    F133-A 驱动SST7789有没有人成功过
    RTOS
    4581
    • Q
      feelsigh LV 5 最后由 qq354813374 编辑
      sys_config_nor.fex文件中已修改为SST7789_CPU驱动
      [lcd0]
      lcd_used            = <1>;
      lcd_driver_name     = "st7789v_cpu";
      lcd_backlight       = <150>;
      lcd_if              = <1>;
      lcd_x               = <240>;
      lcd_y               = <320>;
      lcd_width           = <108>;
      lcd_height          = <64>;
      lcd_dclk_freq       = <18>;
      lcd_pwm_used        = <1>;
      lcd_pwm_ch          = <6>;
      lcd_pwm_pol         = <1>;
      lcd_pwm_max_limit   = <100>;
      lcd_hbp             = <60>;
      lcd_ht              = <298>;
      lcd_hspw            = <30>;
      lcd_vbp             = <340>;
      lcd_vt              = <336>;
      lcd_vspw            = <2>;
      lcd_frm             = <1>;
      lcd_hv_clk_phase    = <0>;
      lcd_hv_sync_polarity= <0>;
      lcd_hv_data_polarity = <1>;
      lcd_gamma_en        = <0>;
      lcd_bright_curve_en = <0>;
      lcd_cmap_en         = <0>;
      lcdgamma4iep        = <22>;
      lcd_cpu_mode        = <1>;
      lcd_cpu_te          = <1>;
      lcd_cpu_if	    = <8>;
      lcd_hv_if	    	= <0>;
      lcd_hv_srgb_seq	    = <0>;
      lcd_rb_swap			= <0>;
      lcd_gpio_0 = <&pio PG 2 1 0 3 0>;
      lcd_gpio_1 = <&pio PD 21 1 0 3 0>;
      pinctrl-0 = <&rgb8_pins_a>;
      pinctrl-1 = <&rgb8_pins_b>;
      其中rgb8_pins_a 和 rgb8_pins_b 在所有文件中均未搜索到 不知道在哪调用的
      make menuconfig中已经打开SST7789_CPU驱动
      编译报错
      修改SST7789_CPU驱动 kmalloc 改为 malloc 后编译不报错
      /*static int bootup_flag = 0;*/
      static void LCD_panel_init(u32 sel)
      	struct disp_panel_para *info =
      	    //kmalloc(sizeof(struct disp_panel_para), GFP_KERNEL);
             malloc(sizeof(struct disp_panel_para));
      	DBG_INFO("\n");
      	bsp_disp_get_panel_info(sel, info);
      	lcd_panel_st7789v_init(sel, info);
      	disp_sys_free(info);
      	return;
      编译打包运行报错
      |                  /'\_/`\       (_ )  _                      ( )( )     /' _`\    /' _`\
      |                  |     |   __   | | (_)  ___  ______  _   _ | || |     | ( ) |   | ( ) |
      |                  | (_) | /'__`\ | | | |/',__)(______)( ) ( )| || |_    | | | |   | | | |
      |                  | | | |(  ___/ | | | |\__, \        | \_/ |(__ ,__) _ | (_) | _ | (_) |
      |                  (_) (_)`\____)(___)(_)(____/        `\___/'   (_)  (_)`\___/'(_)`\___/'
      |version : V3.9.0        |
      |commitid: bea46cdf307086132c4a8de26837731de1388ce5                                                           |
      |sunxiver: 40000        |
      |timever : Thu, 13 Jul 2023 12:51:20 +0800        |
      |compiler: gcc version 8.4.0 (T-HEAD RISCV Tools V1.10.2 B20201104)                                           |
      |optimal : -Os -g -gdwarf-2 -gstrict-dwarf        |
      |linker  : GNU ld (GNU Binutils) 2.32        |
      |newlibc : 3.0.0        |
      |author  : cq        |
      [DBG]: [__mount_parts:0299]:                                classname=DMS
      [DBG]: [__mount_parts:0300]:                                devname=dms01
      [DBG]: [__mount_parts:0327]:                                find last lun.
      [DBG]: [__mount_parts:0357]:                                nPart = 1.
      [DBG]: [__mount_parts:0486]:                                dmsPart: "DMS\dms010" is linked to symbel "B".
      [ERR]: [esFSYS_pread:0331]:                                 fs fatal err
      mount errno: -19!
      [DBG]: [esFSYS_mntfs:0333]:                                 melis_devfs,mount on B.
      [DBG]: [kservice_maintask:0845]:                            partition [B] plug in..
      [DBG]: [__mount_parts:0299]:                                classname=DISK
      [DBG]: [__mount_parts:0300]:                                devname=RAMDISK
      [DBG]: [__mount_parts:0486]:                                rawpart: "DISK\RAMDISK0" is linked to symbel "C".
      [ERR]: [esFSYS_mntfs:0314]:                                 identify the filesystem failure.
