    Neza-D1开发板学习之SPI-LCD灯篇
    • X
      xfdr0805 LV 5 最后由 编辑
      1. Neza-D1开发板芯片很强,但是没有引出RGB接口,板上引出了HDMI与MIPI接口,没引出RGB接口,手里的RGB接口的屏用不上了,扩展IO上有引出SPI1接口,看了一下尺寸,刚好可以放的下2.8”的SPI屏幕,正好手里有以前剩下的屏幕,就画了一块扩展板(可惜芯片是BGA封装,即使我能画出来,也没本事焊上啊!),驱动芯片是ili9341 4线SPI,又加了一个触摸芯片上去,如下图
      2. 设备树配置
          lcd_ili9341@0 {
      		#address-cells = <1>;
      		#size-cells = <1>;
      		compatible = "ilitek,ili9341";
      		reg = <0>;
      		spi-max-frequency = <32000000>;
      		rotation = <0>;
      		spi-cpol;
      		spi-cpha;
      		rgb;
      		fps = <30>;
      		buswidth = <8>;
      		txbuflen = <32768>;
      		reset-gpios = <&pcf8574 6 GPIO_ACTIVE_LOW>;
      		dc-gpios = <&pcf8574 7 GPIO_ACTIVE_LOW>;
      		/*backlight = <&backlight>;*/
      		led-gpios = <&pcf8574 5 GPIO_ACTIVE_HIGH>;
      1. 在内核打开small lcd support选项
        [] Staging drivers --->
        > Support for small TFT LCD display modules --->3
        <*> FB driver for the ILI9341 LCD Controller
      2. 系统启动log
          [    2.670067] fbtft_of_value: buswidth = 8
          [    2.674512] fbtft_of_value: backlight = 39
          [    2.679097] fbtft_of_value: fps = 30
          [    2.683098] fbtft_of_value: txbuflen = 32768
          [    2.691259] GPT:Primary header thinks Alt. header is not at the end of the disk.
          [    2.699560] GPT:625184 != 7774207
          [    2.703265] GPT:Alternate GPT header not at the end of the disk.
          [    2.709981] GPT:625184 != 7774207
          [    2.713688] GPT: Use GNU Parted to correct GPT errors.
          [    2.719480]  mmcblk0: p1 p2 p3 p4
          [    2.987837] random: fast init done
          [    3.036258] graphics fb1: fb_ili9341 frame buffer, 240x320, 150 KiB video memory, 32 KiB buffer memory, fps=31, spi1.0 at 32 MHz
      1. 这里有一点需要注意,我们使用的GPIO是通过PCF8574扩展出来的,对IO读写操作时可能会导致休眠,因此不能在中断函数里使用,我们需要简单的修改一下驱动文件,用一个宏定义即可,如果不修改操作一次IO,就会出现一堆警告
        #define gpio_set_value gpio_set_value_cansleep
      2. 进系统里可以查看是否有对应设备
         # ls /dev/fb*
         /dev/fb0  /dev/fb1
         测试屏幕
         # cat /dev/urandom > /dev/fb1
         cat: write error: No space left on device
         清屏
         # cat /dev/zero > /dev/fb1
         显示图片
