        [ 1.874478] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
        [ 1.881113] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
        [ 1.890636] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1.903006] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1.914296] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
        [ 1.923225] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1.934880] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 1.955788] random: fast init done
        [ 1.959682] sunxi-mmc 4021000.sdmmc: detmode:manually by software
        [ 1.967427] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
        [ 1.975128] usbcore: registered new interface driver usbhid
        [ 1.981399] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
        [ 1.988366] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 2.000038] usbhid: USB HID core driver
        [ 2.004702] fbtft_of_value: buswidth = 8
        [ 2.009208] mmc0: unrecognised SCR structure version 6
        [ 2.015046] fbtft_of_value: debug = 0
        [ 2.019232] mmc0: error -22 whilst initialising SD card
        [ 2.025147] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [ 2.036813] fbtft_of_value: rotate = 90
        [ 2.041153] fbtft_of_value: fps = 60
        [ 2.045217] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [ 2.056785] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
        [ 2.070128] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [ 2.077737] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [ 2.085307] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [ 2.092867] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
        [ 2.099689] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [ 2.353629] *ssd1353_init
        [ 2.455500] rotate 90
        [ 2.463056] xs 0 xe 127 ys 0 ye 159
        [ 2.476286] graphics fb1: fb_ssd1353 frame buffer, 128x160, 40 KiB video memory, 4 KiB buffer memory, fps=100, spi1.0 at 48 MHz
        [ 2.495920] usbcore: registered new interface driver snd-usb-audio
        [ 2.507383] [AUDIOCODEC][sunxi_codec_parse_params][2094]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
        [ 2.507383]
        [ 2.524629] [AUDIOCODEC][sunxi_codec_parse_params][2130]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
        [ 2.536181] [AUDIOCODEC][sunxi_internal_codec_probe][2266]:codec probe finished
        [ 2.545947] sid_rd_ver_reg()254 - ver >= 4, soc ver:5
        [ 2.551685] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
        [ 2.561581] [SNDCODEC][sunxi_card_init][583]:card init finished
        [ 2.569482] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
        [ 2.581100] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input3
        [ 2.593398] [SNDCODEC][sunxi_card_dev_probe][832]:register card finished
        [ 2.601768] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
        [ 2.613477] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
        [ 2.624949] Loading compiled-in X.509 certificates
        [ 2.633382] HDMI2.0 module init end
        [ 2.666447] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
        [ 2.677234] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
        [ 2.689791] clk: Not disabling unused clocks
        [ 2.694677] ALSA device list:
        [ 2.698009] #0: audiocodec
        [ 2.701253] #1: snddmic
        [ 2.704236] alloc_fd: slot 0 not NULL!
        [ 2.708941] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
        [ 2.717732] Please append a correct "root=" boot option; here are the available partitions:
        [ 2.727177] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
        [ 2.736401] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #465
        [ 2.742996] Call Trace:
        [ 2.745738] [<ffffffe0000293ce>] walk_stackframe+0x0/0xa0
        [ 2.751757] [<ffffffe0000295b0>] show_stack+0x2a/0x34
        [ 2.757395] [<ffffffe00047f7f6>] dump_stack+0x20/0x28
        [ 2.763030] [<ffffffe00002e376>] panic+0xee/0x2b6
        [ 2.768266] [<ffffffe000000eda>] mount_block_root+0x1ee/0x28a
        [ 2.774671] [<ffffffe000000ffc>] mount_root+0x86/0x90
        [ 2.780299] [<ffffffe000001116>] prepare_namespace+0x110/0x152
        [ 2.786799] [<ffffffe000000b78>] kernel_init_freeable+0x17e/0x19a
        [ 2.793591] [<ffffffe000492c4e>] kernel_init+0x12/0xee
        [ 2.799321] [<ffffffe000028018>] ret_from_exception+0x0/0xc
        [ 2.805538] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
