    sample_region 范例报错,sample_virvi2venc2muxer都可以运行
      dingxmhan LV 3 最后由 q1215200171 编辑
      sample_region 范例报错,同一张板sample_virvi2venc2muxer都可以运行。另外每次运行以后TF卡就变readonly👻
      ./sample_region -path ./sample_region.conf
      I0101 00:46:55.951219  1094 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
      I0101 00:46:55.975269  1094 confparser.c:60]                <createConfParser> load conf file ./sample_region.conf ok!
      I0101 00:46:55.975879  1094 sample_region.c:238]            <loadSampleRegionConfig> AttachToVi: 1, add_venc_channel:                                                   1, AttachToVe: 0, ChangeDisplayAttrEnable: 1
      I0101 00:46:55.976231  1094 sample_region.c:266]            <loadSampleRegionConfig> OnlineEnable: 0, Onlin[   62.2962                                                  13] VE: before freq=400000000
      eShareBufNum: 2
      I0101 00:46:55.[   62.302850] VE: real freq=400000000
      976463  1094 sample_region.c:270]                           <loadSampleRegionConfig> vipp: 0, VeCh: 0
      W0101 00:46:55.976664  1094 sample_region.c:592]            <main> =============================================>
      I0101 00:46:55.976844  1094 sample_region.c:599]            <main> enable display, VI_to_VO
      I0101 00:46:55.976957  1094 sample_region.c:604]            <main> Had add the VencChanel, add VI_To_Venc
      W0101 00:46:55.977093  1094 sample_region.c:607]            <main> =============================================>
      I0101 00:46:55.977339  1094 mpi_sys.c:840]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      modName : MPP-Platform
      tag   : V1.0 Release
      branch: v5-dev
      commit: 4eed413532ad87725895a8cb1ba75e22fc328233
      date  : 20170725
      author: jenkins
      I0101 00:46:56.005139  1094 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
      [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP600
      branch: libisp-dev
      commit: 14df8348718d093707641fea73eba7db962885f5
      date  : Thu Jul 14 15:40:38 2022 +0800
      I0101 00:46:56.006512  1094 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
      INFO   : cedarc <VeInitialize:1185>: *** ic_version = 0x1302000023010,
      I0101 00:46:56.033246  1094 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:0
      I0101 00:46:56.079727  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
      I0101 00:46:56.080081  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 volume
      I0101 00:46:56.080302  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC2 volume
      I0101 00:46:56.080466  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCDRC
      I0101 00:46:56.080645  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCHPF
      I0101 00:46:56.080803  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DAC volume
      I0101 00:46:56.080926  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACDRC
      I0101 00:46:56.081071  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACHPF
      I0101 00:46:56.081218  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEIN
      I0101 00:46:56.081363  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
      I0101 00:46:56.081478  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
      I0101 00:46:56.081616  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT
      I0101 00:46:56.081989  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
      I0101 00:46:56.082402  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT volume
      I0101 00:46:56.082711  1094 alsa_interface.c:756]           <alsaOpenMixer> set playback vol_val to value: 27
      I0101 00:46:56.082955  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1
      I0101 00:46:56.083330  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
      I0101 00:46:56.083544  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
      I0101 00:46:56.083702  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2
      I0101 00:46:56.083853  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
      I0101 00:46:56.084008  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
      I0101 00:46:56.084164  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:SPK
      I0101 00:46:56.084513  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:digital volume
      I0101 00:46:56.084696  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0101 00:46:56.084855  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      E0101 00:46:56.085019  1094 alsa_interface.c:970]           <alsaMixerSetAudioCodecHubMode> aec_elem_audio_codec_hub_m                                                  ode:tx hub mode-1
      E0101 00:46:56.085250  1094 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx                                                   sync mode-1
      I0101 00:46:56.085505  1094 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:1
      I0101 00:46:56.093014  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:loopback debug
      I0101 00:46:56.093245  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0101 00:46:56.093355  1094 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      E0101 00:46:56.093468  1094 alsa_interface.c:993]           <alsaMixerSetDAudio0HubMode> aec_elem_daudio0_hub_mode:tx                                                   hub mode-1
      E0101 00:46:56.093610  1094 alsa_interface.c:1016]          <alsaMixerSetDAudio0LoopBackEn> aec_elem_daudio0_loopback_                                                  en:loopback debug-1
      E0101 00:46:56.093742  1094 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx                                                   sync mode-1
      [ISP]video device name is vin_video0
      [ISP]open video device[0], detect isp0 success!
      I0101 00:46:56.425138  1094 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:46:56.425879  1094 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[0] update width:1920(1920),                                                   height:1080(1088)
      [ISP]video0 fd[9] ve_online_en=0[   62.942836] [VIN]ve_online close
      , dma_buf_num=0
      open /dev/sunxi_soc_info failed![ISP]open isp device[0] success!
      [ISP_WARN]open /mnt/extsd/isp0_1920_1088_30_ctx_saved.bin failed, err:No such file or directory.
      [ISP]prefer isp config: [gc2053_mipi], 1920x1088, 30, 0, 0
      [ISP_WARN]cannot find gc2053_mipi_1920_1088_30_0_0 isp config, use gc2053_mipi_1920_1088_20_0_0 -> [gc2053_mipi_isp600                                                  _20220511_164617_vlc4_day]
      I0101 00:46:56.815686  1101 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_                                                  id = 0, buf_num=5.
      I0101 00:46:56.822580  1094 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_i                                                  d[0xb5cd0d50]
      E0101 00:46:56.823057  1094 mpi_vo.c:761]                   <AW_MPI_VO_Enable> fatal error! VODevManager is not init!
      I0101 00:46:56.823304  1094 hwdisplay.c:1121]               <hwd_layer_request_hlay> hlay:0, zorder=0, cnt:1
      E0101 00:46:56.823468  1094 hwdisplay.c:115]                <layer_config> ioctl failed: Not a tty
      E0101 00:46:56.823574  1094 hwdisplay.c:184]                <layer_set_para> set para failed
      Segmentation fault (core dumped)
