    通过Buildroot创建东山派D1s的镜像后,通过网络接口写入文件出现死机情况
    5852
      story_xjj LV 5 最后由 编辑
      根据网上的buildroot创建了一个D1s的镜像,启动和运行都是比较正常的,由于东山派D1s没有网络接口,所以我利用RNDIS虚拟了一个网络,SSH可以正常登录,执行命令和查看修改系统的信息没有任何问题。在通过SFTP方式上传是出现了死机的情况,于是采用nfs链接windows的nfs服务器,可以正确链接,向windows的nfs服务器创建文件没有任何问题,但是向linux系统拷贝文件同样会出现死机的情况。
      下面是系统打印的日志,请各位看看是什么原因导致的。
      [53]HELLO! BOOT0 is starting!
      [56]BOOT0 commit : 603490b
      [58]set pll start
      [60]periph0 has been enabled
      [63]set pll end
      [65][pmu]: bus read error
      [67]board init ok
      [69]ZQ value = 0x2e***********
      [72]get_pmu_exist() = -1
      [74]ddr_efuse_type: 0xa
      [77][AUTO DEBUG] single rank and full DQ!
      [81]ddr_efuse_type: 0xa
      [83][AUTO DEBUG] rank 0 row = 13
      [86][AUTO DEBUG] rank 0 bank = 4
      [90][AUTO DEBUG] rank 0 page size = 2 KB
      [93]DRAM BOOT DRIVE INFO: V0.24
      [96]DRAM CLK = 528 MHz
      [98]DRAM Type = 2 (2:DDR2,3:DDR3)
      [102]DRAMC read ODT  off.
      [104]DRAM ODT off.
      [106]ddr_efuse_type: 0xa
      [109]DRAM SIZE =64 M
      [112]DRAM simple test OK.
      [115]dram size =64
      [116]card no is 0
      [118]sdcard 0 line count 4
      [121][mmc]: mmc driver ver 2021-04-2 16:45
      [130][mmc]: Wrong media type 0x0
      [133][mmc]: ***Try SD card 0***
      [161][mmc]: HSSDR52/SDR25 4 bit
      [164][mmc]: 50000000 Hz
      [166][mmc]: 1886 MB
      [168][mmc]: ***SD/MMC 0 init OK!!!***
      [231]Loading boot-pkg Succeed(index=0).
      [234]Entry_name        = opensbi
      [237]Entry_name        = u-boot
      [241]Entry_name        = dtb
      [244]mmc not para
      [245]Jump to second Boot.
      OpenSBI v0.6
              |_|
      Platform Name          : Allwinner SUN20i - T-HEAD Xuantie Platform
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒
      U-Boot 2018.05 (Jun 06 2023 - 14:43:23 +0800) Allwinner Technology
      [00.329]DRAM:  64 MiB
      [00.331]Relocation Offset is: 01ee9000
      [00.336]secure enable bit: 0
      [00.339]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.345]flash init start
      [00.347]workmode = 0,storage type = 1
      [00.351][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [00.356][mmc]: get sdc_type fail and use default host:tm1.
      [00.363][mmc]: can't find node "mmc0",will add new node
      [00.368][mmc]: fdt err returned <no error>
      [00.372][mmc]: Using default timing para
      [00.375][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.411][mmc]: card_caps:0x3000000a
      [00.414][mmc]: host_caps:0x3000003f
      [00.422]sunxi flash init ok
      [00.424]line:703 init_clocks
      [00.427]drv_disp_init
      [00.448]drv_disp_init finish
      [00.451]boot_gui_init:start
      [00.454]set disp.dev2_output_type fail. using defval=0
      [00.461]boot_gui_init:finish
      [00.530]Get bootloader and boot-resource partition number fail!
