    V583S MPP UVC摄像头存储成mp4
      J_Biao LV 5 最后由 编辑
      有没有哪位大佬有写过MPP模块的USB摄像头的采集、显示并存储成MP4的代码
        WhycanService LV 8 最后由 编辑
        //#define LOG_NDEBUG 0
        #define LOG_TAG "sample_uvc2vdec_vo"
        #include <utils/plat_log.h>
        #include <errno.h>
        #include <stdlib.h>
        #include <string.h>
        #include <unistd.h>
        #include <fcntl.h>
        #include <signal.h>
        #include <time.h>
        #include <confparser.h>
        #include <mpi_uvc.h>
        #include <mpi_vdec.h>
        #include <mpi_vo.h>
        #include "vo/hwdisplay.h"
        #include "sample_uvc2vdec_vo.h"
        #include "sample_uvc2vdec_vo_config.h"
        static SampleUvc2VdecVoContext *gpSampleUvc2VdecVoContext = NULL;
        int initSampleUvc2VdecVoContext(SampleUvc2VdecVoContext *pContext)
            memset(pContext, 0, sizeof *pContext);
            pContext->mUILayer = HLAY(2, 0);
            pContext->mVoLayer = MM_INVALID_LAYER;
            pContext->mVOChn = MM_INVALID_CHN;
            pContext->mSubVoLayer = MM_INVALID_LAYER;
            pContext->mSubVOChn = MM_INVALID_CHN;
            cdx_sem_init(&pContext->mSemExit, 0);
            int ret = pthread_mutex_init(&pContext->mFrameLock, NULL);
        	if (ret!=0)
                aloge("fatal error! pthread mutex init fail!");
            int i;
            for(i=0; i< MAX_FRAMEPAIR_ARRAY_SIZE; i++)
                pContext->mDoubleFrameArray[i].mMainFrame.mId = -1;
                pContext->mDoubleFrameArray[i].mSubFrame.mId = -1;
        int destroySampleUvc2VdecVoContext(SampleUvc2VdecVoContext *pContext)
            cdx_sem_deinit(&pContext->mSemExit);
            pthread_mutex_destroy(&pContext->mFrameLock);
        static int ParseCmdLine(int argc, char **argv, SampleUvc2VdecVoCmdLineParam *pCmdLinePara)
            //alogd("sample_region input path is : %s", argv[0]);
            int ret = 0;
            int i = 1;
            memset(pCmdLinePara, 0, sizeof *pCmdLinePara);
            while(i < argc)
                if(!strcmp(argv[i], "-path"))
                    if((++i) >= argc)
                        aloge("fatal error!");
                        ret = -1;
                        break;
                    if(strlen(argv[i]) >= MAX_FILE_PATH_SIZE)
                    strncpy(pCmdLinePara->mConfigFilePath, argv[i], strlen(argv[i]));
                    pCmdLinePara->mConfigFilePath[strlen(argv[i])] = '\0';
                else if(!strcmp(argv[i], "-h"))
                     printf("CmdLine param example:\n"
                        "\t run -path /home/sample_uvc2vo.conf\n");
                     ret = 1;
                     break;
                    printf("CmdLine param example:\n"                "\t run -path /home/sample_uvc2vo.conf\n");
                ++i;
            return ret;
        static ERRORTYPE LoadSampleUvc2VdecVoConfig(SampleUvc2VdecVoConfig *pConfig, const char *conf_path)
            int ret = 0;
            char *ptr = NULL;
            if(!conf_path)
                alogd("user not set config file. use default test parameter!");
                strcpy(pConfig->mDevName, (void *)"/dev/video0");
                pConfig->mPicFormat = UVC_MJPEG;
                pConfig->mCaptureVideoBufCnt = 5;
                pConfig->mCaptureWidth = 1280;
                pConfig->mCaptureHeight = 720;
                pConfig->mCaptureFrameRate = 30;
                pConfig->mbDecodeSubOutEnable = FALSE;
                pConfig->mDecodeSubOutWidthScalePower = 0;
                pConfig->mDecodeSubOutHeightScalePower = 0;
