    大佬们,请教T113主线, 显示屏启动慢问题
      wupaul2001 LV 5 最后由 编辑
      [I] AWBoot r20 starting...
      [D] DRAM: size=128MB
      [D] DRAM: simple test OK.
      [I] SMHC: sdhci2 controller v50310 initialized
      [W] SMHC: error 0x100 status 0x0
      [W] SMHC: cmd timeout
      [D] SMHC: MMC version 5.0
      [D] SMHC: capacity 3.9GB
      [I] SHMC: MMC card detected
      [D] SDMMC: speedtest 512KB in 24ms at 21845KB/S
      [D] FATFS: mount OK
      [I] FATFS: read sun8i-t113-mangopi-dual.dtb addr=44000000
      [D] FATFS: read in 2ms at 11.20MB/S
      [I] FATFS: read zImage addr=44800000
      [D] FATFS: read in 131ms at 38.89MB/S
      [D] FATFS: unmount OK
      [D] FATFS: done in 529ms
      [I] booting linux...
      [    0.000000] Linux version 6.0.1-gd7d8c971c9c5-dirty (paulwu@paulwu-virtual-machine) (arm-linux-gnueabihf-gcc (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) 7.5.0, GNU ld (GNU Binutils for Ubuntu) 2.30) #36 SMP Wed Feb 8 15:05:12 CST 2023
      [    0.000000] OF: fdt: Machine model: MangoPi MQ-Dual
      [    0.000000] cma: Reserved 32 MiB at 0x46000000
      [    0.000000] Zone ranges:
      [    0.000000]   Normal   [mem 0x0000000040000000-0x0000000047ffffff]
      [    0.000000]   HighMem  empty
      [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000047ffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000047ffffff]
      [    0.000000] percpu: Embedded 11 pages/cpu s15508 r8192 d21356 u45056
      [    0.000000] Kernel command line: mem=128M cma=32M root=/dev/mmcblk0p2 init=/sbin/init rootwait console=ttyS0,115200 earlyprintk=sunxi-uart,0x02501400
      [    0.000000] Unknown kernel command line parameters "earlyprintk=sunxi-uart,0x02501400", will be passed to user space.
      [    0.000000] Memory: 83384K/131072K available (8192K kernel code, 950K rwdata, 2212K rodata, 1024K init, 276K bss, 14920K reserved, 32768K cma-reserved, 0K highmem)
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
      [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
      [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000013] Switching to timer-based delay loop, resolution 41ns
      [    0.000190] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.000681] Console: colour dummy device 80x30
      [    0.000730] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000747] pid_max: default: 32768 minimum: 301
      [    0.000903] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.000919] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.001450] CPU: Testing write buffer coherency: ok
      [    0.001774] /cpus/cpu@0 missing clock-frequency property
      [    0.001804] /cpus/cpu@1 missing clock-frequency property
      [    0.001815] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.002575] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.002720] rcu: Hierarchical SRCU implementation.
      [    0.002728] rcu: 	Max phase no-delay instances is 1000.
      [    0.003250] smp: Bringing up secondary CPUs ...
      [    0.003921] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.004045] smp: Brought up 1 node, 2 CPUs
      [    0.004056] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.004064] CPU: All CPU(s) started in SVC mode.
      [    0.004574] devtmpfs: initialized
      [    0.008630] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.008828] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.008849] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.009882] pinctrl core: initialized pinctrl subsystem
      [    0.011289] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.012390] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.013236] thermal_sys: Registered thermal governor 'step_wise'
      [    0.013531] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.013544] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.022318] platform 5460000.tcon-top: Fixing up cyclic dependency with 5100000.mixer
      [    0.022618] platform 5461000.lcd-controller: Fixing up cyclic dependency with 5460000.tcon-top
      [    0.023584] platform 7090000.rtc: Fixing up cyclic dependency with 7010000.clock-controller
      [    0.025024] platform panel: Fixing up cyclic dependency with 5461000.lcd-controller
      [    0.034008] SCSI subsystem initialized
      [    0.034501] usbcore: registered new interface driver usbfs
      [    0.034546] usbcore: registered new interface driver hub
      [    0.034586] usbcore: registered new device driver usb
      [    0.034800] mc: Linux media interface: v0.10
      [    0.034846] videodev: Linux video capture interface: v2.00
      [    0.034921] pps_core: LinuxPPS API ver. 1 registered
      [    0.034928] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.034945] PTP clock support registered
      [    0.035390] Advanced Linux Sound Architecture Driver Initialized.
