    柚木PI蜥蜴 V851S MPP sample rtsp 运行不了
    7566
      aw2022 LV 4 最后由 xiaowenge 编辑
      docker 最新编译出来的镜像。 rtsp 运行出错。 camerademo 运行是能正常获得bmp图片的。
      下面的rtsp 出错的日志。 大佬们帮忙看看。
      root@TinaLinux:/mnt/extsd# ./sample_rtsp -path sample_rtsp.conf
      I0101 02:00:18.289716  1123 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
      I0101 02:00:18.290946  1123 sample_rtsp.c:95]               <ParseCmdLine> sample virvi2venc path:[./sample_rtsp], arg number is [3]
      I0101 02:00:18.292547  1123 confparser.c:60]                <createConfParser> load conf file sample_rtsp.conf ok!
      I0101 02:00:18.293020  1123 sample_rtsp.c:292]              <loadSampleConfig> IspAndVeLinkage config: Enable=1, StreamChn=0
      Committed_AS:       4680 kB
      I0101 02:00:18.304916  1123 mpi_sys.c:840]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      modName : MPP-Platform
      tag   : V1.0 Release
      branch: v5-dev
      commit: 4eed413532ad87725895a8cb1ba75e22fc328233
      date  : 20170725
      author: jenkins
      iniparser: cannot open /etc/cedarx.conf
      iniparser: cannot open /vendor/etc/cedarx.conf
      I0101 02:00:18.308886  1123 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
      [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP600
      branch: libisp-dev
      commit: 14df8348718d093707641fea73eba7db962885f5
      date  : Thu Jul 14 15:40:38 2022 +0800
      I0101 02:00:18.309574  1123 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
      INFO   : cedarc <VeInitialize:1185>: *** ic_version = 0x1302000023010,
      I0101 02:00:18.319359  1123 hwdisplay.c:84]                 <hw_display_init>
      I0101 02:00:18.320045  1123 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
      I0101 02:00:18.320338  1123 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
      I0101 02:00:18.320592  1123 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:0
      I0101 02:00:18.328003  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
      I0101 02:00:18.328287  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 volume
      I0101 02:00:18.328445  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC2 volume
      I0101 02:00:18.328606  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCDRC
      I0101 02:00:18.328738  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCHPF
      I0101 02:00:18.328854  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DAC volume
      I0101 02:00:18.328964  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACDRC
      I0101 02:00:18.329076  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACHPF
      I0101 02:00:18.329187  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEIN
      I0101 02:00:18.329295  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
      I0101 02:00:18.329402  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
      I0101 02:00:18.329529  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT
      I0101 02:00:18.329643  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
      I0101 02:00:18.329804  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT volume
      I0101 02:00:18.329953  1123 alsa_interface.c:756]           <alsaOpenMixer> set playback vol_val to value: 27
      I0101 02:00:18.330078  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1
      I0101 02:00:18.330198  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
      I0101 02:00:18.330308  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
      I0101 02:00:18.330423  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2
      I0101 02:00:18.330556  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
      I0101 02:00:18.330674  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
      I0101 02:00:18.330785  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:SPK
      I0101 02:00:18.330892  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:digital volume
      I0101 02:00:18.331000  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0101 02:00:18.331110  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      E0101 02:00:18.331232  1123 alsa_interface.c:970]           <alsaMixerSetAudioCodecHubMode> aec_elem_audio_codec_hub_mode:tx hub mode-1
      E0101 02:00:18.331393  1123 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
      I0101 02:00:18.331582  1123 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:1
      I0101 02:00:18.332448  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:loopback debug
      I0101 02:00:18.332707  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0101 02:00:18.332862  1123 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      E0101 02:00:18.333029  1123 alsa_interface.c:993]           <alsaMixerSetDAudio0HubMode> aec_elem_daudio0_hub_mode:tx hub mode-1
      E0101 02:00:18.333201  1123 alsa_interface.c:1016]          <alsaMixerSetDAudio0LoopBackEn> aec_elem_daudio0_loopback_en:loopback debug-1
      E0101 02:00:18.333346  1123 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
      I0101 02:00:18.333523  1123 sample_rtsp.c:490]              <configMainStream> main vipp0 ve_online_en:1, dma_buf_num:2, venc ch0 OnlineEnable:1, OnlineShareBufNum:2
      I0101 02:00:18.333914  1123 sample_rtsp.c:517]              <configMainStream> main EncppSharpAttenCoefPer: 100%
      I0101 02:00:18.334065  1123 sample_rtsp.c:527]              <configMainStream> main vbvThreshSize: 147450, vbvBufSize: 933882
      [ISP]video device name is vin_video0
      [ISP]open video device[0], detect isp0 success!
