    xr829挂在驱动上了。晶振不振
    xr829
    6396
      别打了,我学 LV 5 最后由 编辑
      xr829,淘宝来的。两片都是这个问题,晶振不起振
      [   11.621863] [XRADIO] Driver Label:XR_V02.16.91 _HT40_01.33  Jul 20 2023 15:47:33
      [   11.645673] [XRADIO] Allocated hw_priv @ c1f36c80
      [   11.650980] [XRADIO_ERR] Access_file failed, path:/data/misc/wifi/xr_wifi.conf!
      [   11.674293] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.687359] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.699239] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   11.705038] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   11.710829] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   11.716636] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   11.716660] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   11.717756] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.717837] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [   11.750809] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   11.762582] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
      [   11.988591] [XRADIO] Detect SDIO card 1
      [   12.890959] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   12.904638] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   12.917047] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   12.923356] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   12.929660] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   12.935954] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   12.941721] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   12.953060] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   12.963394] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [   12.995799] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   14.033816] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   14.048221] sunxi-mmc sdc1: sdc set ios:clk 100000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   14.061304] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   14.068187] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   14.075003] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   14.081875] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
      [   14.095722] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   14.116765] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   14.135774] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [   14.165594] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   14.234594] [XRADIO] Remove SDIO card 1
      [   14.265578] [SBUS_ERR] sdio probe timeout!
      [   14.270161] [XRADIO_ERR] sbus_sdio_init failed
      难道这俩xr829都亡了吗😖 😖 😖 😖
        别打了,我学 LV 5 最后由 编辑
        @whycan 晕哥,这个是坏了么
          whycan晕哥 LV 9 @haolisheng 最后由 编辑
          @haolisheng
          是全新的吗?感觉可能没焊好。
          H 1 条回复 最后回复 回复 引用 分享 0
            别打了,我学 LV 5 @whycan 最后由 编辑
            感谢晕哥!!!!!!!!大佬指明方向
            重新画了板子,加长了qfn的焊盘,重新焊接了。qfn引脚不挂锡真是新手杀手。
            谢谢晕哥
              whycan晕哥 LV 9 @haolisheng 最后由 whycan 编辑
              @haolisheng
              先把引脚上锡,用烙铁刮干净,然后再焊,或者风枪吹,这样一般就不会虚焊,因为是同种金属黏性好。
                @whycan 受教了感谢。🐸🐸
