    A40i将hdmi输出改为 tft_lcd
    创龙科技专区
      ddrddr LV 5 最后由 编辑
      我a40i 的sdk 刚开始编译的时候./build.sh config 显示选的是 0 hdmi ,我现在想把之前选的hdmi输出改为 tft_lcd,重新执行./build.sh config 选择 4 tft_lcd,但是不起作用,编出来的固件显示输出还是hdmi,
      刚才又重复./build.sh config了好几次了,都没生效,fex文件已经加载 sys_config_tft_lcd.fex 的配置信息了,但是pack出来的固件仍然是hdmi显示输出,可以通过改哪个配置文件修改吗
      配置打包的过程记录:
      Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 5.4.0-150-generic x86_64)
       * Documentation:  https://help.ubuntu.com
       * Management:     https://landscape.canonical.com
       * Support:        https://ubuntu.com/advantage
       * Strictly confined Kubernetes makes edge and IoT secure. Learn how MicroK8s
         just raised the bar for easy, resilient and secure K8s cluster deployment.
         https://ubuntu.com/engage/secure-kubernetes-at-the-edge
       * Canonical Livepatch is available for installation.
         - Reduce system reboots and improve kernel security. Activate at:
           https://ubuntu.com/livepatch
      116 packages can be updated.
      1 update is a security update.
      Your Hardware Enablement Stack (HWE) is supported until April 2023.
      Last login: Tue Aug 22 11:50:20 2023 from 192.168.3.105
      tuner@tuner-virtual-machine:~$
      tuner@tuner-virtual-machine:~$ cd /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee
      tuner@tuner-virtual-machine:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee$ ./build.sh config
      Welcome to mkscript setup progress
      All available chips:
         0. sun8iw11p1
      Choice: 0
      All available platforms:
         0. linux
      Choice: 0
      All available kernel:
         0. linux-3.10
      Choice: 0
      All available boards:
         0. t3-mp1
         1. t3-p1
         2. t3-p2
         3. t3-p3
         4. tlt3_a40i-evm
      Choice: 4
      All available rootfs:
        0. buildroot
        1. buildroot-201611
        2. debian_fs
      Choice: 1
      select buildroot-201611
      All available float:
        0. gnueabi
        1. gnueabihf
      Choice: 1
      select gnueabihf
      All available qt version:
        0. 5.9.0
        1. 5.9.7
      Choice: 0
      select 5.9.0
      All available output configs:
         0. hdmi
         1. vga
         2. lvds_lcd
         3. mipi_lcd
         4. tft_lcd
      Choice: 4
         0. t3
         1. a40i
      Choice: 1
      create misc_config gnueabihf
      build buidroot-201611...
      xgnueabihf
      sun8iw11p1_hf_defconfig
      INFO: build lichee ...
      INFO: chip: sun8iw11p1
      INFO: platform: linux
      INFO: kernel: linux-3.10
      INFO: board: tlt3_a40i-evm
      INFO: output: out/sun8iw11p1/linux/tlt3_a40i-evm
      INFO: build buildroot ...
      make: Entering directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611'
      >>>   Finalizing target directory
      rm -f /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas/*.xml /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas/*.dtd
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/glib-compile-schemas /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/share/glib-2.0/schemas --targetdir=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas
      No schema files found: doing nothing.