      I0101 02:00:18.334538  1123 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 02:00:18.334841  1123 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[0] update width:1920(1920), height:1080(1088)
      [ISP]video0 fd[10] ve_online_en=1, dma_buf_num=2
      open /dev/sunxi_soc_info failed![ISP]open isp device[0] success!
      [ISP]get isp_ctx from /mnt/extsd/isp0_1920_1088_20_ctx_saved.bin success!!!
      [ISP]prefer isp config: [gc2053_mipi], 1920x1088, 20, 0, 0
      [ISP]find gc2053_mipi_1920_1088_20_0 [gc2053_mipi_isp600_20220511_164617_vlc4_day] isp config
      I0101 02:00:18.666341  1123 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb65d5d50]
      I0101 02:00:18.667813  1123 VideoEnc_Component.c:7042]      <VideoEncComponentInit> create VideoEnc threadId:0xb65b2d50
      I0101 02:00:18.668177  1123 VideoEnc_Component.c:2663]      <VideoEncSetChnAttr> vencChn[0] enable online!
      I0101 02:00:18.668368  1123 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[0] Comp StateIdle
      I0101 02:00:18.668592  1128 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 0, buf_num=2.
      I0101 02:00:18.668869  1130 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 02:00:18.669156  1130 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[0] Create VeType=96
      iniparser: cannot open /tmp/libcedarc_dynamic_log_level
      INFO   : cedarc <cdc_log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
      WARNING: cedarc <LogVersionInfo:44>:
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cedar Codec <<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   :
      branch: tina-v853-dev
      commit: ee230a47e5a2392ec315795121c2d112492fac1c
      date  : Fri Jul 22 10:37:50 2022 +0800
      author: wuguanjian
      change-id : I28fe0c31c718f097d61ad6bdbcb4cb5df0bd3575
      release_author : lichaopdc
      patch :
      I0101 02:00:18.688745  1123 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[0] set new framerate:20
      I0101 02:00:18.688983  1123 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[0] enable and set 2DFilter param
      I0101 02:00:18.689107  1123 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[0] enable and set 3DFilter param
      I0101 02:00:18.689203  1123 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[0] SuperFrm Mode:0, IfrmSize:1638400 bits, PfrmSize:546133 bits
      I0101 02:00:18.689319  1123 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
      I0101 02:00:18.689976  1123 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[0] Comp StateExecuting
      I0101 02:00:18.690235  1130 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 02:00:18.690552  1130 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[933882]bytes
      I0101 02:00:18.690751  1130 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[147450]bytes
      I0101 02:00:18.690897  1130 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 1536Kb, set encode vbv size 933888, frame length threshold 147450
      I0101 02:00:18.691076  1130 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[0], EncppEnable=1
      I0101 02:00:18.691218  1130 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
      I0101 02:00:18.691339  1130 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
      I0101 02:00:18.691465  1130 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=1, ShareBufNum=2, OnlineEnableFlag=1
      I0101 02:00:18.691585  1130 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
      [ISP_ERR]isp_stat_process_buffer, line: 268,AEWB: stats error, skipping buffer.
      [ISP_WARN]gc2053_mipi get sensor_temp failed: Invalid argument (22).
      ERROR  : ionAlloc <ion_alloc_palloc_base:349>: ION_IOC_ALLOC error , size = 933888
      [ISP_ERR]isp_sync_debug_info, line: 747,VIDIOC_VIN_ISP_GET_INFO error!
      [ISP]video device name is vin_video12
      [ISP]open video device[12], detect isp0 success!
      ERROR  : ionAlloc <ion_alloc_palloc_base:349>: ION_IOC_ALLOC error , size = 409600
      ERROR  : cedarc <BitStreamCreate:59>: pSbmBuf == NULL.