                pConfig->mDisplayMainX = 0;
                pConfig->mDisplayMainY = 0;
                pConfig->mDisplayMainWidth = 320;
                pConfig->mDisplayMainHeight = 240;
                pConfig->mDisplaySubX = 320;
                pConfig->mDisplaySubY = 0;
                pConfig->mDisplaySubWidth = 320;
                pConfig->mDisplaySubHeight = 240;
                pConfig->mTestFrameCount = 0;
                CONFPARSER_S stConfParser;
                ret = createConfParser(conf_path, &stConfParser);
                if(ret < 0)
                    aloge("load conf fail!");
                    return FAILURE;
                memset(pConfig, 0, sizeof *pConfig);
                ptr = (char *)GetConfParaString(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DEV_NAME, NULL);
                if(ptr)
                    strcpy(pConfig->mDevName, ptr);
                    aloge("fatal error! the uvc dev name is error!");
                    return FAILURE;
                char* pStrPixelFormat = (char *)GetConfParaString(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_PIC_FORMAT, NULL);
                if(!strcmp(pStrPixelFormat, "UVC_MJPEG"))
                else if(!strcmp(pStrPixelFormat, "UVC_H264"))
                    pConfig->mPicFormat = UVC_H264;
                else if(!strcmp(pStrPixelFormat, "UVC_YUY2"))
                    pConfig->mPicFormat = UVC_YUY2;
                    aloge("fatal error! conf file pic_format is [%s]?", pStrPixelFormat);
                pConfig->mCaptureVideoBufCnt = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_CAPTURE_VIDEOBUFCNT, 0);
                pConfig->mCaptureWidth = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_CAPTURE_WIDTH, 640);
                pConfig->mCaptureHeight = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_CAPTURE_HEIGHT, 480);
                pConfig->mCaptureFrameRate = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_CAPTURE_FRAMERATE, 0);
                pConfig->mbDecodeSubOutEnable = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DECODE_SUB_OUT_ENABLE, 0);
                pConfig->mDecodeSubOutWidthScalePower = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DECODE_SUB_OUT_WIDTH_SCALE_POWER, 0);
                pConfig->mDecodeSubOutHeightScalePower = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DECODE_SUB_OUT_HEIGHT_SCALE_POWER, 0);
                pConfig->mDisplayMainX = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DISPLAY_MAIN_X, 0);
                pConfig->mDisplayMainY = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DISPLAY_MAIN_Y, 0);
                pConfig->mDisplayMainWidth = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DISPLAY_MAIN_WIDTH, 0);
                pConfig->mDisplayMainHeight = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DISPLAY_MAIN_HEIGHT, 0);
                pConfig->mDisplaySubX = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DISPLAY_SUB_X, 0);
                pConfig->mDisplaySubY = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DISPLAY_SUB_Y, 0);
                pConfig->mDisplaySubWidth = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DISPLAY_SUB_WIDTH, 0);
                pConfig->mDisplaySubHeight = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_DISPLAY_SUB_HEIGHT, 0);
                pConfig->mTestFrameCount = GetConfParaInt(&stConfParser, SAMPLE_UVC2VDEC_VO_KEY_TEST_FRAME_COUNT, 0);
                destroyConfParser(&stConfParser);
            return SUCCESS;
         * @return suffix of array, if not find, return -1.
