    t113使用nand flash启动后不识别TF卡
    • hsinyuwang
      hsinyuwang LV 6 最后由 编辑
      启动log
      [    0.000000] Linux version 5.4.61 (hsinyuwang@vm) (arm-openwrt-linux-gnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #444 SMP PREEMPT Fri Jul 28 11:40:31 UTC 2023
      [    0.000000] cma: Reserved 8 MiB at 0x47800000
      [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=tty0 console=ttyS3,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07(07/28/2023-18:44:23) aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
      [    0.000000] Memory: 109616K/131072K available (6144K kernel code, 268K rwdata, 1536K rodata, 1024K init, 1175K bss, 13264K reserved, 8192K cma-reserved)
      [    0.000000] 	Tasks RCU enabled.
      [    0.008016] Switching to timer-based delay loop, resolution 41ns
      [    0.014185] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.023964] Console: colour dummy device 80x30
      [    0.029109] printk: console [tty0] enabled
      [    0.033254] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.043643] pid_max: default: 32768 minimum: 301
      [    0.048404] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.055738] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.064099] CPU: Testing write buffer coherency: ok
      [    0.069334] /cpus/cpu@0 missing clock-frequency property
      [    0.074668] /cpus/cpu@1 missing clock-frequency property
      [    0.080026] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.086199] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.092888] rcu: Hierarchical SRCU implementation.
      [    0.098121] smp: Bringing up secondary CPUs ...
      [    0.103743] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.103863] smp: Brought up 1 node, 2 CPUs
      [    0.113695] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.119887] CPU: All CPU(s) started in SVC mode.
      [    0.124969] devtmpfs: initialized
      [    0.139256] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.147410] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.157309] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.164547] pinctrl core: initialized pinctrl subsystem
      [    0.170739] NET: Registered protocol family 16
      [    0.176667] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.210653] rtc_ccu: sunxi ccu init OK
      [    0.216845] ccu: sunxi ccu init OK
      [    0.220671] r_ccu: sunxi ccu init OK
      [    0.242271] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [    0.249817] iommu: Default domain type: Translated
      [    0.254889] sunxi iommu: irq = 24
      [    0.259045] usbcore: registered new interface driver usbfs
      [    0.264595] usbcore: registered new interface driver hub
      [    0.270031] usbcore: registered new device driver usb
      [    0.275852] Advanced Linux Sound Architecture Driver Initialized.
      [    0.282500] Bluetooth: Core ver 2.22
      [    0.286379] NET: Registered protocol family 31
      [    0.290867] Bluetooth: HCI device and connection manager initialized
      [    0.297260] Bluetooth: HCI socket layer initialized
      [    0.302155] Bluetooth: L2CAP socket layer initialized
      [    0.307243] Bluetooth: SCO socket layer initialized
      [    0.312386] pwm module init!
