    SDK文件夹移动位置后编译出来的img 烧录到板子上,报硬件检查错误,怎么回事?
      hy123456 LV 5 最后由 编辑
      R528的SDK,在原来文件下编译时没有问题的,我现在需要复制出一份来做对应修改,但是发现编译出来的img 烧录到板子上,报硬件检查错误,请大神们指点一下是怎么回事?
      ▒[29]HELLO! BOOT0 is starting!T
      [32]BOOT0 commit : 4d16602
      [34]set pll start
      [40]periph0 has been enabled
      [43]set pll end
      [45][pmu]: bus read error
      [47]board init ok
      [49]ZQ value = 0x2e
      [51]get_pmu_exist() = -1
      [53]DRAM BOOT DRIVE INFO: V0.33
      [56]DRAM CLK = 792 MHz
      [59]DRAM Type = 3 (2:DDR2,3:DDR3)
      [62]DRAMC read ODT off.
      [64]DRAM ODT value: 0x42.
      [67]ddr_efuse_type: 0xb
      [70]DRAM SIZE =128 M
      [72]dram_tpr4:0x0
      [74]PLL_DDR_CTRL_REG:0xf8004100
      [77]DRAM_CLK_REG:0xc0000000
      [79][TIMING DEBUG] MR2= 0x18
      [86]DRAM simple test OK.
      [89]rtc standby flag is 0x0, super standby flag is 0x0
      [94]dram size =128
      [96]card no is 2
      [98]sdcard 2 line count 4
      [100][mmc]: mmc driver ver 2021-05-21 14:47
      [110][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [116][mmc]: Try MMC card 2
      [140][mmc]: RMCA OK!
      [142][mmc]: mmc 2 bias 0
      [145][mmc]: MMC 5.1
      [147][mmc]: HSSDR52/SDR25 4 bit
      [150][mmc]: 50000000 Hz
      [152][mmc]: 3740 MB
      [154][mmc]: SD/MMC 2 init OK!!!
      [243]Loading boot-pkg Succeed(index=0).
      [247]Entry_name = u-boot
      [254]Entry_name = optee
      [258]Entry_name = dtb
      [261]tunning data addr:0x430003e8
      [264]Jump to second Boot.
      M/TC: OP-TEE version: 963b7e95 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Wed Jul 28 12:51:52 UTC 2021 arm
      E/TC:0 0 check_hardware_info:90 hardware check error1
      E/TC:0 0 Panic at core/arch/arm/plat-sun8iw20p1/main.c:301 <plat_init>
      E/TC:0 0 Call stack:
      E/TC:0 0 0x41b0a271
        awwwwa LV 8 @hy123456 最后由 编辑
        @hy123456 移动位置后需要删除out文件夹,因为SDK生成的设备的认证信息变化了但是由于SDK移动没有重新生成新的认证
