    g2d 进行缩放没有权限怎么回事?
      hy123456 LV 5 最后由 whycan 编辑
      static int g2d_scale_framebuf(int src_width, int src_height, int dst_width, int dst_height)
       // 获取帧缓冲长度
          int fb_size =  dst_width * dst_height * 4;
      	//int fb_fd = fbfd;
          // 映射帧缓冲到内存
          //void* fb_ptr = mmap(NULL, fb_size, PROT_READ | PROT_WRITE, MAP_SHARED, fb_fd, 0);
          //if (fb_ptr == MAP_FAILED) {
          //    perror("Failed to mmap frame buffer");
          //    //close(fb_fd);
          //    return -1;
          void * fb_ptr = malloc(fb_size);
          if(fb_ptr == NULL) {
              perror("Failed to allocate memory 1111 for scaled image");
              return -1;
         // 分配目标空间内存
          int dst_size = src_width * src_height * 4;
          void* dst_ptr = malloc(dst_size);
          if (dst_ptr == NULL) {
              perror("Failed to allocate memory for scaled image");
              //munmap(fb_ptr, fb_size);
              //close(fb_fd);
              return -1;
      //	memcpy(dst_ptr, fb_ptr, fb_size);
      	memset(dst_ptr, 0x55, dst_size);
          // 打开 G2D 设备
          int g2d_fd = open("/dev/g2d", O_RDWR);
          if (g2d_fd < 0) {
              perror("Failed to open G2D device");
              //close(fb_fd);
              return -1;
      	g2d_stretchblt str;
          g2d_image image_front, scn;
          g2d_rect src_rect, dst_rect;
          /* 设置源图像参数 */
          image_front.addr[0] = dst_ptr;
          image_front.w = src_width;
          image_front.h = src_height;
          image_front.format = G2D_FMT_RGBX8888;
          image_front.pixel_seq = G2D_SEQ_NORMAL;
          image_front.addr[1] = dst_ptr + image_front.w *image_front.h;
          /* 设置目标图像参数 */
          scn.addr[0] = fb_ptr;
          scn.w = dst_width;
          scn.h = dst_height;
          scn.format = G2D_FMT_RGBX8888;
          scn.pixel_seq = G2D_SEQ_NORMAL;
          /* 设置源和目标矩形区域 */
          src_rect.x = 0;
          src_rect.y = 0;
          src_rect.w = src_width;
          src_rect.h = src_height;
          dst_rect.x = 0;
          dst_rect.y = 0;
          dst_rect.w = dst_width;
          dst_rect.h = dst_height;
          /* 设置缩放参数 */
          str.flag = 0;
          str.color = 0xffffffff;
          str.alpha = 0xff;
          /* 设置源图像和矩形区域 */
          str.src_image.addr[0] = image_front.addr[0];
      	str.src_image.addr[1] = image_front.addr[1];
          str.src_image.w = image_front.w;
          str.src_image.h = image_front.h;
          str.src_image.format = image_front.format;
          str.src_image.pixel_seq = image_front.pixel_seq;
          str.src_rect = src_rect;
          /* 设置目标图像和矩形区域 */
          str.dst_image.addr[0] = scn.addr[0];
          str.dst_image.w = scn.w;
          str.dst_image.h = scn.h;
          str.dst_image.format = scn.format;
          str.dst_image.pixel_seq = scn.pixel_seq;
          str.dst_rect = dst_rect;
          // 执行 G2D 缩放操作
          if (ioctl(g2d_fd, G2D_CMD_STRETCHBLT, &str) < 0) {
              perror("G2D_CMD_STRETCHBLT failed....");
             // munmap(fb_ptr, fb_size);
              close(g2d_fd);
              //close(fb_fd);
              return -1;
          // 释放目标空间内存
          free(dst_ptr);
      	free(fb_ptr);
          // 解除帧缓冲内存映射
          // 关闭 G2D 设备
         close(g2d_fd);
      int main() {
          const char *image_path = "image.bmp";
          const char *framebuffer_path = "/dev/fb0";
          //write_to_framebuffer(image_path, framebuffer_path);
      	g2d_scale_framebuf(1024,600,800,480);
      写了个小程序测试一下用g2d进行缩放。执行的时候提示没有权限,问题出在那里了?
      root@TinaLinux:~# /usr/bin/a.out
      G2D_CMD_STRETCHBLT failed....: Operation not permitted