      [    0.316438] g2d 5410000.g2d: Adding to iommu group 0
      [    0.321727] G2D: rcq version initialized.major:252
      [    0.327340] clocksource: Switched to clocksource arch_sys_counter
      [    0.341749] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.358941] NET: Registered protocol family 2
      [    0.363859] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.372316] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.380024] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.387117] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.393608] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.400187] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.407384] NET: Registered protocol family 1
      [    0.412700] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.423067] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.429819] sunxi_spi_resource_get()2438 - [spi0] SPI MASTER MODE
      [    0.435984] sunxi_spi_resource_get()2476 - Failed to get sample mode
      [    0.442377] sunxi_spi_resource_get()2481 - Failed to get sample delay
      [    0.448863] sunxi_spi_resource_get()2485 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.457277] sunxi_spi_clk_init()2527 - [spi0] mclk 100000000
      [    0.463552] sunxi_spi_probe()2978 - [spi0]: driver probe succeed, base c881f000, irq 39
      [    0.473228] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.484522] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.490430] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
      [    0.527055] io scheduler mq-deadline registered
      [    0.531656] io scheduler kyber registered
      [    0.536691] [DISP]disp_module_init
      [    0.540652] disp 5000000.disp: Adding to iommu group 0
      [    0.546305] [DISP] parser_disp_init_para,line:1430:
      [    0.546308] of_property_read fb0_width fail
      [    0.571536] display_fb_request,fb_id:0
      [    0.575799] [DISP] Fb_copy_boot_fb,line:1445:
      [    0.575803] no boot_fb0
      [    0.583066] disp_al_manager_apply ouput_type:0
      [    0.583460] [DISP] lcd_clk_config,line:774:
      [    0.583471] disp 0, clk: pll(192000000),clk(192000000),dclk(16000000) dsi_rate(192000000)
      [    0.583471]      clk real:pll(288000000),clk(288000000),dclk(24000000) dsi_rate(0)
      [    0.584290] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.707368] [ILI9488 LCD INFO] LINE:0159-->LCD_panel_init:
      [    0.707375] [ILI9488 LCD INFO] LINE:0178-->lcd_panel_ili9488_init:
      [    1.151368] Console: switching to colour frame buffer device 60x40
      [    1.225855] [DISP]disp_module_init finish
      [    1.232097] sunxi_sid_init()783 - insmod ok
      [    1.238620] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    1.251283] uart uart3: uart3 supply uart not found, using dummy regulator
      [    1.260885] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
      [    1.271251] sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
      ÿ[    1.281807] printk: console [ttyS3] enabled
      [    1.292017] printk: bootconsole [earlycon0] disabled
      [    1.304631] misc dump reg init
      [    1.310523] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    1.324310] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    1.334121] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    1.344068] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    1.354149] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    1.363397] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    1.373081] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    1.383606] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [    1.394273] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    1.405211] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    1.415660] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    1.425246] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    1.435612] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=205 assert=0
      [    1.446463] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [    1.456512] [ADDR_MGT] addr_mgt_probe: success.
      [    1.463399] dma-buf: Running sanitycheck
      [    1.469263] dma-buf: Running dma_fence
      [    1.474865] sizeof(dma_fence)=48
      [    1.480002] dma-buf: Running dma_fence/sanitycheck
      [    1.486775] dma-buf: Running dma_fence/test_signaling
      [    1.493818] dma-buf: Running dma_fence/test_add_callback
      [    1.501129] dma-buf: Running dma_fence/test_late_add_callback
      [    1.510177] dma-buf: Running dma_fence/test_rm_callback
      [    1.517382] dma-buf: Running dma_fence/test_late_rm_callback
      [    1.526319] dma-buf: Running dma_fence/test_status
      [    1.533014] dma-buf: Running dma_fence/test_error
      [    1.539584] dma-buf: Running dma_fence/test_wait
      [    1.546017] dma-buf: Running dma_fence/test_wait_timeout
      [    1.587353] dma-buf: Running dma_fence/test_stub
      [    1.593756] dma-buf: Running dma_fence/race_signal_callback
      [    1.667350] thread_signal_callback[0] completed 34540 passes, 79 misses
      [    1.677159] thread_signal_callback[1] completed 34541 passes, 79 misses