      [00.564]Loading Environment from SUNXI_FLASH... OK
      [00.587]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.602]update part info
      [00.608]update bootcmd
      [00.617]change working_fdt 0x42aa8da0 to 0x42a88da0
      [00.653]LCD open finish
      [00.667]update dts
      card0 has inited
      curr_device:0
      Device: SUNXI SD/MMC
      Manufacturer ID: 3
      OEM: 5344
      Bus Speed: 50000000
      Mode : SD High Speed (50MHz)
      Rd Block Len: 512
      SD version 3.0
      High Capacity: No
      Capacity: 1.8 GiB
      Bus Width: 4-bit
      Erase Group Size: 512 Bytes
      Partition Map for MMC device 0  --   Partition Type: EFI
      Part    Start LBA       End LBA         Name
              Attributes
              Type GUID
              Partition GUID
        1     0x00008820      0x0000891f      "env"
              attrs:  0x0000000000000000
              type:   0fc63daf-8483-4772-8e79-3d69d8477de4
              guid:   4bc1c54f-615a-4e61-b876-285795eddced
        2     0x00008920      0x00008a1f      "env-redund"
              guid:   500cb3e6-be80-4c8e-8180-3a66fc6db8b9
        3     0x00008a20      0x00018a1f      "boot"
              attrs:  0x0000000000000004
              guid:   bd535aa2-0c9e-4d1d-9ceb-2f181e0f3cd8
        4     0x00018a20      0x0001ca1f      "data"
              guid:   dda40b61-ba8e-40b7-b569-38d88ea31c2a
        5     0x0001ca20      0x0009ca1f      "rootfs"
              guid:   4dcc9a9e-1b69-4513-8edc-561a33b9507b
      7157760 bytes read in 375 ms (18.2 MiB/s)
      [03.176]no vendor_boot partition is found
      Android's image name: sun20i
      [03.191]
      Starting kernel ...
      [03.194][mmc]: MMC Device 2 not found
      [03.197][mmc]: mmc 2 not find, so not exit
      ** 13 printk messages dropped **
      [    0.000000]   DMA32 zone: 15872 pages, LIFO batch:3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15655
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5  init=/sbin/init partitions=ext4 cma=8M  gpt=1 androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(06/06/2023-14:43:23) mbr_offset=1556480 disp_reserve=522240,0x0000000042b15000 androidboot.dramsize=64
      [    0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [    0.000000] Memory: 46388K/63488K available (4808K kernel code, 445K rwdata, 1292K rodata, 164K init, 267K bss, 8908K reserved, 8192K cma-reserved)
      [    0.000009] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000030] riscv_timer_clockevent depends on broadcast, but no broadcast function available
      [    0.000440] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.001337] Console: colour dummy device 80x25
      [    0.001389] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.001409] pid_max: default: 32768 minimum: 301
      [    0.001572] LSM: Security Framework initializing
      [    0.001624] SELinux:  Initializing.
      [    0.001813] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.001835] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.004265] ASID allocator initialised with 65536 entries
      [    0.004477] rcu: Hierarchical SRCU implementation.
      [    0.005330] devtmpfs: initialized
      [    0.026890] random: get_random_u32 called from 0xffffffe0002619ca with crng_init=0
      [    0.028002] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.028039] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
      [    0.028621] pinctrl core: initialized pinctrl subsystem
      [    0.030497] NET: Registered protocol family 16
      [    0.032941] DMA: preallocated 256 KiB pool for atomic allocations
      [    0.032989] audit: initializing netlink subsys (disabled)
      [    0.034157] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
      [    0.034189] cpuidle: using governor menu
      [    0.092602] rtc_ccu: sunxi ccu init OK
      [    0.102573] clock: sunxi ccu init OK
      [    0.103808] clock: sunxi ccu init OK
      [    0.149479] iommu: Default domain type: Translated
      [    0.149708] sunxi iommu: irq = 4
      [    0.151399] SCSI subsystem initialized
      [    0.153758] pwm module init!
      [    0.156151] clocksource: Switched to clocksource riscv_clocksource
      [    0.174454] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.199293] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    0.200350] NET: Registered protocol family 2
      [    0.201470] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.201529] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.201554] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.201574] TCP: Hash tables configured (established 512 bind 512)
      [    0.201772] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.201826] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.202106] NET: Registered protocol family 1
      [    0.203052] RPC: Registered named UNIX socket transport module.
      [    0.203068] RPC: Registered udp transport module.
      [    0.203076] RPC: Registered tcp transport module.
