    将网卡的MAC保存i2c的EEPROM
      z LV 3 最后由 whycan 编辑
      T507的板子,在sunxi-gamc.c文件中,网卡获取到随机的mac地址后,我想写入到i2c挂载的eeprom中,一直有问题,显示写入和读取成功,但是读出来一直是FF。
      这个是驱动里面操作读写的地方。
      static void geth_check_addr(struct net_device *ndev, unsigned char *mac)
          int i;
          int ret;
          char *p = mac;
          struct i2c_adapter *adapter = NULL;
          struct i2c_client client;
          u8 write_data[ETH_ALEN];
          u8 read_data[ETH_ALEN];
          struct i2c_msg msgs[2];  // 修改为两个I2C消息
          if (!is_valid_ether_addr(ndev->dev_addr)) {
              for (i = 0; i < ETH_ALEN; i++, p++) {
                  ndev->dev_addr[i] = simple_strtoul(p, &p, 16);
                  random_ether_addr(ndev->dev_addr);
                  printk("%s: Use random MAC address\n", ndev->name);
                  adapter = i2c_get_adapter(0);
                  if (!adapter) {
                      pr_err("Failed to get I2C adapter\n");
                      return;
                  /* 设置 i2c 设备地址和组件信息 */
                  client.addr = 0x0050;
                  client.adapter = adapter;
                  client.flags = 0;
                  //.driver = NULL,
                  client.dev.platform_data = NULL;
                  /* 将 MAC 地址数据写入 I2C 设备 */
                  memcpy(write_data, ndev->dev_addr, ETH_ALEN);
                  msgs[0].addr = client.addr;
                  msgs[0].flags = 0;
                  msgs[0].len = ETH_ALEN;
                  msgs[0].buf = write_data;
                  ret = i2c_transfer(client.adapter, msgs, 1);
                  if (ret != 1) {
                      pr_err("Failed to write MAC address to I2C device\n");
                  } else {
                      printk("Succeeded to write MAC address to I2C device\n");
      				print_mac_address(write_data);
          			printk("\n");
                  /* 从 I2C 设备读取 MAC 地址数据 */
                  msgs[1].addr = client.addr;
                  msgs[1].flags = I2C_M_RD;
                  msgs[1].len = ETH_ALEN;
                  msgs[1].buf = read_data;
                  ret = i2c_transfer(client.adapter, msgs + 1, 1);
                  if (ret != 1) {
                      pr_err("Failed to read MAC address from I2C device\n");
                  } else {
                      printk("Succeeded to read MAC address from I2C device\n");
                  	print_mac_address(read_data);
          if (adapter)
              i2c_put_adapter(adapter);
      日志显示的读写一直不一致
      这个问题一直没有解决思路和办法,想请教一下✍
        建议先用 i2c-utils测试,i2cset, i2cset命令通过 /dev/i2c-X 测试。
