    wifi 模块无法使用问题
    • N
      NLJ_Moon LV 5 最后由 编辑
      root@TinaLinux:/lib/modules/5.4.61# insmod xr829.ko
      [ 34.226001] ======== XRADIO WIFI OPEN ========
      [ 34.231513] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [ 34.238325] [XRADIO] Allocated hw_priv @ 65abb3d7
      [ 34.244182] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [ 34.260599] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [ 34.467788] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 34.474327] [XRADIO] Detect SDIO card 1
      [ 34.479019] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [ 34.503409] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 34.528273] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 34.542858] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [ 34.564923] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [ 34.576515] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [ 34.588354] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [ 34.600868] mmc1: new high speed SDIO card at address 0001
      [ 34.607506] [SBUS] XRadio Device:sdio clk=50000000
      [ 34.613613] [XRADIO] XRADIO_HW_REV 1.0 detected.
      [ 34.738211] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000.
      [ 34.821706] [XRADIO] Bootloader complete
      [ 34.920347] [XRADIO] Firmware completed.
      [ 34.926350] [WSM] Firmware Label:XR_C09.08.52.73_DBG_02.122 2GHZ HT40 May 18 2021 13:36:09
      [ 34.935832] [XRADIO] Firmware Startup Done.
      [ 34.940741] [XRADIO_WRN] enable Multi-Rx!
      [ 34.945937] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
      root@TinaLinux:/lib/modules/5.4.61# ifconfig wlan0 up
      [ 44.908379] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=bc:bc:44:ed:ed:c5
      [ 44.916542] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=bc:bc:44:ed:ed:c5
      [ 44.931914] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
      root@TinaLinux:/lib/modules/5.4.61# wifi -s
      Can't connect to the wifi daemon server: No such file or directory
      球球大家了,帮忙看看这个是什么问题,wifi命令不能使用,iw命令可以搜索wifi
      X 1 条回复 最后回复 回复 引用 分享 0
      • X
        xiejun LV 2 @NLJ_Moon 最后由 编辑
        @nlj_moon 执行wifi_daemon 然后wifi的测试命令就可以使用了
