    新手求助!T113 Tina-Linux添加systemd后编译报错
      Ary_Ye LV 5 最后由 编辑
      如题,由于要通过ntpdate进行网络对时,但是出现了
      Error resolving ntp.aliyun.com: Unrecognized service (-8)
      根据小正太大佬的说法是要添加systemd,但是在下列添加systemd-timedate服务以后就编译不通过了,而且整个编译过程没有ERROR的标识,唯一感觉有问题的只有缺了这堆文件
      ln -sf ../../lib/libc.so /home/linxiaoyan/Tina-Linux/out/t113-mq_r/staging_dir/target/rootfs/tmp-libc/usr/bin/ldd; exit 0
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libanl-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libanl.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libc-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libgomp-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libcidn-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libcidn.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libcrypt-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libcrypt.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libdl-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libdl.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libm-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libm.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libnsl-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libnsl.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libnss_dns-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libnss_dns.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libnss_files-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libnss_files.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libresolv-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libresolv.so*': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libutil-*.so': No such file or directory
      cp: cannot stat '/home/linxiaoyan/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/./lib/libutil.so*': No such file or directory
      求大佬们指点指点
