    给D1 SDK 添加一个简单的helloworld package
    5
    10
    126671
    • tigger
      tigger LV 7 最后由 whycan 编辑
      目录结构:
      /opt/D1/tina_d1_open$ tree package/helloworld/
      package/helloworld/
      ├── Makefile
      └── src
          ├── helloworld.c
          └── Makefile
      1 directory, 3 files
      package/helloworld/Makefile 文件内容:
      include $(TOPDIR)/rules.mk
      # Name and release number of this package
      PKG_NAME:=helloworld
      PKG_RELEASE:=1
      # This specifies the directory where we’re going to build the program.
      # The root build directory, $(BUILD_DIR), is by default the build_mipsel
      # directory in your OpenWrt SDK directory
      PKG_BUILD_DIR := $(COMPILE_DIR)/$(PKG_NAME)
      HAVE_SOURCE := yes
      include $(BUILD_DIR)/package.mk
      # Specify package information for this program.
      # The variables defined here should be self explanatory.
      # If you are running Kamikaze, delete the DESCRIPTION
      # variable below and uncomment the Kamikaze define
      # directive for the description below
      define Package/$(PKG_NAME)
      	SECTION:=utils
      	CATEGORY:=Utilities
      	TITLE:=hello world test
      endef
      # Uncomment portion below for Kamikaze and delete DESCRIPTION variable above
      define Package/$(PKG_NAME)/description
      If you can’t figure out what this program does, you’re probably
      brain-dead and need immediate medical attention.
      endef
      # Specify what needs to be done to prepare for building the package.
      # In our case, we need to copy the source files to the build directory.
      # This is NOT the default. The default uses the PKG_SOURCE_URL and the
      # PKG_SOURCE which is not defined here to download the source from the web.
      # In order to just build a simple program that we have just written, it is
      # much easier to do it this way.
      define Build/Prepare
      	mkdir -p $(PKG_BUILD_DIR)
      	$(CP) ./src/* $(PKG_BUILD_DIR)/
      endef
      # We do not need to define Build/Configure or Build/Compile directives
      # The defaults are appropriate for compiling a simple program such as this one
      # Specify where and how to install the program. Since we only have one file,
      # the helloworld executable, install it by copying it to the /bin directory on
      # the router. The $(1) variable represents the root directory on the router running
      # OpenWrt. The $(INSTALL_DIR) variable contains a command to prepare the install
      # directory if it does not already exist. Likewise $(INSTALL_BIN) contains the
      # command to copy the binary file from its current location (in our case the build
      # directory) to the install directory.
      define Package/helloworld/install
      	$(INSTALL_DIR) $(1)/bin
      	$(INSTALL_BIN) $(PKG_BUILD_DIR)/helloworld $(1)/bin/
      endef
      # This line executes the necessary commands to compile our program.
      # The above define directives specify all the information needed, but this
      # line calls BuildPackage which in turn actually uses this information to
      # build a package.
      $(eval $(call BuildPackage,$(PKG_NAME)))
      package/helloworld/src/helloworld.c 文件内容:
      * Helloworld.c
      * The most simplistic C program ever written.
      * An epileptic monkey on crack could write this code.
      #include <unistd.h>
      int main(void)
      	printf("Hell! O’ world, why won’t my code compile?\n\n");
      package/helloworld/src/Makefile 文件内容:
      # build helloworld executable when user executes “make”
      helloworld: helloworld.o
      	$(CC) $(LDFLAGS) helloworld.o -o helloworld
      helloworld.o: helloworld.c
      	$(CC) $(CFLAGS) -c helloworld.c
      # remove object files and executable when user executes “make clean”
      clean:
      	rm *.o helloworld
      • tigger
        tigger LV 7 最后由 编辑
        • tigger
          tigger LV 7 最后由 编辑
          root@TinaLinux:/# helloworld
          烧到板子,执行 helloworld,完全OK
          • tigger
            实际测试的时候, helloworld 文件夹可以埋多三层,make 还能找到,如果四层/五层以上就扫描不到不到了。
            执行: mv package/helloworld package/test1/test2/test3/
            重新 lunch
            make package/helloworld/compile
            或者:
            make package/test1/test2/test3/helloworld/compile
            均可以成功。
            参考这个链接: https://www.litreily.top/2021/01/15/mk-scan/
            J 1 条回复 最后回复 回复 引用 分享 0
              jordonwu LV 6 @tigger 最后由 编辑
              @tigger 在 给D1 SDK 添加一个简单的helloworld package 中说:
              递归多少层都可以,只要你source xxx 正确了
              • tigger
                tigger LV 7 最后由 编辑
                ubuntu:/opt/D1/tina_d1_open$ ls package/test1/test2/test3/test4/test5/test6/helloworld/
                Makefile  src
                ubuntu:/opt/D1/tina_d1_open$ make package/test1/test2/test3/test4/test5/test6/helloworld/compile
                ===This's tina environment.===
                special target, skip mboot,marisc
                make[1]: Entering directory '/opt/D1/tina_d1_open'
                make[1]: *** No rule to make target 'package/test1/test2/test3/test4/test5/test6/helloworld/compile'.  Stop.
