    D1s芯片烧录melis固件启动报错,大家帮我看看咋回事
      liu11372650 LV 2 最后由 编辑
      错误日志
      [34]HELLO! BOOT0 is starting!
      [37]BOOT0 commit : 889f614
      sbi2ekernel
      |                  /'\_/`\       (_ )  _                      ( )( )     /' _`\    /' _`\
      |                  |     |   __   | | (_)  ___  ______  _   _ | || |     | ( ) |   | ( ) |
      |                  | (_) | /'__`\ | | | |/',__)(______)( ) ( )| || |_    | | | |   | | | |
      |                  | | | |(  ___/ | | | |\__, \        | \_/ |(__ ,__) _ | (_) | _ | (_) |
      |                  (_) (_)`\____)(___)(_)(____/        `\___/'   (_)  (_)`\___/'(_)`\___/'
      |version : V3.9.0        |
      |commitid: a850c7b6b408b36ea58bcce024f7c788688ca5ab                                                           |
      |sunxiver: 40000        |
      |timever : Mon, 04 Sep 2023 06:29:12 -0700        |
      |compiler: gcc version 8.4.0 (T-HEAD RISCV Tools V1.10.2 B20201104)                                           |
      |optimal : -Os -g -gdwarf-2 -gstrict-dwarf        |
      |linker  : GNU ld (GNU Binutils) 2.32        |
      |newlibc : 3.0.0        |
      |author  : user        |
      [DBG]: [__mount_parts:0299]:                                classname=DMS
      [DBG]: [__mount_parts:0300]:                                devname=dms01
      [DBG]: [__mount_parts:0327]:                                find last lun.
      [DBG]: [__mount_parts:0357]:                                nPart = 1.
      [DBG]: [__mount_parts:0486]:                                dmsPart: "DMS\dms010" is linked to symbel "B".
      [ERR]: [esFSYS_pread:0331]:                                 fs fatal err
      mount errno: -19!
      [DBG]: [esFSYS_mntfs:0333]:                                 melis_devfs,mount on B.
      [DBG]: [kservice_maintask:0845]:                            partition [B] plug in..
      [DBG]: [__mount_parts:0299]:                                classname=DISK
      [DBG]: [__mount_parts:0300]:                                devname=RAMDISK
      [DBG]: [__mount_parts:0486]:                                rawpart: "DISK\RAMDISK0" is linked to symbel "C".
      [ERR]: [esFSYS_mntfs:0314]:                                 identify the filesystem failure.
      [ERR]: [__mount_parts:0541]:                                mount C failure.
      dfs already init.
      flash : 1
      sip : 0
      hal_spi_hw_config()2025 [spi0] clock_frequency = 50000000HZ
      hal_spi_init()2215 [spi0] DMA xfer enable
      nor_scan
      flash : 1
      sip : 0
      nor_factory_init
      nor flash init ok
      scheduler startup
      [DBG]: [__mount_parts:0300]:                                devname=ROOTFS
      [DBG]: [__mount_parts:0486]:                                rawpart: "DISK\ROOTFS0" is linked to symbel "D".
      [DBG]: [esFSYS_mntfs:0333]:                                 minfs,mount on D.
      [DBG]: [kservice_maintask:0845]:                            partition [D] plug in..
      [DBG]: [melis_udisk_part_check:0557]:                       melis_udisk_part_check 557 copy udisk_buff
      [DBG]: [__mount_parts:0300]:                                devname=UDISK
      [DBG]: [check_msdos_partition:0640]:
      [DBG]: [__mount_parts:0486]:                                rawpart: "DISK\UDISK0" is linked to symbel "E".
      [DBG]: [esFSYS_mntfs:0333]:                                 fat,mount on E.
      [DBG]: [kservice_maintask:0845]:                            partition [E] plug in..
