    为什么T507内核启动失败报undefined instruction错误?
      as3213406 LV 3 最后由 xiaowenge 编辑
      [170]HELLO! BOOT0 is starting!
      [173]BOOT0 commit : 2bfa9d6
      [176]set pll start
      [179]periph0 has been enabled
      [182]set pll end
      [184]PMU: AXP858
      [189]dram return write ok
      [192]board init ok
      [194]debug:rtc h-m-s value:0x11e
      [197]DRAM BOOT DRIVE INFO: V0.651
      [200]the chip id is 0x7c00
      [203]chip id check OK
      [207]DRAM_VCC set to 1500 mv
      [209]DRAM CLK =672 MHZ
      [212]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [220]Actual DRAM SIZE =2048 M
      [223]DRAM SIZE =2048 MBytes, para1 = 30fa, para2 = 8001000, dram_tpr13 = 6041
      [237]DRAM simple test OK.
      [239]rtc standby flag is 0x0, super standby flag is 0x0
      [245]dram size =2048
      [248]Use rtc to store dram tuning para
      [251]card no is 2
      [253]sdcard 2 line count 8
      [256][mmc]: mmc driver ver 2020-07-21-202106151039
      [266][mmc]: Wrong media type 0x0, but host is sdc2, try mmc first
      [273][mmc]: ***Try MMC card 2***
      [297][mmc]: RMCA OK!
      [299][mmc]: bias 4
      [303][mmc]: MMC 5.1
      [305][mmc]: HSSDR52/SDR25 8 bit
      [308][mmc]: 50000000 Hz
      [310][mmc]: 7456 MB
      [312][mmc]: ***SD/MMC 2 init OK!!!***
      [332]Loading boot-pkg Succeed(index=0).
      [336]Entry_name        = u-boot
      [342]Entry_name        = monitor
      [345]Entry_name        = dtb
      [349]--monitor_base:1207959552
      [352]tunning data addr:0x4a0003e8
      [355]Jump to second Boot.
      [358]uboot_base:1241513984
      U-Boot 2018.05 (Jul 24 2023 - 14:21:09 +0800) Allwinner Technology
      [00.400]CPU:   Allwinner Family
      [00.403]Model: sun50iw9
      I2C:   ready
      [00.407]DRAM:  2 GiB
      [00.410]Relocation Offset is: 75f36000
      [00.431]secure enable bit: 0
      [00.434]pmu_axp152_probe pmic_bus_read fail
      [00.438]PMU: AXP858
      [00.447]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
      [00.454]gic: sec monitor mode
      [00.458]ir_sys_cfg: error:no node for ir boot recovery settings
      [00.465]flash init start
      [00.467]workmode = 0,storage type = 2
      [00.470]MMC:     2
      [00.472][mmc]: mmc driver ver uboot2018:2020-5-24 16:54:00-202103251925
      [00.479][mmc]: get sdc_type fail and use default host:tm4.
      [00.488][mmc]: SUNXI SDMMC Controller Version:0x40502
      [00.512][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
      [00.518]sunxi flash init ok
      [00.521]Loading Environment from SUNXI_FLASH... OK
      [00.532]out of usb burn from boot: not need burn key
      [00.537]Item0 (Map) magic is bad
      [00.539]the secure storage item0 copy0 magic is bad
      [00.544]Item0 (Map) magic is bad
      [00.547]the secure storage item0 copy1 magic is bad
      [00.552]Item0 (Map) magic is bad
      [00.559]update dts
      [00.566]load file(ULI/factory/snum.txt) error.
      [00.576]load file(ULI/factory/mac.txt) error.
      [00.586]load file(ULI/factory/wifi_mac.txt) error.
      [00.596]load file(ULI/factory/bt_mac.txt) error.
      [00.606]load file(ULI/factory/selinux.txt) error.
      [00.616]load file(ULI/factory/specialstr.txt) error.
      [00.623]update part info
      [00.629]update bootcmd
      [00.631]No ethernet found.
      do_bootm_states states:1807
      do_bootm_states ret:0
      ## Booting Android Image at 0x45000000 ...
      Android's image name: sun50i_arm64
      Kernel load addr 0x40080000 size 20517 KiB
         kernel data at 0x45000800, len = 0x01409008 (21008392)
      ## Transferring control to Linux (at address 40080000)...
      ## Linux machid: 00000000, FDT addr: 44000000, fake:0
      [03.864]Starting kernel ...
      [03.866][mmc]: mmc exit start
      [03.884][mmc]: mmc 2 exit ok
      pc : [<40000000>]          lr : [<bff37523>]
      reloc pc : [<ca0ca000>]    lr : [<4a001523>]
      sp : bbefa670  ip : 00000007     fp : 00000001
      r10: bff8003f  r9 : bbf15e60     r8 : 00000001
      r7 : 40080000  r6 : bff99510     r5 : 00000000  r4 : 44000000
      r3 : 00000001  r2 : 44000000     r1 : 40080000  r0 : 8000ff04
      Flags: nzcv  IRQs off  FIQs off  Mode UK6_32
      Resetting CPU ...
      resetting ...
        WhycanService LV 8 @as3213406 最后由 编辑
        @as3213406 在 为什么T507内核启动失败报undefined instruction错误? 中说:
        mmc 2 exit ok
        Resetting CPU ...
        resetting ...
        没有找到内核。
        检查是否没有找到kernel,kernel地址是否正确,kernel压缩格式是否正确,kernel的配置格式是否正确,启动模式ramdisk和extlinux是否正确,安卓镜像打包是否损坏
