    D1s mipi显示屏有问题
    5004
      Maihuanyi LV 5 最后由 编辑
      使用最新的tian V2.1源码
      修改了st7701s.c的代码
      struct LCM_setting_table {
          u8 cmd;
          u32 count;
          u8 para_list[128];
      根据商家给的参数改了static struct LCM_setting_table lcm_initialization_setting[]
      设备树如下:
      lcd_driver_name     = "st7701s";
          lcd_backlight       = <100>;
          lcd_if              = <4>;
          lcd_x               = <720>;
          lcd_y               = <1280>;
          lcd_width           = <62>;
          lcd_height          = <110>;
          lcd_dclk_freq       = <100>;
          lcd_pwm_used        = <1>;
          lcd_pwm_ch          = <7>;
          lcd_pwm_freq        = <1000>;
          lcd_pwm_pol         = <0>;
          lcd_pwm_max_limit   = <255>;
          lcd_hbp             = <40>;
          lcd_ht              = <800>;
          lcd_hspw            = <10>;
          lcd_vbp             = <11>;
          lcd_vt              = <1307>;
          lcd_vspw            = <3>;
          lcd_dsi_if          = <0>;
          lcd_dsi_lane        = <4>;
          lcd_lvds_if         = <0>;
          lcd_lvds_colordepth = <0>;
          lcd_lvds_mode       = <0>;
          lcd_frm             = <0>;
          lcd_hv_clk_phase    = <0>;
          lcd_hv_sync_polarity= <0>;
          lcd_gamma_en        = <0>;
          lcd_bright_curve_en = <0>;
          lcd_cmap_en         = <0>;
          lcd_fsync_en        = <0>;
          lcd_fsync_act_time  = <1000>;
          lcd_fsync_dis_time  = <1000>;
          lcd_fsync_pol       = <0>;
          deu_mode            = <0>;
          lcdgamma4iep        = <22>;
          smart_color         = <90>;
      显示的效果有竖的花纹
        whycan晕哥 LV 9 @Maihuanyi 最后由 编辑
        @maihuanyi
        cat /sys/class/disp/disp/attr/sys
        看下 ref_fps 是不是60左右?
        M 3 条回复 最后回复 回复 引用 分享 0
          Maihuanyi LV 5 @whycan 最后由 编辑
          @whycan 是的
            @whycan 4b9fceba-e042-426a-8112-ce34146cbf14-578163ba1851bc9e81a3f75a5618e1a.jpg
              @whycan 调成这样了,不知道调整那个参数