      [    1.747346] thread_signal_callback[0] completed 36845 passes, 36845 misses
      [    1.757445] thread_signal_callback[1] completed 36856 passes, 36855 misses
      [    1.767960] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
      [    1.777624] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      [    1.787867] sunxi-spinand-phy: not detect any munufacture from id table
      [    1.797673] sunxi-spinand-phy: get spi-nand Model from fdt fail
      [    1.806644] sunxi-spinand-phy: get phy info from fdt fail
      [    1.813977] sunxi-spinand-phy: not detect munufacture from fdt
      [    1.822915] sunxi-spinand-phy: detect munufacture from id table: Winbond
      [    1.832791] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      [    1.842196] sunxi-spinand-phy: ========== arch info ==========
      [    1.851190] sunxi-spinand-phy: Model:               W25N01GVZEIG
      [    1.860424] sunxi-spinand-phy: Munufacture:         Winbond
      [    1.869232] sunxi-spinand-phy: DieCntPerChip:       1
      [    1.876172] sunxi-spinand-phy: BlkCntPerDie:        1024
      [    1.883429] sunxi-spinand-phy: PageCntPerBlk:       64
      [    1.890461] sunxi-spinand-phy: SectCntPerPage:      4
      [    1.897387] sunxi-spinand-phy: OobSizePerPage:      64
      [    1.904388] sunxi-spinand-phy: BadBlockFlag:        0x0
      [    1.911508] sunxi-spinand-phy: OperationOpt:        0x7
      [    1.918644] sunxi-spinand-phy: MaxEraseTimes:       65000
      [    1.925957] sunxi-spinand-phy: EccFlag:             0x0
      [    1.933098] sunxi-spinand-phy: EccType:             2
      [    1.940008] sunxi-spinand-phy: EccProtectedType:    3
      [    1.946883] sunxi-spinand-phy: ========================================
      [    1.956692] sunxi-spinand-phy:
      [    1.961395] sunxi-spinand-phy: ========== physical info ==========
      [    1.970656] sunxi-spinand-phy: TotalSize:    128 M
      [    1.977183] sunxi-spinand-phy: SectorSize:   512 B
      [    1.983709] sunxi-spinand-phy: PageSize:     2 K
      [    1.990010] sunxi-spinand-phy: BlockSize:    128 K
      [    1.996472] sunxi-spinand-phy: OOBSize:      64 B
      [    2.002836] sunxi-spinand-phy: ========================================
      [    2.012346] sunxi-spinand-phy:
      [    2.016900] sunxi-spinand-phy: ========== logical info ==========
      [    2.025752] sunxi-spinand-phy: TotalSize:    128 M
      [    2.032148] sunxi-spinand-phy: SectorSize:   512 B
      [    2.038550] sunxi-spinand-phy: PageSize:     4 K
      [    2.044712] sunxi-spinand-phy: BlockSize:    256 K
      [    2.051070] sunxi-spinand-phy: OOBSize:      128 B
      [    2.057395] sunxi-spinand-phy: ========================================
      [    2.066699] sunxi-spinand-phy: block lock register: 0x00
      [    2.073676] sunxi-spinand-phy: feature register: 0x19
      [    2.080272] sunxi-spinand-phy: sunxi physic nand init end
      [    2.087695] Creating 5 MTD partitions on "sunxi_mtd_nand":
      [    2.095645] 0x000000000000-0x000000100000 : "boot0"
      [    2.108249] 0x000000100000-0x000000400000 : "uboot"
      [    2.128216] 0x000000400000-0x000000500000 : "secure_storage"
      [    2.136898] random: fast init done
      [    2.148220] 0x000000500000-0x000000580000 : "pstore"
      [    2.158223] 0x000000580000-0x000008000000 : "sys"
      [    2.268620] libphy: Fixed MDIO Bus: probed
      [    2.274700] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    2.283999] sunxi-ehci: EHCI SUNXI driver
      [    2.289922] get ehci1-controller wakeup-source is fail.
      [    2.296916] sunxi ehci1-controller don't init wakeup source
      [    2.305220] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b62288, 0x:c8835000, irq_no:38
      [    2.320380] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    2.336113] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    2.350603] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    2.360204] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    2.372528] sunxi-ehci 4200000.ehci1-controller: irq 56, io mem 0x04200000
      [    2.407381] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    2.418446] hub 1-0:1.0: USB hub found
      [    2.423946] hub 1-0:1.0: 1 port detected
      [    2.430179] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    2.439666] sunxi-ohci: OHCI SUNXI driver
      [    2.445881] get ohci1-controller wakeup-source is fail.
      [    2.453154] sunxi ohci1-controller don't init wakeup source
      [    2.461947] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b62518
      [    2.474192] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    2.490599] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    2.505501] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    2.515525] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    2.528132] sunxi-ohci 4200400.ohci1-controller: irq 57, io mem 0x04200400
      [    2.612136] hub 2-0:1.0: USB hub found
      [    2.617829] hub 2-0:1.0: 1 port detected
      [    2.624290] i2c /dev entries driver
      [    2.629700] sunxi cedar version 1.1
      [    2.635131] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    2.644101] VE: sunxi_cedar_probe power-domain init!!!