      [    0.203083] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.203769] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.204558] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.204900] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
      [    0.204983] sunxi_spi_resource_get()2189 - Failed to get sample mode
      [    0.204997] sunxi_spi_resource_get()2194 - Failed to get sample delay
      [    0.205008] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.205091] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
      [    0.206115] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base ffffffd00405a000, irq 31
      [    0.209015] workingset: timestamp_bits=62 max_order=14 bucket_order=0
      [    0.220136] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.221717] NFS: Registering the id_resolver key type
      [    0.221786] Key type id_resolver registered
      [    0.221797] Key type id_legacy registered
      [    0.221825] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.221836] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [    0.221845] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
      [    0.223431] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.252354] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
      [    0.252372] io scheduler mq-deadline registered
      [    0.252383] io scheduler kyber registered
      [    0.253838] [DISP]disp_module_init
      [    0.254716] disp 5000000.disp: Adding to iommu group 0
      [    0.255678] [DISP] disp_init,line:2386:
      [    0.255686] smooth display screen:0 type:1 mode:4
      [    0.304151] display_fb_request,fb_id:0
      [    0.312032] disp_al_manager_apply ouput_type:1
      [    0.312245] [DISP] lcd_clk_config,line:744:
      [    0.312262] disp 0, clk: pll(144000000),clk(144000000),dclk(24000000) dsi_rate(144000000)
      [    0.312262]      clk real:pll(288000000),clk(288000000),dclk(24000000) dsi_rate(0)
      [    0.313992] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.573128] Console: switching to colour frame buffer device 60x34
      [    0.595688] [DISP]disp_module_init finish
      [    0.596841] sunxi_sid_init()551 - insmod ok
      [    0.597581] pwm-regulator: supplied by regulator-dummy
      [    0.600021] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    0.600595] uart uart0: get regulator failed
      [    0.600634] uart uart0: uart0 supply uart not found, using dummy regulator
      [    0.601160] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
      [    0.601196] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      [    0.729826] free logo buffer src_phy_addr=0x42b15000  fb_height=272  src_stride=1920
      [    0.730413] Freeing logo buffer memory: 512K
      [    1.342486] printk: console [ttyS0] enabled
      [    1.348720] misc dump reg init
      [    1.354109] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
      [    1.361395] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      [    1.377323] random: fast init done
      [    1.877371] random: crng init done
      [    2.366319] sunxi-spinand-phy: read id failed : -110
      [    2.371943] spi-nand: probe of spi0.0 failed with error -110
      [    2.378885] libphy: Fixed MDIO Bus: probed
      [    2.383776] using random self ethernet address
      [    2.388865] using random host ethernet address
      [    2.394683] usb0: HOST MAC de:32:0e:9f:12:b4
      [    2.399684] usb0: MAC 3a:b5:56:4b:1d:f6
      [    2.404027] using random self ethernet address
      [    2.409037] using random host ethernet address
      [    2.414159] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
      [    2.421654] g_ether gadget: g_ether ready
      [    2.428474] sunxi-rtc 7090000.rtc: registered as rtc0
      [    2.434246] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:15:45 UTC (945)
      [    2.443532] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    2.449641] i2c /dev entries driver
      [    2.453605] IR NEC protocol handler initialized
      [    2.462334] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    2.472441] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    2.478708] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    2.485073] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    2.491520] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    2.497974] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    2.504493] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    2.511070] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    2.517620] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    2.525363] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.536566] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    2.556750] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.581061] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
      [    2.587191] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.599877] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    2.611116] sunxi_set_cur_vol_work()397 WARN: get power supply failed
      [    2.618856] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    2.628700] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.640668] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    2.647008] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    2.653384] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    2.660185] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    2.666758] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    2.673405] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    2.680040] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    2.686649] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.698318] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    2.704871] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    2.714814] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.726079] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    2.735048] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.746731] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.771161] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    2.778904] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.786484] ashmem: initialized
      [    2.790034] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.796966] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.808789] exFAT: Version 1.3.0
      [    2.812421] g_ether gadget: high-speed config #2: RNDIS
      [    2.821746] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.836038] NET: Registered protocol family 10
      [    2.843370] Segment Routing with IPv6
      [    2.847709] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.857253] NET: Registered protocol family 17
      [    2.862293] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.869512] Key type dns_resolver registered
      [    2.874380] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.881288] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.893735] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.900739] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.912440] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.919382] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.956476] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    2.981654] mmc0: new high speed SD card at address e624
      [    2.989522] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [    2.999742] mmcblk0: mmc0:e624 SU02G 1.84 GiB
      [    3.016137] sunxi-i2c sunxi-i2c2: probe success
      [    3.022617] sunxi-i2c sunxi-i2c3: sunxi-i2c3 supply twi not found, using dummy regulator
      [    3.044217] GPT:Primary header thinks Alt. header is not at the end of the disk.
