    V853 USB烧录不了问题—各位大佬帮忙看下
    7299
      wl17761275256 LV 5 最后由 编辑
      一、烧写问题描述:
      • 1、USB上电后设备识别
      • 2、PhoenixSuit.exe全志烧写工具识别
      • 3、串口打印log
      ------run profile file-----
       --------------------------[    6.926014]
      [    6.926014] insmod_device_driver
      [    6.926014]
      swu_param: ####
      swu_software: ####
      swu_mode: ####
      root@TinaLinux:/# [    6.999539] urandom_read: 2 callbacks suppressed
      [    6.999547] random: wpa_supplicant: uninitialized urandom read (3 bytes read)
      [    7.013061] random: wpa_supplicant: uninitialized urandom read (1024 bytes re                  ad)
      [    7.173337] android_work: sent uevent USB_STATE=CONNECTED
      [    7.199100] configfs-gadget gadget: high-speed config #1: c
      [    7.205527] android_work: sent uevent USB_STATE=CONFIGURED
      udhcpc: sending discover
      1970-01-01 00:06:43:079: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_ex                  ist:32]: wpa_supplicant not exist
      1970-01-01 00:06:44:097: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_ex                  ist:32]: wpa_supplicant not exist
      1970-01-01 00:06:45:114: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_ex                  ist:32]: wpa_supplicant not exist
      1970-01-01 00:06:46:329: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_ex                  ist:32]: wpa_supplicant not exist
      1970-01-01 00:06:47:346: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_ex                  ist:32]: wpa_sup[   12.172806] random: wpa_supplicant: uninitialized urandom rea                  d (3 bytes read)
      plicant not exist
      1970-0[   12.182932] random: wpa_supplicant: uninitialized urandom read (1024 by                  tes read)
      1-01 00:06:47:346: WMG_ERROR [src/os/linux/linux_wpa.c:start_supplicant:365]:  f                  ailed to start wpa_supplicant times 1
      1970-01-01 00:06:47:349: WMG_ERROR [src/os/linux/linux_wpa.c:start_supplicant:36                  5]:  failed to start wpa_supplicant times 2
      1970-01-01 00:06:47:349: WMG_ERROR [src/os/linux/linux_wpa.c:linux_connect_to_su                  pplicant:1522]:  start wpa_supplicant failed
      1970-01-01 00:06:47:349: WMG_ERROR [src/wmg_sta.c:sta_mode_enable:416]:  failed                   to connect to wpa_supplicant
      1970-01-01 00:06:47:349: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:991]:  w                  ifi sta mode enable faile
      1970-01-01 00:06:47:349: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:1014]:                    switch after current_mode_bitmap:0x0
      1970-01-01 00:06:47:349: WMG_ERROR [src/wmg_common.c:wifimg_switch_mode:1021]:                    switch mode faile
      1970-01-01 00:06:47:349: WMG_ERROR [src/wmg_common.c:__wifi_on:49]:  failed to s                  witch wifi mode
      1970-01-01 00:06:47:349: WMG_ERROR [wifi_deamon.c:cmd_handle_o:277]:  wifi on st                  a mode failed
      udhcpc: no lease, forking to background
      [   99.476134] random: crng init done
      • 4、烧写失败
        二、现象疑问
      • 1、USB硬件上是从CPU——共模电感——USB连接器。没有发现硬件上的问题。
      • 2、软件上使用同样的代码在双目开发板上没有问题,可以连接PhoenixSuit.exe烧录软件。
      各位大佬,需要指点迷津呀,小弟在此谢过了。
        whycan晕哥 LV 9 @wl17761275256 最后由 编辑
        @wl17761275256
        按住FEL上电能进入烧写状态吗?
        W 2 条回复 最后回复 回复 引用 分享 0
          wl17761275256 LV 5 @whycan 最后由 编辑
          @whycan
          我试一下,补充一下使用SD卡烧录系统是没有问题的。
            @wl17761275256
            我记得只有安卓点这个地方才能进入烧录模式,你确认Linux可以这么做吗?
              @whycan
              上电后直接进去烧录界面,但是还是烧录失败。
                @whycan
                先连接设备后,要点一下,才能进入烧录。
                  @whycan 在 V853 USB烧录不了问题—各位大佬帮忙看下 中说:
                  @wl17761275256
                  这个问题已经困扰我们太久了,还没有什么破解办法方法吗。😂
                  W 1 条回复 最后回复 回复 引用 分享 0
                    wl17761275256 LV 5 @wl17761275256 最后由 编辑
                    @whycan
                    我发现了一个问题,我在上电后面刚识别设备时就点击固件烧录,可以进去烧录进度条。但是发现设备管理器里面弹出有不识别的设备。这个是不是就是烧录不进去设备没有识别呀。
                    有什么办法吗?
                      @whycan
                        @wl17761275256
                        和这里没有关系,我这三台电脑CPU都这样,烧录正常。
                        看下是不是电源问题,电流不够?把电源拉死了?
                          @whycan
                          经过测试发现一个问题,使用USB供电是能识别到USB设备(Tina ADB能弹出来)。使用外部电源,把USB的电源断开就无法识别USB设备(Tina ADB不能弹出来)。
