    D1S哪吒开发板,电阻屏问题在使用ts_uinput后没有释放动作的问题
    • K
      kzc1209 LV 2 最后由 编辑
      ,坐标是对的,但是就是没有释放的动作,使用EVENT0没有转换之前是正常的,请问这是什么原因呢
      • K
        kzc1209 LV 2 最后由 编辑
        解决了,将ts.conf文件下的注释掉一些 如下:
        # Uncomment if you wish to use the one-wire linux input layer S70/A70...
        # module_raw one_wire_ts_input
        # Uncomment if you wish to use the linux input layer event interface
        module_raw input
        # Uncomment if you're using a Sharp Zaurus SL-5500/SL-5000d
        # module_raw collie
        # Uncomment if you're using a Sharp Zaurus SL-C700/C750/C760/C860
        # module_raw corgi
        # Uncomment if you're using a device with a UCB1200/1300/1400 TS interface
        # module_raw ucb1x00
        # Uncomment if you're using an HP iPaq h3600 or similar
        # module_raw h3600
        # Uncomment if you're using a Hitachi Webpad
        # module_raw mk712
        # Uncomment if you're using an IBM Arctic II
        # module_raw arctic2
        #module pthres pmin=1
        #module variance delta=30
        #module dejitter delta=100
        module linear