      SDC:hal_sdc_create host:0x402065d8 id:0
      host debug mask 3c[ERR] SDC:name ???,port 6,port_num 0,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name ???,port 6,port_num 1,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name ???,port 6,port_num 2,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name ???,port 6,port_num 3,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name ???,port 6,port_num 4,mul_sel 2, pull 1, drv_level 1
      [ERR] SDC:name ???,port 6,port_num 5,mul_sel 2, pull 1, drv_level 1
      SDC:Not implement __mci_restore_io,819
      SDC:Not imp hal_sdc_init,2236
      SDC:hal_sdc_init,2269 no imp
      SDC:hal_sdc_init,2278 no imp
      SDC:SDC Host Capability:0x3820f Ocr avail:0x3f0000
      SDC:Not implement __mci_hold_io,804
      SDC:SDC cd_mode:2 present_val:0
      SDC:SDC id:0 dma_use:1 present:0
       driver version SD/MMC/SDIO Host Controller Driver(v0.29 2022-09-01 16:50) init ok.
      host_id =0!
      [ERR]: [hal_ths_init:0094]:                                 0x2009404, 0x2009400, 0x2009430, 0x2009408
      key name:thermal_sensor key size:64 key offset:20
      thermal_sensor:
      ef 00 7b 89 0d b0 e9 01
      ERR ekernel/drivers/hal/source/usb/manager/usb_manager.c 276 usb_script_parse :script_parser_fetch usbc0 usb_drv_vbus_gpio fail
      port_info->port.port_type:2
      [ERR]: [gpio_conf_set:0468]:                                gpio_desc is not inited
      [ERR]: [hal_gpio_pinmux_set_function:0701]:                 set pin mux error!
      the cir_master_init success
      Warning: clk pll-audio0 should not be changed, please recheck whether the operation is correct
      [SND_ERR][sunxi_daudio_gpio_init:1012][daudio1] sys_config has no GPIO
      [ehci-usb1] insmod host driver!
      phy_vbase : 0x4200800, usbc_no : 1, efuse : 0x1e9b00d
      [ohci-usb1] insmod host driver!
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\slib.mod.
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\display.mod.
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\mixture.mod.
      [ERR]: [hal_pwm_pinctrl_init:0269]:                         [pwm7] not support in sys_config
      [ERR]: [hal_pwm_control:0580]:                              [pwm7] clk_osc24m not support in sys_config
      [DBG]: [layer_request:0691]:                                layer_request MOD_DISP_LAYER_WORK_MODE_SCALER
      [DBG]: [layer_request:0739]:                                requested: ch:0, id:0  disp_mgr[0].req_layer_cnt = 1
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\charset.mod.
      msh />enter app_entry
      Execute startup script begin..............
               install mod para num [2]: insmod d:\mod\orange.mod
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\mod\orange.mod.
      Mod:d:\mod\orange.mod Installed!, mod id=120
               install mod para num [2]: insmod d:\apps\desktop.mod
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\apps\desktop.mod.
      [DBG]: [DESKTOP_MOpen:0091]:                                DESKTOP_MOpen.
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\apps\init.axf.
      Mod:d:\apps\desktop.mod Installed!, mod id=127
      ...............Execute startup script end
      [DBG]: [msg_srv_init_key_channel:0163]:                     emit_ctr.h_keyGraber=0x40dfb180
      [DBG]: [msg_srv_init_key_channel:0174]:                     LdevID=0
      [DBG]: [application_init_process:0856]:                     &           application_init_process enter!             &
      [DBG]: [application_init_process:0874]:                     application_init_process 874 before live_init
      [DBG]: [live_init:0054]:                                    ~~~~~~~~~~~~~~before dsk_set_isn_charset~~~~~~~~~~~
      [DBG]: [alsa_open_pcm:0316]:                                alsa open pcm! card:[audiocodec], pcmFlag:[1](0-cap;1-play)
      [DBG]: [dsk_display_set_lcd_brightness:0300]:               setting lcd_bright=176
      [DBG]: [application_init_process:0882]:                     application_init_process 882 before gscene_bgd_init
      [DBG]: [gscene_bgd_is_file_exist:0633]:                     file is exist:d:\apps\bg_default0.bgd
      [DBG]: [gscene_bgd_init:0143]:                              bgd_com->screen_size.width = 480  bgd_com->screen_size.height = 272  ftype = 1
      [DBG]: [application_init_process:0903]:                     .start device monitor .......................................