        int FindFrameIdInArray(SampleUvc2VdecVoContext *pContext, unsigned int nFrameId)
            int suffix = -1;
            int matchNum = 0;
            int i;
            for(i=0; i<MAX_FRAMEPAIR_ARRAY_SIZE; i++)
                if(nFrameId == pContext->mDoubleFrameArray[i].mMainFrame.mId)
                    if(0 == matchNum)
                        suffix = i;
                        aloge("fatal error! already match num[%d], current suffix[%d], id[%d]", matchNum, i, nFrameId);
                    matchNum++;
            return suffix;
        static ERRORTYPE SampleUvc2VdecVo_VOCallbackWrapper(void *cookie, MPP_CHN_S *pChn, MPP_EVENT_TYPE event, void *pEventData)
            ERRORTYPE ret = SUCCESS;
            SampleUvc2VdecVoContext *pContext = (SampleUvc2VdecVoContext*)cookie;
            if(MOD_ID_VOU == pChn->mModId)
                int bMainFrameFlag = 0;
                if(pChn->mDevId == pContext->mVoLayer && pChn->mChnId == pContext->mVOChn)
                    bMainFrameFlag = 1;
                    if(pContext->mConfigParam.mbDecodeSubOutEnable)
                        if(pChn->mDevId == pContext->mSubVoLayer && pChn->mChnId == pContext->mSubVOChn)
                            bMainFrameFlag = 0;
                            aloge("fatal error! VO layerId[%d]chnId[%d] is invalid! main/sub frame all wrong!", pChn->mDevId, pChn->mChnId);
                        aloge("fatal error! VO layerId[%d]!=[%d], chnId[%d]!=[%d]", pChn->mDevId, pContext->mVoLayer, pChn->mChnId, pContext->mVOChn);
                switch(event)
                    case MPP_EVENT_RELEASE_VIDEO_BUFFER:
                        VIDEO_FRAME_INFO_S *pVideoFrameInfo = (VIDEO_FRAME_INFO_S*)pEventData;
                        pthread_mutex_lock(&pContext->mFrameLock);
                        VdecDoubleFrameInfo *pDbFramePair = NULL;
                        int suffix = FindFrameIdInArray(pContext, pVideoFrameInfo->mId);
                        if(suffix >= 0)
                            pDbFramePair = &pContext->mDoubleFrameArray[suffix];
                            aloge("fatal error! why not find frameId[%d]?", pVideoFrameInfo->mId);
                        if(bMainFrameFlag)
                            pDbFramePair->mMainRefCnt--;
                            if(pDbFramePair->mMainRefCnt < 0)
                                aloge("fatal error! mainRefCnt[%d] wrong!", pDbFramePair->mMainRefCnt);
                            pDbFramePair->mSubRefCnt--;
                            if(pDbFramePair->mSubRefCnt < 0)
                                aloge("fatal error! subRefCnt[%d] wrong!", pDbFramePair->mSubRefCnt);
                        if(0 == pDbFramePair->mMainRefCnt && 0 == pDbFramePair->mSubRefCnt)
                            ret = AW_MPI_VDEC_ReleaseDoubleImage(pContext->mVdecChn, &pDbFramePair->mMainFrame, &pDbFramePair->mSubFrame);
                            if(SUCCESS == ret)
                                pContext->mHoldFrameNum--;
                                if(pContext->mHoldFrameNum < 0)
                                    aloge("fatal error! holdframe num[%d] < 0, check code!", pContext->mHoldFrameNum);
                                aloge("fatal error! why release frame to vdec fail[0x%x]?", ret);
                        pthread_mutex_unlock(&pContext->mFrameLock);
                        break;
                    case MPP_EVENT_SET_VIDEO_SIZE:
                        SIZE_S *pDisplaySize = (SIZE_S*)pEventData;
                        alogd("volayer[%d][%d] report video display size[%dx%d]", pChn->mDevId, pChn->mChnId, pDisplaySize->Width, pDisplaySize->Height);