      [    0.036308] clocksource: Switched to clocksource arch_sys_counter
      [    0.043641] NET: Registered PF_INET protocol family
      [    0.043835] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
      [    0.044391] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.044423] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.044435] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.044456] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.044476] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.044560] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.044594] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.044762] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [    0.045442] RPC: Registered named UNIX socket transport module.
      [    0.045457] RPC: Registered udp transport module.
      [    0.045461] RPC: Registered tcp transport module.
      [    0.045464] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.046911] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.051812] NFS: Registering the id_resolver key type
      [    0.051881] Key type id_resolver registered
      [    0.051887] Key type id_legacy registered
      [    0.052123] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
      [    0.052133] io scheduler mq-deadline registered
      [    0.052138] io scheduler kyber registered
      [    0.066486] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
      [    0.073817] panel-simple panel: supply power not found, using dummy regulator
      [    0.077231] CAN device driver interface
      [    0.077977] PPP generic driver version 2.4.2
      [    0.078239] PPP BSD Compression module registered
      [    0.078248] PPP Deflate Compression module registered
      [    0.078476] PPP MPPE Compression module registered
      [    0.078484] NET: Registered PF_PPPOX protocol family
      [    0.078573] usbcore: registered new interface driver asix
      [    0.078616] usbcore: registered new interface driver ax88179_178a
      [    0.078644] usbcore: registered new interface driver cdc_ether
      [    0.078679] usbcore: registered new interface driver smsc95xx
      [    0.078706] usbcore: registered new interface driver net1080
      [    0.078733] usbcore: registered new interface driver cdc_subset
      [    0.078775] usbcore: registered new interface driver zaurus
      [    0.078835] usbcore: registered new interface driver sierra_net
      [    0.078873] usbcore: registered new interface driver cdc_ncm
      [    0.078900] usbcore: registered new interface driver r8153_ecm
      [    0.078905] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.078910] ehci-platform: EHCI generic platform driver
      [    0.079114] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.079144] ohci-platform: OHCI generic platform driver
      [    0.079316] usbcore: registered new interface driver usb-storage
      [    0.079407] usbcore: registered new interface driver option
      [    0.079435] usbserial: USB Serial support registered for GSM modem (1-port)
      [    0.081774] sun6i-rtc 7090000.rtc: registered as rtc0
      [    0.081896] sun6i-rtc 7090000.rtc: setting system clock to 1970-01-02T00:00:01 UTC (86401)
      [    0.082025] sun6i-rtc 7090000.rtc: RTC enabled
      [    0.082350] i2c_dev: i2c /dev entries driver
      [    0.083532] bm_cw2015_init
      [    0.084202] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    0.085303] sun8i-ce 3040000.crypto: Set mod clock to 300000000 (300 Mhz) from 400000000 (400 Mhz)
      [    0.085622] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
      [    0.085946] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
      [    0.086157] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
      [    0.086395] sun8i-ce 3040000.crypto: will run requests pump with realtime priority
      [    0.086560] sun8i-ce 3040000.crypto: Register cbc(aes)
      [    0.086582] sun8i-ce 3040000.crypto: Register ecb(aes)