      ERROR  : cedarc <h264InitMemory:4440>: h264Context->pBSMamager == NULL
      ERROR  : cedarc <VencInit:744>: venc_init_fail
      E0101 02:00:19.355744  1130 VideoEnc_Component.c:2043]      <CedarvVideoEncInit> fatal error vencInit fail:6
      E0101 02:00:19.356111  1130 VideoEnc_Component.c:8025]      <ComponentThread> fatal error! vdeclib init fail[0xa008800c]
      E0101 02:00:19.356262  1130 mpi_venc.c:327]                 <VideoEncEventHandler> fatal error! venc state transition incorrect:a008800c.
      wlan0 ip:172.16.1.101
                                      *               AW RTSP LIB VERSION:                            *
                                      *               BUILD BY WHO:        *
                                      *               BUILD TIME:                                             *
         rtsp://172.16.1.101:8554/ch0
      I0101 02:00:19.357638  1132 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 02:00:19.359535  1132 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[933882]bytes
      I0101 02:00:19.359813  1132 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[147450]bytes
      I0101 02:00:19.360147  1132 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 1536Kb, set encode vbv size 933888, frame length threshold 147450
      I0101 02:00:19.360348  1132 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[0], EncppEnable=1
      I0101 02:00:19.360503  1132 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
      I0101 02:00:19.360629  1132 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
      I0101 02:00:19.360760  1132 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=1, ShareBufNum=2, OnlineEnableFlag=1
      I0101 02:00:19.360878  1132 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
      WARNING: cedarc <VencInit:692>: the state[1] is not idle when call init
      E0101 02:00:19.361673  1132 VideoEnc_Component.c:2043]      <CedarvVideoEncInit> fatal error vencInit fail:ffffffff
      I0101 02:00:19.362036  1132 VideoEnc_Component.c:2121]      <CedarvVideoEncInit> set Color2Grey [0], in Venchn[0]
      I0101 02:00:19.362245  1132 VideoEnc_Component.c:2128]      <CedarvVideoEncInit> vencChn[0] had init!
      E0101 02:00:19.362399  1132 VideoEnc_Component.c:4276]      <VideoEncExtraData> fatal error! vdeclib init fail[0xffffffff]
      E0101 02:00:19.362529  1132 sample_rtsp.c:1010]             <getVencStreamThread> fatal error! get spspps fail[0xffffffff]!
      open /dev/sunxi_soc_info failed![ISP]---------   LDCI Video12 Init OK   ---------
      [ISP]--------- LDCI Video12 Streamon OK ---------
      W0101 02:00:20.363203  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:21.363680  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:22.364056  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:23.364432  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      [ISP_ERR]isp_sync_debug_info, line: 747W0101 02:00:24.364974  1132 sample_rtsp.c:1216] <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:25.365367  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:26.365737  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:27.366095  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:28.366467  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:29.366849  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:30.367220  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 02:00:31.367596  1132 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
        mysteryli LV 7 最后由 编辑
        我的也是,我也试了VIRVI2VENC也不行
        vi_g2d可以
          WhycanService LV 8 @aw2022 最后由 编辑
          @aw2022 在 柚木PI蜥蜴 V851S MPP sample rtsp 运行不了 中说:
          缺少编码器的配置文件,需要复制一份到指定位置
            aw2022 LV 4 @WhycanService 最后由 q1215200171 编辑
            @whycanservice 源码里找到一份v851s_linux_cedarx.conf 复制到/etc/cedarx.conf 。 然后还是不行。 大佬们帮忙再看看什么问题。
            I0101 00:15:09.713781  1097 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
            I0101 00:15:09.715806  1097 sample_rtsp.c:95]               <ParseCmdLine> sample virvi2venc path:[./sample_rtsp], arg number is [3]
            I0101 00:15:09.718249  1097 confparser.c:60]                <createConfParser> load conf file sample_rtsp.conf ok!