      [ERR]: [__mount_parts:0541]:                                mount C failure.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x0000000040032ef8.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x0000000040033110.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x00000000400331c8.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x00000000400392ca.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x00000000400393f2.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x000000004008bbd6.
      dfs already init.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x000000004008e3fa.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x000000004008ee7c.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x0000000040031384.
      flash : 1
      sip : 0
      hal_spi_hw_config()2025 [spi0] clock_frequency = 50000000HZ
      hal_spi_init()2215 [spi0] DMA xfer enable
      nor_scan
      flash : 1
      sip : 0
      nor_factory_init
      nor flash init ok
      scheduler startup
      [DBG]: [__mount_parts:0300]:                                devname=ROOTFS
      [DBG]: [__mount_parts:0486]:                                rawpart: "DISK\ROOTFS0" is linked to symbel "D".
      [DBG]: [esFSYS_mntfs:0333]:                                 minfs,mount on D.
      [DBG]: [kservice_maintask:0845]:                            partition [D] plug in..
      [DBG]: [melis_udisk_part_check:0557]:                       melis_udisk_part_check 557 copy udisk_buff
      [DBG]: [__mount_parts:0300]:                                devname=UDISK
      [DBG]: [check_msdos_partition:0640]:
      [DBG]: [__mount_parts:0486]:                                rawpart: "DISK\UDISK0" is linked to symbel "E".
      [DBG]: [esFSYS_mntfs:0333]:                                 fat,mount on E.
      [DBG]: [kservice_maintask:0845]:                            partition [E] plug in..
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x000000004003a348.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x000000004003a414.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x000000004003a8d6.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x000000004003ab40.
      [ERR]: [hal_ths_init:0094]:                                 0x2009404, 0x2009400, 0x2009430, 0x2009408
      key name:thermal_sensor key size:64 key offset:20
      thermal_sensor:
      f2 00 99 89 0e b0 e1 01
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x00000000400311b2.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x00000000400331d8.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x000000004003458e.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x00000000400399ae.
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x0000000040039e68.
      the cir_master_init success
      [WRN]: [do_initcall_level:0096]:                            initcall: 0x0000000040065296.
      Warning: clk pll-audio0 should not be changed, please recheck whether the operation is correct
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\slib.mod.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 216, addr = 00000000e8700000.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 8440, addr = 00000000e87000d8.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 568, addr = 00000000e87021d0.
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\display.mod.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 10432, addr = 00000000e9a00000.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 5032, addr = 00000000e9a028c0.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 1872, addr = 00000000e9a03c68.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 6264, addr = 00000000e9a043b8.
      [WRN]: [Mod_Display_MInit:1092]:                            ...Mod_Display_MInit
      [WRN]: [Mod_Display_MOpen:1105]:                            ....Mod_Display_MOpen  mp.used = 0
      [WRN]: [Mod_Display_MOpen:1115]:                            ....Mod_Display_MOpen   mod_disp_mp.mid = fa  (__mp *)&mod_disp_mp = e9a05818
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\mixture.mod.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 16216, addr = 00000000e9b00000.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 3572, addr = 00000000e9b03f58.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 20, addr = 00000000e9b04d4c.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 1056, addr = 00000000e9b04d60.
      [WRN]: [LoadDataFromFile:0163]:                             fileLen=14891
      [WRN]: [open_ram_bmp:0250]:                                 base=0x40dd0000, size=0x3a2b
      [WRN]: [open_ram_bmp:0279]:                                 bg pic is compress...
      [WRN]: [Parse_Pic_BMP_ByRam:0159]:                          bmp:(32, 640, 480, 2560)
      [WRN]: [close_bmp:0227]:                                    esMEMS_Pfree: g_pbmp_buf=40dd4000, g_bmp_size=1228854 ,Psize = 1201
      [DBG]: [layer_request:0691]:                                layer_request MOD_DISP_LAYER_WORK_MODE_SCALER
      [DBG]: [layer_request:0739]:                                requested: ch:0, id:0  disp_mgr[0].req_layer_cnt = 1
      [ERR]: [open_lcd_backlight:0627]:                           get backlight err,default to 100
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\charset.mod.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 32, addr = 00000000e4400000.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 1544, addr = 00000000e4400020.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 222016, addr = 00000000e4400628.
      msh />enter app_entry
      Execute startup script begin..............
               install mod para num [2]: insmod d:\mod\orange.mod
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\orange.mod.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 4184, addr = 00000000e1800000.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 181108, addr = 00000000e1801058.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 82956, addr = 00000000e182d3cc.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 1392, addr = 00000000e18417d8.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 280384, addr = 00000000e1841d48.
      [WRN]: [GUI_Init:0080]:                                     GUI_Init gui get scn    w = 0    h = 0
      Mod:d:\mod\orange.mod Installed!, mod id=120
               install mod para num [2]: insmod d:\apps\desktop.mod
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\apps\desktop.mod.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 3112, addr = 00000000e1f00000.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 103212, addr = 00000000e1f00c28.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 35492, addr = 00000000e1f19f54.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 2192, addr = 00000000e1f229f8.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 5888, addr = 00000000e1f23288.
