    V851S 打开Secure boot sboot引导启动失败
    @why
    • O
      olongcha LV 4 最后由 编辑
      参照文档<Tina_Linux_安全_开发指南.pdf>
      • 成功通过pack -s 生成了secure固件
      • 烧写secure固件后,按照下面log判断,应该是成功烧写了文档所说的 efuse ”secure enable bit“
      • 因为目前还在调试阶段并且板子只有1块,所以还不想先烧录rotpk.bin。 我看文档说,只打开secure enable bit 不烧录rotpk.bin 是可以烧写安全固件的
      • 目前开机卡在了开机log的位置,根据文档猜测应该是卡在sboot里面。但是sboot的源码又是闭源的,没法追踪
      • 开机log:
      [86]HELLO! SBOOT is starting!OT
      [89]sboot commit : 4b419f21ba
      [157][pmu]: bus read error
      [160]set pll start
      [162]periph0 has been enabled
      [165]set pll end
      [166]board init ok
      [168]DRAM use internal ZQ!!
      [171]ZQ value = 0x31
      [173]chip id check OK
      [175]POWER SETTING ERROR!
      [177]DRAM BOOT DRIVE INFO: V0.16
      [180]DRAM CLK = 528 MHz
      [182]DRAM Type = 2 (2:DDR2,3:DDR3)
      [185]DRAMC read ODT  off.
      [188]DRAM ODT off.
      [190]DRAM SIZE =64 M
      [192]dram_tpr4:0x0
      [196]DRAM simple test OK.
      [198]rtc standby flag is 0x0, super standby flag is 0x0
      [203]dram size =64
      [205]audio:avcc calibration
      [208]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [213]block from 8 to 32
      [675]Check is correct.
      [677]OLD version: 0.0
      [679]NEW version: 0.0
      [684]don't have rotpk, skip check
      [691]sample_atoi err: ch 0x00 is not a digit or hex ch
      [696]__merge_extension_value err1: in sunxi_bytes_merge
      [701]get extension value failed
      [704]sunxi_rsa_calc: probe extension failed
      [708]root certif verify itself failed
      • 修改点:
      diff --git a/device/config/chips/v851s/configs/xxxx/board.dts b/device/config/chips/v851s/configs/xxxx/board.dts
      index 951e43a41..c671bd9fa 100755
      --- a/device/config/chips/v851s/configs/xxxx/board.dts
      +++ b/device/config/chips/v851s/configs/xxxx/board.dts
      @@ -10,6 +10,13 @@
              compatible = "allwinner,sun8iw21p1", "arm,sun8iw21p1", "allwinner,v851s";
      +       reserved-memory {
      +               optee_reserve {
      +                       reg = <0 0x41980000 0 0x00080000>;
              soc@03000000 {
                      wlan: wlan@0 {
      diff --git a/device/config/chips/v851s/configs/xxxx/linux/config-4.9 b/device/config/chips/v851s/configs/xxxx/linux/config-4.9
      index 792a64c1e..a7023ae0c 100755
      --- a/device/config/chips/v851s/configs/xxxx/linux/config-4.9
      +++ b/device/config/chips/v851s/configs/xxxx/linux/config-4.9
      @@ -1160,16 +1160,14 @@ CONFIG_SERIAL_SUNXI_CONSOLE=y
       # CONFIG_TCG_TPM is not set
       # CONFIG_XILLYBUS is not set
       # CONFIG_SUNXI_SCR is not set
      -# CONFIG_SUNXI_SYS_INFO is not set
      +CONFIG_SUNXI_SYS_INFO=y
      +# CONFIG_SUNXI_QA_TEST is not set