            I0101 00:15:09.719619  1097 sample_rtsp.c:292]              <loadSampleConfig> IspAndVeLinkage config: Enable=1, StreamChn=0
            I0101 00:15:09.731293  1097 mpi_sys.c:840]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
            tag   : V1.0 Release
            branch: v5-dev
            date  : 20170725
            author: jenkins
            I0101 00:15:09.738094  1097 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
            IPCORE: ISP600
            branch: libisp-dev
            I0101 00:15:09.741012  1097 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
            I0101 00:15:09.751740  1097 hwdisplay.c:84]                 <hw_display_init>
            I0101 00:15:09.752451  1097 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
            I0101 00:15:09.752766  1097 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
            I0101 00:15:09.753585  1097 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:0
            I0101 00:15:09.761326  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
            I0101 00:15:09.762087  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 volume
            I0101 00:15:09.762819  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC2 volume
            I0101 00:15:09.763479  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCDRC
            I0101 00:15:09.763706  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCHPF
            I0101 00:15:09.764785  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DAC volume
            I0101 00:15:09.765682  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACDRC
            I0101 00:15:09.766839  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACHPF
            I0101 00:15:09.767515  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEIN
            I0101 00:15:09.768227  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
            I0101 00:15:09.769297  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
            I0101 00:15:09.769980  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT
            I0101 00:15:09.770208  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
            I0101 00:15:09.771391  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT volume
            I0101 00:15:09.772093  1097 alsa_interface.c:756]           <alsaOpenMixer> set playback vol_val to value: 27
            I0101 00:15:09.773187  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1
            I0101 00:15:09.773857  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
            I0101 00:15:09.774512  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
            I0101 00:15:09.775846  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2
            I0101 00:15:09.776958  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
            I0101 00:15:09.777679  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
            I0101 00:15:09.777884  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:SPK
            I0101 00:15:09.778563  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:digital volume
            I0101 00:15:09.779222  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
            I0101 00:15:09.780352  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
            E0101 00:15:09.781480  1097 alsa_interface.c:970]           <alsaMixerSetAudioCodecHubMode> aec_elem_audio_codec_hub_mode:tx hub mode-1
            E0101 00:15:09.782229  1097 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
            I0101 00:15:09.783065  1097 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:1
            I0101 00:15:09.785307  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:loopback debug
            I0101 00:15:09.786053  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
            I0101 00:15:09.786265  1097 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
            E0101 00:15:09.787438  1097 alsa_interface.c:993]           <alsaMixerSetDAudio0HubMode> aec_elem_daudio0_hub_mode:tx hub mode-1
            E0101 00:15:09.788214  1097 alsa_interface.c:1016]          <alsaMixerSetDAudio0LoopBackEn> aec_elem_daudio0_loopback_en:loopback debug-1
            E0101 00:15:09.789370  1097 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
            I0101 00:15:09.789681  1097 sample_rtsp.c:490]              <configMainStream> main vipp0 ve_online_en:1, dma_buf_num:2, venc ch0 OnlineEnable:1, OnlineShareBufNum:2
            I0101 00:15:09.789860  1097 sample_rtsp.c:517]              <configMainStream> main EncppSharpAttenCoefPer: 100%
            I0101 00:15:09.789999  1097 sample_rtsp.c:527]              <configMainStream> main vbvThreshSize: 147450, vbvBufSize: 933882
            I0101 00:15:09.791087  1097 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:09.793459  1097 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[0] update width:1920(1920), height:1080(1088)
            I0101 00:15:09.794153  1097 videoInputHw.c:957]             <videoInputHw_SetChnAttr> ViCh[0] LBC pix:0x3132434c, line_tar_bits[0]:9216, line_tar_bits[1]:13824
            I0101 00:15:09.796455  1097 videoInputHw.c:977]             <videoInputHw_SetChnAttr> bs_len:61440, frm_bit:11520
            I0101 00:15:10.143911  1097 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb68a7d50]
            I0101 00:15:10.146239  1097 VideoEnc_Component.c:7042]      <VideoEncComponentInit> create VideoEnc threadId:0xb6884d50
            I0101 00:15:10.147150  1097 VideoEnc_Component.c:2663]      <VideoEncSetChnAttr> vencChn[0] enable online!
            I0101 00:15:10.147872  1097 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[0] Comp StateIdle
            I0101 00:15:10.148190  1102 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 0, buf_num=2.