      [DBG]: [application_init_process:0911]:                     application_init_process 911 before init_mainwin_create
      [DBG]: [dsk_display_set_lcd_brightness:0300]:               setting lcd_bright=192
      [DBG]: [__hbar_layer_create:0107]:                          hbar fb 480 24 gui_dir=0
      [DBG]: [__hbar_layer_create:0108]:                          hbar src 0 0 480 24
      [DBG]: [__hbar_layer_create:0109]:                          hbar scn 0 0 480 24
      [DBG]: [reset_headbar_data:0287]:                           xxxxxx para->data.volume = 30
      [DBG]: [reset_headbar_data:0291]:                           xxxxxx bright = 11
      [DBG]: [init_mainwin_cb:2445]:                              .start device monitor .......................................
      [DBG]: [application_init_process:0917]:                     application_init_process 917 before _process_init
      [DBG]: [applet_info_manager_load_dir:0320]:                 find dir file d:\apps\desktop\app_root.desktop!
      [DBG]: [applet_info_manager_load_file:0280]:                filename = d:\apps\desktop\app_root.desktop len=124
      [DBG]: [__activity_load_common:0408]:                       load application application://app_root.
      [DBG]: [LDR_LoadFile:0261]:                                 filepath = d:\apps\app_root.axf.
      [DBG]: [app_home_create:0688]:                              ********  enter multi screen home application  **************
      [DBG]: [gscene_bgd_is_file_exist:0633]:                     file is exist:d:\apps\bg_defaul[usb0] insmod device driver!
      adbd version:AW-V1.1.0, compiled on: Aug 26 2023 21:12:52
      phy_vbase : 0x4100400, usbc_no : 0, efuse : 0x1e9b00d
      adbd service init successful
      t0.bgd
      [DBG]: [get_fb_from_file:0423]:                             filename=d:\apps\bg_default0.bgd
      [DBG]: [get_fb_from_file:0465]:                             bg pic is compress...
      [DBG]: [get_fb_from_file:0468]:                             compress_buf=41310000
                                               EXC_LOAD_PAGE_FAULT
      thread: initprocess, entry: 0x00000000e1701c0a, stack_base: 0x0000000040fb7000,stack_size: 0x00010000.
       x0:0x0000000000000000   ra:0x00000000e17099a0   sp:0x0000000040fc6430   gp:0x0000000040130bbc
       tp:0x0000000040230240   t0:0x0000000000000001   t1:0x00000000400bf46a   t2:0x000000004142a644
       s0:0x8181818181818000   s1:0x00081818181416b4   a0:0x8181818181818181   a1:0x0000000000000466
       a2:0x0000000000000001   a3:0x0000000000000008   a4:0x0000000000000001   a5:0x0000000000000000
       a6:0x0000000000000320   a7:0x0000000010000201   s2:0x0000000040143af0   s3:0x00000000413cb854
       s5:0x0000000040143ae0   s5:0x8181818181818181   s6:0x0000000040164000   s7:0x0000000041182740
       s8:0x0000000000000000   s9:0x0000000041310000  s10:0x0000000000000001  s11:0x000000000005dc00
       t3:0x0000000000119454   t4:0x0000000000000004   t5:0x0000000000000008   t6:0x000000000000001f
      other:
      sepc    :0x000000004003049c
      scause  :0x000000000000000d
      stval   :0x00000060a0669ad0