      PYTHONPATH="/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7/sysconfigdata/:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7/site-packages/" /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/python2.7 support/scripts/pycompile.py /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7
      find /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7 -name '*.pyo' -print0 | xargs -0 --no-run-if-empty rm -f
      mkdir -p /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc
      echo "T3/A40i-Tronlong" > /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/hostname
      /bin/sed -i -e '$a \127.0.1.1\tT3/A40i-Tronlong' -e '/^127.0.1.1/d' /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/hosts
      echo "Welcome to Allwinner T3 Linux Platform V1.4" > /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/issue
      mkdir -p /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/network/
      ( echo "# interface file auto-generated by buildroot"; echo ; echo "auto lo"; echo "iface lo inet loopback"; echo ; echo "allow-hotplug eth0"; echo "iface eth0 inet dhcp"; ) > /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/network/interfaces
      /bin/sed -i -e s,^root:[^:]*:,root::, /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/shadow
      ln -sf bash /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/bin/sh
      /bin/sed -i -e '/ttyS0::respawn:\/bin\/login/d' /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
      /bin/sed -i -e '/# Put a getty on the serial port/a\ttyS0::respawn:/bin/login -f root' /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
      /bin/sed -i -e '/^#.*-o remount,rw \/$/s~^#\+~~' /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
      Generating locale zh_CN.UTF-8
      rm -f /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge
      for i in C en_US zh_CN locale-archive; do echo $i >> /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge; done
      for dir in /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/locale /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/locale; do for langdir in $dir/*; do if [ -e "${langdir}" ]; then grep -qx "${langdir##*/}" /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge || rm -rf $langdir; fi done; done
      if [ -d /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale ]; then for lang in C en_US zh_CN; do if [ -f /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale/$lang/XLC_LOCALE ]; then echo "$lang/XLC_LOCALE: $lang"; fi done > /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale/locale.dir; fi
      rm -rf /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/include /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/aclocal \
              /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/pkgconfig /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/pkgconfig \
              /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/cmake /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/cmake
      find /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/{lib,share}/ -name '*.cmake' -print0 | xargs -0 rm -f
      find /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/ /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/libexec/ \
              \( -name '*.a' -o -name '*.la' \) -print0 | xargs -0 rm -f
      rm -rf /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/zsh
      rm -rf /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/man /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/man
      rm -rf /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/info /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/info
      rm -rf /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/doc /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/doc
      rm -rf /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/gtk-doc
      rmdir /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share 2>/dev/null
      Makefile:641: recipe for target 'target-finalize' failed
      make[1]: [target-finalize] Error 1 (ignored)
      find /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target -type f \( -perm /111 -o -name '*.so*' \) -not \( -name 'libpthread*.so*' -o -name 'ld-*.so*' -o -name '*.ko' \) -print0 | xargs -0 /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note 2>/dev/null || true
      find /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ -type f -name 'libpthread*.so*' | \
              xargs -r /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note --strip-debug
      find /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ -type f -name 'ld-*.so*' | \
      test -f /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/ld.so.conf && \
              { echo "ERROR: we shouldn't have a /etc/ld.so.conf file"; exit 1; } || true
      test -d /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/ld.so.conf.d && \
              { echo "ERROR: we shouldn't have a /etc/ld.so.conf.d directory"; exit 1; } || true
              echo "NAME=Buildroot"; \
              echo "VERSION=2016.11 Fri Aug 25 10:39:19 CST 2023"; \
              echo "ID=buildroot"; \
              echo "VERSION_ID=2016.11"; \
              echo "PRETTY_NAME=\"Buildroot 2016.11\"" \
      ) >  /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/etc/os-release
      >>>   Executing post-build script target/user_rootfs_build.sh
      run user rootfs build script------------genrootfs =
      not genrootfs DO NOT compile sdk lib
      make: Leaving directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611'
      INFO: build buildroot OK.
      INFO: build kernel ...
      INFO: prepare toolchain of sun8iw11p1...
      no file name,use gz
      Building kernel
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/output/lib/modules/3.10.65-rt69
      Copy rootfs for arm
      rootfs_32bit.cpio_buildroot_201611.gz
        CHK     include/generated/uapi/linux/version.h
        CHK     include/generated/utsrelease.h
      make[1]: 'include/generated/mach-types.h' is up to date.
