    使用官方烧录工具PhoenixSuit烧录t113镜像到sd卡没成功过,一直是烧录固件失败,打印内容如下
    2640
      ah669741 LV 4 最后由 xiaowenge 编辑
      2222222222[20]HELLO! BOOT0 is starting!
      [23]BOOT0 commit : adaf1174cc
      [26]set pll start
      [32]periph0 has been enabled
      [35]set pll end
      [37][pmu]: bus read error
      [39]board init ok
      [41]key press : 2
      [43]detected_f user input 2
      [30622]fes begin commit:adaf1174cc
      [30625]set pll start
      [30631]periph0 has been enabled
      [30634]set pll end
      [30636][pmu]: bus read error
      [30638]board init ok
      [30640]beign to init dram
      [30643]ZQ value = 0x2e
      [30645]get_pmu_exist() = -1
      [30648]ddr_efuse_type: 0xa
      [30650]trefi:7.8ms
      [30653][AUTO DEBUG] single rank and full DQ!
      [30657]ddr_efuse_type: 0xa
      [30659]trefi:7.8ms
      [30662][AUTO DEBUG] rank 0 row = 13
      [30665][AUTO DEBUG] rank 0 bank = 8
      [30668][AUTO DEBUG] rank 0 page size = 2 KB
      [30673]DRAM BOOT DRIVE INFO: V0.33
      [30676]DRAM CLK = 936 MHz
      [30678]DRAM Type = 3 (2:DDR2,3:DDR3)
      [30681]DRAMC read ODT  off.
      [30684]DRAM ODT value: 0x42.
      [30687]ddr_efuse_type: 0xa
      [30690]DRAM SIZE =128 M
      [30692]dram_tpr4:0x0
      [30694]PLL_DDR_CTRL_REG:0xf8004d00
      [30697]DRAM_CLK_REG:0xc0000000
      [30700][TIMING DEBUG] MR2= 0x20
      [30704]DRAM simple test OK.
      [30707]rtc standby flag is 0x0, super standby flag is 0x0
      [30712]init dram ok
      U-Boot 2018.05-g2a1965a (Jul 10 2022 - 02:50:57 +0000) Allwinner Technology
      [32.287]CPU:   Allwinner Family
      [32.290]Model: sun8iw20
      [32.292]DRAM:  128 MiB
      [32.295]Relocation Offset is: 04ebc000
      [32.321]secure enable bit: 0
      [32.324]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [32.330]gic: normal mode
      [32.332]flash init start
      [32.335]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [32.342][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [32.349][mmc]: Is not Boot mode!
      [32.352][mmc]: SUNXI SDMMC Controller Version:0x50310
      [32.363][mmc]: ************Try SD card 2************
      [32.368][mmc]: mmc 2 cmd timeout 100 status 100
      [32.373][mmc]: smc 2 err, cmd 8,  RTO
      [32.376][mmc]: mmc 2 close bus gating and reset
      [32.381][mmc]: mmc 2 cmd timeout 100 status 100
      [32.385][mmc]: smc 2 err, cmd 55,  RTO
      [32.389][mmc]: mmc 2 close bus gating and reset
      [32.393][mmc]: ************Try MMC card 2************
      [32.402][mmc]: mmc 2 cmd timeout 100 status 100
      [32.406][mmc]: smc 2 err, cmd 1,  RTO
      [32.409][mmc]: mmc 2 close bus gating and reset
      [32.413][mmc]: Card did not respond to voltage select!
      [32.418][mmc]: ************SD/MMC 2 init error!************
      [32.424][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [32.430]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
      [32.436]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
      [32.444]sunxi-spinand-phy: request spi0 gpio ok
      [32.448]sunxi-spinand-phy: request general tx dma channel ok!
      [32.453]sunxi-spinand-phy: request general rx dma channel ok!
      [32.459]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [32.463]sunxi-spinand-phy: init spic0 clk ok
      [33.467]sunxi-spinand-phy: read id failed : -110
      try nand fail
      [33.474]unrecognized JEDEC id bytes: ff, ff, ff
      data abort
      pc : [<47efd66c>]          lr : [<47efd64f>]
      reloc pc : [<4304166c>]    lr : [<4304164f>]
      sp : 43e59c28  ip : 0000000d     fp : 43000508
      r10: 43012be9  r9 : 43e9be70     r8 : 00000102
      r7 : 47f72648  r6 : ffffffed     r5 : 47f41cec  r4 : 43edc680
      r3 : 00003000  r2 : 00000001     r1 : c0000000  r0 : 00000030
      Flags: Nzcv  IRQs on  FIQs off  Mode SVC_32
        他还是用的 SDC2
        Try SD card 2
        [32.393][mmc]: Try MMC card 2
        首先,修改一下系统,参考 https://bbs.aw-ol.com/topic/1002/
        打开 lichee/brandy-2.0/u-boot-2018/drivers/sunxi_flash/mmc/sdmmc.c 文件,把 return sdmmc_init_for_sprite(0, 2) 改为 return sdmmc_init_for_sprite(0, 0)
        int sunxi_sprite_mmc_probe(void)
        #ifndef CONFIG_MACH_SUN50IW11
        -      	return sdmmc_init_for_sprite(0, 2);
        +	return sdmmc_init_for_sprite(0, 0);
        #else
        	int workmode = uboot_spare_head.boot_data.work_mode;
        	if (workmode == WORK_MODE_CARD_PRODUCT)
        		return -1;
        A 2 条回复 最后回复 回复 引用 分享 0
          ah669741 LV 4 @WhycanService 最后由 编辑
          @whycanservice 好的感谢
            @whycanservice 有个问题SD card 0是sd卡,SD card 1是emmc,SD card 2是spi flash,这个顺序对么