      [    2.651218] VE: install start!!!
      [    2.651218]
      [    2.659305] VE: cedar-ve the get irq is 40
      [    2.659305]
      [    2.668289] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [    2.668289]
      [    2.681286] VE: install end!!!
      [    2.681286]
      [    2.688737] VE: sunxi_cedar_probe
      [    2.693857] Bluetooth: HCI UART driver ver 2.3
      [    2.700034] Bluetooth: HCI UART protocol H4 registered
      [    2.706956] Bluetooth: HCI UART protocol BCSP registered
      [    2.714409] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [    2.725465] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    2.737751] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    2.746271] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    2.754942] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    2.763733] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    2.772503] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    2.781385] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    2.790253] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    2.799131] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    2.808442] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    2.815059] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    2.824101] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.837764] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    2.860380] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.887399] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    2.894395] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.909073] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    2.911627] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.921580] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    2.938077] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.944673] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    2.962085] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.968237] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    2.968245] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    3.001244] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    3.004706] mmc0: host does not support reading read-only switch, assuming write-enable
      [    3.010616] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    3.024158] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    3.031791] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    3.031798] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    3.046250] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    3.055584] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    3.065053] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    3.105901] mmc0: new high speed SDHC card at address 59b4
      [    3.115359] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.129498] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    3.152568] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.179739] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    3.190333] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    3.200944] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    3.201969] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    3.201969]
      [    3.233825] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.237376] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    3.262700] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
      [    3.263510] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.274755] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    3.301114] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    3.310780] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    3.320447] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    3.330095] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    3.330123] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.353882] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    3.363911] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    3.377777] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    3.392719] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    3.404018] NET: Registered protocol family 10
      [    3.410564] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    3.418308] Segment Routing with IPv6
      [    3.426403] NET: Registered protocol family 17
      [    3.433063] Bluetooth: RFCOMM TTY layer initialized
      [    3.440011] Bluetooth: RFCOMM socket layer initialized
      [    3.447237] Bluetooth: RFCOMM ver 1.11
      [    3.453431] Registering SWP/SWPB emulation handler
      [    3.477784] get ehci0-controller wakeup-source is fail.
      [    3.485154] sunxi ehci0-controller don't init wakeup source
      [    3.494198] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b61d68, 0x:c88ed000, irq_no:36
      [    3.510336] [sunxi-ehci0]: Not init ehci0
      [    3.516540] get ohci0-controller wakeup-source is fail.
      [    3.523912] sunxi ohci0-controller don't init wakeup source
      [    3.532900] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b61ff8
      [    3.545297] [sunxi-ohci0]: Not init ohci0
      [    3.552449] ubi0: attaching mtd4
      [    3.739483] ubi0: scanning is finished
      [    3.750692] ubi0 warning: ubi_eba_init: cannot reserve enough PEBs for bad PEB handling, reserved 18, need 20
      [    3.766395] ubi0: attached mtd4 (name "sys", size 122 MiB)
      [    3.775182] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [    3.785484] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [    3.795688] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [    3.806087] ubi0: good PEBs: 490, bad PEBs: 0, corrupted PEBs: 0
      [    3.815408] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [    3.826107] ubi0: max/mean erase counter: 18/12, WL threshold: 4096, image sequence number: 0
      [    3.838288] ubi0: available PEBs: 0, total reserved PEBs: 490, PEBs reserved for bad PEB handling: 18
      [    3.851299] ubi0: background thread "ubi_bgt0d" started, PID 75
      [    3.861759] block ubiblock0_5: created from ubi0:5(rootfs)
      [    3.871139] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      [    3.886696] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    3.901800] input: gpio-keys as /devices/platform/gpio-keys/input/input1
      [    3.914729] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    3.927299] cfg80211: failed to load regulatory.db
      [    3.927308] clk: Not disabling unused clocks
      [    3.940342] ALSA device list:
      [    3.945054]   #0: audiocodec
      [    3.949660] alloc_fd: slot 0 not NULL!