       # CONFIG_SUNXI_SMC is not set
      -CONFIG_DUMP_REG=y
      -CONFIG_DUMP_REG_MISC=y
      +# CONFIG_DUMP_REG is not set
       # CONFIG_SUNXI_TIMER_TEST is not set
       # CONFIG_SUNXI_TRANSFORM is not set
       # CONFIG_SUNXI_DI is not set
      -CONFIG_SUNXI_G2D=y
      -CONFIG_SUNXI_G2D_MIXER=y
      -CONFIG_SUNXI_G2D_ROTATE=y
      +# CONFIG_SUNXI_G2D is not set
       # CONFIG_SUNXI_DSPO is not set
       CONFIG_SUNXI_NNA_VIP=y
       # CONFIG_SUNXI_NNA_GALCORE is not set
      @@ -2335,7 +2333,13 @@ CONFIG_ANDROID=y
       # CONFIG_FPGA is not set
       # CONFIG_SUNXI_MPP is not set
      -# CONFIG_TEE is not set
      +CONFIG_TEE=y
      +# TEE drivers
      +CONFIG_OPTEE=y
      +# CONFIG_OPTEE_BENCHMARK is not set
       # Firmware Drivers
      diff --git a/device/config/chips/v851s/configs/xxxx/uboot-board.dts b/device/config/chips/v851s/configs/xxxx/uboot-board.dts
      index 8e603bdd4..1d216d290 100755
      --- a/device/config/chips/v851s/configs/xxxx/uboot-board.dts
      +++ b/device/config/chips/v851s/configs/xxxx/uboot-board.dts
      @@ -17,6 +17,15 @@
                      enable-active-high;
      +       firmware {
      +               optee {
      +                       shm_base = <0x418E0000>;
      +                       shm_size = <0x00020000>;
      +                       ta_ram_base = <0x41a00000>;
      +                       ta_ram_size = <0x00100000>;
              box_start_os0 {
                      compatible = "allwinner,box_start_os";
                      start_type = <0x1>;
      diff --git a/target/allwinner/v851s-xxxx/defconfig b/target/allwinner/v851s-xxxx/defconfig
      index 79ad4391a..b9a3da692 100755
      --- a/target/allwinner/v851s-xxxx/defconfig
      +++ b/target/allwinner/v851s-xxxx/defconfig
      @@ -76,8 +76,8 @@ CONFIG_SUNXI_SD_BOOT_KERNEL_FORMAT_BOOTIMG=y
       # CONFIG_SUNXI_MKBOOTIMG_ADD_DTB is not set
       # CONFIG_SUNXI_SMALL_STORAGE_OTA is not set
       # CONFIG_SUNXI_RECOVERY_INITRAMFS_PART is not set
      -CONFIG_SUNXI_RECOVERY_INITRAMFS_KERNEL_FORMAT_UIMAGE=y
      -# CONFIG_SUNXI_RECOVERY_INITRAMFS_KERNEL_FORMAT_BOOTIMG is not set
      +# CONFIG_SUNXI_RECOVERY_INITRAMFS_KERNEL_FORMAT_UIMAGE is not set
      +CONFIG_SUNXI_RECOVERY_INITRAMFS_KERNEL_FORMAT_BOOTIMG=y
       # CONFIG_SUNXI_SEPARATE_APP_FROM_ROOTFS is not set
       # CONFIG_SUNXI_SEPARATE_DATA_FROM_ROOTFS is not set
       # CONFIG_CUSTOMIZE_IMAGE_NAME is not set
      @whycan 晕哥可以帮忙看一下吗?感谢!
        whycan晕哥 LV 9 @olongcha 最后由 编辑
        T113-S3 / V853 安全固件学习记录
        https://bbs.aw-ol.com/topic/2834/share/1
        O 1 条回复 最后回复 回复 引用 分享 1
        • O
          olongcha LV 4 @whycan 最后由 编辑
          @whycan 这个贴我也有看,但是似乎都是基于烧了rotpk.bin的情况分析的。所以这个rotpk.bin是一定要烧才能启动吗,不烧的话跑不下去是吗?上面文档的描述,又好像是不烧可以启动。还望指点一下