      [    0.086591] sun8i-ce 3040000.crypto: Register cbc(des3_ede)
      [    0.086601] sun8i-ce 3040000.crypto: Register ecb(des3_ede)
      [    0.086632] sun8i-ce 3040000.crypto: CryptoEngine Die ID 0
      [    0.087509] usbcore: registered new interface driver usbhid
      [    0.087520] usbhid: USB HID core driver
      [    0.090258] NET: Registered PF_PACKET protocol family
      [    0.090290] can: controller area network core
      [    0.090370] NET: Registered PF_CAN protocol family
      [    0.090379] can: raw protocol
      [    0.090386] can: broadcast manager protocol
      [    0.090394] can: netlink gateway - max_hops=1
      [    0.090501] Key type dns_resolver registered
      [    0.090641] Registering SWP/SWPB emulation handler
      [    0.109299] sun20i-d1-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.111235] printk: console [ttyS0] disabled
      [    0.131488] 2500000.serial: ttyS0 at MMIO 0x2500000 (irq = 231, base_baud = 1500000) is a 16550A
      [    1.063712] printk: console [ttyS0] enabled
      [    1.089476] 2500400.serial: ttyS1 at MMIO 0x2500400 (irq = 232, base_baud = 1500000) is a 16550A
      [    1.119591] 2500800.serial: ttyS2 at MMIO 0x2500800 (irq = 233, base_baud = 1500000) is a 16550A
      [    1.153811] 2500c00.serial: ttyS3 at MMIO 0x2500c00 (irq = 234, base_baud = 1500000) is a 16550A
      [    1.183930] 2501000.serial: ttyS4 at MMIO 0x2501000 (irq = 235, base_baud = 1500000) is a 16550A
      [    1.213990] 2501400.serial: ttyS5 at MMIO 0x2501400 (irq = 236, base_baud = 1500000) is a 16550A
      [    1.224877] ehci-platform 4101000.usb: EHCI Host Controller
      [    1.226025] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
      [    1.230558] ehci-platform 4101000.usb: new USB bus registered, assigned bus number 1
      [    1.240321] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
      [    1.253269] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 2
      [    1.262075] hub 2-0:1.0: USB hub found
      [    1.262188] ehci-platform 4200000.usb: EHCI Host Controller
      [    1.265892] hub 2-0:1.0: 1 port detected
      [    1.273384] ohci-platform 4200400.usb: Generic Platform OHCI controller
      [    1.282058] ohci-platform 4200400.usb: new USB bus registered, assigned bus number 3
      [    1.286339] ehci-platform 4200000.usb: new USB bus registered, assigned bus number 4
      [    1.289999] ehci-platform 4101000.usb: irq 237, io mem 0x04101000
      [    1.299657] cw2015_probe...
      [    1.306790] ohci-platform 4200400.usb: irq 241, io mem 0x04200400
      [    1.313038] ehci-platform 4200000.usb: irq 239, io mem 0x04200000
      [    1.326325] ehci-platform 4101000.usb: USB 2.0 started, EHCI 1.00
      [    1.333168] hub 1-0:1.0: USB hub found
      [    1.337002] hub 1-0:1.0: 1 port detected
      [    1.356327] ehci-platform 4200000.usb: USB 2.0 started, EHCI 1.00
      [    1.363121] hub 4-0:1.0: USB hub found
      [    1.366976] hub 4-0:1.0: 1 port detected
      [    1.381015] hub 3-0:1.0: USB hub found
      [    1.384817] hub 3-0:1.0: 1 port detected
      [    1.399013] Goodix-TS 1-005d: supply AVDD28 not found, using dummy regulator
      [    1.406213] Goodix-TS 1-005d: supply VDDIO not found, using dummy regulator
      [    1.428026] musb-hdrc musb-hdrc.2.auto: VBUS_ERROR in a_idle (80, <SessEnd), retry #0, port1 00000104
      [    1.466400] ohci-platform 4101400.usb: Generic Platform OHCI controller
      [    1.473046] ohci-platform 4101400.usb: new USB bus registered, assigned bus number 5
      [    1.481050] ohci-platform 4101400.usb: irq 240, io mem 0x04101400
      [    1.526431] Goodix-TS 1-005d: Error reading 1 bytes from 0x8140: -6
      [    1.561060] hub 5-0:1.0: USB hub found
      [    1.564854] hub 5-0:1.0: 1 port detected
      [    1.568905] Goodix-TS 1-005d: Error reading 1 bytes from 0x8140: -6
      [    1.606314] Goodix-TS 1-005d: I2C communication failure: -6
      [    1.613952] ALSA device list:
      [    1.617017]   No soundcards found.