        CALL    scripts/checksyscalls.sh
        CC      scripts/mod/devicetable-offsets.s
        GEN     scripts/mod/devicetable-offsets.h
        HOSTCC  scripts/mod/file2alias.o
        HOSTLD  scripts/mod/modpost
        CHK     include/generated/compile.h
        CHK     kernel/config_data.h
        CC      drivers/soc/allwinner/pm/standby/common.o
        CC      drivers/soc/allwinner/pm/standby/standby_twi.o
        CC      drivers/soc/allwinner/pm/standby/power/axp_power.o
        CC      drivers/soc/allwinner/pm/standby/power/axp15_power.o
        CC      drivers/soc/allwinner/pm/standby/power/axp22_power.o
        CC      drivers/soc/allwinner/pm/standby/power/axp20_power.o
        CC      drivers/soc/allwinner/pm/standby/power/standby_power.o
      drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_get_voltage':
      drivers/soc/allwinner/pm/standby/power/standby_power.c:43:9: warning: implicit declaration of function 'axp20_get_volt' [-Wimplicit-function-declaration]
         ret = axp20_get_volt(tree);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:46:9: warning: implicit declaration of function 'axp22_get_volt' [-Wimplicit-function-declaration]
         ret = axp22_get_volt(tree);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:59:9: warning: implicit declaration of function 'axp15_get_volt' [-Wimplicit-function-declaration]
         ret = axp15_get_volt(tree);
      drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_set_voltage':
      drivers/soc/allwinner/pm/standby/power/standby_power.c:84:9: warning: implicit declaration of function 'axp20_set_volt' [-Wimplicit-function-declaration]
         ret = axp20_set_volt(tree, voltage);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:87:9: warning: implicit declaration of function 'axp22_set_volt' [-Wimplicit-function-declaration]
         ret = axp22_set_volt(tree, voltage);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:100:9: warning: implicit declaration of function 'axp15_set_volt' [-Wimplicit-function-declaration]
         ret = axp15_set_volt(tree, voltage);
      drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_get_state':
      drivers/soc/allwinner/pm/standby/power/standby_power.c:128:9: warning: implicit declaration of function 'axp20_get_state' [-Wimplicit-function-declaration]
         ret = axp20_get_state(tree);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:131:9: warning: implicit declaration of function 'axp22_get_state' [-Wimplicit-function-declaration]
         ret = axp22_get_state(tree);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:144:9: warning: implicit declaration of function 'axp15_get_state' [-Wimplicit-function-declaration]
         ret = axp15_get_state(tree);
      drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_set_state':
      drivers/soc/allwinner/pm/standby/power/standby_power.c:172:9: warning: implicit declaration of function 'axp20_set_state' [-Wimplicit-function-declaration]
         ret = axp20_set_state(tree, state);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:188:9: warning: implicit declaration of function 'axp15_set_state' [-Wimplicit-function-declaration]
         ret = axp15_set_state(tree, state);
      drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_suspend_calc':
      drivers/soc/allwinner/pm/standby/power/standby_power.c:217:9: warning: implicit declaration of function 'axp20_suspend_calc' [-Wimplicit-function-declaration]
         ret = axp20_suspend_calc(mask, func);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:221:9: warning: implicit declaration of function 'axp22_suspend_calc' [-Wimplicit-function-declaration]
         ret = axp22_suspend_calc(mask, func);
      drivers/soc/allwinner/pm/standby/power/standby_power.c:234:9: warning: implicit declaration of function 'axp15_suspend_calc' [-Wimplicit-function-declaration]
         ret = axp15_suspend_calc(mask, func);
        CC      drivers/soc/allwinner/pm/standby/standby_clock.o
        CC      drivers/soc/allwinner/pm/standby/standby_debug.o
        AS      drivers/soc/allwinner/pm/standby/standby_divlib.o
        CC      drivers/soc/allwinner/pm/standby/standby_dram.o
        AS      drivers/soc/allwinner/pm/standby/./../mem_mmu_pc_asm.o
        CC      drivers/soc/allwinner/pm/standby/./../mem_divlibc.o
        CC      drivers/soc/allwinner/pm/standby/./../mem_clk.o
        CC      drivers/soc/allwinner/pm/standby/./../mem_timing.o
        CC      drivers/soc/allwinner/pm/standby/./../mem_serial.o
        CC      drivers/soc/allwinner/pm/standby/./../mem_printk.o
        CC      drivers/soc/allwinner/pm/standby/./../pm_debug.o
        CC      drivers/soc/allwinner/pm/standby/main.o
      drivers/soc/allwinner/pm/standby/main.c: In function 'standby_main':
      drivers/soc/allwinner/pm/standby/main.c:135:3: warning: implicit declaration of function 'power_enter_super_calc' [-Wimplicit-function-declaration]
         power_enter_super_calc(&pm_info, &extended_standby_para_info,
      drivers/soc/allwinner/pm/standby/main.c:144:3: warning: implicit declaration of function 'standby_twi_init_losc' [-Wimplicit-function-declaration]
         standby_twi_init_losc(pm_info.pmu_arg.twi_port);
      drivers/soc/allwinner/pm/standby/main.c: In function 'bus_enter_lowfreq':
      drivers/soc/allwinner/pm/standby/main.c:332:3: warning: implicit declaration of function 'standby_clk_ldodisable' [-Wimplicit-function-declaration]
         standby_clk_ldodisable();
      drivers/soc/allwinner/pm/standby/main.c: In function 'bus_freq_resume':
      drivers/soc/allwinner/pm/standby/main.c:342:3: warning: implicit declaration of function 'standby_clk_ldoenable' [-Wimplicit-function-declaration]