      sstatus :0x0000000200004120
      sscratch:0x0000000000000000
      -------backtrace-----------
      backtrace : 0X4003049C
      backtrace : 0XE170999C
      backtrace : 0XE1707F58
      backtrace : 0XE1706BF2
      backtrace : 0XE1706CA0
      backtrace : 0X4003118E
      backtrace : 0XE92024AC
      backtrace : 0X400B34EC
      backtrace : 0XE1825368
      backtrace : 0XE1813624
      backtrace : 0XE1817D76
      backtrace : 0XE9203B16
      backtrace : 0XE9200A30
      backtrace : 0XE9241D74
      backtrace : 0XE1F0DBBA
      backtrace : 0XE1F0938A
      backtrace : 0XE1F07FF0
      backtrace : 0XE1F08184
      backtrace : 0XE17018B8
      backtrace : 0XE1701E36
      backtrace : 0X40028E9E
      backtrace : 0X40028E3E
          -----------------------------------------------TSK Usage Report----------------------------------------------------------
              name     errno    entry       stat   prio     tcb     slice stacksize      stkfree  lt    si   so       stack_range
          adbd-output    0   0x400addc0    suspend   20   0x40230d38    5     8192        7616    05  0000 0000  [0x412cc000-0x412ce000]
           adbd-input    0   0x400addc0    suspend   20   0x40230b58    5     8192        7600    05  0000 0000  [0x412ca000-0x412cc000]
           initbkhdle   -2   0xe1704ba8    running   24   0x40230978   15     2048        1592    15  0000 0000  [0x40e87000-0x40e87800]
        headbar_fresh    0   0xe1703eae    suspend   24   0x40230798   15     8192        7608    15  0000 0000  [0x4121e000-0x41220000]
           0xE1F0B02A    0   0xe1f0b02a    suspend   24   0x402305b8   15    16384       15552    15  0000 0000  [0x40fc7000-0x40fcb000]
         appmsg2emitq    0   0xe1f0c81e    suspend    9   0x402303d8   20     4096        3480    20  0000 0000  [0x40fac000-0x40fad000]
          initprocess    0   0xe1701c0a    running   24   0x402301f8   15    65536       59392    07  0000 0000  [0x40fb7000-0x40fc7000]
         emitq2orange   -2   0xe1f0d41e    running   24   0x40230018   15     4096        3008    13  0000 0000  [0x40fab000-0x40fac000]
             OrangTmr    0   0xe18123c2    suspend    9   0x4022fe38   20     4096        3544    20  0000 0000  [0x40f6d000-0x40f6e000]
               tshell    0   0x400aa1ee    suspend   20   0x4022fc58   10    16384       13008    01  0000 0000  [0x40edb000-0x40edf000]
             kb_input    0   0x400b1c18    suspend    3   0x4022fa78   10     4096        2752    10  0000 0000  [0x40ed9000-0x40eda000]
               hub_tt    0   0x4002f9b8    suspend    3   0x4022f898   10     8192        7872    10  0000 0000  [0x40e73000-0x40e75000]
      hub-status-thread    0   0x4006ac2a    suspend    3   0x4022f6b8   10     8192        7712    10  0000 0000  [0x40e71000-0x40e73000]
      giveback_workqueue    0   0x4002f9b8    suspend    3   0x4022f4d8   10     1024         704    10  0000 0000  [0x402a2c00-0x402a3000]
               hub_tt    0   0x4002f9b8    suspend    3   0x4022f2f8   10     8192        7872    10  0000 0000  [0x40e67000-0x40e69000]