      [    3.958312] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
      [    3.971231] devtmpfs: mounted
      [    3.977886] Freeing unused kernel memory: 1024K
      [    3.987502] Run /pseudo_init as init process
      [    4.706715] UBIFS (ubi0:7): Mounting in unauthenticated mode
      [    4.716025] UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 104
      [    4.744355] random: crng init done
      [    4.770429] UBIFS (ubi0:7): recovery needed
      [    4.921813] UBIFS (ubi0:7): recovery completed
      [    4.928450] UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "rootfs_data"
      [    4.939907] UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      [    4.953676] UBIFS (ubi0:7): FS size: 3096576 bytes (2 MiB, 12 LEBs), journal size 1806337 bytes (1 MiB, 5 LEBs)
      [    4.967656] UBIFS (ubi0:7): reserved for root: 146258 bytes (142 KiB)
      [    4.977507] UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID B9215416-B885-4FE1-9784-B5F966954AF9, small LPT model
      [    5.260087] UBIFS (ubi0:8): Mounting in unauthenticated mode
      [    5.269238] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 133
      [    5.354310] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
      [    5.365182] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      [    5.378940] UBIFS (ubi0:8): FS size: 53673984 bytes (51 MiB, 208 LEBs), journal size 2580480 bytes (2 MiB, 10 LEBs)
      [    5.393269] UBIFS (ubi0:8): reserved for root: 2535154 bytes (2475 KiB)
      [    5.403286] UBIFS (ubi0:8): media format: w5/r0 (latest is w5/r0), UUID 254AC323-E796-441E-9597-B9747E9125E4, small LPT model
      insmod: can't insert '/lib/modules/5.4.61/sunxi_gpadc.ko': No such file or directory
      [    5.575971] ======== XRADIO WIFI OPEN ========
      [    5.582951] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [    5.592472] [XRADIO] Allocated hw_priv @ 92b02454
      [    5.599698] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [    5.618767] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [    5.828722] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    5.842672] [XRADIO] Detect SDIO card 1
      [    5.842782] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    5.871373] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    5.899341] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    5.909899] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    5.919638] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    5.937146] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    5.953823] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    5.964258] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    5.974703] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    5.985137] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    5.994789] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    7.447622] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    7.887418] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [    7.997598] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.011645] [XRADIO] Remove SDIO card 1
      [    8.027402] [SBUS_ERR] sdio probe timeout!
      [    8.027429] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    8.033438] [XRADIO_ERR] sbus_sdio_init failed
      [    8.050656] xradio_core_init failed (-110)!
      [    8.056440] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.084693] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    8.095183] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    8.104883] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.122369] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.139035] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    8.149442] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    8.159844] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    8.170257] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    8.179875] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    8.225930] ======== XRADIO WIFI OPEN ========
      [    8.232967] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [    8.242654] [XRADIO] Allocated hw_priv @ 6acdb30e
      [    8.249930] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [    8.269066] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [    8.479093] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.493086] [XRADIO] Detect SDIO card 1
      [    8.493192] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    8.521757] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.549664] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    8.560170] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    8.569904] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.587436] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    8.604130] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    8.614573] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    8.625032] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    8.635488] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    8.645137] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   10.527415] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [   10.637604] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   10.651656] [XRADIO] Remove SDIO card 1
      [   10.667410] [SBUS_ERR] sdio probe timeout!
      [   10.667427] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   10.673451] [XRADIO_ERR] sbus_sdio_init failed
      [   10.690618] xradio_core_init failed (-110)!
      [   10.696431] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   10.724648] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   10.735142] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   10.744827] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   10.762314] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   10.778962] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   10.789374] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   10.799792] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   10.810197] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   10.819811] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      • hsinyuwang
        在坛子里发现了同样的问题,有人解决了吗?
