    f1c200s Tina分区烧录报烧写MBR失败,有没有大佬帮忙看看!!
    • X
      xlbwxbl LV 5 最后由 编辑
      烧写时无法选择全盘擦除升级(好像是这个芯片就是这样的),所以只能选择分区擦除。然后烧入失败。
      小机端打印log如下:
      [23]init dram ok
      U-Boot 2014.07 (Jul 31 2018 - 14:59:19) Allwinner Technology
      uboot commit : 6604446f7bddb8fe53f2b993100929f92a5f4d6e
      i2c_init: by cpux
      [I2C-DEBUG]:i2c_set_clock() 354
      [I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
      i2c_init ok
      [2.935]pmbus:   ready
      axp: get node[/soc/pmu0] error
      axp_probe error
      [2.941]PMU: cpux 408 Mhz,AXI=408 Mhz
      PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
      DRAM:  32 MiB
      [2.950]fdt addr: 0x809e7920
      [2.953]gd->fdt_size: 0xc2a0
      Relocation Offset is: 01524000
      int sunxi_dma_init---
      irq enable
      [3.022]flash init start
      workmode = 16,storage type = 3
      try card 1
      [3.028][mmc]: mmc driver ver 2018-6-1 17:39:00
      SUNXI SD/MMC: 1
      [3.046][mmc]: ************Try SD card 1************
      [mmc]: mmc 1 cmd 8 timeout, err 100
      [mmc]: smc 1 err, cmd 8,  RTO
      [mmc]: mmc 1 close bus gating and reset
      [mmc]: mmc 1 mmc cmd 8 err 0x00000100
      [3.064][mmc]: mmc send if cond failed
      [mmc]: mmc 1 cmd 55 timeout, err 100
      [mmc]: smc 1 err, cmd 55,  RTO
      [mmc]: mmc 1 mmc cmd 55 err 0x00000100
      [3.081][mmc]: send app cmd failed
      [3.084][mmc]: ************Try MMC card 1************
      [mmc]: mmc 1 cmd 1 timeout, err 100
      [mmc]: smc 1 err, cmd 1,  RTO
      [mmc]: mmc 1 mmc cmd 1 err 0x00000100
      [3.106][mmc]: read op condition failed
      [3.109][mmc]: mmc send op cond failed
      Card did not respond to voltage select!
      [3.116][mmc]: ************SD/MMC 1 init error!!!************
      [3.122][mmc]: mmc_init_boot: mmc int fail
      [3.126][mmc]: mmc_init: mmc init fail, err -17
      MMC init failed
      try emmc fail
      [3.133]NAND_UbootProbe start...
      [3.136]NB1 : enter phy init
      [3.138]nand_physic_init
      [3.142]nand0: get node offset error
      [3.145]init nctri NAND PIORequest error!
      [3.149]nand_physic_init, init nctri error
      [3.153]nand_physic_init init_parameter error
      [3.157]nand_physic_init error -1
      [3.160]SpiNandHwInit: Start Nand Hardware initializing Jun  9 2018 19:05:34.....
      [3.167]uboot: nand version: 3 6008 20180610 1300
      [3.184]request spi gpio  ok!
      irq enable
      [3.190]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c7c
      [3.197]request general tx dma channel ok!
      [3.201]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x81db8c9c
      [3.208]request general rx dma channel ok!
      [3.212]SPI nand ID: 20c21720 1720c217
      [3.215]_SearchNandArchi fail
      [3.218][ERR]SpiNandHwInit: SCN_AnalyzeNandSystem() failed!
      [3.223]SpiNandHwInit: End Nand Hardware initializing ..... FAIL!