            I0101 00:15:10.149001  1104 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:10.149847  1104 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[0] Create VeType=265
            tag   :
            author: wuguanjian
            patch :
            I0101 00:15:10.170299  1097 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[0] set new framerate:20
            I0101 00:15:10.171366  1097 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[0] enable and set 2DFilter param
            I0101 00:15:10.172036  1097 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[0] enable and set 3DFilter param
            I0101 00:15:10.172186  1097 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[0] SuperFrm Mode:0, IfrmSize:1638400 bits, PfrmSize:546133 bits
            I0101 00:15:10.172312  1097 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
            I0101 00:15:10.172420  1097 sample_rtsp.c:638]              <configSubStream> vipp[4] crop en:1 X:0 Y:0 W:1888 H:1072
            I0101 00:15:10.172508  1097 sample_rtsp.c:651]              <configSubStream> sub EncppSharpAttenCoefPer: 33%
            I0101 00:15:10.172584  1097 sample_rtsp.c:661]              <configSubStream> sub vbvThreshSize: 24000, vbvBufSize: 152000
            [ISP]video device name is vin_video4
            [ISP]open video device[4], detect isp0 success!
            I0101 00:15:10.172958  1097 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:10.173230  1097 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[4] update width:640(640), height:360(368)
            I0101 00:15:10.173343  1097 videoInputHw.c:957]             <videoInputHw_SetChnAttr> ViCh[4] LBC pix:0x3132434c, line_tar_bits[0]:3072, line_tar_bits[1]:4608
            I0101 00:15:10.173697  1097 videoInputHw.c:977]             <videoInputHw_SetChnAttr> bs_len:20480, frm_bit:3840
            I0101 00:15:10.385952  1097 videoInputHw.c:1254]            <videoInputHw_SetCrop> vipp[4] set crop X:0, Y:0, Width:1888, Height:1072
            I0101 00:15:10.390404  1097 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb67bad50]
            I0101 00:15:10.392488  1097 VideoEnc_Component.c:7042]      <VideoEncComponentInit> create VideoEnc threadId:0xb6797d50
            I0101 00:15:10.392801  1097 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[1] Comp StateIdle
            I0101 00:15:10.393641  1105 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 4, buf_num=3.
            I0101 00:15:10.394459  1107 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:10.395545  1107 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[1] Create VeType=96
            open /dev/sunxi_soc_info failed!WARNING: cedarc <LogVersionInfo:44>:
            tag   :
            author: wuguanjian
            patch :
            I0101 00:15:10.408120  1097 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[1] set new framerate:20
            I0101 00:15:10.408362  1097 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[1] enable and set 2DFilter param
            I0101 00:15:10.408479  1097 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[1] enable and set 3DFilter param
            I0101 00:15:10.408581  1097 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[1] SuperFrm Mode:0, IfrmSize:266666 bits, PfrmSize:88888 bits
            I0101 00:15:10.408691  1097 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
            I0101 00:15:10.408804  1097 sample_rtsp.c:772]              <configSubLapseStream> subLapse EncppSharpAttenCoefPer: 33%
            I0101 00:15:10.408902  1097 sample_rtsp.c:782]              <configSubLapseStream> SubLapse vbvThreshSize: 24000, vbvBufSize: 152000
            I0101 00:15:10.409241  1097 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb6774d50]
            I0101 00:15:10.411029  1097 VideoEnc_Component.c:7042]      <VideoEncComponentInit> create VideoEnc threadId:0xb6751d50
            I0101 00:15:10.411918  1097 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[2] Comp StateIdle
            I0101 00:15:10.413191  1109 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:10.414276  1109 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[2] Create VeType=96
            tag   :
            author: wuguanjian
            patch :
            I0101 00:15:10.426941  1097 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[2] set new framerate:20
            I0101 00:15:10.427180  1097 sample_rtsp.c:1464]             <main> Lapse set TimeLapse 1000000 us
            I0101 00:15:10.427319  1097 VideoEnc_Component.c:4036]      <VideoEncSetTimeLapse> SetTimeLapse: captureIntervalUs=1000000.000000, dstFrameIntervalUs=50000.000000, recType=1
            I0101 00:15:10.427424  1097 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[2] enable and set 2DFilter param
            I0101 00:15:10.427514  1097 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[2] enable and set 3DFilter param
            I0101 00:15:10.427598  1097 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[2] SuperFrm Mode:0, IfrmSize:266666 bits, PfrmSize:88888 bits
            I0101 00:15:10.427703  1097 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
            I0101 00:15:10.428441  1097 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[0] Comp StateExecuting
            I0101 00:15:10.429272  1104 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:10.429630  1104 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[933882]bytes
            I0101 00:15:10.429757  1104 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[147450]bytes
            I0101 00:15:10.429880  1104 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 1536Kb, set encode vbv size 933888, frame length threshold 147450
            I0101 00:15:10.429987  1104 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[0], EncppEnable=1
            I0101 00:15:10.430076  1104 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
            I0101 00:15:10.430152  1104 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
            I0101 00:15:10.430231  1104 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=1, ShareBufNum=2, OnlineEnableFlag=1
            I0101 00:15:10.430306  1104 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
            ERROR  : ionAlloc <ion_alloc_palloc_base:349>: ION_IOC_ALLOC error , size = 3064768
            ERROR  : cedarc <h265InitMemRecRefE230:4002>: palloc failed for recRefBufLbcVir, size = 3064768
            ERROR  : cedarc <h265InitMemory:4171>: EncAdapterMemPalloc for rec/ref fail
            I0101 00:15:10.942006  1105 videoInputHw.c:4882]            <VideoInputHw_CapThread> vipp[4] drop 10 frames done!