      [DBG]: [DESKTOP_MOpen:0091]:                                DESKTOP_MOpen.
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\apps\init.axf.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 552, addr = 00000000e1700000.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 52936, addr = 00000000e1700228.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 14248, addr = 00000000e170d0f0.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 5912, addr = 00000000e1710898.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 3304, addr = 00000000e1711fb0.
      Mod:d:\apps\desktop.mod Installed!, mod id=127
      ...............Execute startup script end
      [DBG]: [msg_srv_init_key_channel:0163]:                     emit_ctr.h_keyGraber=0x40d62180
      [DBG]: [msg_srv_init_key_channel:0174]:                     LdevID=0
      [DBG]: [application_init_process:0856]:                     &           application_init_process enter!             &
      [WRN]: [power_open:0329]:                                   power_timer start
      [DBG]: [application_init_process:0874]:                     application_init_process 874 before live_init
      [DBG]: [live_init:0054]:                                    ~~~~~~~~~~~~~~before dsk_set_isn_charset~~~~~~~~~~~
      [WRN]: [audio_play_init:0413]:                              [PLAY]audio_play_init,dev:0000000040125ef0
      [WRN]: [audio_play_open:0575]:                              [PLAY]audio_play_open,dev:0000000040125ef0,0
      [DBG]: [alsa_open_pcm:0316]:                                alsa open pcm! card:[audiocodec], pcmFlag:[1](0-cap;1-play)
      [DBG]: [application_init_process:0882]:                     application_init_process 882 before gscene_bgd_init
      [DBG]: [gscene_bgd_is_file_exist:0633]:                     file is exist:d:\apps\bg_default0.bgd
      [DBG]: [gscene_bgd_init:0143]:                              bgd_com->screen_size.width = 0  bgd_com->screen_size.height = 0  ftype = 1
      [DBG]: [application_init_process:0907]:                     try to open /dev/hwsc failed!
      [DBG]: [application_init_process:0911]:                     application_init_process 911 before init_mainwin_create
      [WRN]: [init_mainwin_create:3361]:                          before GUI_ManWinCreate
      [WRN]: [init_mainwin_cb:2405]:                              Init_reg_para->poweroff:0
      [WRN]: [init_mainwin_cb:2406]:                              init_ctr->autooff_timeout:0
      [WRN]: [init_mainwin_cb:2407]:                              Init_reg_para->close_screen:0
      [WRN]: [init_mainwin_cb:2408]:                              init_ctr->closescn_timeout:0
      [WRN]: [init_dialog_uipara:0044]:                           ======get display size:width=0,height=0
      [WRN]: [init_dialog_uipara:0163]:                           ===========800 X 480 dialog uipara
      [DBG]: [__hbar_layer_create:0107]:                          hbar fb 800 46 gui_dir=0
      [DBG]: [__hbar_layer_create:0108]:                          hbar src 0 0 800 46
      [DBG]: [__hbar_layer_create:0109]:                          hbar scn 0 0 800 46
      [WRN]: [sunxi_keyboard_thread:0501]:                        filter invalid event packet!
      [WRN]: [key_msg_cb:0976]:                                   +++++++++++++++++ GUI_MSG_KEY_DOWN
      [WRN]: [GUI_WinGetMsgQueue:2559]:                           h_win empty!
      [WRN]: [GUI_PostMessage:2212]:                              get windows msgqueue failed!
      [WRN]: [dsk_power_get_voltage_level:0153]:                  info.rest_vol=-1
      [WRN]: [dsk_get_charge_state:0412]:                         in charge
      [DBG]: [reset_headbar_data:0287]:                           xxxxxx para->data.volume = 30
      [DBG]: [reset_headbar_data:0291]:                           xxxxxx bright = 0
      [DBG]: [init_mainwin_cb:2449]:                              try to open /dev/hwsc failed!
      [WRN]: [init_mainwin_create:3363]:                          after GUI_ManWinCreate
      [WRN]: [GUI_SetActiveManWin:0111]:                          active main win from no active to init.
      [WRN]: [GUI_SetActiveManWin:0122]:                          before GUI_WinLock
      [WRN]: [GUI_SetActiveManWin:0134]:                          before GUI_WinSetFocusChild
      [DBG]: [application_init_process:0917]:                     application_init_process 917 before _process_init
      [DBG]: [applet_info_manager_load_dir:0320]:                 find dir file d:\apps\desktop\app_root.desktop!
      [DBG]: [applet_info_manager_load_file:0280]:                filename = d:\apps\desktop\app_root.desktop len=124
      [WRN]: [activity_set_load_para:0666]:                       activity_set_load_para
      [WRN]: [activity_set_load_para:0682]:                       app_name=root
      [WRN]: [activity_set_load_para:0687]:                       src_name=
      [DBG]: [__activity_load_common:0408]:                       load application application://app_root.