                make[1]: Leaving directory '/opt/D1/tina_d1_open'
                /opt/D1/tina_d1_open/build/toplevel.mk:304: recipe for target 'package/test1/test2/test3/test4/test5/test6/helloworld/compile' failed
                make: *** [package/test1/test2/test3/test4/test5/test6/helloworld/compile] Error 2
                #### make failed to build some targets (8 seconds) ####
                真不行,按理 scan.mk 不可能无限层级遍历Makefile 文件。
                • U
                  ubuntu LV 7 最后由 编辑
                  ubuntu:/opt/D1/tina_d1_open$ mv package/test1/test2/test3/test4/test5/test6/helloworld/ package/test1/test2/test3
                  ubuntu:/opt/D1/tina_d1_open$ lunch
                  You're building on Linux
                  Lunch menu... pick a combo:
                       1. d1_f133evb1_rgb800x480-tina
                       2. d1_nezha_min2-tina
                       3. d1_nezha_min3-tina
                       4. d1_nezha_min-tina
                       5. d1_nezha-tina
                  Which would you like? [Default d1_nezha]: 5
                  TINA_BUILD_TOP=/opt/D1/tina_d1_open
                  TINA_TARGET_ARCH=riscv
                  TARGET_PRODUCT=d1_nezha
                  TARGET_PLATFORM=d1
                  TARGET_BOARD=d1-nezha
                  TARGET_PLAN=nezha
                  TARGET_BUILD_VARIANT=tina
                  TARGET_BUILD_TYPE=release
                  TARGET_KERNEL_VERSION=5.4
                  TARGET_UBOOT=u-boot-2018
                  TARGET_CHIP=sun20iw1p1
                  ubuntu:/opt/D1/tina_d1_open$ make package/test1/test2/test3/helloworld/compile
                  Collecting package info: done
                  Collecting target info: done
                  make[2]: Entering directory '/opt/D1/tina_d1_open/package/libs/toolchain'
                  if [ -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libc" >> /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
                  if [ -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libgcc" >> /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
                  if [ -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libssp" >> /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
                  if [ -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libstdcpp" >> /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
                  if [ -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "libpthread" >> /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
                  if [ -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean ]; then rm -f /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install.clean; fi; echo "librt" >> /opt/D1/tina_d1_open/out/d1-nezha/staging_dir/target/pkginfo/toolchain.default.install
                  make[2]: Leaving directory '/opt/D1/tina_d1_open/package/libs/toolchain'
                  make[2]: Entering directory '/opt/D1/tina_d1_open/package/test1/test2/test3/helloworld'
                  make[2]: Leaving directory '/opt/D1/tina_d1_open/package/test1/test2/test3/helloworld'
                  #### make completed successfully (29 seconds) ####
                  为了证实,我再次操作了一遍。
                  • jinxiangwzh
                    jinxiangwzh LV 7 最后由 编辑
                    Utilities这个目录怎么创建的?
                      whycan晕哥 LV 9 @jinxiangwzh 最后由 编辑
                      @jinxiangwzh
                      CATEGORY:=Utilities 指的是 make menuconfig 的第一级菜单。
                      • jinxiangwzh
                        jinxiangwzh LV 7 @whycan 最后由 编辑