         standby_clk_ldoenable();
        CC      drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.o
      drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c: In function 'dram_udelay':
      drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:30:2: warning: implicit declaration of function 'change_runtime_env' [-Wimplicit-function-declaration]
        change_runtime_env();
      drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:31:2: warning: implicit declaration of function 'delay_us' [-Wimplicit-function-declaration]
        delay_us(n);
      In file included from drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:18:0:
      drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c: In function 'mctl_channel_init_standby':
      drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_hal-sun8iw11.h:77:35: warning: implicit declaration of function 'printk' [-Wimplicit-function-declaration]
       #define dram_dbg_0(fmt, args...)  printk(fmt, ##args)
      drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:713:2: note: in expansion of macro dram_dbg_0'
        dram_dbg_0("mctl_channel_init_standby\n");
      rm -rf *.o drivers/soc/allwinner/pm/standby/./*.o
        CC      drivers/soc/allwinner/pm/mem_divlibc.o
        CC      drivers/soc/allwinner/pm/mem_int.o
        CC      drivers/soc/allwinner/pm/mem_clk.o
        CC      drivers/soc/allwinner/pm/mem_gpio.o
        CC      drivers/soc/allwinner/pm/mem_timing.o
        CC      drivers/soc/allwinner/pm/mem_serial.o
        AS      drivers/soc/allwinner/pm/standby.o
        LD      drivers/soc/allwinner/pm/pm_tmp.o
        LD      drivers/soc/allwinner/pm/built-in.o
        LD      drivers/soc/allwinner/built-in.o
        LD      drivers/soc/built-in.o
        LD      drivers/video/sunxi/disp2/hdmi/hdmi.o
        LD      drivers/video/sunxi/disp2/hdmi/built-in.o
        LD      drivers/video/sunxi/built-in.o
        LD      drivers/video/built-in.o
        LD      drivers/built-in.o
        LINK    vmlinux
        LD      vmlinux.o
        MODPOST vmlinux.o
      WARNING: modpost: Found 1 section mismatch(es).
      To see full details build your kernel with:
      'make CONFIG_DEBUG_SECTION_MISMATCH=y'
        GEN     .version
        UPD     include/generated/compile.h
        CC      init/version.o
        LD      init/built-in.o
        KSYM    .tmp_kallsyms1.o
        KSYM    .tmp_kallsyms2.o
        LD      vmlinux
        SORTEX  vmlinux
        SYSMAP  System.map
        OBJCOPY arch/arm/boot/Image
        Kernel: arch/arm/boot/Image is ready
        GZIP    arch/arm/boot/compressed/piggy.gzip
        AS      arch/arm/boot/compressed/piggy.gzip.o
        LD      arch/arm/boot/compressed/vmlinux
        OBJCOPY arch/arm/boot/zImage
        Kernel: arch/arm/boot/zImage is ready
        UIMAGE  arch/arm/boot/uImage
      Image Name:   Linux-3.10.65-rt69
      Created:      Fri Aug 25 10:39:44 2023
      Image Type:   ARM Linux Kernel Image (uncompressed)
      Data Size:    5238000 Bytes = 5115.23 KiB = 5.00 MiB
      Load Address: 40008000
      Entry Point:  40008000
        Image arch/arm/boot/uImage is ready
        Building modules, stage 2.
        MODPOST 19 modules
      'arch/arm/boot/Image' -> 'output/bImage'
      'arch/arm/boot/uImage' -> 'output/uImage'
      'arch/arm/boot/zImage' -> 'output/zImage'
      Building modules
      build nand library /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/nand/sun8iw11p1/lib
      build nand with existing library
      make: Entering directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/nand'
      make -C /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10 M=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/nand
      make[1]: Entering directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10'
        LD [M]  /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/nand/sun8iw11p1/nand.o
        MODPOST 1 modules
        LD [M]  /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/nand/sun8iw11p1/nand.ko
      make[1]: Leaving directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10'
      make: Leaving directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/nand'
      [GPU]: Building mali400 device driver...
      make: Entering directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu'
      make -j -C mali400/kernel_mode/driver/src/devicedrv/mali BUILD=release
      make[1]: Entering directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali'
      make ARCH=arm -C /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10 M=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali modules
      make[2]: Entering directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10'
        CC [M]  /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/__malidrv_build_info.o
        LD [M]  /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.o
        MODPOST 1 modules
        CC      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.mod.o
        LD [M]  /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.ko
      make[2]: Leaving directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10'
      make[1]: Leaving directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali'
      'mali400/kernel_mode/driver/src/devicedrv/mali/mali.ko' -> '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/output/lib/modules/3.10.65-rt69/mali.ko'
      make: Leaving directory '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/linux-3.10/modules/gpu'
      [GPU]: mali400 device driver has been built.
      regenerate rootfs cpio
      4283 blocks
      5005 blocks
      build_ramfs
      Copy boot.img to output directory ...