                        break;
                    case MPP_EVENT_RENDERING_START:
                        alogd("volayer[%d][%d] report rendering start", pChn->mDevId, pChn->mChnId);
                        break;
                    default:
                        //postEventFromNative(this, event, 0, 0, pEventData);
                        aloge("fatal error! unknown event[0x%x] from channel[0x%x][0x%x][0x%x]!", event, pChn->mModId, pChn->mDevId, pChn->mChnId);
                        ret = ERR_VO_ILLEGAL_PARAM;
                        break;
                aloge("fatal error! why modId[0x%x]?", pChn->mModId);
                ret = FAILURE;
            return ret;
        void handle_exit(int signo)
            alogd("user want to exit!");
            if(gpSampleUvc2VdecVoContext != NULL)
                cdx_sem_up(&gpSampleUvc2VdecVoContext->mSemExit);
        int main(int argc, char **argv)
            int result = 0;
            SampleUvc2VdecVoContext *pContext = (SampleUvc2VdecVoContext*)malloc(sizeof(SampleUvc2VdecVoContext));
            initSampleUvc2VdecVoContext(pContext);
            gpSampleUvc2VdecVoContext = pContext;
            if(ParseCmdLine(argc, argv, &pContext->mCmdLineParam) != 0)
                result = -1;
                goto _exit;
            char *pConfigFilePath = NULL;
            if(strlen(pContext->mCmdLineParam.mConfigFilePath) > 0)
                pConfigFilePath = pContext->mCmdLineParam.mConfigFilePath;
            if(LoadSampleUvc2VdecVoConfig(&pContext->mConfigParam, pConfigFilePath) != SUCCESS)
                aloge("fatal error! no config file or parse conf file fail");
                result = -1;
                goto _exit;
            if (signal(SIGINT, handle_exit) == SIG_ERR)
                perror("error:can't catch SIGSEGV");
            memset(&pContext->mSysconf, 0, sizeof(MPP_SYS_CONF_S));
            pContext->mSysconf.nAlignWidth = 32;
            AW_MPI_SYS_SetConf(&pContext->mSysconf);
            AW_MPI_SYS_Init();
            AW_MPI_VDEC_SetVEFreq(MM_INVALID_CHN, 648);
            ERRORTYPE eRet = AW_MPI_UVC_CreateDevice(pContext->mConfigParam.mDevName);
            if(eRet != SUCCESS)
                aloge("error: the %s UVC device can not create!", pContext->mConfigParam.mDevName);
            UVC_ATTR_S attr;
            memset(&attr, 0, sizeof attr);
            attr.mPixelformat = pContext->mConfigParam.mPicFormat;
            attr.mUvcVideo_BufCnt = pContext->mConfigParam.mCaptureVideoBufCnt;
            attr.mUvcVideo_Width = pContext->mConfigParam.mCaptureWidth;
            attr.mUvcVideo_Height = pContext->mConfigParam.mCaptureHeight;
            attr.mUvcVideo_Fps = pContext->mConfigParam.mCaptureFrameRate;
            eRet = AW_MPI_UVC_SetDeviceAttr(pContext->mConfigParam.mDevName, &attr);
            if(eRet != SUCCESS)
                aloge("error: the %s UVC can not set device attr", pContext->mConfigParam.mDevName);
            eRet = AW_MPI_UVC_GetDeviceAttr(pContext->mConfigParam.mDevName, &attr);
            if(eRet != SUCCESS)
                aloge("error: the %UVC can not get device attr", pContext->mConfigParam.mDevName);
            pContext->mUvcChn = 0;
            eRet = AW_MPI_UVC_CreateVirChn(pContext->mConfigParam.mDevName, pContext->mUvcChn);
            if(eRet != SUCCESS)
                aloge("error: the %s UVC can not create virchannel[%d]", pContext->mConfigParam.mDevName, pContext->mUvcChn);
            pContext->mVdecChn = 0;
            VDEC_CHN_ATTR_S VdecChnAttr;