            E0101 00:15:10.943643  1104 VideoEnc_Component.c:2043]      <CedarvVideoEncInit> fatal error vencInit fail:6
            E0101 00:15:10.945865  1104 VideoEnc_Component.c:8025]      <ComponentThread> fatal error! vdeclib init fail[0xa008800c]
            E0101 00:15:10.946162  1104 mpi_venc.c:327]                 <VideoEncEventHandler> fatal error! venc state transition incorrect:a008800c.
            wlan0 ip:192.168.137.213
                                            *               BUILD BY WHO:        *
                                            *               BUILD TIME:                                             *
               rtsp://192.168.137.213:8554/ch0
            I0101 00:15:10.949045  1097 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[1] Comp StateExecuting
            I0101 00:15:10.949927  1107 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:10.954779  1111 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:10.958605  1107 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[152000]bytes
            I0101 00:15:10.960062  1107 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[24000]bytes
            I0101 00:15:10.961228  1106 VideoEnc_Component.c:6308]      <VideoEncEmptyThisBuffer> send frame when venc state[0x2] is not executing
            I0101 00:15:10.961996  1106 VideoEnc_Component.c:6383]      <VideoEncEmptyThisBuffer> VencChn[1]: first video frame pts[906735953]us,tm1[906736917]us, vSize[640x368], frmId[1,12]
            I0101 00:15:10.962755  1107 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
            I0101 00:15:10.963510  1111 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[933882]bytes
            I0101 00:15:10.965688  1111 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[147450]bytes
            I0101 00:15:10.964224  1107 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[1], EncppEnable=1
            I0101 00:15:10.967565  1107 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
            I0101 00:15:10.966505  1111 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 1536Kb, set encode vbv size 933888, frame length threshold 147450
            I0101 00:15:10.968440  1107 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
            I0101 00:15:10.971053  1107 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=0, ShareBufNum=0, OnlineEnableFlag=0
            I0101 00:15:10.970192  1111 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[0], EncppEnable=1
            I0101 00:15:10.972517  1111 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
            I0101 00:15:10.973506  1111 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
            I0101 00:15:10.974158  1111 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=1, ShareBufNum=2, OnlineEnableFlag=1
            I0101 00:15:10.971701  1107 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
            I0101 00:15:10.975632  1111 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
            E0101 00:15:10.985825  1111 VideoEnc_Component.c:2043]      <CedarvVideoEncInit> fatal error vencInit fail:ffffffff
            I0101 00:15:10.986878  1111 VideoEnc_Component.c:2121]      <CedarvVideoEncInit> set Color2Grey [0], in Venchn[0]
            I0101 00:15:10.987637  1111 VideoEnc_Component.c:2128]      <CedarvVideoEncInit> vencChn[0] had init!
            E0101 00:15:10.988302  1111 VideoEnc_Component.c:4276]      <VideoEncExtraData> fatal error! vdeclib init fail[0xffffffff]
            E0101 00:15:10.989163  1111 sample_rtsp.c:1018]             <getVencStreamThread> fatal error! get spspps fail[0xffffffff]!