      Copy modules to target ...
      ./scripts/build.sh
      sun8iw11p1 compile Kernel successful
      INFO: build kernel OK.
      INFO: build rootfs ...
              echo "VERSION=2016.11 Fri Aug 25 10:39:55 CST 2023"; \
      run user rootfs build script------------genrootfs = y
      cp: target '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/target/bin/' is not a directory
      you must compile QT5.9.0 first!!!!!!!
      \nlibsdk.so compile ok!!!\n\n
      make[2]: Nothing to be done for 'all'.
      cp: cannot stat '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/sdktest/eve_module/classifier/*': No such file or directory
      make finish!!!
      echo ----------vproxy---------
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./videoprosy.cpp -o ./videopro.o -rdynamic -fPIC -shared   -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX  -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DCDX_V27  -DSUPPORT_NEW_DRIVER  -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0  -I-I./ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/include/disp2 -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/include/utils -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib//include/cutils/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/media -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/camera -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/camera/moudle -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/camera/allwinnertech/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/camera/allwinnertech/water_mark/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/camera/adas/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/storage/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/sound/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/memory/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/misc/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/audioenc/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/eve_module/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/eve_module -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/adecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/aencoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/adecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/libxml -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/live -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/openssl -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/sdecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/zlib -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcedarc/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/base/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/muxer/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/parser/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/playback/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/stream/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/common/plugin -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/xplayer/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/../shm/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/
      In file included from ./videoprosy.cpp:8:0:
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:19:1: warning: 'typedef' was ignored in this declaration
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:25:1: warning: 'typedef' was ignored in this declaration
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot  -o ./libvideoproxy.so ./videopro.o  -rdynamic -fPIC -shared -L./cedarx// -Wl,--no-undefined -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/cedarx/lib_hf/ -Wl,--no-undefined -ladecoder -laencoder -lcdx_base -lcdx_common -lcdx_muxer -lcdx_parser -lcdx_playback -lcdx_stream -lMemAdapter  -lcdc_base  -lsubdecoder -lvdecoder -lvencoder -lVE -lvideoengine -lxmetadataretriever -lxplayer -lrt -lpthread -lz -lcrypto -lssl -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/libs_hf -lsdk_compose  -lsdk_disp  -lsdk_g2d -lsdk_dvr   -lsdk_player  -lsdk_tr -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/lib/ -lGLESv2 -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib   -lsdk  -ltinyalsa  -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/libs    -lawshm -lawcommediavideo  -I../shm/ -I../dbusmedia/
      cp ./libvideoproxy.so /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoproxy/../../sdk_lib/libs
      make[2]: Circular videoserv <- videoserv dependency dropped.