      hub-status-thread    0   0x4006ac2a    suspend    3   0x4022f118   10     8192        7712    10  0000 0000  [0x40e65000-0x40e67000]
      giveback_workqueue    0   0x4002f9b8    suspend    3   0x4022ef38   10     1024         704    10  0000 0000  [0x402a2800-0x402a2c00]
           0x40038A2E    0   0x40038a2e    suspend   24   0x4022eb78   15     4096        3600    15  0000 0000  [0x4028b000-0x4028c000]
      usb-hardware-scan    0   0x4007a872    suspend    3   0x4022e998   10     8192        5040    09  0000 0000  [0x40db7000-0x40db9000]
                disp2    0   0x4002f9b8    suspend   15   0x4022e7b8   10     8192        5736    09  0000 0000  [0x40d62000-0x40d64000]
      hub-main-thread    0   0x4006c9e6    suspend    3   0x4022e5d8   10     8192        6928    10  0000 0000  [0x402fe000-0x40300000]
            kmsg2appq    0   0x400b6154    suspend    6   0x4022e3f8   10     4096        3376    07  0000 0000  [0x4028a000-0x4028b000]
             mnt_task    0   0x400df94e    suspend    7   0x4022e218   10    16384       15936    10  0000 0000  [0x4023a000-0x4023e000]
                tidle    0   0x4002bac2    running   31   0x4013d030   32     8192        7488    21  0000 0000  [0x4013d228-0x4013f228]
                timer    0   0x4002f834    suspend    8   0x4013f900   10    16384       16016    10  0000 0000  [0x4013fad8-0x40143ad8]
          memory info:
              Total  0x03e9c000
              Used   0x010ec3f8
              Max    0x010f17f8
          ------------------------------------------------memory information-------------------------------------------------------
      dump stack memory:
      0x0000000040fc6430: 0x00000000 0x00000000 0x41310000 0x00000000
      0x0000000040fc6440: 0x00000010 0x00000000 0x000000ff 0x00000000
      0x0000000040fc6450: 0xe170b5d8 0x00000000 0x413cb854 0x00000000
      0x0000000040fc6460: 0x40274260 0x00000000 0x00119454 0x00000000
      0x0000000040fc6470: 0x0005dc00 0x00000000 0xe17099a0 0x00000000
      0x0000000040fc6480: 0x40274260 0x00000000 0xe1707f5c 0x00000000
      0x0000000040fc6490: 0x41310000 0x00000000 0xe170b5d8 0x00000000
      0x0000000040fc64a0: 0x40230240 0x00000000 0x412cf000 0x00000000
      0x0000000040fc64b0: 0x411827a4 0x00000000 0x00000001 0x00000000
      0x0000000040fc64c0: 0x00000002 0x00000000 0x00000001 0x00000000
      0x0000000040fc64d0: 0x00000320 0x00000000 0x000001e0 0x00000000
      0x0000000040fc64e0: 0x00001000 0x00000000 0x00000320 0x000001e0
      0x0000000040fc64f0: 0x41310054 0x00000000 0x4136dc54 0x00000000
      0x0000000040fc6500: 0x413cb854 0x00000000 0x00000001 0x00000000
      0x0000000040fc6510: 0x00ff0110 0x00000000 0x00000000 0x00000000
      0x0000000040fc6520: 0x00000000 0x00000000 0x00000002 0x00000000
      0x0000000040fc6530: 0xe170f178 0x00000000 0xdeadbeef 0x00000000
      0x0000000040fc6540: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040fc6550: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040fc6560: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040fc6570: 0xe1800000 0x00000000 0x403143f8 0x00000000
      0x0000000040fc6580: 0x40fc67b0 0x00000000 0x41182738 0x00000000
