    哪吒官方HDMI固件烧写后,开机log报错
      Luobibaicai LV 2 最后由 编辑
      3.837833] Loading compiled-in X.509 certificates
      [ 3.845596] HDMI 2.0 driver init start!
      [ 3.849888] boot_hdmi=false
      [ 3.853168] ERROR: pinctrl_get for HDMI2.0 DDC fail
      [ 3.860175] HDMI2.0 module init end
      [ 3.889847] twi twi2: twi2 supply twi not found, using dummy regulator
      [ 3.905156] pcf857x 2-0038: probed
      [ 3.915298] sunxi_i2c_probe()2262 - [i2c2] probe success
      [ 3.931337] debugfs: Directory '2031000.dmic' with parent 'snddmic' already p resent!
      [ 3.941736] sunxi-audio-card 2031060.sounddmic: snd-soc-dummy-dai <-> 2031000 .dmic mapping ok
      [ 3.952584] debugfs: Directory '2034000.daudio' with parent 'sndhdmi' already present!
      [ 3.963156] sunxi-audio-card 20340a0.sounddaudio2: snd-soc-dummy-dai <-> 2034 000.daudio mapping ok
      [ 3.974846] get ehci0-controller wakeup-source is fail.
      [ 3.980843] sunxi ehci0-controller don't init wakeup source
      [ 3.987091] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi _ehci: 0xffffffe0008d6388, 0x:ffffffd0052f5000, irq_no:2e
      [ 4.000648] [sunxi-ehci0]: Not init ehci0
      [ 4.005606] get ohci0-controller wakeup-source is fail.
      [ 4.011590] sunxi ohci0-controller don't init wakeup source
      [ 4.017836] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi _ohci: 0xffffffe0008d6ec8
      [ 4.028265] [sunxi-ohci0]: Not init ohci0
      [ 4.033976] ubi0: attaching mtd3
      [ 4.270390] HDMI cable is connected
      [ 5.044833] ubi0: scanning is finished
      [ 5.064842] ubi0: attached mtd3 (name "sys", size 250 MiB)
      [ 5.071080] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [ 5.078745] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [ 5.086405] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [ 5.094194] ubi0: good PEBs: 1000, bad PEBs: 0, corrupted PEBs: 0
      [ 5.101017] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [ 5.109090] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [ 5.118425] ubi0: available PEBs: 16, total reserved PEBs: 984, PEBs reserved for bad PEB handling: 20
      [ 5.128886] ubi0: background thread "ubi_bgt0d" started, PID 69
      [ 5.137570] block ubiblock0_5: created from ubi0:5(rootfs)
      [ 5.146049] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [ 5.157024] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [ 5.164658] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [ 5.174384] clk: Not disabling unused clocks
      [ 5.179153] ALSA device list:
      [ 5.182594] cfg80211: failed to load regulatory.db
      [ 5.188037] #0: audiocodec
      [ 5.191320] #1: snddmic
      [ 5.194238] #2: sndhdmi
      [ 5.197165] alloc_fd: slot 0 not NULL!
      [ 5.201659] error: invalid cea_vic code:0
      [ 5.206128] [HDMI2 error]: sink do not support this mode:0
      [ 5.216980] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
      [ 5.228621] devtmpfs: mounted
      [ 5.232203] Freeing unused kernel memory: 208K
      [ 5.237185] This architecture does not have kernel memory protection.
      [ 5.244440] Run /sbin/init as init process
      [ 6.134021] init: Console is alive
      [ 6.138105] init: - watchdog -
      [ 6.141765] init: - preinit -
      /dev/by-name/UDISK already format by ubifs
      [ 7.526856] mount_root: mounting /dev/root
      [ 7.532140] mount_root: loading kmods from internal overlay
      [ 7.798481] block: attempting to load /etc/config/fstab
      [ 7.843835] UBIFS (ubi0:8): Mounting in unauthenticated mode
      [ 7.850704] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 111
      [ 7.982288] UBIFS (ubi0:8): recovery needed
      [ 8.281147] UBIFS (ubi0:8): recovery completed
      [ 8.286320] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
      [ 8.294831] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      [ 8.306532] UBIFS (ubi0:8): FS size: 192503808 bytes (183 MiB, 746 LEBs), journal size 9420800 bytes (8 MiB, 37 LEB s)
      [ 8.318402] UBIFS (ubi0:8): reserved for root: 0 bytes (0 KiB)
      [ 8.325002] UBIFS (ubi0:8): media format: w4/r0 (latest is w5/r0), UUID A1957C40-5280-4546-88CF-CA8E706E0EE4, small LPT model
      [ 8.341965] block: extroot: UUID match (root: e4aac755-48e1b7c8-b32425c0-67317875, overlay: e4aac755-48e1b7c8-b3242 5c0-67317875)
      [ 8.363851] mount_root: switched to extroot
      [ 8.385428] procd: - early -
      [ 8.388790] procd: - watchdog -
      [ 8.823250] procd: - watchdog -
      [ 8.827078] procd: - ubus -
      [ 8.834802] procd (1): /proc/126/oom_adj is deprecated, please use /proc/126/oom_score_adj instead.
      [ 9.062844] procd: - init -
      [ 10.287575] fuse: init (API version 7.31)
      [ 10.446765] file system registered
      [ 10.611464] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [ 10.630766] get ctp_power is fail, -22
      [ 10.634949] get ctp_power_ldo_vol is fail, -22
      [ 10.639911] sunxi_ctp_startup: ctp_power_io is invalid.
      [ 10.746542] get ctp_gesture_wakeup fail, no gesture wakeup
      [ 10.810487] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
      [ 10.907370] read descriptors
      [ 10.920510] read strings
      [ 11.080664] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.100442] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.120450] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.135478] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.158909] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.180533] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [ 11.340434] <<-GTP-ERROR->> GTP i2c test failed time 1.
      [ 11.370718] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.388698] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.410669] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.430459] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.445566] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.468807] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [ 11.650433] <<-GTP-ERROR->> GTP i2c test failed time 2.
      [ 11.680599] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.700487] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.720449] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.729948] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.760247] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.780463] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [ 11.940434] <<-GTP-ERROR->> GTP i2c test failed time 3.
      [ 11.970683] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 11.989313] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.010666] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.030452] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.046059] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.069192] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [ 12.250440] <<-GTP-ERROR->> GTP i2c test failed time 4.
      [ 12.280596] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.290322] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.302185] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.313749] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.325123] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [ 12.335822] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [ 12.500419] <<-GTP-ERROR->> GTP i2c test failed time 5.
      [ 12.530433] I2C communication ERROR!
