    R128适配SPI LCD+LVGL
    A Series
    5
    7
    7886
    • baiwen
      100ask LV 6 最后由 baiwen 编辑
      硬件
      • 板子: 全志R128开发板
      • 屏幕:SPI LCD 1.54寸 240x240分辨率
      效果演示
      [Video]
      1 条回复 最后回复 回复 引用 分享 4
        DOT小文哥 LV 8 最后由 编辑
        这个面包板插上去就挺好的
        • X
          xiaok LV 3 最后由 编辑
          大佬能看看sys_config.fex怎么配置吗,驱动是用的nv3029s还是st7789。
          baiwen 1 条回复 最后回复 回复 引用 分享 0
          • baiwen
            100ask LV 6 @xiaok 最后由 编辑
            这是我的一些笔记:
            所使用的补丁:spilcd2.0.zip
            ![ecd799ae-c9d0-46f1-8314-65f191526151-image.png](/assets/uploads/files/1700016539588-ecd799ae-c9d0-46f1-8314-65f191526151-image.png) 修改默认clk
            /home/book/work/allwinner/R128-FreeRTOS/lichee/rtos-hal/hal/source/spi/common_spi.h
            	#define SPI_MOD_CLK 40000000    /* sample mode frequency  */
            修改调试等级
            /home/book/work/allwinner/R128-FreeRTOS/lichee/rtos-hal/hal/source/spi/hal_spi.c
            	#define SPI_INFO_LEVEL
            	#define SPI_DATA_LEVEL
            	#define SPI_DUMPREG_LEVEL
            修改默认DMA buffer size
            /home/book/work/allwinner/R128-FreeRTOS/lichee/rtos-hal/include/hal/sunxi_hal_spi.h
            //#define ALIGN_DMA_BUF_SIZE (4096 + 64)
            #ifdef CONFIG_USE_100ASK_DISPLAY_SCREEN_240X240
            	#define ALIGN_DMA_BUF_SIZE ((240*240*4) + 64)
            #elif CONFIG_USE_100ASK_DISPLAY_SCREEN_320X480
            	#define ALIGN_DMA_BUF_SIZE ((320*480*4) + 64)
            #else
            修改SPI引脚配置
            /home/book/work/allwinner/R128-FreeRTOS/lichee/rtos-hal/hal/source/spi/platform/spi_sun20iw2.h
            #define SPI1_PARAMS \
            {   .port = 1, \
            	.reg_base = SUNXI_SPI1_PBASE, .irq_num = SUNXI_IRQ_SPI1, .gpio_num = 3, \
            	.pclk_pll_type = HAL_SUNXI_AON_CCU, .pclk_pll_id = CLK_DEVICE, \
            	.pclk_hosc_type = HAL_SUNXI_AON_CCU, .pclk_hosc_id = CLK_HOSC, \
            	.bus_type = HAL_SUNXI_CCU, .bus_id = CLK_BUS_SPI1, \
            	.mclk_type = HAL_SUNXI_CCU, .mclk_id = CLK_SPI1, \
            	.reset_type = HAL_SUNXI_RESET, .reset_id = RST_SPI1, \
            	.gpio_clk = GPIOA(13), .gpio_mosi = GPIOA(18), .gpio_miso = -1, \
            	.gpio_cs0 = GPIOA(12), .gpio_wp = -1, .gpio_hold = -1, \
            	.mux = 6, .driv_level = GPIO_DRIVING_LEVEL2, \
            注释SUPPORT_DBI_IF
            /home/book/work/allwinner/R128-FreeRTOS/lichee/rtos-hal/hal/source/spilcd/lcd_fb/lcd_fb_feature.h
            #if defined (CONFIG_ARCH_SUN50IW11) || defined(CONFIG_ARCH_SUN8IW20) || defined(CONFIG_ARCH_SUN20IW1) \
                    || defined(CONFIG_ARCH_SUN20IW2)
            //#define SUPPORT_DBI_IF
            sys_config.fex配置
            /home/book/work/allwinner/R128-FreeRTOS/board/r128s2/pro/configs/sys_config.fex
            ;SPI controller configuration
            ;Please config spi in dts
            [spi1]
            spi1_used       = 1
            spi1_cs_number  = 1
            spi1_cs_bitmap  = 1
            spi1_cs0        = port:PA12<6><0><3><default>
            spi1_sclk       = port:PA13<6><0><3><default>
            spi1_mosi       = port:PA18<6><0><3><default>
            spi1_miso       = port:PA21<6><0><3><default>
            ;spi1_hold       = port:PA19<6><0><2><default>
            ;spi1_wp         = port:PA20<6><0><2><default>
            [pwm6]
            pwm_used        = 1
            pwm_positive    = port:PA26<4><0><3><default>
            ;lcd_fb0 configuration
            [lcd_fb0]
            lcd_used            = 1
            lcd_model_name      = "spilcd"
            lcd_driver_name     = "lcd_100ask_240x240"
            lcd_x               = 240
            lcd_y               = 240
            lcd_width           = 28
            lcd_height          = 28
            lcd_data_speed      = 40
            lcd_pwm_used        = 1
            lcd_pwm_ch          = 6
            lcd_pwm_freq        = 5000
            lcd_pwm_pol         = 0
            lcd_if              = 0
            lcd_pixel_fmt       = 11
            lcd_dbi_fmt         = 2
            lcd_dbi_clk_mode    = 1
            lcd_dbi_te          = 1
            fb_buffer_num       = 2
            lcd_dbi_if          = 4
            lcd_rgb_order       = 0
            lcd_fps             = 10
            lcd_spi_bus_num     = 1
            lcd_frm             = 2
            lcd_gamma_en        = 1
            lcd_backlight       = 100
            lcd_power_num       = 0
            lcd_gpio_regu_num   = 0
            lcd_bl_percent_num  = 0
            lcd_spi_dc_pin      = port:PA19<1><0><3><0>
            ;lcd_gpio_0          = port:PA12<1><0><2><0>
            • Referenced by  baiwen baiwen
            • AKIMIZU
              AKIMIZU LV 2 最后由 编辑
              请教一下,韦东山的R128S2驱屏套件如何驱动韦东山的7寸50PIN RGB888屏幕?能出个教程吗?谢谢!
              W 1 条回复 最后回复 回复 引用 分享 0
                wj8331585 LV 6 @AKIMIZU 最后由 编辑
                @akimizu 他们正在录视频。下下周应该会有。👍
                baiwen 1 条回复 最后回复 回复 引用 分享 1
                • baiwen
                  100ask LV 6 @wj8331585 最后由 编辑
                  @wj8331585 下周应该就有了,今天刚好录制了5节:https://www.bilibili.com/video/BV1oC4y1w7AH
