    eyesee-mpp编译报错,请问有大佬遇到过么
      mysteryli LV 7 最后由 编辑
      报错内容如下
      l@l-Default-string:~/action2-v851s/openwrt/package/allwinner/eyesee-mpp/middleware$ mm -B
      make openwrt_rootfs package/middleware/clean V=s
      ===There is tina environment.===
       Note: make is the shell functon in envsetup.sh.
      == action: openwrt_rootfs, action_args: package/middleware/clean V=s ==
      ========ACTION List: build_openwrt_rootfs package/middleware/clean V=s;========
      options :
      ==mkcmd.sh: build_openwrt_rootfs package/middleware/clean V=s==
      make: Entering directory '/home/l/action2-v851s/openwrt/openwrt'
      make[1]: Entering directory '/home/l/action2-v851s/openwrt/openwrt'
      CreateSoftLink  /home/l/action2-v851s/openwrt/openwrt/tmp link to  /home/l/action2-v851s/out/v851s/lizard/openwrt/tmp
      CreateSoftLink  /home/l/action2-v851s/openwrt/openwrt/staging_dir link to  /home/l/action2-v851s/out/v851s/lizard/openwrt/staging_dir
      make[2]: Entering directory '/home/l/action2-v851s/openwrt/openwrt'
      make[2]: Leaving directory '/home/l/action2-v851s/openwrt/openwrt'
      Check Vendor Package...
      CreateSoftLink  /home/l/action2-v851s/openwrt/openwrt/package/subpackage link to  /home/l/action2-v851s/openwrt/package
      end
      Can't locate FindBin.pm in @INC (you may need to install the FindBin module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at ./scripts/package-metadata.pl line 2.
      BEGIN failed--compilation aborted at ./scripts/package-metadata.pl line 2.
      Failed to build tmp/.config-package.in
      /home/l/action2-v851s/openwrt/openwrt/include/toplevel.mk:83: recipe for target 'prepare-tmpinfo' failed
      make[1]: *** [prepare-tmpinfo] Error 1
      make[1]: Leaving directory '/home/l/action2-v851s/openwrt/openwrt'
      /home/l/action2-v851s/openwrt/openwrt/include/toplevel.mk:236: recipe for target 'package/middleware/clean' failed
      make: *** [package/middleware/clean] Error 2
      make: Leaving directory '/home/l/action2-v851s/openwrt/openwrt'
      make openwrt_rootfs package/middleware/compile V=s
      == action: openwrt_rootfs, action_args: package/middleware/compile V=s ==
      ========ACTION List: build_openwrt_rootfs package/middleware/compile V=s;========
      options :
      ==mkcmd.sh: build_openwrt_rootfs package/middleware/compile V=s==
      end
      /home/l/action2-v851s/openwrt/openwrt/include/toplevel.mk:236: recipe for target 'package/middleware/compile' failed
      make: *** [package/middleware/compile] Error 2