      [    3.052635] sunxi-i2c sunxi-i2c3: probe success
      [    3.060905] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    3.071944] GPT:641607 != 3862527
      [    3.075655] GPT:Alternate GPT header not at the end of the disk.
      [    3.082411] GPT:641607 != 3862527
      [    3.088650] GPT: Use GNU Parted to correct GPT errors.
      [    3.094537]  mmcblk0: p1 p2 p3 p4 p5
      [    3.100639] OF: fdt: not creating '/sys/firmware/fdt': CRC check failed
      [    3.108186] clk: Not disabling unused clocks
      [    3.112992] alloc_fd: slot 0 not NULL!
      [    3.124331] EXT4-fs (mmcblk0p5): INFO: recovery required on readonly filesystem
      [    3.132649] EXT4-fs (mmcblk0p5): write access will be enabled during recovery
      [    3.398100] EXT4-fs (mmcblk0p5): recovery complete
      [    3.407612] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
      [    3.416816] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
      [    3.427057] devtmpfs: mounted
      [    3.430695] Freeing unused kernel memory: 164K
      [    3.435666] This architecture does not have kernel memory protection.
      [    3.442927] Run /sbin/init as init process
      SELinux:  Could not open policy file <= /etc/selinux/targeted/policy/policy.33:  No such file or directory
      [    3.793658] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
      Starting syslogd: OK
      Starting klogd: OK
      Running sysctl: OK
      Populating /dev using udev: [    4.399733] udevd[99]: starting version 3.2.11
      [    4.510830] udevd[100]: starting eudev-3.2.11
      [    5.111156] sunxi_gpadc_init,2151, success
      [    5.156743] sunxi_gpadc_setup: get channel scan data failed
      [    5.163738] input: sunxi-gpadc0 as /devices/virtual/input/input0
      done
      Initializing random number generator: OK
      Saving random seed: OK
      Starting system message bus: done
      Starting rpcbind: OK
      Starting network: OK
      Starting sshd: OK
      Starting NFS statd: OK
      Starting NFS services: OK
      Starting NFS daemon: [   10.396690] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
      [   10.405529] NFSD: unable to find recovery directory /var/lib/nfs/v4recovery
      [   10.414286] NFSD: Unable to initialize client recovery tracking! (-2)
      [   10.421975] NFSD: starting 90-second grace period (net f0000019)
      OK
      Starting NFS mountd: OK
      Starting IIO Server Daemon
      Welcome to Buildroot
      buildroot login: [   33.126226] usb1-vbus: disabling
      [  344.313661] BUG: Bad page state in process swapper  pfn:42ac8
      [  344.320109] page:ffffffe0035b4bc0 refcount:-2 mapcount:0 mapping:0000000000000000 index:0x0
      [  344.329455] flags: 0x0()
      [  344.332291] raw: 0000000000000000 0000000000000100 0000000000000122 0000000000000000
      [  344.340960] raw: 0000000000000000 0000000000000000 fffffffeffffffff
      [  344.347969] page dumped because: nonzero _refcount
      [  344.353323] Modules linked in: snd_soc_sunxi_simple_card snd_soc_dmic snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore sunxi_gpadc
      [  344.370383] CPU: 0 PID: 0 Comm: swapper Not tainted 5.4.61 #4
      [  344.376811] Call Trace:
      [  344.379545] [<ffffffe00002b0ca>] 0xffffffe00002b0ca
      [  344.384999] [<ffffffe00002b282>] 0xffffffe00002b282
      [  344.390457] [<ffffffe0004c5232>] 0xffffffe0004c5232
      [  344.395913] [<ffffffe0000a33ee>] 0xffffffe0000a33ee
      [  344.401369] [<ffffffe0000a34b6>] 0xffffffe0000a34b6
