    T113麻雀,TF卡启动,经常卡死
    3370
    • G
      gonboy LV 5 最后由 编辑
      32G TF卡,启动时,经常卡死在如下代码, 如何解决?
      ‘’‘bash
      [ 5.299707] Run /pseudo_init as init process
      [ 5.998854] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
      [ 6.020692] EXT4-fs (mmcblk0p7): mounted filesystem with journalled data mode. Opts: data=journal
        whycan晕哥 LV 9 最后由 whycan 编辑
        是不是把整个剩余分区都作为ext4根文件系统了?
        G 1 条回复 最后回复 回复 引用 分享 0
        • G
          gonboy LV 5 @whycan 最后由 编辑
          @whycan 启动后,查看了,TD卡,剩余的29G大小 分区。 是ext4。
          系统主分区不是ext4, 是默认的squashfs
            whycan晕哥 LV 9 @gonboy 最后由 编辑
            @gonboy
            那有没有卡在 ext4 文件系统加载?
            • G
              @whycan 1. 没有文件,在ext4分区,进行启动加载。
              2. 这种现象,貌似 是对 29G的空间进行,格式化。(偶尔会启动慢)
              [    6.412934] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
              insmod: can't insert '/lib/modules/5.4.61/usb-storage.ko': No such file or directory
              [    6.467474] sunxi_gpadc_init,2151, success
              [    6.472441] sunxi_gpadc_setup: get channel scan data failed
              [    6.479050] input: sunxi-gpadc0 as /devices/virtual/input/input1
              [    6.491148] get ctp_power is fail, -22
              [    6.495359] get ctp_power_ldo_vol is fail, -22
              [    6.500392] sunxi_ctp_startup: ctp_power_io is invalid.
              [    6.506288] get ctp_gesture_wakeup fail, no gesture wakeup
              [    6.512475] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
              [    6.709604] input: gt9xxnew_ts as /devices/virtual/input/input2
              [    6.996971] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
              [    7.104136] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
              [    7.110433] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    7.122094] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
              [    7.142279] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    7.167200] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    7.182888] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
              [    7.196179] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
              [    7.214867] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
              [    7.226470] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
              [    7.238313] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
              [    7.250839] mmc1: new high speed SDIO card at address 0001
              ------run rc.final file-----
              mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory
