    有没有大神帮忙看看xr806的http的get接口获取数较大的适合会容易出现下面问题
    • T
      Tristan_C LV 4 最后由 编辑
      有没有大神帮忙看看,附件的代码,在执行之后,会出现获取的内容后半段是乱码的情况
      试用xr806芯片,开发板,采用example里面的httpc例程,适当修改如下,主要功能就是通过天气接口,获取天气json数据,然后调用cjson接口解析
       * Copyright (C) 2017 XRADIO TECHNOLOGY CO., LTD. All rights reserved.
       *  Redistribution and use in source and binary forms, with or without
       *  modification, are permitted provided that the following conditions
       *  are met:
       *    1. Redistributions of source code must retain the above copyright
       *       notice, this list of conditions and the following disclaimer.
       *    2. Redistributions in binary form must reproduce the above copyright
       *       notice, this list of conditions and the following disclaimer in the
       *       documentation and/or other materials provided with the
       *       distribution.
       *    3. Neither the name of XRADIO TECHNOLOGY CO., LTD. nor the names of
       *       its contributors may be used to endorse or promote products derived
       *       from this software without specific prior written permission.
       *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
       *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
       *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
       *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
       *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
       *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
       *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
       *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
       *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
       *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
       *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
      #include "kernel/os/os.h"
      #include "common/framework/platform_init.h"
      #include "net/wlan/wlan.h"
      #include "common/framework/net_ctrl.h"
      #include "net/HTTPClient/HTTPCUsr_api.h"
      #include "mbedtls/mbedtls.h"
      #include "cjson/cJSON.h"
      #define  DEMO_TEST_FUNC_TIME		1
      #define  DEMO_TEST_FUNC_WEATHER		2
      #define  DEMO_TEST_FUNC				DEMO_TEST_FUNC_WEATHER
      #define HTTPC_DEMO_THREAD_STACK_SIZE (16 * 1024) /* ssl need more stack */
      static OS_Thread_t httpc_demo_thread;
      #if (DEMO_TEST_FUNC == DEMO_TEST_FUNC_WEATHER)
      #	define HTTPC_DEMO_URL "http://t.weather.sojson.com/api/weather/city/101210101"
      #else
      #	define HTTPC_DEMO_URL "http://quan.suning.com/getSysTime.do"
      static HTTPParameters httpc_demo_param;
      char httpc_demo_buf[8192] = {0};
      static void httpc_demo_download(char *url, int use_ssl)
      	uint32_t download_len = 0;
      	INT32 recv_len = 0;
      	int32_t ret;
      	uint32_t download_time = 0;
      	memset(&httpc_demo_param, 0, sizeof(httpc_demo_param));
      	memcpy(httpc_demo_param.Uri, url, strlen(url));
      	httpc_demo_param.nTimeout = 30; //timeout 30s for every get
      	download_time = OS_GetTicks();
      	memset(httpc_demo_buf, 0, sizeof(httpc_demo_buf));
      	while (1) {
      		ret = HTTPC_get(&httpc_demo_param, httpc_demo_buf, sizeof(httpc_demo_buf), &recv_len);
      		if (ret != HTTP_CLIENT_SUCCESS) {
      			break;
      		download_len += recv_len;
      		printf("%.*s", sizeof(httpc_demo_buf), httpc_demo_buf);
      		printf("\n\nhttp get return value: %d, len=%u\n\n", ret, download_len);
      	if (ret == HTTP_CLIENT_EOS) {
      		download_time = OS_GetTicks() - download_time;
      		printf("\n\n\ndownload complete, download_len %d, time %ds\n\n\n",
      		       download_len, download_time/1000);
      		cJSON* cjson = cJSON_Parse(httpc_demo_buf);//将JSON字符串转换成JSON结构体
      		if(cjson == NULL)						//判断转换是否成功
      			printf("cjson error...\n\n");
      			printf("%s\n\n",cJSON_Print(cjson));//打包成功调用cJSON_Print打印输出
      			char * city = cJSON_GetObjectItem(cjson,"city")->valuestring;
      			char * temp = cJSON_GetObjectItem(cjson,"wendu")->valuestring;
      			char * humi = cJSON_GetObjectItem(cjson,"shidu")->valuestring;
      			printf("城市: %s\n",city);
      			printf("温度:%s\n",temp);
      			printf("湿度:%s\n",humi);
      #else
      			char * time_1 = cJSON_GetObjectItem(cjson,"sysTime1")->valuestring;
      			char * time_2 = cJSON_GetObjectItem(cjson,"sysTime2")->valuestring;
      			printf("time_1: %s\n\n",time_1);
      			printf("time_2: %s\n\n",time_2);
      	} else {
      		printf("\n\ndownload error, ret=%d\n", ret);
      static void httpc_demo_fun(void *arg)
      	while(1)
      		httpc_demo_download(HTTPC_DEMO_URL, 0);
      		OS_MSleep(5000);
      	OS_ThreadDelete(&httpc_demo_thread);
      static void net_cb(uint32_t event, uint32_t data, void *arg)
      	uint16_t type = EVENT_SUBTYPE(event);
      	switch (type) {
      	case NET_CTRL_MSG_NETWORK_UP:
      		if (!OS_ThreadIsValid(&httpc_demo_thread)) {
      			OS_ThreadCreate(&httpc_demo_thread,
      			                    "httpc_demo_thread",
      			                    httpc_demo_fun,
      			                    (void *)NULL,
      			                    OS_THREAD_PRIO_APP,
      			                    HTTPC_DEMO_THREAD_STACK_SIZE);
      		break;
      	case NET_CTRL_MSG_NETWORK_DOWN:
      		break;
      	default:
      		break;
      int main(void)
      	observer_base *net_ob;
      	platform_init();
      	printf("httpc demo start\n\n");
      	printf("use these commands to connect ap:\n\n");
      	printf("1. config ssid and password : net sta config ssid password\n");
      	printf("2. enable sta to connect ap : net sta enable\n\n");
      	/* create an observer to monitor the net work state */
      	net_ob = sys_callback_observer_create(CTRL_MSG_TYPE_NETWORK,
      	                                     NET_CTRL_MSG_ALL,
      	                                     net_cb,
      	                                     NULL);
      	if (net_ob == NULL)
      		return -1;
      	if (sys_ctrl_attach(net_ob) != 0)
      		return -1;
      配网之后,拉取http数据,出现了后半段乱码的情形
      判了一小段时间更是出现了heap问题
      但我看这个heap已经开到了200多KB了,应该不至于这么快出现问题
      请大神们帮忙把把关,把把脉,感激不尽!
      httpc.rar