      [3.229]NB1 : nand phy init fail
      [3.232]NB1 : enter phy Exit
      nand release dma:81db8c7c
      nand release dma:0
      sunxi dma exit
      [3.240]NAND_UbootProbe end: 0xffffffff
      try nand fail
      flash size =0x8000 sectors
      sunxi spinor is initing...int sunxi_dma_init---
      irq enable
      sunxi_dma_install_int ok
      OK
      spinor id:0x1720c2
      spi_freq = 40000000
      spinor id is 1720c2
      try nor successed
      read mbr copy[0] failed
      read mbr copy[1] failed
      read mbr copy[2] failed
      read mbr copy[3] failed
      [3.274]flash init end
      [3.276]try to burn key
      [3.280]inter uboot shell
      work mode=0x10
      run usb efex
      delay time 2500
      usb init ok
      set address 0xd
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      sys_confog.fex文件配置如下:
      #kernel command arguments
      enforcing=1
      #earlyprintk=sunxi-uart,0x01c25000
      earlyprintk=sunxi-uart,0x01C25800
      initcall_debug=1
      #console=ttyS1,115200
      console=ttyS3,115200
      nor_root=/dev/mtdblock4
      nand_root=/dev/nandd
      mmc_root=/dev/mmcblk0p7
      init=/sbin/init
      rdinit=/rdinit
      loglevel=8
      cma=32M
      verify=no
      rootdelay=5
      #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
      setargs_nor=setenv bootargs enforcing=${enforcing} earlyprintk=${earlyprintk} initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nor_root} init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma}
      setargs_nand=setenv bootargs enforcing=${enforcing} earlyprintk=${earlyprintk} initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma}
      setargs_mmc=setenv  bootargs enforcing=${enforcing} earlyprintk=${earlyprintk} initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} rootdelay=${rootdelay}
      #uImage/fat32  addr:0x80007fc0 = 0x80008000(kernel entry) - 0x40(uImage header Bytes)
      #boot_normal=fatload sunxi_flash boot 80007fc0 uImage;bootm 80007fc0
      #boot_recovery=fatload sunxi_flash recovery 80007fc0 uImage;bootm 80007fc0
      #boot.img/fat32  addr:0x80007800 = 0x80008000(kernel entry) - 0x200(boot.img header Bytes)
      #boot_normal=fatload sunxi_flash boot 80007800 boot.img;boota 80007800 boot
      #boot_recovery=fatload sunxi_flash recovery 80007800 boot.img;boota 80007800 recovery
      #uImage/raw
      boot_normal=sunxi_flash read 80007fc0 boot;bootm 80007fc0
      boot_recovery=sunxi_flash read 80007fc0 recovery;bootm 80007fc0
      #boot.img/raw  same as sunxi-dev
      #boot_normal=sunxi_flash read 45000000 boot;boota 45000000 boot
      #boot_recovery=sunxi_flash read 45000000 recovery;boota 45000000 recovery
      boot_fastboot=fastboot
      #recovery key
      recovery_key_value_max=0x13
      recovery_key_value_min=0x10
      #fastboot key
      fastboot_key_value_max=0x8
      fastboot_key_value_min=0x2
      #uboot system env config
      bootdelay=0
      bootcmd=run setargs_nand boot_normal#default nand boot
      env-3.10.cfg配置如下:
      enforcing=1
      initcall_debug=1
      init=/sbin/init
      rdinit=/rdinit
      loglevel=8
      cma=32M
      verify=no
      rootdelay=5
      #uImage/raw
      #recovery key
      #fastboot key
      bootdelay=0
      相关分区配置文件如下:
      sys_partition.fex
      ;    mbr的大小, 以Kbyte为单位
      [mbr]
      size = 4096
      ;  partition 定义范例:
      ; 注:1、name唯一, 不允许同名
      ;     2、name最大12个字符
      ;     4、为了安全和效率考虑,分区大小最好保证为16M字节的整数倍
      [partition_start]
      [partition]
          name         = bootlogo
          size         = 1024
          downloadfile = "bootlogo.fex"
          user_type    = 0x8000
      [partition]
          name         = env
          size         = 512
          downloadfile = "env.fex"
          user_type    = 0x8000
      [partition]
          name         = boot
          ;size         = 4096
          size         = 12288
          downloadfile = "boot.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs
          size         = 51200
          downloadfile = "rootfs.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs_data
          size         = 51200
          user_type    = 0x8000
      ;[partition]
      ;  name         = extend
      ;   size         = 8192
      ;    downloadfile = "usr.fex"
      ;    user_type    = 0x8000
      [partition]
          name         = misc
          size         = 512
          user_type    = 0x8000
      [partition]
          name         = private
          size         = 512
          user_type    = 0x8000
      [partition]
          name         = UDISK
          user_type    = 0x8100
      sys_partition_nor.fex
      ;    mbr的大小, 以Kbyte为单位
      [mbr]
      size = 16
      ;  partition 定义范例:
      ; 注:1、name唯一, 不允许同名
      ;     2、name最大12个字符
      [partition_start]
      [partition]
          name         = bootlogo
          size         = 1024
          user_type    = 0x8000
      [partition]
          name         = env
          size         = 256
          user_type    = 0x8000
      [partition]
          name         = boot
          size         = 5120
          user_type    = 0x8000
      [partition]
          name         = rootfs
          ;size         = 1024
          size         = 11520
          user_type    = 0x8000
      [partition]
          name         = rootfs_data
          size         = 1024
          user_type    = 0x8000
      ;[partition]
      ;    name         = extend
      ;    size         = 8192
      [partition]
          name         = misc
          size         = 128
          user_type    = 0x8000
      [partition]
          name         = private
          size         = 128
          user_type    = 0x8000
      [partition]
          name         = UDISK
          user_type    = 0x8100