            memset(&VdecChnAttr, 0, sizeof VdecChnAttr);
            VdecChnAttr.mType = PT_MJPEG;
            VdecChnAttr.mPicWidth = 0;
            VdecChnAttr.mPicHeight = 0;
            VdecChnAttr.mInitRotation = ROTATE_NONE;
            VdecChnAttr.mOutputPixelFormat = MM_PIXEL_FORMAT_YVU_SEMIPLANAR_420;
            VdecChnAttr.mSubPicEnable = pContext->mConfigParam.mbDecodeSubOutEnable;
            VdecChnAttr.mSubPicWidthRatio = pContext->mConfigParam.mDecodeSubOutWidthScalePower;
            VdecChnAttr.mSubPicHeightRatio = pContext->mConfigParam.mDecodeSubOutHeightScalePower;
            VdecChnAttr.mSubOutputPixelFormat = MM_PIXEL_FORMAT_YVU_SEMIPLANAR_420;
            VdecChnAttr.mVdecVideoAttr.mMode = VIDEO_MODE_FRAME;
            VdecChnAttr.mVdecVideoAttr.mSupportBFrame = 1;
            eRet = AW_MPI_VDEC_CreateChn(pContext->mVdecChn, &VdecChnAttr);
            if(eRet != SUCCESS)
                aloge("fatal error: the %s uvc can not create vdec chn[%s]", pContext->mConfigParam.mDevName, pContext->mVdecChn);
            pContext->mVoDev = 0;
            AW_MPI_VO_Enable(pContext->mVoDev);
            AW_MPI_VO_AddOutsideVideoLayer(pContext->mUILayer);
            AW_MPI_VO_CloseVideoLayer(pContext->mUILayer);
            VO_PUB_ATTR_S stPubAttr;
            memset(&stPubAttr, 0, sizeof(VO_PUB_ATTR_S));
            AW_MPI_VO_GetPubAttr(pContext->mVoDev, &stPubAttr);
            stPubAttr.enIntfType = VO_INTF_LCD;
            stPubAttr.enIntfSync = VO_OUTPUT_NTSC;
            AW_MPI_VO_SetPubAttr(pContext->mVoDev, &stPubAttr);
            int hlay0 = 0;
            while(hlay0 < VO_MAX_LAYER_NUM)
                if(SUCCESS == AW_MPI_VO_EnableVideoLayer(hlay0))
                    break;
                hlay0+=4;
            if(hlay0 >= VO_MAX_LAYER_NUM)
                aloge("error: enable video layer failed");
            pContext->mVoLayer = hlay0;
            AW_MPI_VO_GetVideoLayerAttr(pContext->mVoLayer, &pContext->mLayerAttr);
            pContext->mLayerAttr.stDispRect.X = pContext->mConfigParam.mDisplayMainX;
            pContext->mLayerAttr.stDispRect.Y = pContext->mConfigParam.mDisplayMainY;
            pContext->mLayerAttr.stDispRect.Width = pContext->mConfigParam.mDisplayMainWidth;
            pContext->mLayerAttr.stDispRect.Height = pContext->mConfigParam.mDisplayMainHeight;
            AW_MPI_VO_SetVideoLayerAttr(pContext->mVoLayer, &pContext->mLayerAttr);
            BOOL bSuccessFlag = FALSE;
            pContext->mVOChn = 0;
            while(pContext->mVOChn < VO_MAX_CHN_NUM)
                eRet = AW_MPI_VO_CreateChn(pContext->mVoLayer, pContext->mVOChn);
                if(SUCCESS == eRet)
                    bSuccessFlag = TRUE;
                    break;
                else if(ERR_VO_CHN_NOT_DISABLE == eRet)
                    alogd("vo channel[%d] is exist, find next", pContext->mVOChn);
                    pContext->mVOChn++;
                    aloge("error:create vo channel[%d] ret[0x%x]", pContext->mVOChn, eRet);
                    pContext->mVOChn++;
            if(!bSuccessFlag)
                aloge("fatal error: create vo channel failed");
            MPPCallbackInfo cbInfo;
            cbInfo.cookie = (void *)pContext;
            cbInfo.callback = (MPPCallbackFuncType)&SampleUvc2VdecVo_VOCallbackWrapper;
            AW_MPI_VO_RegisterCallback(pContext->mVoLayer, pContext->mVOChn, &cbInfo);
            AW_MPI_VO_SetChnDispBufNum(pContext->mVoLayer, pContext->mVOChn, 2);
                int hlay0 = 0;
                        break;
                    hlay0+=4;
                pContext->mSubVoLayer = hlay0;
