    D1s关闭sdc1启动不了
      Maihuanyi LV 5 最后由 编辑
      由于板子没有用到sdc1的管脚作为引脚使用,把sdc1的设备树关闭,发现启动不了,卡在挂载mmcblk0p5上,
      &sdc1 {
          bus-width = <4>;
          no-mmc;
          no-sd;
          cap-sd-highspeed;
          /*sd-uhs-sdr12*/
          /*sd-uhs-sdr25;*/
          /*sd-uhs-sdr50;*/
          /*sd-uhs-ddr50;*/
          /*sd-uhs-sdr104;*/
          /*sunxi-power-save-mode;*/
          /*sunxi-dis-signal-vol-sw;*/
          cap-sdio-irq;
          keep-power-in-suspend;
          ignore-pm-notify;
          max-frequency = <150000000>;
          ctl-spec-caps = <0x8>;
          status = "disable";
      启动的log如下
      VE: sunxi_cedar_probe
      ashmem: initialized
      exFAT: Version 1.3.0
      [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000487740, 0x:ffffffd0040d7000, irq_no:2e
      [sunxi-ehci0]: Not init ehci0
      [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000487b08
      [sunxi-ohci0]: Not init ohci0
      otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      alloc_fd: slot 0 not NULL!
      VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
      Please append a correct "root=" boot option; here are the available partitions:
      Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #128
      Call Trace:
      [<ffffffe00001f164>] walk_stackframe+0x0/0x98
      [<ffffffe00001f31c>] show_stack+0x2a/0x34
      [<ffffffe0002dea16>] dump_stack+0x20/0x28
      [<ffffffe000023724>] panic+0xec/0x272
      [<ffffffe000000ef2>] mount_block_root+0x214/0x27a
      [<ffffffe000000fde>] mount_root+0x86/0x90
      [<ffffffe000001130>] prepare_namespace+0x148/0x152
      [<ffffffe000000b54>] kernel_init_freeable+0x166/0x198
      [<ffffffe0002ef17c>] kernel_init+0x12/0xee
      [<ffffffe00001ded0>] ret_from_exception+0x0/0xc
      ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
      有人遇到过这样的问题吗?要怎么解决?
        WhycanService LV 8 最后由 编辑
        SDC1关闭可以会导致mmc设备号改变,检查一下SDC的实际设备号。开启loglevel=7查看报错输出
        M 1 条回复 最后回复 回复 引用 分享 0
          Maihuanyi LV 5 @WhycanService 最后由 编辑
          @whycanservice
          全部的loglevel=7打印的log
          U-Boot 2018.07-config-dirty (Jun 16 2023 - 10:30:39 +0800) Allwinner Technology
          [00.261]DRAM:  64 MiB
          [00.261]Relocation Offset is: 01f05000
          [00.263]secure enable bit: 0
          can't support chip type 24064
          [00.263]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          sunxi flash map init
          SPI ALL:   ready
          [00.265]flash init start
          [00.265]workmode = 0,storage type = 1
          [00.266][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
          [00.266][mmc]: get sdc_type fail and use default host:tm1.
          [00.268][mmc]: can't find node "mmc0",will add new node
          [00.268][mmc]: fdt err returned <no error>
          [00.269][mmc]: Using default timing para
          [00.269][mmc]: SUNXI SDMMC Controller Version:0x50310
          [00.282][mmc]: card_caps:0x3000000a
          [00.282][mmc]: host_caps:0x3000003f
          [00.283]sunxi flash init ok
          [00.283]line:703 init_clocks
          [00.284]drv_disp_init
          [00.294]drv_disp_init finish
          [00.300]Loading Environment from SUNXI_FLASH... OK
          [00.316]boot_gui_init:start
          [00.316]set disp.dev2_output_type fail. using defval=0
          [00.703]set disp.fb0_rot_used fail. using defval=0
          [00.703]set disp.fb0_rot_degree fail. using defval=0
          [00.706]boot_gui_init:finish
          [00.708]bmp_name=bootlogo.bmp size 38454
          [00.715]out of usb burn from boot: not need burn key
          [00.724]LCD open finish
          [00.738]Item0 (Map) magic is bad
          [00.739]the secure storage item0 copy0 magic is bad
          [00.761]Item0 (Map) magic is bad
          [00.761]the secure storage item0 copy1 magic is bad
          root_partition is rootfs
          set root to /dev/mmcblk0p5
          [00.764]update part info
          [00.765]update bootcmd
          [00.766]change working_fdt 0x42ac4da0 to 0x42aa4da0
          [00.768]The storage not support sample function
          [00.788]update dts
          [01.993]no vendor_boot partition is found
          Android's image name: d1s-nezha_sd
          Detect comp none
          [02.002]
          Starting kernel ...