      [  344.406824] [<ffffffe0000a5824>] 0xffffffe0000a5824
      [  344.412279] [<ffffffe0000a6324>] 0xffffffe0000a6324
      [  344.417736] [<ffffffe0000a643e>] 0xffffffe0000a643e
      [  344.423193] [<ffffffe0003e3706>] 0xffffffe0003e3706
      [  344.428646] [<ffffffe000386a86>] 0xffffffe000386a86
      [  344.434103] [<ffffffe000386c04>] 0xffffffe000386c04
      [  344.439560] [<ffffffe00038eef0>] 0xffffffe00038eef0
      [  344.445015] [<ffffffe00038f104>] 0xffffffe00038f104
      [  344.450471] [<ffffffe00038fc88>] 0xffffffe00038fc88
      [  344.455927] [<ffffffe000390bb0>] 0xffffffe000390bb0
      [  344.461381] [<ffffffe000053b7a>] 0xffffffe000053b7a
      [  344.466837] [<ffffffe000053c06>] 0xffffffe000053c06
      [  344.472294] [<ffffffe000053c80>] 0xffffffe000053c80
      [  344.477748] [<ffffffe000056a38>] 0xffffffe000056a38
      [  344.483203] [<ffffffe0000530b0>] 0xffffffe0000530b0
      [  344.488660] [<ffffffe0002a6104>] 0xffffffe0002a6104
      [  344.494116] [<ffffffe0004da23e>] 0xffffffe0004da23e
      [  344.499571] [<ffffffe000029e18>] 0xffffffe000029e18
      [  344.505025] [<ffffffe00005cba0>] 0xffffffe00005cba0
      [  344.510480] Disabling lock debugging due to kernel taint
      [  373.079383] BUG: Bad page state in process swapper  pfn:422e0
      [  373.085837] page:ffffffe003599100 refcount:-1 mapcount:0 mapping:0000000000000000 index:0x0
      [  373.095183] flags: 0x0()
      [  373.098021] raw: 0000000000000000 0000000000000100 0000000000000122 0000000000000000
      [  373.106694] raw: 0000000000000000 0000000000000000 ffffffffffffffff
      [  373.113695] page dumped because: nonzero _refcount
      [  373.119052] Modules linked in: snd_soc_sunxi_simple_card snd_soc_dmic snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore sunxi_gpadc
      [  373.136144] CPU: 0 PID: 0 Comm: swapper Tainted: G    B             5.4.61 #4
      [  373.144129] Call Trace:
      [  373.146865] [<ffffffe00002b0ca>] 0xffffffe00002b0ca
      [  373.152325] [<ffffffe00002b282>] 0xffffffe00002b282
      [  373.157783] [<ffffffe0004c5232>] 0xffffffe0004c5232
      [  373.163242] [<ffffffe0000a33ee>] 0xffffffe0000a33ee
      [  373.168701] [<ffffffe0000a34b6>] 0xffffffe0000a34b6
      [  373.174161] [<ffffffe0000a5824>] 0xffffffe0000a5824
      [  373.179620] [<ffffffe0000a6324>] 0xffffffe0000a6324
      [  373.185079] [<ffffffe0000a643e>] 0xffffffe0000a643e
      [  373.190538] [<ffffffe0003e3706>] 0xffffffe0003e3706
      [  373.195997] [<ffffffe000386a86>] 0xffffffe000386a86
      [  373.201456] [<ffffffe000386c04>] 0xffffffe000386c04
      [  373.206915] [<ffffffe00038eef0>] 0xffffffe00038eef0
      [  373.212375] [<ffffffe00038f104>] 0xffffffe00038f104
      [  373.217834] [<ffffffe000390074>] 0xffffffe000390074
      [  373.223293] [<ffffffe0003901b0>] 0xffffffe0003901b0
      [  373.228752] [<ffffffe000390c06>] 0xffffffe000390c06
      [  373.234212] [<ffffffe000053b7a>] 0xffffffe000053b7a
      [  373.239672] [<ffffffe000053c06>] 0xffffffe000053c06
      [  373.245130] [<ffffffe000053c80>] 0xffffffe000053c80
      [  373.250590] [<ffffffe000056a38>] 0xffffffe000056a38
      [  373.256049] [<ffffffe0000530b0>] 0xffffffe0000530b0
      [  373.261508] [<ffffffe0002a6104>] 0xffffffe0002a6104
      [  373.266968] [<ffffffe0004da23e>] 0xffffffe0004da23e
      [  373.272427] [<ffffffe000029e18>] 0xffffffe000029e18
      [  373.277887] [<ffffffe00005cba0>] 0xffffffe00005cba0
      [  375.083493] ------------[ cut here ]------------
      [  375.088671] kernel BUG at mm/slub.c:3995!