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\apps\app_root.axf.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 419628, addr = 00000000e9200000.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 128708, addr = 00000000e926672c.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 84056, addr = 00000000e9285df0.
      [WRN]: [MODS_LoadSectionData:0129]:                         size 14700, addr = 00000000e929a648.
      [WRN]: [__activity_mainwin_create:0110]:                    create_info.hParent=40ebd1f8
      [WRN]: [__activity_create:0139]:                            thiz->win=40ebd738
      [DBG]: [app_home_create:0688]:                              ********  enter multi screen home application  **************
      [DBG]: [get_fb_from_file:0423]:                             filename=d:\apps\bg_default0.bgd
      [DBG]: [get_fb_from_file:0465]:                             bg pic is compress...
      [DBG]: [get_fb_from_file:0468]:                             compress_buf=413ef000
                                               EXC_LOAD_PAGE_FAULT
      thread: initprocess, entry: 0x00000000e1701d48, stack_base: 0x0000000041046000,stack_size: 0x00010000.
       x0:0x0000000000000000   ra:0x00000000e170b506   sp:0x0000000041055360   gp:0x0000000040111864
       tp:0x000000004020e340   t0:0x0000000000000001   t1:0x00000000400a6ec8   t2:0x0000000041509644
       s0:0x8181818181818000   s1:0x00081818181416d5   a0:0x8181818181818181   a1:0x0000000000000466
       a2:0x0000000000000001   a3:0x0000000000000008   a4:0x0000000000000001   a5:0x0000000000000000
       a6:0x0000000000000320   a7:0x0000000010000201   s2:0x0000000040124af0   s3:0x0000000000119454
       s5:0x0000000040124ae0   s5:0x8181818181818181   s6:0x0000000040143000   s7:0x00000000e170d1b0
       s8:0x00000000e170d800   s9:0x000000000005dc00  s10:0x0000000040ef5740  s11:0x0000000000000001
       t3:0x0000000000119454   t4:0x0000000000000004   t5:0x0000000000000008   t6:0x000000000000001f
      other:
      sepc    :0x000000004002fec8
      scause  :0x000000000000000d
      stval   :0x00000060a0648b54
      sstatus :0x0000000200004120
      sscratch:0x0000000000000000
      -------backtrace-----------
      backtrace : 0X4002FEC8
      backtrace : 0XE170B502
      backtrace : 0XE1709A36
      backtrace : 0XE1708414
      backtrace : 0XE1708508
          -----------------------------------------------TSK Usage Report----------------------------------------------------------
              name     errno    entry       stat   prio     tcb     slice stacksize      stkfree  lt    si   so       stack_range
           initbkhdle   -2   0xe170521c    running   24   0x4020ea78   15     2048        1592    15  0000 0000  [0x40dbd800-0x40dbe000]
        headbar_fresh    0   0xe17038f4    suspend   24   0x4020e898   15     8192        7560    15  0000 0000  [0x41312000-0x41314000]
           0xE1F0D710    0   0xe1f0d710    suspend   24   0x4020e6b8   15    16384       15536    15  0000 0000  [0x40efd000-0x40f01000]
         appmsg2emitq    0   0xe1f0f6d4    suspend    9   0x4020e4d8   20     4096        3464    20  0000 0000  [0x41043000-0x41044000]
          initprocess    0   0xe1701d48    running   24   0x4020e2f8   15    65536       59184    05  0000 0000  [0x41046000-0x41056000]
         emitq2orange   -2   0xe1f1101c    running   24   0x4020e118   15     4096        2688    11  0000 0000  [0x41042000-0x41043000]
             OrangTmr    0   0xe1812e5e    suspend    9   0x4020df38   20     4096        3544    20  0000 0000  [0x40eb7000-0x40eb8000]
               tshell    0   0x4009061e    suspend   20   0x4020dd58   10    16384       12768    08  0000 0000  [0x40e19000-0x40e1d000]
             kb_input    0   0x40098c80    suspend    3   0x4020db78   10     4096        2248    09  0000 0000  [0x40e0f000-0x40e10000]
           0x40039AFE    0   0x40039afe    running   24   0x4020d7b8   15     4096        3248    08  0000 0000  [0x4026a000-0x4026b000]