          [02.002][mmc]: MMC Device 2 not found
          [02.002][mmc]: mmc 2 not find, so not exit
          ** 1 printk messages dropped **
          Zone ranges:
            DMA32    [mem 0x0000000040000000-0x0000000043ffffff]
            Normal   empty
          Movable zone start for each node
          Early memory node ranges
            node   0: [mem 0x0000000040000000-0x0000000043ffffff]
          On node 0 totalpages: 16384
            DMA32 zone: 0 pages reserved
          elf_hwcap is 0x20112d
          pcpu-alloc: [0] 0
          Kernel command line: earlyprintk=sunxi-uart,0x02500c00 clk_ignore_unused initcall_debug=0 console=ttyS3,1500000 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:recovery@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun20iw1p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.07-config-dirty(06/16/2023-10:30:39) mbr_offset=1556480 disp_reserve=3686400,0x0000000042b54000 androidboot.dramsize=64
          Sorting __ex_table...
          Memory: 55728K/65536K available (2902K kernel code, 327K rwdata, 1132K rodata, 116K init, 176K bss, 9808K reserved, 0K cma-reserved)
          SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
          rcu: Preemptible hierarchical RCU implementation.
                  Tasks RCU enabled.
          rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
          Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
          devtmpfs: initialized
          random: get_random_u32 called from bucket_table_alloc.isra.27+0x102/0x124 with crng_init=0
          clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
          cpuidle: using governor menu
          rtc_ccu: sunxi ccu init OK
          clock: sunxi ccu init OK
          sun6i-dma 3002000.dma-controller: sunxi dma probed
          sunxi iommu: irq = 4
          SCSI subsystem initialized
          pwm module init!
          G2D: rcq version initialized.major:252
          sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
          sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
          sunxi_spi_resource_get()2438 - [spi0] SPI MASTER MODE
          sunxi_spi_resource_get()2476 - Failed to get sample mode
          sunxi_spi_resource_get()2481 - Failed to get sample delay
          sunxi_spi_resource_get()2485 - sample_mode:-1431633921 sample_delay:-1431633921
          sunxi_spi_clk_init()2527 - [spi0] mclk 100000000
          sunxi_spi_probe()2978 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
          io scheduler kyber registered
          [DISP]disp_module_init
          [DISP] disp_init,line:2387:
          display_fb_request,fb_id:0
          [DISP]disp_module_init finish
          sunxi_sid_init()783 - insmod ok
          [DISP] lcd_clk_config,line:774:
          disp 0, clk: pll(378000000),clk(378000000),dclk(63000000) dsi_rate(63000000)
               clk real:pll(372000000),clk(372000000),dclk(93000000) dsi_rate(150000000)
          sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
          uart uart1: uart1 supply uart not found, using dummy regulator
          uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
          uart uart2: uart2 supply uart not found, using dummy regulator
          uart2: ttyS2 at MMIO 0x2500800 (irq = 20, base_baud = 1500000) is a SUNXI
          uart uart3: uart3 supply uart not found, using dummy regulator
          uart3: ttyS3 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
          sw_console_setup()1807 - console setup baud 1500000 parity n bits 8, flow n
          printk: console [ttyS3] enabled
          uart uart4: uart4 supply uart not found, using dummy regulator
          uart4: ttyS4 at MMIO 0x2501000 (irq = 22, base_baud = 1500000) is a SUNXI
          uart uart5: uart5 supply uart not found, using dummy regulator
          uart5: ttyS5 at MMIO 0x2501400 (irq = 23, base_baud = 1500000) is a SUNXI
          misc dump reg init
          sunxi-ehci: EHCI SUNXI driver
          [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000487ed0, 0x:ffffffd004075000, irq_no:31
          Freeing logo buffer memory: 3600K
          sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
          hub 1-0:1.0: USB hub found
          hub 1-0:1.0: 1 port detected
          sunxi-ohci: OHCI SUNXI driver
          [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe000488298
          hub 2-0:1.0: USB hub found
          hub 2-0:1.0: 1 port detected
          sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:29 UTC (29)
          i2c /dev entries driver
          sunxi cedar version 1.1
          VE: install start!!!
          VE: cedar-ve the get irq is 6
          VE: install end!!!
          ashmem: initialized
          CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #133
          Call Trace:
          [<ffffffe0002dea0a>] dump_stack+0x20/0x28
          [<ffffffe0002ef170>] kernel_init+0x12/0xee
          没有看到有sdc的设备号,我用的是SD卡启动