      [  375.093157] Kernel BUG [#1]
      [  375.096278] Modules linked in: snd_soc_sunxi_simple_card snd_soc_dmic snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore sunxi_gpadc
      [  375.113355] CPU: 0 PID: 0 Comm: swapper Tainted: G    B             5.4.61 #4
      [  375.121340] sepc: ffffffe0000aac98 ra : ffffffe0000aac68 sp : ffffffe000623a40
      [  375.129425]  gp : ffffffe00068e138 tp : ffffffe000628660 t0 : 322e3535322e3535
      [  375.137508]  t1 : 0d303039313a3035 t2 : cb0000450008b412 s0 : ffffffe000623a90
      [  375.145585]  s1 : ffffffe0035994f0 a0 : ffffffe0035994f0 a1 : 0000000000000000
      [  375.153658]  a2 : 000000000000007f a3 : ffffffe0020f2147 a4 : 0000000000000000
      [  375.161724]  a5 : 0000000000000000 a6 : 534f480a0d312e31 a7 : 322e393332203a54
      [  375.169795]  s2 : ffffffe00066df50 s3 : 0000000000000000 s4 : ffffffe0020f2042
      [  375.177863]  s5 : ffffffe00066df80 s6 : 0000000000000105 s7 : 0000000000000001
      [  375.185943]  s8 : ffffffd004056004 s9 : 000000000000062a s10: 0000000000000105
      [  375.194017]  s11: 0000000000000001 t3 : fe011101000080ff t4 : faffffef0107a8c0
      [  375.202096]  t5 : eef3b7006c070bde t6 : ffffffe0020e0147
      [  375.208032] sstatus: 0000000200000100 sbadaddr: 0000000000000000 scause: 0000000000000003
      [  375.217241] ---[ end trace 6a0a5cb09348a66f ]---
      [  375.222396] Kernel panic - not syncing: Fatal exception in interrupt
      [  375.229510] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
      S 1 条回复 最后回复 回复 引用 分享 0
        story_xjj LV 5 @story_xjj 最后由 编辑
        @story_xjj
        我还发现了一个怪现象,因为创建的SD卡镜像中,boot分区时fat格式的,如果用读卡器把文件复制到boot分区中,然后重新引导系统,挂载boot分区,再把文件复制到或移动到根分区中,就不会出现死机的情况。一切正常。
        而且编译的文件可以正确执行。
        [root@buildroot ~]# ls
        mywork  nfs     nfs.sh
        [root@buildroot ~]# mount -t vfat /dev/disk/by-partlabel/boot nfs
        [root@buildroot ~]# cd nfs
        [root@buildroot nfs]# ls
        Image                       boot.img                    sun20i-d1s-nezha-linux.dtb
        System Volume Information   main
        [root@buildroot nfs]# mv main ../mywork/
        Image                       boot.img
        System Volume Information   sun20i-d1s-nezha-linux.dtb
        [root@buildroot nfs]# cd ..
        mywork  nfs     nfs.sh
        [root@buildroot ~]# cd mywork/
        [root@buildroot mywork]# ls
        main
        [root@buildroot mywork]# ll
        total 12
        -rwxr-xr-x    1 root     root         11608 Jun  7  2023 main
        [root@buildroot mywork]# ./main
        hello world!
          story_xjj LV 5 最后由 story_xjj 编辑
          问题有新的进展了,因为boot分区时fat格式的,我将boot分区挂载到root分区的目录下,然后通过sftp将文件传送到boot分区中,传送成功了,系统并没有死机。似乎这个文件复制过程死机和ext4文件系统有关系。原来传输的文件大小为5k左右,我把文件调大到10k,传输同样会失败。我现在也不清楚时文件系统格式的问题还是文件大小的问题,有没有大神可以出来指导一下。
          M 1 条回复 最后回复 回复 引用 分享 0
            Maihuanyi LV 5 @story_xjj 最后由 编辑
            @story_xjj 我也遇到这个问题了,你解决了吗
              story_xjj LV 5 @Maihuanyi 最后由 编辑
              @maihuanyi 没有解决,希望有高手出面解决
              V 1 条回复 最后回复 回复 引用 分享 0
              • V
                vctorspace LV 3 @story_xjj 最后由 编辑
                @story_xjj 请问解决了吗,我也遇到同样问题