                AW_MPI_VO_GetVideoLayerAttr(pContext->mSubVoLayer, &pContext->mSubLayerAttr);
                pContext->mSubLayerAttr.stDispRect.X = pContext->mConfigParam.mDisplaySubX;
                pContext->mSubLayerAttr.stDispRect.Y = pContext->mConfigParam.mDisplaySubY;
                pContext->mSubLayerAttr.stDispRect.Width = pContext->mConfigParam.mDisplaySubWidth;
                pContext->mSubLayerAttr.stDispRect.Height = pContext->mConfigParam.mDisplaySubHeight;
                AW_MPI_VO_SetVideoLayerAttr(pContext->mSubVoLayer, &pContext->mSubLayerAttr);
                pContext->mSubVOChn = 0;
                while(pContext->mSubVOChn < VO_MAX_CHN_NUM)
                    eRet = AW_MPI_VO_CreateChn(pContext->mSubVoLayer, pContext->mSubVOChn);
                    if(SUCCESS == eRet)
                        break;
                        alogd("vo channel[%d] is exist, find next", pContext->mSubVOChn);
                        pContext->mSubVOChn++;
                        aloge("error:create vo channel[%d] ret[0x%x]", pContext->mSubVOChn, eRet);
                if(!bSuccessFlag)
                AW_MPI_VO_RegisterCallback(pContext->mSubVoLayer, pContext->mSubVOChn, &cbInfo);
                AW_MPI_VO_SetChnDispBufNum(pContext->mSubVoLayer, pContext->mSubVOChn, 2);
            MPP_CHN_S UvcChn = {MOD_ID_UVC, (int)pContext->mConfigParam.mDevName, pContext->mUvcChn}; // note: UvcChn->mDevId is the pointer of char *;
            MPP_CHN_S VdecChn = {MOD_ID_VDEC, 0, pContext->mVdecChn};
            eRet = AW_MPI_SYS_Bind(&UvcChn, &VdecChn);
            if(eRet != SUCCESS)
                aloge("fatal error! bind uvc2vdec fail[0x%x]", eRet);
            eRet = AW_MPI_UVC_EnableDevice(pContext->mConfigParam.mDevName);
            if(eRet != SUCCESS)
                aloge("fatal error: the %UVC device can not start", pContext->mConfigParam.mDevName);
            eRet = AW_MPI_UVC_StartRecvPic(pContext->mConfigParam.mDevName, pContext->mUvcChn);
            if(eRet != SUCCESS)
                aloge("fatal error: the %s UVC can not start virchannel[%d]", pContext->mConfigParam.mDevName, pContext->mUvcChn);
            AW_MPI_VDEC_StartRecvStream(pContext->mVdecChn);
            AW_MPI_VO_StartChn(pContext->mVoLayer, pContext->mVOChn);
                AW_MPI_VO_StartChn(pContext->mSubVoLayer, pContext->mSubVOChn);
            //get frame from vdec, send frame to vo.
            VIDEO_FRAME_INFO_S mainFrameInfo;
            VIDEO_FRAME_INFO_S subFrameInfo;
            while(1)
                if(pContext->mConfigParam.mTestFrameCount > 0)
                    if(pContext->mFrameCounter>=pContext->mConfigParam.mTestFrameCount)
                        alogd("get [%d] frames from vdec, prepare to exit!", pContext->mFrameCounter);
                        break;
                if(cdx_sem_get_val(&pContext->mSemExit) > 0)
                    alogd("detect user exit signal! prepare to exit!");
                    break;
                eRet = AW_MPI_VDEC_GetDoubleImage(pContext->mVdecChn, &mainFrameInfo, &subFrameInfo, 500);
                VdecDoubleFrameInfo *pDstDbFrame = NULL;
                if(SUCCESS == eRet)
                    int suffix = FindFrameIdInArray(pContext, mainFrameInfo.mId);
                    if(-1 == suffix)
                        if(pContext->mValidDoubleFrameBufferNum >= MAX_FRAMEPAIR_ARRAY_SIZE)
                            aloge("fatal error! frame number [%d] too much!", pContext->mValidDoubleFrameBufferNum);
                        pDstDbFrame = &pContext->mDoubleFrameArray[pContext->mValidDoubleFrameBufferNum];