      echo -------------------
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./background_video_player.cpp -o ./background_video_player.o -g  -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX  -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DADAS_ENABLE -DCDX_V27  -DSUPPORT_NEW_DRIVER  -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0 -DBGVIDEO_SER -I-I./ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/include/disp2 -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/include/utils -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib//include/cutils/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/media -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera/moudle -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/water_mark/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera/adas/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/storage/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/sound/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/memory/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/misc/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/audioenc/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/eve_module/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/eve_module -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/aencoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/libxml -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/live -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/openssl -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/sdecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/zlib -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcedarc/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/base/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/muxer/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/parser/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/playback/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/stream/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/plugin -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xplayer/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/../shm/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/
      In file included from ./background_video_player.cpp:11:0:
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:19:1: warning: 'typedef' was ignored in this declaration
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:25:1: warning: 'typedef' was ignored in this declaration
      ./background_video_player.cpp: In static member function 'static int CBackGroundMediaVideo::handleShareMemControlCmd(int, int, char*, void*, void*)':
      ./background_video_player.cpp:410:21: warning: NULL used in arithmetic [-Wpointer-arith]
          if(pout->val0 != NULL)
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./bg_video_serv_warper.cpp    -o ./bg_video_serv_warper.o    -g  -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX  -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DADAS_ENABLE -DCDX_V27  -DSUPPORT_NEW_DRIVER  -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0  -DBGVIDEO_SER -I-I./ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/include/disp2 -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/include/utils -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib//include/cutils/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/media -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera/moudle -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/water_mark/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/camera/adas/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/storage/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/sound/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/memory/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/misc/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/audioenc/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/eve_module/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/eve_module -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/aencoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/libxml -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/live -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/openssl -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/sdecoder -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/zlib -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcedarc/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/base/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/muxer/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/parser/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/playback/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/stream/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/plugin -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xplayer/include -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/../shm/ -I/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/
      In file included from ./bg_video_serv_warper.cpp:14:0:
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot  -o ./video_serv  ./background_video_player.o ./bg_video_serv_warper.o -DBGVIDEO_SER -L./cedarx// -Wl,--no-undefined -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/cedarx/lib_hf/ -Wl,--no-undefined -ladecoder -laencoder -lcdx_base -lcdx_common -lcdx_muxer -lcdx_parser -lcdx_playback -lcdx_stream -lMemAdapter  -lcdc_base  -lsubdecoder -lvdecoder -lvencoder -lVE -lvideoengine -lxmetadataretriever -lxplayer -lrt -lpthread -lz -lcrypto -lssl -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/libs_hf -lsdk_compose  -lsdk_disp  -lsdk_g2d -lsdk_dvr   -lsdk_player  -lsdk_tr -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/lib/ -lGLESv2 -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib  -lsdk   -ltinyalsa -L/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/target/user_rootfs_misc/a40i/sdk_demo/videoservice/../../sdk_lib/libs   -lawshm -lawcommediavideo
      ./makeMediaUI: line 9: ../../../../../../buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/Qt-5.9.0/bin/qmake: No such file or directory
      /home/tronlong/work/T3/sdk/allwin/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/Qt-5.9.0/bin/qmake -o Makefile MediaUI.pro
      make[2]: /home/tronlong/work/T3/sdk/allwin/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/Qt-5.9.0/bin/qmake: Command not found
      Makefile:460: recipe for target 'Makefile' failed
      make[2]: *** [Makefile] Error 127
      ./makeCameraUI: line 9: ../../../../../../buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/Qt-5.9.0/bin/qmake: No such file or directory
      /home/tronlong/work/T3/sdk/allwin/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/Qt-5.9.0/bin/qmake -o Makefile CameraUI.pro
      Makefile:563: recipe for target 'Makefile' failed
      ./makeLauncher: line 9: ../../../../../../buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/Qt-5.9.0/bin/qmake: No such file or directory
      /home/tronlong/work/T3/sdk/allwin/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/Qt-5.9.0/bin/qmake -o Makefile Launcher.pro
      Makefile:400: recipe for target 'Makefile' failed
      run user rootfs build script---------done!
      >>>   Generating root filesystem image rootfs.ext2
      rm -f /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      rm -f /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
      rm -f /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
      echo '#!/bin/sh' > /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      echo "set -e" >> /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      echo "chown -h -R 0:0 /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target" >> /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      printf '        dbus -1 dbus -1 * /var/run/dbus - dbus DBus messagebus user\n   - - docker -1 * - - - Docker Application Container Framework\n  - - input -1 * - - - Input device group\n       mosquitto -1 nogroup -1 * - - - Mosquitto user\n         sshd -1 sshd -1 * - - - SSH drop priv user\n    ftp -1 ftp -1 * /home/ftp - - Anonymous FTP User\n\n' >> /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
      PATH="/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain//bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/buildroot-201611/support/scripts/mkusers /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target >> /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      cat system/device_table.txt > /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
      printf '        /bin/busybox                     f 4755 0  0 - - - - -\n        /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n' >> /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
      echo "/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/makedevs -d /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target" >> /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      printf '        PATH="/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain//bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" mke2img -d /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target -G 4 -R 1 -b 2097152 -B 0 -i 524288 -I 0 -o /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2\n' >> /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      chmod a+x /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      PATH="/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain//bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/fakeroot -- /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
      rootdir=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target
      table='/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt'
      tune2fs 1.43.3 (04-Sep-2016)
      Please run e2fsck -f on the filesystem.