                disp2    0   0x4002f41c    suspend   15   0x4020d5d8   10     8192        7872    10  0000 0000  [0x402ad000-0x402af000]
            kmsg2appq    0   0x4009d6d2    suspend    6   0x4020d3f8   10     4096        3360    07  0000 0000  [0x40269000-0x4026a000]
             mnt_task    0   0x400c7826    suspend    7   0x4020d218   10    16384       15936    10  0000 0000  [0x40219000-0x4021d000]
                tidle    0   0x4002bbae    running   31   0x4011e030   32     8192        7488    23  0000 0000  [0x4011e228-0x40120228]
                timer    0   0x4002f298    suspend    8   0x40120900   10    16384       16016    10  0000 0000  [0x40120ad8-0x40124ad8]
          memory info:
              Total  0x03ebd000
              Used   0x011fb680
              Max    0x01200a80
          ------------------------------------------------memory information-------------------------------------------------------
      dump stack memory:
      0x0000000041055360: 0xe170d800 0x00000000 0x0005dc00 0x00000000
      0x0000000041055370: 0x414aa854 0x00000000 0x00000000 0x00000000
      0x0000000041055380: 0x40253260 0x00000000 0x00119454 0x00000000
      0x0000000041055390: 0x00000010 0x00000000 0x000000ff 0x00000000
      0x00000000410553a0: 0x413ef000 0x00000000 0xe170b506 0x00000000
      0x00000000410553b0: 0x00000010 0x00000000 0xe1709a3a 0x00000000
      0x00000000410553c0: 0xe170d800 0x00000000 0x413ef000 0x00000000
      0x00000000410553d0: 0xe170d1b0 0x00000000 0xe170b4ec 0x00000000
      0x00000000410553e0: 0x410554e0 0x00000000 0x0005dc00 0x00000000
      0x00000000410553f0: 0x0005dc00 0x00000000 0x413d1000 0x00000000
      0x0000000041055400: 0x40ef57a4 0x00000000 0x00000001 0x00000000
      0x0000000041055410: 0x00000002 0x00000000 0x00000001 0x00000000
      0x0000000041055420: 0x00000320 0x00000000 0x000001e0 0x00000000
      0x0000000041055430: 0x00010001 0x00000000 0x00000320 0x000001e0
      0x0000000041055440: 0x413ef054 0x00000000 0x4144cc54 0x00000000
      0x0000000041055450: 0x414aa854 0x00000000 0x00000001 0x00000000
      0x0000000041055460: 0x00ff0110 0x00000000 0x00000000 0x00000000
      0x0000000041055470: 0x00000000 0x00000000 0x00000002 0x00000000
      0x0000000041055480: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000041055490: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x00000000410554a0: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x00000000410554b0: 0xdeadbeef 0x00000000 0xe1800000 0x00000000
      0x00000000410554c0: 0x40ebd738 0x00000000 0x402b1178 0x00000000
      0x00000000410554d0: 0x41055740 0x00000000 0x40ef5738 0x00000000
      0x00000000410554e0: 0xe1712828 0x00000000 0xe1708418 0x00000000
      0x00000000410554f0: 0x00000000 0x00000000 0x41055518 0x00000000
      0x0000000041055500: 0x00000008 0x00000000 0xdeadbeef 0x00000000
      0x0000000041055510: 0xdeadbeef 0x00000000 0x00e1f000 0x00000000
      0x0000000041055520: 0x0000000a 0x00000000 0xe170850c 0x00000000
      0x0000000041055530: 0x41055740 0x00000000 0x0000000a 0x00000000
      0x0000000041055540: 0xe1700000 0x00000000 0xe9236fb0 0x00000000
      0x0000000041055550: 0xe9266fd8 0x00000000 0xe9266fc8 0x00000000
      dump epc memory:
      0x000000004002fec8: 0x449b478b 0x8b8d4709 0x04e79463 0x818f90ef
      0x000000004002fed8: 0x449b478b 0x000f5717 0xc3470713 0x7c27b58b
      0x000000004002fee8: 0x578b8b8d 0x631c449b 0x00c59693 0x8f95e42e
      0x000000004002fef8: 0x80efe31c 0x65a2ff9f 0x64068556 0x74e260a6
      0x000000004002ff08: 0x79a27942 0x6ae27a02 0x61616b42 0xf2cff06f
      0x000000004002ff18: 0x18078b63 0xfd1f80ef 0x478b89aa 0xb78b449b
      0x000000004002ff28: 0x979b7c27 0x8c1d00c7 0x57b74018 0x879351ab
      0x000000004002ff38: 0x0e631ab7 0x061300f7 0x05975a90 0x8593000a
      0x000000004002ff48: 0x05175365 0x0513000a 0xd0ef6b65 0x781cd79f
      0x000000004002ff58: 0x000f5717 0xbb870713 0x00fab023 0x5054631c
      0x000000004002ff68: 0x03543823 0xe31c8f95 0x871b405c 0xc0580017
