    Neza-D1开发板学习之按键和旋转编码器篇
    • X
      xfdr0805 LV 5 最后由 编辑
      1. Neza-D1开发板上只引出一个按键,是使用的LRADC检检测按键的,想使用更多按键,可以使用板子上通过PCF8574扩展出来的IO,我画的扩展板使用了四个按键,分别为PP0,PP1,PP2,PP4
      2. 设备树配置如下 内核需要勾选 Polled input device skeleton
         gpio_keys {
             compatible = "gpio-keys";
             pinctrl-names = "default";
             /*pinctrl-0 = <&key_pins>;*/
             #address-cells = <1>;
             #size-cells = <0>;
             autorepeat;
             button@0 {
                 label = "Key volume up";
                 linux,code = <KEY_VOLUMEUP>;
                 gpios = <&pcf8574 0 GPIO_ACTIVE_LOW>; /* PP0 */
             button@1 {
                 label = "Key volume down";
                 linux,code = <KEY_VOLUMEDOWN>;
                 gpios = <&pcf8574 1 GPIO_ACTIVE_LOW>; /* PP1 */
             button@2 {
                 label = "Key back";
                 linux,code = <KEY_BACK>;
                 gpios = <&pcf8574 2 GPIO_ACTIVE_LOW>; /* PP2 */
             button@3 {
                 label = "Key enter";
                 linux,code = <KEY_ENTER>;
                 gpios = <&pcf8574 4 GPIO_ACTIVE_LOW>; /* PP4 */
      3. 编码器接在D1的PD14 PD15 设备树如下
        注意需要内核勾选<*> Polled GPIO Decoder Input driver
         rotary {
             compatible = "rotary-encoder";
             /*pinctrl-0 = <&rotary_pins>;*/
             gpios = <&pio 3 14 GPIO_ACTIVE_LOW>, <&pio 3 15 GPIO_ACTIVE_LOW>; /* PD14, PD15 */
             linux,axis = <0>; /* REL_X */
             rotary-encoder,encoding = "gray";
             rotary-encoder,relative-axis;
        然后在内核勾选
      4. 系统启动会有如下log
         [    0.111735] input: sunxi-keyboard as /devices/virtual/input/input0  这是板载的那个LRADC 按键
         [    1.668976] rotary-encoder soc@3000000:rotary: gray 这是旋转编码器
         [    1.675145] input: soc@3000000:rotary as /devices/platform/soc@3000000/soc@3000000:rotary/input/input1
         [    3.178668] input: soc@3000000:gpio_keys as /devices/platform/soc@3000000/soc@3000000:gpio_keys/input/input5 这是扩展出来的那4个按键
      5. 查看系统里已注册的输入设备,用这个比较清楚,ls /dev/input也可以
         # evtest
         No device specified, trying to scan all of /dev/input/event*
         Available devices:
         /dev/input/event0:      sunxi-keyboard
         /dev/input/event1:      soc@3000000:rotary
         /dev/input/event2:      sunxi-ir
         /dev/input/event3:      audiocodec sunxi Audio Jack
         /dev/input/event4:      soc@3000000:gpio_keys
         /dev/input/event5:      ns2009_ts
      6. 可以使用evtest或hexdump来测试按键是否正常了
      7. 在代码使用就比较简单了
         #include <errno.h>
         #include <global.h>
         #include <linux/fcntl.h>
         #include <linux/input.h>
         #include <signal.h>
         #include <stdio.h> //-std=c99  -std=gnu99
         #include <stdlib.h>
         #include <string.h>
         #include <sys/types.h>
         #include <unistd.h>
         #define msleep(t) usleep((t)*1000)
         FILE *fp;
         int32_t fd_key;
         int32_t fd_encoder;
         struct input_event t;
             fd_key = open("/dev/input/event1", O_RDONLY | O_NONBLOCK);
             if (fd_key < 0)
                 fprintf(stderr, "error:can not open /dev/input/event1\n");
                 return -1;
             fd_encoder = open("/dev/input/event4", O_RDONLY | O_NONBLOCK);
             if (fd_encoder < 0)
                 fprintf(stderr, "error:can not open /dev/input/event4\n");
                 return -1;
             while (1)
                 // rotary encoder
                 if (read(fd_encoder, &t, sizeof(t)) == sizeof(t))
                     if (t.type == EV_REL)
                         LOG_D("ROTARY DIR: %d->%s\n", t.value, t.value == 1 ? "CC" : "CW");
                         rotary_encoder_handler(&u8g2, t.value);
                 // key
                 if (read(fd_key, &t, sizeof(t)) == sizeof(t))
                     if (t.type == EV_KEY)
                         switch (t.code)
                         case KEY_OK:
                             LOG_D("KEY_ENTER %s \n", t.value ? "Pressed" : "Released");
                             if (t.value == 0)
                                 rotary_encoder_button_handler(&u8g2);
                             break;
                         case KEY_SELECT:
                             LOG_D("KEY_SELECT %s \n", t.value ? "Pressed" : "Released");
                             break;
                         case KEY_VOLUMEUP:
                             LOG_D("KEY_VOLUMEUP %s \n", t.value ? "Pressed" : "Released");
                             if (t.value == 0)
                                 rotary_encoder_handler(&u8g2, -1);
                             break;
                         case KEY_VOLUMEDOWN:
                             LOG_D("KEY_VOLUMEDOWN %s \n", t.value ? "Pressed" : "Released");
                             if (t.value == 0)
                                 rotary_encoder_handler(&u8g2, 1);
                             break;
                         default:
                             break;
                 usleep(1);
      • tigger
        tigger LV 7 最后由 编辑
        居然还有轮询的旋转编码器驱动,学到新姿势了。
