    Tina通过命令行连接WiFi
    5
    6
    7094
    • aldfaaa
      whycan矿工-小叶 LV 7 最后由 aldfaaa 编辑
      首先配置wpa_supplicant的配置文件:/etc/wifi/ake.conf
      ctrl_interface=/var/run/wpa_supplicant
      update_config=1
      network={
              ssid="(SSID)"
              psk="(PWD)"
      然后
      # 主要连接操作
       wpa_supplicant -Dnl80211 -iwlan0 -c/etc/wifi/ake.conf -B
      # 通过DHCP服务获得IP地址等信息
      udhcpc -i wlan0 -B
      # 搜索WIFI
      wpa_cli -iwlan0 scan
      wpa_cli -iwlan0 scan_result
      # 检查WiFi连接状态
      wpa_cli -iwlan0 status
      WiFi已连接的应答
      想开机配置网络和WiFi, 可以修改/etc/init.d/wpa_supplicant文件第48行左右:
      if [ x$brlan=="xbr-lan" ]; then
          echo "change the default ip address 192.168.1.1"
          ifconfig br-lan 192.168.100.1
          # 加你所想操作的指令
      fi
      1 条回复 最后回复 回复 引用 分享 3
      • BedRock
        BedRock LV 6 最后由 编辑
        我又一个更好的方法,不知当讲不当讲,🤤 🤤 🤤 🤤 🤤
        忍不住了,我还是说说
        1.扫描wifi
        root@TinaLinux:/# wifi_scan_results_test
        ***Start scan!***
        bssid / frequency / signal level / flags / ssid
        90:67:1c:f8:11:ac       2422    -37     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       AW-PDC-RTOS-MUSIC
        9c:9d:7e:e1:a7:c6       2462    -45     [WPA2-PSK-CCMP][WPS][ESS]       Redmi_9EC8
        88:d7:f6:88:8b:c0       2412    -50     [WPA2-PSK-CCMP][WPS][ESS]       AW-PDC-PD4-316Test
        34:29:12:ac:c3:b9       2462    -56     [WPA2-PSK-CCMP][WPS][ESS]
        50:d2:f5:f1:b7:08       2457    -58     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       AW-PDC-PD2-xiaomi2.4g
        34:29:12:ac:c3:b8       2462    -59     [WPA2-PSK-CCMP][WPS][ESS]       AW-PDC-KY_IPV6_1
        80:e8:6f:d9:6b:80       2437    -61     [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS]      AWOffice
        3c:20:93:0e:2f:97       2412    -54     [WPA-PSK-TKIP][WPA2-PSK-CCMP][ESS]      test_123
        7e:b5:9b:1d:e2:89       2437    -64     [WPA2-PSK-CCMP][ESS]    AWTest
        7c:b5:9b:fd:e2:89       2437    -65     [WPA-EAP-CCMP+TKIP][WPA2-EAP-CCMP+TKIP][ESS]    AWOffice
        7e:b5:9b:2d:e2:89       2437    -66     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]    CangKu-221
        7e:b5:9b:3d:e2:89       2437    -66     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]    AW-MLC-221
        80:e8:6f:d9:6b:82       2437    -62     [WPA2-PSK-CCMP][ESS]    AWTest
        ac:e3:42:9c:7f:78       2412    -64     [WPA2-PSK-CCMP][WPS][ESS]       AW-PDC-PSW-CAI
        04:d4:c4:b9:b9:f8       2457    -67     [WPA2-PSK-CCMP][WPS][ESS]       ipv6
        5c:a4:8a:bf:25:72       2437    -68     [WPA2-PSK-CCMP][ESS]    AWTest
        5c:a4:8a:bf:25:70       2437    -69     [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS]      AWOffice
        bc:67:1c:f8:9f:80       2427    -70     [WPA2-PSK-CCMP][ESS]    AWTest
        2e:f4:32:07:7e:02       2452    -73     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][ESS]    OUT RF
        80:e8:6f:d9:fd:a2       2412    -74     [WPA2-PSK-CCMP][ESS]    AWTest
        38:1c:1a:2e:b3:50       2437    -74     [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS]      AWOffice
        80:e8:6f:d9:fd:a0       2412    -75     [WPA-EAP-CCMP][WPA2-EAP-CCMP][ESS]      AWOffice
        38:1c:1a:2e:b3:52       2437    -75     [WPA2-PSK-CCMP][ESS]    AWTest
        ec:6c:9f:af:89:79       2452    -76     [WPA2-PSK-CCMP][ESS]    AW-APD-GMSipv6
        66:6e:97:1a:5a:e4       2462    -81     [WPA2-PSK-CCMP][ESS]    AWTest
        8c:be:be:2d:ec:22       2412    -81     [WPA-PSK-CCMP+TKIP][WPA2-PSK-CCMP+TKIP][WPS][ESS]       AW-AE2-TEST1
        80:8f:1d:8a:36:76       2412    -61     [ESS]   AW-PDC-PD2-TEST-2.4G
        fc:53:9e:c1:b9:2d       2462    -72     [ESS]   MEIZUtest
        Wifi get_scan_results: Success!
        2. 连接wifi
        # 后面两个参数是  ssid 和 pwd
        root@TinaLinux:/# wifi_connect_ap_test AWTest xxxxxx
        Connecting to the network(AWTest)......
        Connected to the AP(AWTest)
        Getting ip address(AWTest)......
        Wifi connect ap : Success!
        开机连接如上😀
        Z Y 3 条回复 最后回复 回复 引用 分享 0
        • Referenced by  aldfaaa aldfaaa
          zjs0920 LV 1 @BedRock 最后由 编辑
            yi20416yi LV 3 @BedRock 最后由 编辑
            这个怎么解决呢?
              请问一下这是什么原因?
              S 1 条回复 最后回复 回复 引用 分享 0
                spr2023 LV 4 @yi20416yi 最后由 编辑
                @yi20416yi log提示你检查驱动,你要先确定内核配置文件里面WiFi相关的驱动和选项都选好了,WiFi驱动也没问题并且编译上了,还有那你设备树sdio引脚和WiFi regon什么的引脚之类的,再或者你WiFi驱动的固件文件是对的,嗯。。很多