      0x000000004002ff78: 0x5418eb99 0x000f5797 0xb9c78793 0x66e7c68b
      0x000000004002ff88: 0xd40be814 0x404c66e7 0x5a634450 0x505402b6
      0x000000004002ff98: 0x05178756 0x0513000a 0xd0ef4ee5 0x2423bf3f
      0x000000004002ffa8: 0x445c0004 0x6406c05c 0x74e260a6 0x7a027942
      0x000000004002ffb8: 0x6b426ae2 0x79a2854e 0x806f6161 0x441cf31f
      0x000000004002ffc8: 0xc41c37fd 0x8e639fad 0x061300c7 0x05975f30
      0x000000004002ffd8: 0x8593000a 0x05174a25 0x0513000a 0xd0ef5125
      0x000000004002ffe8: 0x4058ce5f 0x10e3445c 0x681cfcf7 0x000f5497
      0x000000004002fff8: 0xb2448493 0x541ce791 0x66f4c78b 0xfa8785e3
      0x0000000040030008: 0xcf89441c 0x5ff00613 0x000a0597 0x46858593
      0x0000000040030018: 0x000a0517 0x4a850513 0xcabfd0ef 0x970b541c
      0x0000000040030028: 0xc78b06f4 0x986366f4 0x681c0687 0xe31c4589
      0x0000000040030038: 0xc01c57fd 0x000f5797 0xd2478793 0x000f5717
      0x0000000040030048: 0xd1470713 0x63104394 0x851be300 0xe8100016
      0x0000000040030058: 0xdae3c388 0xc394f4a5 0x000a3783 0x3703e310
      0x0000000040030068: 0x07b30009 0x83b140f4 0x04f7178b 0x000f5717
      0x0000000040030078: 0xcf470713 0x47014314 0x02d74363 0x80ef854e
      0x0000000040030088: 0x5797e6df 0x8793000f 0x438cce27 0x85226785
      0x0000000040030098: 0x02f5c5bb 0x8713b59d 0x6b9c0107 0xd00bb769
      0x00000000400300a8: 0x070544e7 0x60a6bfd1 0x74e26406 0x79a27942
      0x00000000400300b8: 0x6ae27a02 0x61616b42 0x80828082 0x5797cd09
      从打印的日志情况看,应该是还没有进行液晶初始化
      其中ST7789_CPU 驱动文件中 LCD_cfg_panel_info 函数内容被注释掉了,我打开和关闭没一点反应
      示波器量液晶数据引脚、时钟引脚、CS引脚始终没有波形
      全志开发太难了,怎么配置如何配置的资料真实寥寥无几,几句话直接概括,问代理商的技术说他们也没有整过SST7789的液晶
      S 1 条回复 最后回复 回复 引用 分享 0
        @qq354813374 在 F133-A 驱动SST7789有没有人成功过 中说:
        这个配置方法是Linux设备树的,你在melis里这样配置怎么可能被识别。
        fex的语法与linux设备树的不一样,找错文档了
        melis的配置方法:
        ;lcd0 configuration
        ;lcd_hbp:              hsync back porch
        ;lcd_ht:               hsync total cycle
        ;lcd_vbp:              vsync back porch
        ;lcd_vt:               vysnc total cycle
        ;lcd_hspw:             hsync plus width
        ;lcd_vspw:             vysnc plus width
        [lcd0]
        lcd_used            = 1
        lcd_backlight       = 150
        lcd_if              = 1
        lcd_x               = 240
        lcd_y               = 320
        lcd_width           = 108
        lcd_height          = 64
        lcd_rb_swap         = 0
        lcd_dclk_freq       = 18
        lcd_pwm_used        = 1
        lcd_pwm_ch          = 7
        lcd_pwm_freq        = 50000
        lcd_pwm_pol         = 1
        lcd_hbp             = 60
        lcd_ht              = 298
        lcd_hspw            = 30
        lcd_vbp             = 340
        lcd_vt              = 336
        lcd_vspw            = 2
        lcd_lvds_if         = 0
        lcd_lvds_colordepth = 1
        lcd_lvds_mode       = 0
        lcd_frm             = 1
        lcd_io_phase        = 0x0000
        lcd_gamma_en        = 0
        lcd_bright_curve_en = 0
        lcd_cmap_en         = 0
        deu_mode            = 0
        lcdgamma4iep        = 22
        smart_color         = 90
        lcd_bl_en           = port:PH06<1><0><default><1>
        lcd_power           = port:power2<1><0><default><1>
        ;lcd_fsync_en =1
        ;lcd_fsync_act_time = 1000
        ;lcd_fsync_pol = 0
        lcd_gpio_0               = port:PD00<2><0><default><default>
        lcd_gpio_1               = port:PD01<2><0><default><default>
        lcd_gpio_2               = port:PD02<2><0><default><default>
        lcd_gpio_3               = port:PD03<2><0><default><default>
        lcd_gpio_4               = port:PD04<2><0><default><default>
        lcd_gpio_5               = port:PD05<2><0><default><default>
        lcd_gpio_6               = port:PD06<2><0><default><default>
        lcd_gpio_7               = port:PD07<2><0><default><default>
        lcd_gpio_8               = port:PD08<2><0><default><default>