      0x0000000040fc6590: 0xe170f178 0x00000000 0xe1706bf6 0x00000000
      0x0000000040fc65a0: 0x40314530 0x00000000 0xdeadbeef 0x00000000
      0x0000000040fc65b0: 0xe1800000 0x00000000 0x00e1f000 0x00000000
      0x0000000040fc65c0: 0x0000000a 0x00000000 0xe1706ca4 0x00000000
      0x0000000040fc65d0: 0xe1700000 0x00000000 0xe9228efc 0x00000000
      0x0000000040fc65e0: 0xe9250338 0x00000000 0x40f6f8f8 0x00000000
      0x0000000040fc65f0: 0x403143f8 0x00000000 0x40031192 0x00000000
      0x0000000040fc6600: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040fc6610: 0x0000ff5b 0x00074402 0x403143f8 0x00000000
      0x0000000040fc6620: 0x40f6f8f8 0x00000000 0x40f6f738 0x00000000
      dump epc memory:
      0x000000004003049c: 0x449b478b 0x8b8d4709 0x04e79463 0xa0df80ef
      0x00000000400304ac: 0x449b478b 0x00113717 0x66070713 0x7c27b58b
      0x00000000400304bc: 0x578b8b8d 0x631c449b 0x00c59693 0x8f95e42e
      0x00000000400304cc: 0x80efe31c 0x65a29edf 0x64068556 0x74e260a6
      0x00000000400304dc: 0x79a27942 0x6ae27a02 0x61616b42 0xf2cff06f
      0x00000000400304ec: 0x18078b63 0x9c5f80ef 0x478b89aa 0xb78b449b
      0x00000000400304fc: 0x979b7c27 0x8c1d00c7 0x57b74018 0x879351ab
      0x000000004003050c: 0x0e631ab7 0x061300f7 0x85975a90 0x8593000b
      0x000000004003051c: 0x85170625 0x0513000b 0xd0ef1e25 0x781cd41f
      0x000000004003052c: 0x00113717 0x5e470713 0x00fab023 0x5054631c
      0x000000004003053c: 0x03543823 0xe31c8f95 0x871b405c 0xc0580017
      0x000000004003054c: 0x5418eb99 0x00113797 0x5c878793 0x66e7c68b
      0x000000004003055c: 0xd40be814 0x404c66e7 0x5a634450 0x505402b6
      0x000000004003056c: 0x85178756 0x0513000b 0xd0ef01a5 0x2423bbbf
      0x000000004003057c: 0x445c0004 0x6406c05c 0x74e260a6 0x7a027942
      0x000000004003058c: 0x6b426ae2 0x79a2854e 0x806f6161 0x441c925f
      0x000000004003059c: 0xc41c37fd 0x8e639fad 0x061300c7 0x85975f30
      0x00000000400305ac: 0x8593000b 0x8517fce5 0x0513000b 0xd0ef03e5
      0x00000000400305bc: 0x4058cadf 0x10e3445c 0x681cfcf7 0x00113497
      0x00000000400305cc: 0x55048493 0x541ce791 0x66f4c78b 0xfa8785e3
      0x00000000400305dc: 0xcf89441c 0x5ff00613 0x000b8597 0xf9458593
      0x00000000400305ec: 0x000b8517 0xfd450513 0xc73fd0ef 0x970b541c
      0x00000000400305fc: 0xc78b06f4 0x986366f4 0x681c0687 0xe31c4589
      0x000000004003060c: 0xc01c57fd 0x00113797 0x75078793 0x00113717
      0x000000004003061c: 0x74070713 0x63104394 0x851be300 0xe8100016
      0x000000004003062c: 0xdae3c388 0xc394f4a5 0x000a3783 0x3703e310
      0x000000004003063c: 0x07b30009 0x83b140f4 0x04f7178b 0x00113717
      0x000000004003064c: 0x72070713 0x47014314 0x02d74363 0x80ef854e
      0x000000004003065c: 0x3797861f 0x87930011 0x438c70e7 0x85226785
      0x000000004003066c: 0x02f5c5bb 0x8713b59d 0x6b9c0107 0xd00bb769
      0x000000004003067c: 0x070544e7 0x60a6bfd1 0x74e26406 0x79a27942
      0x000000004003068c: 0x6ae27a02 0x61616b42 0x80828082 0x3797cd09
      msh />
        awwwwa LV 8 @liu11372650 最后由 编辑
        @liu11372650 在 D1s芯片烧录melis固件启动报错,大家帮我看看咋回事 中说:
        0x000000004003049c
        根据这个地址,objdump出来elf去找一下是哪一个函数报错