            I0101 00:15:10.990999  1107 VideoEnc_Component.c:2059]      <CedarvVideoEncInit> Venc Init success
            I0101 00:15:10.991649  1107 VideoEnc_Component.c:2068]      <CedarvVideoEncInit> Venc SetCallbacks success
            I0101 00:15:11.001115  1107 VideoEnc_Component.c:2078]      <CedarvVideoEncInit> Venc Start success
            I0101 00:15:11.001837  1107 VideoEnc_Component.c:2121]      <CedarvVideoEncInit> set Color2Grey [0], in Venchn[1]
            I0101 00:15:11.002573  1107 VideoEnc_Component.c:2128]      <CedarvVideoEncInit> vencChn[1] had init!
            I0101 00:15:11.003308  1107 VideoEnc_Component.c:8042]      <ComponentThread> VencChn[1]: idle/pause[0x2]->executing ...
                                            *               BUILD BY WHO:        *
                                            *               BUILD TIME:                                             *
               rtsp://192.168.137.213:8554/ch1
            I0101 00:15:11.005987  1097 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[2] Comp StateExecuting
            I0101 00:15:11.006940  1109 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
            I0101 00:15:11.007310  1109 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[152000]bytes
            I0101 00:15:11.007463  1109 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[24000]bytes
            I0101 00:15:11.007565  1109 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
            I0101 00:15:11.007672  1109 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[2], EncppEnable=1
            I0101 00:15:11.007759  1109 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
            I0101 00:15:11.007836  1109 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
            I0101 00:15:11.007920  1109 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=0, ShareBufNum=0, OnlineEnableFlag=0
            I0101 00:15:11.008016  1109 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
            W0101 00:15:11.990828  1111 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
            W0101 00:15:12.015697  1113 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
            I0101 00:15:12.962310  1106 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-0] has no frame input?
            [ISP_ERR]video_wait_buffer, line: 488,video4 select timeout!
            W0101 00:15:12.962655  1105 videoInputHw.c:4945]            <VideoInputHw_CapThread> vipp[4] get frame fail! frameBufId[1] is not release
            W0101 00:15:12.962785  1105 videoInputHw.c:4949]            <VideoInputHw_CapThread> vipp[4] get frame fail! [1]frames are not release
            W0101 00:15:12.991292  1111 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
            I0101 00:15:13.006042  1108 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-1] has no frame input?
            W0101 00:15:13.016035  1113 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
            W0101 00:15:13.991665  1111 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
            W0101 00:15:14.016371  1113 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
            I0101 00:15:14.962673  1106 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-0] has no frame input?
            W0101 00:15:14.963650  1105 videoInputHw.c:4945]            <VideoInputHw_CapThread> vipp[4] get frame fail! frameBufId[1] is not release
            W0101 00:15:14.963823  1105 videoInputHw.c:4949]            <VideoInputHw_CapThread> vipp[4] get frame fail! [1]frames are not release
            W0101 00:15:14.992041  1111 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
            I0101 00:15:15.006379  1108 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-1] has no frame input?
            W0101 00:15:15.016720  1113 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
            W0101 00:15:15.992461  1111 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
            W0101 00:15:16.017067  1113 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
            I0101 00:15:16.963031  1106 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-0] has no frame input?
            W0101 00:15:16.965868  1105 videoInputHw.c:4945]            <VideoInputHw_CapThread> vipp[4] get frame fail! frameBufId[1] is not release
            W0101 00:15:16.966048  1105 videoInputHw.c:4949]            <VideoInputHw_CapThread> vipp[4] get frame fail! [1]frames are not release
            W0101 00:15:16.992809  1111 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
            I0101 00:15:17.006702  1108 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-1] has no frame input?
            W0101 00:15:17.017421  1113 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
            W0101 00:15:17.993152  1111 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
            W0101 00:15:18.017738  1113 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
              @aw2022 运行之前联网了吗?
                aw2022 LV 4 @WhycanService 最后由 编辑
                @whycanservice 联网了的。
                  WhycanService LV 8 最后由 编辑
                  怀疑open版本sdk缺少组件,之后会跟进一下
                  • Referenced by  kanken6174 kanken6174