        lcd_gpio_9               = port:PD09<2><0><default><default>
        lcd_gpio_10              = port:PD10<2><0><default><default>
        lcd_gpio_11              = port:PD11<2><0><default><default>
        lcd_gpio_12              = port:PD12<2><0><default><default>
        lcd_gpio_13              = port:PD13<2><0><default><default>
        lcd_gpio_14              = port:PD14<2><0><default><default>
        lcd_gpio_15              = port:PD15<2><0><default><default>
        lcd_gpio_16              = port:PD16<2><0><default><default>
        lcd_gpio_17              = port:PD17<2><0><default><default>
        lcd_gpio_18              = port:PD18<2><0><default><default>
        lcd_gpio_19              = port:PD19<2><0><default><default>
        lcd_gpio_20              = port:PD20<2><0><default><default>
        lcd_gpio_21              = port:PD21<2><0><default><default>
        ;lcd_gpio_22              = port:PD22<2><0><default><default>
        ;lcd_gpio_23              = port:PD23<2><0><default><default>
        ;lcdclk              = port:PD18<2><0><default><default>
        ;fsync               = port:PD19<2><0><default><default>
        ;lcdhs               = port:PD20<2><0><default><default>
        ;lcdvs               = port:PD21<2><0><default><default>
        在Linux上已经驱动过st7789v i80屏幕,melis平台理论上是一样的操作。
        #include "st7789v_cpu.h"
        #define CPU_TRI_MODE
        #define DBG_INFO(format, args...) // (printk("[ST7789V LCD INFO] LINE:%04d-->%s:"format, __LINE__, __func__, ##args))
        #define DBG_ERR(format, args...) // (printk("[ST7789V LCD ERR] LINE:%04d-->%s:"format, __LINE__, __func__, ##args))
        #define panel_reset(val) sunxi_lcd_gpio_set_value(sel, 0, val)
        #define lcd_cs(val)  sunxi_lcd_gpio_set_value(sel, 1, val)
        static void lcd_panel_st7789v_init(u32 sel, struct disp_panel_para *info);
        extern void tcon_reset(u32 sel);
         * @name       :lcd_esd_check
         * @brief      :check if panel is ok
         * @param[IN]  :sel:index of dsi
         * @param[OUT] :none
         * @return     :0 if ok, else not ok
        static s32 lcd_esd_check(u32 sel)
          // pr_info("[lcd_esd_check] %d\n", sel);
        	tcon_reset(sel);
        static void LCD_cfg_panel_info(struct panel_extend_para *info)
            return;
        	LCD_OPEN_FUNC(sel, LCD_power_on, 120);
        #ifdef CPU_TRI_MODE
        	LCD_OPEN_FUNC(sel, LCD_panel_init, 100);
        	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50);
        #else
        	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 100);
        	LCD_OPEN_FUNC(sel, LCD_panel_init, 50);
        	LCD_CLOSE_FUNC(sel, LCD_bl_close, 20);
        #ifdef CPU_TRI_MODE
        	LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 10);
        	LCD_CLOSE_FUNC(sel, LCD_panel_exit, 50);
        #else
        	LCD_CLOSE_FUNC(sel, LCD_panel_exit, 10);
        	LCD_CLOSE_FUNC(sel, LCD_power_off, 0);
        	/*config lcd_power pin to open lcd power0 */
        	sunxi_lcd_power_enable(sel, 0);
        	sunxi_lcd_pin_cfg(sel, 1);
        	/*lcd_cs, active low */
        	lcd_cs(1);
        	sunxi_lcd_delay_ms(10);
        	/*lcd_rst, active hight */
        	panel_reset(1);
        	panel_reset(0);
        	panel_reset(1);
        	// sunxi_lcd_delay_ms(20);
        	sunxi_lcd_pin_cfg(sel, 0);
        	/*config lcd_power pin to close lcd power0 */
        	sunxi_lcd_power_disable(sel, 0);
        	sunxi_lcd_pwm_enable(sel);
        	/*config lcd_bl_en pin to open lcd backlight */
        	sunxi_lcd_backlight_enable(sel);
        	/*config lcd_bl_en pin to close lcd backlight */
        	sunxi_lcd_pwm_disable(sel);
        	DBG_INFO("\n");
        	kfree(info);
        	return;
        	sunxi_lcd_cpu_write_index(0, 0x28);
        	sunxi_lcd_cpu_write_index(0, 0x10);
        	DBG_INFO("\n");
        	lcd_cs(0);
        	sunxi_lcd_delay_ms(1);
        	panel_reset(1);
        	sunxi_lcd_delay_ms(2);
