    A133芯片安卓13无法启动
      yzyzx LV 2 最后由 whycan 编辑
      A133新板子,在烧录后进入内核卡住无法启动了怎么办log
      [02.780][axp][err]: can't find cldo3 from table
      [02.844]set disp.fb0_rot_used fail. using defval=0
      [02.849]set disp.fb0_rot_degree fail. using defval=0
      [02.854]soc ic_ver:0x4, qa_val:0x0, markid:0x1400 dclk[0-200] display_cfg_flag:0
      [02.861]boot_gui_init:finish
      [02.877]bmp_name=bootlogo.bmp size 3072054
      [02.962]LCD open finish
      [02.983]Item0 (Map) magic is bad
      [02.986]the secure storage item0 copy0 magic is bad
      [02.999]Item0 (Map) magic is bad
      [03.001]the secure storage item0 copy1 magic is bad
      [03.006]Item0 (Map) magic is bad
      [03.009]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [03.019]usb prepare ok
      [03.322]overtime
      [03.327]do_burn_from_boot usb : no usb exist
      [03.331][ARISC ERROR] :get [allwinner,arisc_space] device node error
      CACHE: Misaligned operation at range [bffa0260, bffa0578]
      [SCP] :sunxi-arisc driver begin startup 2
      [SCP] :0x1
      [SCP] :arisc version: [lbata-te-331rdna1dio1v-3d-1.ytri]
      [SCP] :arisc startup ready
      [SCP] :arisc startup notify message feedback
      [SCP] :send hard sync feedback message: 0x900200
      [SCP] :sunxi-arisc driver v1.10 is starting
      List file under ULI/factory
      [03.387]update part info
      [03.406]update bootcmd
      [03.408]change working_fdt 0xbbe9ae50 to 0xbbe6ae50
      [03.413][mmc]: can't find node "mmc2" try sunxi-mmc
      [03.418][mmc]: delete mmc-hs400-1_8v from dtb
      [03.422][mmc]: delete mmc-hs200-1_8v from dtb
      [03.426][mmc]: get max-frequency ok 50000000 Hz
      [03.452]Could not find pmu_ext type: update_pmu_ext_info_to_kernel: L63
      [03.459]update dts
      ramdisk use init boot
      Android's image name: arm64
      ERROR: reserving fdt memory region failed (addr=bbf49000 size=3e8000)
      [04.411]Starting kernel ...
      [04.414][mmc]: mmc exit start
      [04.432][mmc]: mmc 2 exit ok
      [    2.062863][  T170] Unable to handle kernel paging request at virtual address fffffffffffffe73
      [    2.072528][  T170] Mem abort info:
      [    2.072530][  T170]   ESR = 0x96000005
      [    2.072534][  T170]   EC = 0x25: DABT (current EL), IL = 32 bits
      [    2.072538][  T170]   SET = 0, FnV = 0
      [    2.072542][  T170]   EA = 0, S1PTW = 0
      [    2.087323][  T170]   FSC = 0x05: level 1 translation fault
      [    2.087328][  T170] Data abort info:
      [    2.105993][  T170]   ISV = 0, ISS = 0x00000005
      [    2.111070][  T170]   CM = 0, WnR = 0
      [    2.115169][  T170] swapper pgtable: 4k pages, 39-bit VAs, pgdp=00000000426c6000
      [    2.123431][  T170] [fffffffffffffe73] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
      [    2.133955][  T170] Internal error: Oops: 96000005 [#1] PREEMPT SMP
      [    2.134170][    T5] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-DDR52 dt B
      [    2.140957][  T170] Modules linked in: disp(E) nand(E) sunxi_nsi(E) sun50i_cpufreq_nvmem(E) sunxi_addr(E) axp2101_i2c(E) ccu_sun50iw10(E) )
      [    2.153655][    T5] mmc0: Host Software Queue enabled
      [    2.206952][  T137] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.236132][  T170] CPU: 1 PID: 170 Comm: kworker/1:2 Tainted: G            E     5.15.41-dirty #3
      [    2.236139][  T170] Hardware name: sun50iw10 (DT)
      [    2.236145][  T170] Workqueue: events start_work.01935dffa4f02fa2f1b7b22e4ce61daf.cfi_jt [disp]
      [    2.237424][  T137] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.241796][    C0] sunxi-mmc 4020000.sdmmc: smc 1 p0 err, cmd 8, RTO !!
      [    2.254102][  T170]
      [    2.254106][  T170] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
      [    2.264138][    T5] mmc0: new DDR MMC card at address 0001
      [    2.269358][  T170] pc : regulator_enable+0x2c/0x8c
      [    2.269367][    C0] sunxi-mmc 4020000.sdmmc: smc 1 p0 err, cmd 55, RTO !!
      [    2.269371][  T170] lr : disp_sys_power_enable+0x1c/0x58 [disp]
      [    2.279102][    C0] sunxi-mmc 4020000.sdmmc: smc 1 p0 err, cmd 55, RTO !!
      [    2.291428][  T170] sp : ffffffc00ad63bf0
      [    2.299734][    C0] sunxi-mmc 4020000.sdmmc: smc 1 p0 err, cmd 55, RTO !!
      [    2.301334][  T170] x29: ffffffc00ad63c10 x28: 0000000000000402
      [    2.310585][    T5] mmcblk0: mmc0:0001 AT2S6A 14.6 GiB
      [    2.315995][  T170]  x27: ffffff807fb14e60
      [    2.316000][  T170] x26: ffffff800c9b5b10 x25: 0000000000000000 x24: ffffffc001af70c8
      [    2.316011][  T170] x23: ffffff807fb19305
      [    2.316008][    C0] sunxi-mmc 4020000.sdmmc: smc 1 p0 err, cmd 55, RTO !!
      [    2.316014][  T170]  x22: ffffff80057b8000 x21: ffffff80057b8000
      [    2.316021][  T170] x20: ffffff8005b54400 x19: fffffffffffffdfb x18: ffffffc00ad46040
      [    2.316039][  T137] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.337996][    T5]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27
      [    2.343199][  T170]
      [    2.343202][  T170] x17: ffffffffffffffff x16: 0000000000000000 x15: 0000000000000004
      [    2.343213][  T170] x14: ffffffc00a8860a0 x13: 0000000000000fff x12: 0000000000000003
      [    2.343223][  T170] x11: ffffffc001b50b24 x10: 0000000000000370 x9 : f4be659754e5ff00
      [    2.343233][  T170] x8 : f4be659754e5ff00
      [    2.350169][    T5] mmcblk0rpmb: mmc0:0001 AT2S6A 4.00 MiB, chardev (235:0)
      NOTICE:  sunxi_usb_dev_register
      NOTICE:  sunxi_usb_main_loop
        yzyzx LV 2 最后由 编辑
        哪个大佬帮忙看看问题出在哪
          WhycanService LV 8 最后由 编辑
          为啥log只有报错之后的,其余log还有吗
