    谁能提供一份XR829的固件 sdd_xr829.bin
    5295
    • X
      xfdr0805 LV 5 最后由 编辑
      # modprobe xr829.ko
      [  100.391586] ======== XRADIO WIFI OPEN ========
      [  100.398517] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
      [  100.405334] [XRADIO] Allocated hw_priv @ 000000009b3877eb
      [  100.413152] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [  100.429430] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [  100.636545] [XRADIO] Detect SDIO card 1
      [  100.651420] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  100.673356] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [  100.693300] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  100.717916] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  100.737273] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [  100.762531] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [  100.774088] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [  100.786258] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [  100.798775] mmc1: new high speed SDIO card at address 0001
      [  100.806454] [SBUS] XRadio Device:sdio clk=50000000
      [  100.872826] [XRADIO] XRADIO_HW_REV 1.0 detected.
      [  100.881593] xradio_wlan mmc1:0001:1: Direct firmware load for sdd_xr829.bin failed with error -2
      [  100.891437] [XRADIO_ERR] xradio_parse_sdd: can't load sdd file sdd_xr829.bin.
      [  100.899420] [XRADIO_ERR] xradio_load_firmware failed(-2).
      [  100.906159] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      使用的是韦老师的【极简操作】使用builroot 2021一键编译生成D1 nezha 系统镜像!
      目前编译完驱动,加载时找不到sdd_xr829.bin buildroot里好像没有,谁能提供一份XR829的固件 sdd_xr829.bin,谢谢!
        dreamer LV 4 最后由 编辑
        $ find . -name sdd_xr829.bin
        ./out/d1-nezha/staging_dir/target/rootfs/lib/firmware/sdd_xr829.bin
        ./out/d1-nezha/compile_dir/target/rootfs/lib/firmware/sdd_xr829.bin
        ./out/d1-nezha/compile_dir/target/linux-firmware/ipkg-sunxi/xr829-firmware/lib/firmware/sdd_xr829.bin
        ./package/firmware/linux-firmware/xr829/sdd_xr829.bin
        X 2 条回复 最后回复 回复 引用 分享 0
        • X
          xfdr0805 LV 5 @dreamer 最后由 编辑
          • X
            @dreamer
            我搜遍了,也没找到,Tina SDK 没能下载下来
              dreamer LV 4 最后由 编辑
              整个firmware打包了: d1_linux_firmware.tgz
                dreamer LV 4 最后由 编辑
                全志 RISCV 指令集 D1 开发板 哪吒 资料合集
                https://whycan.com/t_6440.html
                这里有晕哥上传到百度云的SDK,你可以先下载,然后再 git pull
                • X
                  非常感谢!我下载试试