                        pContext->mValidDoubleFrameBufferNum++;
                        pDstDbFrame = &pContext->mDoubleFrameArray[suffix];
                    if(pDstDbFrame->mMainRefCnt!=0 || pDstDbFrame->mSubRefCnt!=0)
                        aloge("fatal error! refCnt[%d],[%d] != 0", pDstDbFrame->mMainRefCnt, pDstDbFrame->mSubRefCnt);
                    pDstDbFrame->mMainFrame = mainFrameInfo;
                        pDstDbFrame->mSubFrame = subFrameInfo;
                    pContext->mFrameCounter++;
                    pContext->mHoldFrameNum++;
                    alogw("why not get frame from vdec for too long? ret=0x%x", eRet);
                    continue;
                pDstDbFrame->mMainRefCnt++;
                    pDstDbFrame->mSubRefCnt++;
                eRet = AW_MPI_VO_SendFrame(pContext->mVoLayer, pContext->mVOChn, &pDstDbFrame->mMainFrame, 0);
                if(SUCCESS == eRet)
                    aloge("fatal error! why send frame to vo fail? layer[%d]chn[%d], ret[0x%x]", pContext->mVoLayer, pContext->mVOChn, eRet);
                    pDstDbFrame->mMainRefCnt--;
                    eRet = AW_MPI_VO_SendFrame(pContext->mSubVoLayer, pContext->mSubVOChn, &pDstDbFrame->mSubFrame, 0);
                    if(SUCCESS == eRet)
                        aloge("fatal error! why send frame to vo fail? layer[%d]chn[%d], ret[0x%x]", pContext->mSubVoLayer, pContext->mSubVOChn, eRet);
                        pDstDbFrame->mSubRefCnt--;
            AW_MPI_VO_StopChn(pContext->mVoLayer, pContext->mVOChn);
                AW_MPI_VO_StopChn(pContext->mSubVoLayer, pContext->mSubVOChn);
            AW_MPI_VDEC_StopRecvStream(pContext->mVdecChn);
            AW_MPI_UVC_StopRecvPic(pContext->mConfigParam.mDevName, pContext->mUvcChn);
            AW_MPI_VO_DestroyChn(pContext->mVoLayer, pContext->mVOChn);
                AW_MPI_VO_DestroyChn(pContext->mSubVoLayer, pContext->mSubVOChn);
            AW_MPI_VDEC_DestroyChn(pContext->mVdecChn);
            pContext->mVdecChn = MM_INVALID_CHN;
            AW_MPI_UVC_DestroyVirChn(pContext->mConfigParam.mDevName, pContext->mUvcChn);
            pContext->mUvcChn = MM_INVALID_CHN;
            AW_MPI_UVC_DisableDevice(pContext->mConfigParam.mDevName);
            AW_MPI_UVC_DestroyDevice(pContext->mConfigParam.mDevName);
            //stContext.mConfigParam.mDevName = NULL;
            AW_MPI_VO_OpenVideoLayer(pContext->mUILayer); /* open ui layer. */
            AW_MPI_VO_DisableVideoLayer(pContext->mVoLayer);
                AW_MPI_VO_DisableVideoLayer(pContext->mSubVoLayer);
            AW_MPI_VO_RemoveOutsideVideoLayer(pContext->mUILayer);
            /* disalbe vo dev */
            AW_MPI_VO_Disable(pContext->mVoDev);
            pContext->mVoDev = MM_INVALID_DEV;
            AW_MPI_SYS_Exit();
            if(pContext->mHoldFrameNum != 0)
                aloge("fatal error! why holdframe num[%d] != 0?", pContext->mHoldFrameNum);
            alogd("vdec buffer number is [%d]", pContext->mValidDoubleFrameBufferNum);
            int i;
            for(i=0;i<pContext->mValidDoubleFrameBufferNum;i++)
                alogd("vdec buffer[%d] id =[%d]", i, pContext->mDoubleFrameArray[i].mMainFrame.mId);
        _exit:
            destroySampleUvc2VdecVoContext(pContext);
            free(pContext);
            alogd("%s test result: %s", argv[0], ((0 == result) ? "success" : "fail"));
            return result;
        J 1 条回复 最后回复 回复 引用 分享 0
          J_Biao LV 5 @WhycanService 最后由 编辑
          @whycanservice 你好,这个源码应该是做UVC解码显示的吧,我想要的是USB的摄像头接入后可以实时显示采集到的图像视频,并且同步把数据编码封装成MP4进行存储
