    T507跳转U-boot失败
    5678
      as3213406 LV 3 最后由 whycan 编辑
      [95]HELLO! BOOT0 is starting!
      [98]BOOT0 commit : 2bfa9d6
      [100]set pll start
      [103]periph0 has been enabled
      [106]set pll end
      [108]PMU: AXP858
      [114]dram return write ok
      [116]board init ok
      [118]debug:rtc h-m-s value:0x61a30
      [121]DRAM BOOT DRIVE INFO: V0.651
      [125]the chip id is 0x7c00
      [127]chip id check OK
      [131]DRAM_VCC set to 1500 mv
      [134]DRAM CLK =672 MHZ
      [136]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [145]Actual DRAM SIZE =2048 M
      [148]DRAM SIZE =2048 MBytes, para1 = 30fa, para2 = 8001000, dram_tpr13 = 6041
      [161]DRAM simple test OK.
      [164]rtc standby flag is 0x0, super standby flag is 0x0
      [169]dram size =2048
      [172]Use rtc to store dram tuning para
      [176]card no is 2
      [178]sdcard 2 line count 8
      [180][mmc]: mmc driver ver 2020-07-21-202106151039
      [191][mmc]: Wrong media type 0x0, but host is sdc2, try mmc first
      [197][mmc]: ***Try MMC card 2***
      [222][mmc]: RMCA OK!
      [224][mmc]: bias 4
      [227][mmc]: MMC 5.1
      [229][mmc]: HSSDR52/SDR25 8 bit
      [232][mmc]: 50000000 Hz
      [235][mmc]: 7456 MB
      [237][mmc]: ***SD/MMC 2 init OK!!!***
      [260]Loading boot-pkg Succeed(index=0).
      [264]Entry_name        = u-boot
      [271]Entry_name        = monitor
      [275]Entry_name        = dtb
      [278]tunning data addr:0x4a0003e8
      [282]Jump to second Boot.
      [284]monitor_base:1207959552
      [287]optee_base:0,uboot_base:1241513984
      NOTICE:  BL3-1: v1.0(debug):f0130ea
      NOTICE:  BL3-1: Built : 10:23:13, 2022-04-14
      NOTICE:  BL3-1 commit: 8
      NOTICE:  hardware error1
      PANIC in EL3 at x30 = 0x0000000048001f54
                                              x0 =            0x0000000000000001
        x1 =          0x0000000005000000
        x2 =          0x0000000000000060
       x3 =           0x0000000000000000
                                        x4 =          0x0000000048018ad8
        x5 =          0x0000000048018ad8
        x6 =          0x000000004803cd50
        x7 =  0x0000000048180000
                       x8 =           0x000000004803c000
                                                        x9 =          0x0000000048000168
        x10 =         0x000000004800734c
        x11 =         0xa0061fca00000000
               x12 =          0xf4807f8600000000
                                                x13 =         0x53283f1c0591fa8c
        x14 =         0x240b7471fe7b1fa9
        x15 =         0x424ef31ffcaf9b2f
       x16 =          0x2b4849ca736ab127
                                        x17 =         0x1b01590500021400
        x18 =         0xe91cfe0e0002a79d
        x19 =         0x0000000048017442
        x20 = 0x0000000048000000
                       x21 =          0x0000000008100044
                                                        x22 =         0x2ef06b67ed63761f
        x23 =         0xb028dc38ed046d95
        x24 =         0xd3898634e3e45f37
               x25 =          0x23014804dfeeefa8
                                                x26 =         0x17dfb99582b6329c
        x27 =         0x96f3548135b7dcbe
        x28 =         0x126f6b662fa95ff3
       x29 =          0x000000004801a6d0
                                        scr_el3 =             0x0000000000000030
        sctlr_el3 =           0x0000000000cd183f
        cptr_el3 =            0x0000000000000000
                       tcr_el3 =              0x000000008081351f
        daif =                0x00000000000002c0
        mair_el3 =            0x00000000000004ff
       spsr_el3 =             0x00000000000001cd
                                                elr_el3 =             0x59b5d904f7434ced
        ttbr0_el3 =           0x000000004803cb40
        esr_el3 =     0x00000000ecf6b85e
                       far_el3 =              0xa739e4673bfae041
        spsr_el1 =            0x00000000000001cd
        elr_el1 =             0xa8d50a21e7bb17df
       spsr_abt =             0x00000000920484da
                                                spsr_und =            0x0000000038081b35
        spsr_irq =            0x00000000b0068b24
        spsr_fiq =    0x00000000b80a1b32
                       sctlr_el1 =            0x0000000000c50838
        actlr_el1 =           0x0000000000000000
        cpacr_el1 =           0x0000000000000000
       csselr_el1 =           0x0000000000000000
                                                sp_el1 =              0x200e60ca8c9fab51
        esr_el1 =             0x000000008a7f4e36
        ttbr0_el1 =   0xcc25b5fa90686ab9
                       ttbr1_el1 =            0xc0528d3325756fdb
        mair_el1 =            0x44e048e000098aa4
        amair_el1 =           0x0000000000000000
       tcr_el1 =              0x0000000000000000
                                                tpidr_el1 =           0x0a15183c9024c782
        tpidr_el0 =           0xc1423283011dc2c2
        tpidrro_el0 = 0x296d627045be4b5e
                       dacr32_el2 =           0x00000000c12d8a3d
        ifsr32_el2 =          0x000000000000101a
        par_el1 =             0xe00000baff1bce27
       mpidr_el1 =            0x0000000080000000
                                                afsr0_el1 =           0x0000000000000000
        afsr1_el1 =           0x0000000000000000
        contextidr_el1 =               0x0000000000000000
                                        vbar_el1 =            0x0000000000000000
        cntp_ctl_el0 =                0x0000000000000000
        cntp_cval_el0 =0xd6c558ab4a374cd5
                        cntv_ctl_el0 =                0x0000000000000000
        cntv_cval_el0 =               0xc0037d94ed4b97e4
        cntkctl_el1 =         0x0000000000000000
                       fpexc32_el2 =          0x0000000000000700
        sp_el0 =              0x000000004801a6d0
        cpuectlr_el1 =                0x0000000000000040
        WhycanService LV 8 最后由 编辑
        optee失败了,是否sdk匹配芯片,optee是绑定芯片的
          as3213406 LV 3 @WhycanService 最后由 编辑
          @whycanservice 查看boot0_main.c文件,发现进入e95d77ee-9bae-49b9-8c5b-d62b26b7e0ae-企业微信截图_16902537252313.png boot0_jmp_monitor(monitor_base);这段代码后就报错了。
            sagfa LV 2 最后由 编辑
            遇到同样的问题,请问是如何解决的?谢谢
