    【模块第三弹】哪吒中的LEDC的驱动
    5
    7
    6797
    • BedRock
      BedRock LV 6 最后由 编辑
      实现了控制LEDC的接口,通过宏定义控制LEDC的个数,前提是需要在dts中打开这么多个LEDC设备。封装成内部接口,当然也可以自定义修改。
      • 集成颜色解码接口,使用宏定义声明颜色,调用颜色解码接口即可显示出对应的颜色。
      • 目前有三种流水样式,其他流水样式可以参考这三种流水样式做修改。
      代码main.c
      #include "ws2812.h"
          printf("demo 1\n");
          //LEDC_LiuShui();
          //LED_LiuShui2();
          LiuSui3();
      代码ws2812.h
      #ifndef WS2812_H
      #define WS2812_H
      #include <stdlib.h>
      #include <unistd.h>
      #include <sys/types.h>
      #include <sys/stat.h>
      #include <fcntl.h>
      typedef unsigned char uint8;
      typedef unsigned int uint32;
      #define LED_NUM 32
      #define LEDC_RED_PATH "/sys/class/leds/sunxi_led%dr/brightness"
      #define LEDC_GREEN_PATH "/sys/class/leds/sunxi_led%dg/brightness"
      #define LEDC_BLUE_PATH "/sys/class/leds/sunxi_led%db/brightness"
      #define delay_ms(x)  (usleep(x*1000))
      #define MediumTurquoise 0x48D1CC
      #define Gold            0xFFD700
      #define DarkGray        0xA9A9A9
      #define Magenta         0xFF00FF
      #define Yellow          0xFFFF00
      int LED_LiuShui2();
      int LEDC_LiuShui();
      int LED_Color(int led,uint8 R,uint8 G,uint8 B);
      int ColorDecode(uint32 color ,uint8 *R,uint8 *G,uint8 *B);
      int LiuSui3();
      代码ws2812.c
      #include "ws2812.h"
      static int export_fd;
      static int color[3] = {0,0,255}; //RGB
      int LED_LiuShui2(){
          int i;
          int mode = 0;
          int R= 0 ,G = 0,B = 0;
          while(1){
              if(i == 32)
                  i = 0;
                  mode += 1;
              if(mode == 0){
                  R = 255; G = 0; B = 0;
              if (mode == 1){
                  R = 0; G = 255; B = 0;
              if(mode == 2){
                  R = 0; G = 0; B = 255;
              if(mode == 3)
                  mode = 0;
                  printf("delate 0\n");
              LED_Color(i,R,G,B);
              i++;
              delay_ms(20);
          return 1;
      int LEDC_LiuShui(){
          int i = 0,len;
          char ledPath[45] = {0};
          char led_write[3] = {0};
          printf("demo 1 \n");
          while(1){
              for(i = 0 ; i < LED_NUM ; i++){
              printf("LED %d \n",i);
              sprintf(ledPath,LEDC_BLUE_PATH,i);
              export_fd = open(ledPath, O_WRONLY);
              if(-1 == export_fd)
                  printf("[%s]:[%d] open gpio direction file error\r\n", __FUNCTION__, __LINE__);
                  return -1;
              len = sprintf(led_write,"%d",color[2]);
              if(-1 == write(export_fd, led_write, len))
                  printf("[%s]:[%d] write operation direction error\r\n", __FUNCTION__, __LINE__);
                  close(export_fd);
                  return -1;
              close(export_fd);
              if(i>3){
                  sprintf(ledPath,LEDC_BLUE_PATH,i-3);
                  if(-1 == export_fd)
                      return -1;
                  len = sprintf(led_write,"%d",0);
                      close(export_fd);
                      return -1;
                  close(export_fd);
              else {
                  sprintf(ledPath,LEDC_BLUE_PATH,i+29);
                  if(-1 == export_fd)
                      return -1;
                      close(export_fd);
                      return -1;
                  close(export_fd);
              delay_ms(50);
          printf("demo 1 end \n");
          return 1;
          int len;
          sprintf(ledPath,LEDC_BLUE_PATH,led);
          if(-1 == export_fd)
              return -1;
          len = sprintf(led_write,"%d",B);
              close(export_fd);
              return -1;
          close(export_fd);
          sprintf(ledPath,LEDC_GREEN_PATH,led);
          if(-1 == export_fd)
              return -1;
          len = sprintf(led_write,"%d",G);
              close(export_fd);
              return -1;
          close(export_fd);
          sprintf(ledPath,LEDC_RED_PATH,led);
          if(-1 == export_fd)
              return -1;
          len = sprintf(led_write,"%d",R);
              close(export_fd);
              return -1;
          close(export_fd);
      int ColorDecode(uint32 color ,uint8 *R,uint8 *G,uint8 *B){
          *R = (color >> 16) & 0x000011;
          *G = (color >> 8 ) & 0x000011;
          *B = (color >> 0 ) & 0x000011;
      int LiuSui3(){
          int i;
          int mode = 0;
          uint8 R= 0 ,G = 0,B = 0;
          while(1){
              if(i == 32)
                  i = 0;
                  mode += 1;
              if(mode == 0){
                  ColorDecode(MediumTurquoise,&R,&G,&B);
              if (mode == 1){
                  ColorDecode(Gold,&R,&G,&B);
              if(mode == 2){
                  ColorDecode(DarkGray,&R,&G,&B);
              if(mode == 3)
                  mode = 0;
              LED_Color(i,R,G,B);
              i++;
              delay_ms(20);
          return 1;
      Makefile
      CC := riscv64-unknown-linux-gnu-gcc
      target = ws2812
      LDFLAGS ?= -lm
      CFLAGS ?= -I .
      CSRCS += ws2812.c
      MAINSRC  = main.c
      all : default
      OBJEXT ?= .o
      COBJS = $(CSRCS:.c=$(OBJEXT))
      MAINOBJ = $(MAINSRC:.c=$(OBJEXT))
      # SRCS =  $(CSRCS) $(MAINSRC)s
      %.o: %.c
      	@$(CC)  $(CFLAGS) -c $< -o $@
      	@echo "CC $<"
      default:  $(COBJS) $(MAINOBJ)
      	$(CC) -o $(target) $(MAINOBJ)  $(COBJS) $(LDFLAGS)
      clean:
      	rm -f $(target) $(AOBJS) $(COBJS) $(MAINOBJ)
      • BedRock
        BedRock LV 6 最后由 编辑
        代码文件:WS2812.tar.gz
          DOT小文哥 LV 8 最后由 编辑
          Holihi~看看实际效果
          • tigger
            tigger LV 7 最后由 编辑
            闲鱼上面看到的,显示屏是WS2812
              HQEmbed LV 6 最后由 编辑
              不错,买了根灯条回来,效果是挺漂亮的。不过FIFO最大32的深度,如果更多颗灯要怎么编程呢?
                HQEmbed LV 6 最后由 编辑
                LEDC在一个机型上要真正用起来,的确是个比较吸引视觉的部件,但32还是少了点
                  huali LV 3 最后由 编辑
                  测试200个灯没问题;大于32个灯,驱动程序自动DMA传输,小于32,CPU传输
