    使用OpenCV实时显示USB摄像头画面到屏幕上
    5
    7
    6906
    • IAMLIUBO
      IAMLIUBO LV 5 最后由 编辑
      前置工作:
      在Ubuntu中交叉编译Opencv 4.5.1 运行于Tina Linux中(整合帖)
      借助OpenCV实时显示摄像头画面,需要先参考上面的帖子编译好OpenCV。
      剩下的工作就很简单了,代码是从stackoverflow借鉴(copy)的,交叉编译下就可以运行了:
      fbwrite_video.cpp
       * @file fbwrite_video.cpp
       * Displays OpenCV video on framebuffer.
       * Compile with
       * g++ -o fbwrite_video -lopencv_core -lopencv_highgui -lopencv_imgproc fbwrite_video.cpp
       * Contains code from https://stackoverflow.com/questions/4722301/writing-to-frame-buffer
      #include <iostream> // for std::cerr
      #include <opencv2/opencv.hpp>  // for cv::cvtColor
      #include <fstream>  // for ofstream
      // this is C :/
      #include <stdint.h> // for uint32_t
      #include <sys/ioctl.h> // for ioctl
      #include <linux/fb.h> // for fb_
      #include <fcntl.h> // for O_RDWR
      struct framebuffer_info {
          uint32_t bits_per_pixel; uint32_t xres_virtual;
      struct framebuffer_info get_framebuffer_info(const char *framebuffer_device_path)
          struct framebuffer_info info;
          struct fb_var_screeninfo screen_info;
          int fd = -1;
          fd = open(framebuffer_device_path, O_RDWR);
          if (fd >= 0) {
              if (!ioctl(fd, FBIOGET_VSCREENINFO, &screen_info)) {
                  info.xres_virtual = screen_info.xres_virtual;
                  info.bits_per_pixel = screen_info.bits_per_pixel;
          return info;
      // C ends here
      int main(int, char **)
          const int frame_width = 240;
          const int frame_height = 320;
          const int frame_rate = 10;
          framebuffer_info fb_info = get_framebuffer_info("/dev/fb0");
          cv::VideoCapture cap(0);
          if (!cap.isOpened()) {
              std::cerr << "Could not open video device." << std::endl;
              return 1;
          } else {
              std::cout << "Successfully opened video device." << std::endl;
              cap.set(cv::CAP_PROP_FRAME_WIDTH, frame_width);
              cap.set(cv::CAP_PROP_FRAME_HEIGHT, frame_height);
              cap.set(cv::CAP_PROP_FPS, frame_rate);
              std::ofstream ofs("/dev/fb0");
              cv::Mat frame;
              cv::Mat rotation_fream;
              while (true) {
                  cap >> frame;
                  if (frame.depth() != CV_8U) {
                      std::cerr << "Not 8 bits per pixel and channel." << std::endl;
                  } else if (frame.channels() != 3) {
                      std::cerr << "Not 3 channels." << std::endl;
                  } else {
                      // 3 Channels (assumed BGR), 8 Bit per Pixel and Channel
                      cv::transpose(frame, rotation_fream);
                      cv::flip(rotation_fream, frame, 0);
                      int framebuffer_width = fb_info.xres_virtual;
                      int framebuffer_depth = fb_info.bits_per_pixel;
                      cv::Size2f frame_size = frame.size();
                      cv::Mat framebuffer_compat;
                      switch (framebuffer_depth) {
                          case 16:
                              cv::cvtColor(frame, framebuffer_compat, cv::COLOR_BGR2BGR565);
                              for (int y = 0; y < frame_size.height ; y++) {
                                  ofs.seekp(y * framebuffer_width * 2);
                                  ofs.write(reinterpret_cast<char *>(framebuffer_compat.ptr(y)), frame_size.width * 2);
                              break;
                          case 32:
                                  std::vector<cv::Mat> split_bgr;
                                  cv::split(frame, split_bgr);
                                  split_bgr.push_back(cv::Mat(frame_size, CV_8UC1, cv::Scalar(255)));
                                  cv::merge(split_bgr, framebuffer_compat);
                                      ofs.seekp(y * framebuffer_width * 4);
                                      ofs.write(reinterpret_cast<char *>(framebuffer_compat.ptr(y)), frame_size.width * 4);
                              break;
                          default:
                              std::cerr << "Unsupported depth of framebuffer." << std::endl;
      这里分辨率是适配我的小屏幕的,如果用别的屏幕可以修改代码中的分辨率。
      CMakeLists.txt
      cmake_minimum_required(VERSION 2.8)
      project( fbwrite_video )
      SET(CROSS_COMPILE 1)
      set(CMAKE_SYSTEM_NAME Linux)
      SET(CMAKE_BUILD_TYPE "Release")
      set(CMAKE_C_COMPILER "/path/to/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/riscv64-unknown-linux-gnu-gcc")
      set(CMAKE_CXX_COMPILER "/path/to/tina-d1-open/prebuilt/gcc/linux-x86/riscv/toolchain-thead-glibc/riscv64-glibc-gcc-thead_20200702/bin/riscv64-unknown-linux-gnu-g++")
      find_package(OpenCV REQUIRED)
      include_directories(${OpenCV_INCLUDE_DIRS})
      add_executable(opencvTest fbwrite_video.cpp)
      target_link_libraries(opencvTest "/path/to//risc-v/install/lib/libopencv_world.so.4.5.2")
      效果:
      俺的B站
      本站播放:
      这里只是简单测试下,大家也可以跑点真正的CV代码,套路都差不多。