      [    1.645971] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
      [    1.655021] Waiting for root device /dev/mmcblk0p2...
      [    1.660145] usb 4-1: new high-speed USB device number 2 using ehci-platform
      [    1.719665] mmc0: new DDR MMC card at address 0001
      [    1.725404] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
      [    1.732254]  mmcblk0: p1 p2
      [    1.735913] mmcblk0boot0: mmc0:0001 4FPD3R 4.00 MiB
      [    1.742581] mmcblk0boot1: mmc0:0001 4FPD3R 4.00 MiB
      [    1.782563] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [    1.789955] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [    1.867356] hub 4-1:1.0: USB hub found
      [    1.872348] hub 4-1:1.0: 5 ports detected
      [    1.978501] EXT4-fs (mmcblk0p2): recovery complete
      [    1.985511] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: disabled.
      [    1.994518] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    2.002019] devtmpfs: mounted
      [    2.005975] Freeing unused kernel image (initmem) memory: 1024K
      [    2.012131] Run /sbin/init as init process
      [    2.126093] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: disabled.
      Starting syslogd: OK
      Starting klogd: OK
      Running sysctl: OK
      [    2.226408] usb 4-1.1: new high-speed USB device number 3 using ehci-platform
      Initializing random number generator... [    2.379371] smsc95xx v2.0.0
      [    2.499076] SMSC LAN8700 usb-004:003:01: attached PHY driver (mii_bus:phy_addr=usb-004:003:01, irq=245)
      [    2.509232] smsc95xx 4-1.1:1.0 eth0: register 'smsc95xx' at usb-4200000.usb-1.1, smsc95xx USB 2.0 Ethernet, 42:f5:7d:e0:78:74
      [    7.366312] random: crng init done
      done.
      Starting haveged: haveged: listening socket at 3
      OK
      Starting network: [    7.510376] smsc95xx 4-1.1:1.0 eth0: hardware isn't capable of remote wakeup
      [    7.521342] smsc95xx 4-1.1:1.0 eth0: Link is Down
      OK
      Starting sshd: OK
      Failed to open mixer
      ls: /dev/sd*: No such file or directory
      cat: can't open '/SyTech/SmartMining/Excavator_Terminal_Equipment/Release/typeflag': No such file or directory
      sh: 1: unknown operand
      cp: can't stat '/SyTech/SmartMining/Excavator_Terminal_Equipment/Release/pointercal_0': No such file or directory
      mv: can't rename '/etc/pointercal_0': No such file or directory
      cp: can't stat '/SyTech/SmartMining/Excavator_Terminal_Equipment/Release/profile_0': No such file or directory
      mv: can't rename '/etc/profile_0': No such file or directory
      fdisk -l size error.
      /etc/init.d/autoresize:Disk Size=1024M no need to resize.
      cat: can't open '/etc/init.d/resizeflag': No such file or directory
      [    8.015393] rc522 probe!
      cat: can't open '/etc/init.d/usbplugout': No such file or directory
      /etc/init.d/lastsim exist
      use inside sim0
      [   13.216317] usb 1-1: new high-speed USB device number 2 using ehci-platform
      [   14.798286] usb 1-1: USB disconnect, device number 2
      [   18.411715] sun4i-drm display-engine: bound 5100000.mixer (ops 0xc0953bd8)
      [   18.418985] sun4i-drm display-engine: bound 5460000.tcon-top (ops 0xc09580a4)
      [   18.426718] sun4i-drm display-engine: bound 5461000.lcd-controller (ops 0xc094fc4c)
      [   18.435001] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
      [   18.487934] Console: switching to colour frame buffer device 128x37
      看LOG, 10多秒才启动显示屏,请教大佬们是那里问题
      W 1 条回复 最后回复 回复 引用 分享 1
        wupaul2001 LV 5 @wupaul2001 最后由 编辑
        @wupaul2001 换个6.1.0的内核好了
        K 1 条回复 最后回复 回复 引用 分享 1
        • K
          kevin_allwinner LV 5 @wupaul2001 最后由 编辑