      Creating journal inode: done
      This filesystem will be automatically checked every 20 mounts or
      0 days, whichever comes first.  Use tune2fs -c or -i to override.
      mke2img: e2fsck was successfully run on '/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2' (ext4)
      Setting maximal mount count to -1
      Setting interval between checks to 0 seconds
      /usr/bin/install -m 0644 support/misc/target-dir-warning.txt /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
      ln -sf rootfs.ext2 /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext4
      INFO: build rootfs OK.
      INFO: build lichee OK.
      no SATA
      tuner@tuner-virtual-machine:/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee$ ./build.sh pack
      xgnueabihf
      INFO: packing firmware ...
      copying tools file
      copying configs file
      ./out/aultls32.fex
      ./out/aultools.fex
      ./out/boot_package.cfg
      ./out/boot_package.fex
      ./out/boot_package_nor.cfg
      ./out/cardscript.fex
      ./out/cardscript_secure.fex
      ./out/cardtool.fex
      ./out/diskfs.fex
      ./out/env.cfg
      ./out/env_burn.cfg
      ./out/image.cfg
      renamed './out/image_linux.cfg' -> './out/image.cfg'
      ./out/split_xxxx.fex
      ./out/sunxi.fex
      ./out/sys_config.fex
      ./out/sys_config_hdmi.fex
      ./out/sys_config_lvds_lcd.fex
      ./out/sys_config_mipi_lcd.fex
      ./out/sys_config_tft_lcd.fex
      ./out/sys_config_vga.fex
      ./out/sys_partition_dump.fex
      renamed './out/sys_partition_linux.fex' -> './out/sys_partition.fex'
      ./out/sys_partition_linux_128M.fex
      ./out/sys_partition_linux_256M.fex
      ./out/sys_partition_linux_mmc.fex
      ./out/sys_partition_private.fex
      ./out/toc0.fex
      ./out/toc1.fex
      ./out/usbtool.fex
      ./out/usbtool_test.fex
      copying boot resource
      lzma: out/bootlogo.bmp: No such file or directory
      copying boot file
      p=soc c=product state=0
      p=soc c=platform state=0
      p=soc c=target state=0
      p=soc c=norflash state=0
      p=soc c=power_sply state=0
      p=soc c=card_boot state=0
      p=soc c=pm_para state=0
      p=soc c=card0_boot_para state=0
      p=soc c=card2_boot_para state=0
      p=soc c=twi_para state=0
      p=soc c=uart_para state=0
      p=soc c=jtag_para state=0
      p=soc c=clock state=0
      p=soc c=dram state=0
      p=soc c=emac0 state=0
      p=soc c=gmac0 state=0
      p=soc c=can0 state=0
      p=soc c=can0 state=1
      p=soc c=twi0 state=0
      p=soc c=twi1 state=0
      p=soc c=twi2 state=0
      p=soc c=twi3 state=0
      p=soc c=twi4 state=0
      p=soc c=ir0 state=0
      p=soc c=uart0 state=0
      p=soc c=uart0 state=1
      p=soc c=uart1 state=0
      p=soc c=uart1 state=1
      p=soc c=uart2 state=0
      p=soc c=uart2 state=1
      p=soc c=uart3 state=0
      p=soc c=uart3 state=1
      p=soc c=uart4 state=0
      p=soc c=uart4 state=1
      p=soc c=uart5 state=0
      p=soc c=uart5 state=1
      p=soc c=uart6 state=0
      p=soc c=uart6 state=1
      p=soc c=uart7 state=0
      p=soc c=uart7 state=1
      p=soc c=spi0 state=0
      p=soc c=spi1 state=0
      p=soc c=spi2 state=0
      p=soc c=spi3 state=0
      p=soc c=rtp_para state=0
      p=soc c=ctp state=0
      p=soc c=ctp_list state=0
      p=soc c=tkey_para state=0
      p=soc c=motor_para state=0
      p=soc c=nand0 state=0
      p=soc c=sata state=0
      p=soc c=boot_disp state=0
      p=soc c=disp state=0
      p=soc c=tv0 state=0
      p=soc c=tv1 state=0
      p=soc c=tvd state=0
      p=soc c=tvd0 state=0
      p=soc c=tvd1 state=0
      p=soc c=tvd2 state=0