      H 1 条回复 最后回复 回复 引用 分享 2
      • BedRock
        BedRock LV 6 最后由 编辑
        咦,videocapture可以直接打开摄像头吗,我之前尝试不能打开摄像头?😣
        IAMLIUBO 1 条回复 最后回复 回复 引用 分享 0
        • IAMLIUBO
          IAMLIUBO LV 5 @BedRock 最后由 编辑
          @bedrock
          ? 没问题呀,可以打开的
          • BedRock
            BedRock LV 6 最后由 编辑
            那有了CV一切都好玩了起来😄
              波哥干得漂亮,再流畅一点点就如丝顺滑了。
              • Referenced by  L lfdcn
                hu487364 LV 5 @IAMLIUBO 最后由 编辑
                @iamliubo 您好,我参照您给出的代码,成功运行,但是当我修改分辨率时,最后运行的结果不对,请问我具体应该如何修改。下面是我自己修改的:
                  逗 LV 5 最后由 编辑
                  @iamliubo 在 使用OpenCV实时显示USB摄像头画面到屏幕上 中说:
                  您好,我的opencv交叉编译过了,但是板子上的lib没有空间了,我就把lib放到了sd中,然后通过软链接到lib中,但运行opencv_version函数还是会报错如下:
                  root@TinaLinux:/mnt/sdcard# ./opencv_version
                  Error loading shared library ../../lib/libopencv_core.so: Symbolic link loop (needed by ./opencv_version)
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device9availableEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl6DeviceC1Ev: symbol not found
                  Error relocating ./opencv_version: _ZN2cv5utils5trace7details8traceArgERKNS2_8TraceArgEPKc: symbol not found
                  Error relocating ./opencv_version: _ZN2cv5errorEiRKNS_6StringEPKcS4_i: symbol not found
                  Error relocating ./opencv_version: _ZN2cv17CommandLineParserD1Ev: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device24preferredVectorWidthLongEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv22getHardwareFeatureNameEi: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device11addressBitsEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl10haveAmdFftEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device14doubleFPConfigEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv17CommandLineParser12printMessageEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device15maxMemAllocSizeEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv5utils5trace7details6RegionC1ERKNS3_21LocationStaticStorageE: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device13driverVersionEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device12localMemSizeEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv17CommandLineParser3hasERKNS_6StringE: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl12PlatformInfo4nameEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device17hostUnifiedMemoryEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv20checkHardwareSupportEi: symbol not found
                  Error relocating ./opencv_version: _ZN2cv19getBuildInformationEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl6DeviceD1Ev: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv17CommandLineParser9getByNameERKNS_6StringEbiPv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device4typeEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv17CommandLineParserC1EiPKPKcRKNS_6StringE: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device4nameEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl9useOpenCLEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl12PlatformInfo9getDeviceERNS0_6DeviceEi: symbol not found
                  Error relocating ./opencv_version: _ZN2cv24currentParallelFrameworkEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv6String8allocateEj: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device26preferredVectorWidthDoubleEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device25preferredVectorWidthShortEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device16maxWorkGroupSizeEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl12PlatformInfo12deviceNumberEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl6Device10getDefaultEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv5utils5trace7details8traceArgERKNS2_8TraceArgEi: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl11haveAmdBlasEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv6String10deallocateEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl15getPlatfomsInfoERSt6vectorINS0_12PlatformInfoESaIS2_EE: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device15maxComputeUnitsEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device24preferredVectorWidthCharEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv13getNumThreadsEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device10extensionsEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv5utils5trace7details6Region7destroyEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device25preferredVectorWidthFloatEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl10haveOpenCLEv: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device7versionEv: symbol not found
                  Error relocating ./opencv_version: _ZN2cv3ocl12PlatformInfoD1Ev: symbol not found
                  Error relocating ./opencv_version: _ZNK2cv3ocl6Device23preferredVectorWidthIntEv: symbol not found
                  root@TinaLinux:/mnt/sdcard# bash: cd: /mnt/sdcard/samples: 没有那个文件或目录