        	panel_reset(0);
        	panel_reset(1);
        	sunxi_lcd_cpu_write_index(0, 0x11);
        	sunxi_lcd_delay_ms(12);
        	sunxi_lcd_cpu_write_index(0, 0x36);
        	sunxi_lcd_cpu_write_data( 0, 0x00);
        	sunxi_lcd_cpu_write_index(0, 0x3A);
        	sunxi_lcd_cpu_write_data( 0, 0x05); /* RGB565 */
        	sunxi_lcd_cpu_write_index(0, 0xB2);
        	sunxi_lcd_cpu_write_data( 0, 0x0C);
        	sunxi_lcd_cpu_write_data( 0, 0x33);
        	sunxi_lcd_cpu_write_index(0, 0xB7);
        	sunxi_lcd_cpu_write_data( 0, 0x70);
        	/*ST7789V Power setting */
        	sunxi_lcd_cpu_write_index(0, 0xBB);
        	sunxi_lcd_cpu_write_data( 0, 0x35);
        	sunxi_lcd_cpu_write_index(0, 0xC2);
        	sunxi_lcd_cpu_write_data( 0, 0x01);
        	sunxi_lcd_cpu_write_index(0, 0xC3);
        	sunxi_lcd_cpu_write_data( 0, 0xaf);
        	sunxi_lcd_cpu_write_index(0, 0xC4);
        	sunxi_lcd_cpu_write_data( 0, 0x20);
        	sunxi_lcd_cpu_write_index(0, 0xC6);
        	sunxi_lcd_cpu_write_data( 0, 0x0F);
        	sunxi_lcd_cpu_write_index(0, 0xD0);
        	sunxi_lcd_cpu_write_data( 0, 0xA4);
        	sunxi_lcd_cpu_write_data( 0, 0xA1);
        	// /*ST7789V gamma setting */
        	sunxi_lcd_cpu_write_index(0, 0xE0);
        	sunxi_lcd_cpu_write_data( 0, 0xD0);
        	sunxi_lcd_cpu_write_data( 0, 0x08);
        	sunxi_lcd_cpu_write_data( 0, 0x0E);
        	sunxi_lcd_cpu_write_data( 0, 0x09);
        	sunxi_lcd_cpu_write_data( 0, 0x31);
        	sunxi_lcd_cpu_write_data( 0, 0x48);
        	sunxi_lcd_cpu_write_data( 0, 0x17);
        	sunxi_lcd_cpu_write_data( 0, 0x14);
        	sunxi_lcd_cpu_write_data( 0, 0x15);
        	sunxi_lcd_cpu_write_data( 0, 0x34);
        	sunxi_lcd_cpu_write_index(0, 0xE1);
        	sunxi_lcd_cpu_write_index(0, 0xd6);
        	sunxi_lcd_cpu_write_data( 0, 0xa1);
        #if 0 //defined(CPU_TRI_MODE)
        	/* enable te, mode 0 */
        	sunxi_lcd_cpu_write_index(0, 0x35);
        	sunxi_lcd_cpu_write_data(0, 0x00);
        	sunxi_lcd_cpu_write_index(0, 0x44);
        	sunxi_lcd_cpu_write_data(0, 0x80);
        	sunxi_lcd_cpu_write_index(0, 0x29);
        	if(strcmp(info->lcd_model_name, "inv") == 0x00) {
        		sunxi_lcd_cpu_write_index(0, 0x21);
        	} else {
        		sunxi_lcd_cpu_write_index(0, 0x20);
        	u16 x = 0, y = 0,w = 0, h = 0;
        	if(strcmp(info->lcd_size, "1.3") == 0) {
        		x = 0;
        		y = 0;
        		w = 240 - 1;
        		h = 240 - 1;
        	} else if (strcmp(info->lcd_size, "2.0") == 0) { /* 2.4 */
        		// sunxi_lcd_cpu_write_index(0, 0x36);
        		// sunxi_lcd_cpu_write_data( 0, 0xA0);
        		x = 0;
        		y = 0;
        		w = 240 - 1;
        		h = 320 - 1;
        	} else { /* 2.4 */
        		x = 0;
        		y = 0;
        		w = 240 - 1;
        		h = 320 - 1;
        	/* set to 240x240 */
        	sunxi_lcd_cpu_write_index(0, 0x2a);
        	sunxi_lcd_cpu_write_data(0, (u8)(x>>8));
        	sunxi_lcd_cpu_write_data(0, (u8)(x));
        	sunxi_lcd_cpu_write_data(0, (u8)(w>>8));
        	sunxi_lcd_cpu_write_data(0, (u8)(w));
        	sunxi_lcd_cpu_write_index(0, 0x2b);
        	sunxi_lcd_cpu_write_data(0, (u8)(y>>8));
        	sunxi_lcd_cpu_write_data(0, (u8)(y));
        	sunxi_lcd_cpu_write_data(0, (u8)(h>>8));
        	sunxi_lcd_cpu_write_data(0, (u8)(h));
        	sunxi_lcd_cpu_write_index(0, 0x2c);
        /* panel driver name, must mach the name of lcd_drv_name in sys_config.fex */
        struct __lcd_panel st7789v_cpu_panel = {
        	.name = "st7789v_cpu",
        	.func = {
        		.cfg_panel_info = LCD_cfg_panel_info,
        Q 1 条回复 最后回复 回复 引用 分享 0
          soso90 LV 7 @qq354813374 最后由 编辑
          @qq354813374 居然是melis,不错。搞完我也试试。melis帖子太少了
          • Q
            feelsigh LV 5 @WhycanService 最后由 编辑
            @whycanservice
            按照你说的方式进行配置,现在WR有时钟信号,CS也有信号但是不对,RS也有但是也不对
              WhycanService LV 8 @qq354813374 最后由 编辑
              @qq354813374 按照屏幕实际调整就好了