      p=soc c=tvd3 state=0
      p=soc c=lcd0 state=0
      p=soc c=lcd0 state=1
      p=soc c=pwm0 state=0
      p=soc c=pwm0 state=1
      p=soc c=pwm4 state=0
      p=soc c=pwm4 state=1
      p=soc c=car_reverse state=0
      p=soc c=Transmit_fm state=0
      p=soc c=hdmi state=0
      p=soc c=ak7601 state=0
      p=soc c=csi0 state=0
      p=csi0 c=csi0_dev0 state=0
      p=soc c=csi1 state=0
      p=csi1 c=csi1_dev0 state=0
      p=soc c=tvout_para state=0
      p=soc c=tvin_para state=0
      p=soc c=di state=0
      p=soc c=sdc0 state=0
      p=soc c=sdc1 state=0
      p=soc c=sdc2 state=0
      p=soc c=sdc3 state=0
      p=soc c=smc state=0
      p=soc c=gpio_para state=0
      p=soc c=usbc0 state=0
      p=soc c=usbc1 state=0
      p=soc c=usbc2 state=0
      p=soc c=gsensor_para state=0
      p=soc c=gps_para state=0
      p=soc c=ril_para state=0
      p=soc c=wlan state=0
      p=soc c=bt state=0
      p=soc c=btlpm state=0
      p=soc c=gy_para state=0
      p=soc c=ls_para state=0
      p=soc c=compass_para state=0
      p=soc c=spdif state=0
      p=soc c=sndspdif state=0
      p=soc c=audiohdmi state=0
      p=soc c=sndhdmi state=0
      p=soc c=snddaudio0 state=0
      p=soc c=daudio0 state=0
      p=soc c=snddaudio1 state=0
      p=soc c=daudio1 state=0
      p=soc c=sndcodec state=0
      p=soc c=codec state=0
      p=soc c=pmu0 state=0
      p=soc c=charger0 state=0
      p=soc c=powerkey0 state=0
      p=soc c=regulator0 state=0
      p=soc c=axp_gpio0 state=0
      p=soc c=dvfs_table state=0
      p=soc c=Vdevice state=0
      p=soc c=gpu_mali400_0 state=0
      Conver script to dts ok.
      dtbpath=/mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/tools/pack/out/sunxi.fex
      update_fdt: u-boot.fex will merage sunxi.fex, generate u-boot.fex
      ---0xd0, 0xd
      update_fdt: num 863156 randto1k
      update_fdt: num 161056 randto1k
      file1_len = d2c00, file2_len = 29800
      dtb offset d2c00,size 29800
      update_fdt:genrate /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/tools/pack/out/u-boot.fex ok
      pack boot package
      content_count=1
      packing for linux
      normal
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/tools/pack/pctools/linux/eDragonEx/
      Begin Parse sys_partion.fex
      FilePath: boot-resource.fex
      FileLength=447000Add partion env.fex ENV_FEX000000000
      FilePath: env.fex
      FilePath: boot.fex
      FileLength=ceb000Add partion rootfs.fex ROOTFS_FEX000000
      FilePath: rootfs.fex
      FileLength=80000000sys_config.fex Len: 0x12439
      config.fex Len: 0xceb4
      split_xxxx.fex Len: 0x200
      sys_partition.fex Len: 0xaeb
      sunxi.fex Len: 0x27520
      boot0_nand.fex Len: 0x8000
      boot0_sdcard.fex Len: 0x8000
      u-boot.fex Len: 0x110000
      toc1.fex Len: 0x8
      toc0.fex Len: 0x8
      fes1.fex Len: 0x3d80
      boot_package.fex Len: 0x114000
      full_img.fex Len: 0x16
      usbtool.fex Len: 0x23000
      aultools.fex Len: 0x27c29
      aultls32.fex Len: 0x2455d
      cardtool.fex Len: 0x11c00
      cardscript.fex Len: 0x779
      sunxi_mbr.fex Len: 0x10000
      dlinfo.fex Len: 0x4000
      arisc.fex Len: 0x6
      boot-resource.fex Len: 0x447000
      Vboot-resource.fex Len: 0x4
      env.fex Len: 0x20000
      Venv.fex Len: 0x4
      boot.fex Len: 0xceb000
      Vboot.fex Len: 0x4
      rootfs.fex Len: 0x80000000
      Vrootfs.fex Len: 0x4
      BuildImg 0
      /mnt/work_sdc1/tlA40i/LinuxSDK/tlLichee/tools/pack/sun8iw11p1_linux_tla40i-evm_uart0.img
      pack finish
      no SATA
      • livpo
        livpo LV 6 最后由 编辑
        1. 尝试选择其他显示方式,看是否可以切换成功
        2. 从log看,SDK包文件夹名字有改动,不确定是否影响。
