    调试RTL8201F提示“sunxi-gmac 4500000.eth eth0: No PHY found!”
    • G
      glorystar LV 2 最后由 xiaowenge 编辑
      A133 android平台 kernel5.4 调试以太网,网卡芯片用的RTL8201F百兆,提示“sunxi-gmac 4500000.eth eth0: No PHY found!”,复位信号有了,晶振有也有起震,帮忙看下,多谢!下面是dts配置。
      sun50iw10p1.dtsi
      gmac0: eth@4500000 {
      			compatible = "allwinner,sunxi-gmac";
      			reg = <0x0 0x04500000 0x0 0x10000>,
      			      <0x0 0x03000030 0x0 0x4>;
      			interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
      			interrupt-names = "gmacirq";
      			clocks = <&ccu CLK_BUS_EMAC0>, <&ccu CLK_EMAC0_25M>;
      			clock-names = "gmac", "ephy";
      			resets = <&ccu RST_BUS_EMAC0>;
      			device_type = "gmac0";
      			pinctrl-0 = <&gmac_pins_a>;
      			pinctrl-1 = <&gmac_pins_b>;
      			phy-mode;
      			use_ephy25m;
      			tx-delay = <7>;
      			rx-delay = <31>;
      			phy-rst = <&pio PB 6 GPIO_ACTIVE_LOW>;
      			gmac-power0;
      			gmac-power1;
      			gmac-power2;
      			status = "disabled";
      gmac_pins_a: gmac@0 {
      				pins = "PH0", "PH1", "PH2", "PH3",
      						 "PH4", "PH5", "PH6", "PH7",
      						 "PH9", "PH10", "PH13", "PH14",
      						 "PH15", "PH16", "PH17", "PH18";
      				function = "gmac0";
      				drive-strength = <30>;
      gmac_pins_b: gmac@1 {
      				function = "gpio_in";
      board.dts
      &gmac0 {
      		phy-mode = "rmii";
      		use_ephy25m = <1>;
