    V853 yolov5混合量化后导出nbg文件失败
      zhanghw LV 2 最后由 编辑
      用int8量化后导出nbg文件正常。将一个层改为int16后导出ngb文件失败
      customized_quantize_layers:
      Sigmoid_Sigmoid_194_16_Mul_Mul_195_12: dynamic_fixed_point-i16
      失败输出打印:
      [Galcore]: system reserved pool0 CPU physical=0x1000000 GPU physical=0x1000000 virtual=0x1000000 size=0xf3334000
      E [ops/vsi_nn_op_conv2d.c:op_check:430]Inputs/Outputs data type not support: DFP INT16, SYMM PC INT8, SYMM PC INT64, ASYM UINT8
      E [vsi_nn_graph.c:setup_node:483]Check node[145] CONV2D fail
      E [vnn_yolov5ssimprj.c:vnn_CreateYolov5sSimprj:6523]CHECK STATUS(-1:A generic error code, used when no other describes the error.)
      E [main.c:vnn_CreateNeuralNetwork:202]CHECK PTR 202
      E [main.c:main:236]CHECK PTR 236
      E Fatal model generation error: 65280
      W ----------------Error(1),Warning(0)----------------
      File "pegasus.py", line 131, in <module>
      File "pegasus.py", line 116, in main
      File "acuitylib/app/exporter/commands.py", line 178, in execute
      File "acuitylib/vsi_nn.py", line 653, in export_ovxlib
      File "acuitylib/app/exporter/ovxlib_case/export_ovxlib.py", line 73, in run
      File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 744, in generate
      File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 702, in _gen_special_case
      File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 679, in _gen_nb_file
      File "acuitylib/acuitylog.py", line 263, in e
      acuitylib.acuityerror.AcuityError: ('Fatal model generation error: 65280', 'nbg_generate')
      [834012] Failed to execute script 'pegasus' due to unhandled exception!
