    t113的spi设置clk的频率
      dort91011 LV 5 最后由 编辑
      请教下老铁们,t113的spi怎么设置clk的频率啊
      这里调了没用,应用层设了也没用
        axw_fae LV 4 最后由 编辑
        你要注意一下,这儿的 spi 速度值并不是可以随便设置的! 因為 cpu 除频后会配不上! 会跳到默认的 10Mhz 的速度。
        建议你可以在 .... spi 中,加打印,看看你那值是否可以通过!
        /driver/spi/spi-sunxi.c 中
        /* set spi clock */
        static void spi_set_clk(u32 spi_clk, u32 ahb_clk, struct sunxi_spi *sspi)
                u32 spi_test = 100000000;
                u32 get_spi;
        	dprintk(DEBUG_INFO, "set spi clock %d, mclk %d\n", spi_clk, ahb_clk);
        	for(spi_test = 50000000; spi_test >= 20000000; spi_test -= 1000000)
        		clk_set_rate(sspi->mclk, spi_test);
        		get_spi = clk_get_rate(sspi->mclk);
        		printk("spi_test %d  == get %d \n", spi_test, get_spi);
        像我以 100Mhz 到 80Mhz , 每 1Mhz 做变化!
        [    1.079831] spi_test 100000000  == get 100000000 ␍␊
        [    1.093426] spi_test 99000000  == get 96000000 ␍␊
        [    1.098527] spi_test 98000000  == get 96000000 ␍␊
        [    1.103587] spi_test 97000000  == get 96000000 ␍␊
        [    1.108714] spi_test 96000000  == get 96000000 ␍␊
        [    1.113807] spi_test 95000000  == get 92307692 ␍␊
        [    1.118905] spi_test 94000000  == get 92307692 ␍␊
        [    1.123996] spi_test 93000000  == get 92307692 ␍␊
        [    1.129127] spi_test 92000000  == get 87771428 ␍␊
        [    1.134193] spi_test 91000000  == get 87771428 ␍␊
        [    1.139293] spi_test 90000000  == get 87771428 ␍␊
        [    1.144406] spi_test 89000000  == get 87771428 ␍␊
        [    1.149506] spi_test 88000000  == get 87771428 ␍␊
        [    1.154601] spi_test 87000000  == get 85714285 ␍␊
        [    1.159739] spi_test 86000000  == get 85714285 ␍␊
        [    1.164835] spi_test 85000000  == get 80000000 ␍␊
        [    1.169939] spi_test 84000000  == get 80000000 ␍␊
        [    1.175074] spi_test 83000000  == get 80000000 ␍␊
        [    1.180142] spi_test 82000000  == get 80000000 ␍␊
        [    1.185243] spi_test 81000000  == get 80000000 ␍␊
        [    1.190346] spi_test 80000000  == get 80000000 ␍␊
        就可以知道,有一些值设置是不行的! 要特定值才行!
