    Nano pi neo 加载文件系统的时候出现的问题
    nano neo pi 文件系统
      aaabbb222 LV 4 最后由 编辑
      修改了include/configs/sun8i.h文件中的内容 ,具体如下: 提示的root后面的参数不对,是不是文件系统对应的名称不对,不是/dev/mmcblk0p2?
      谢谢大侠。
      #define CONFIG_BOOTCOMMAND "setenv bootm_boot_mode sec; "
      "load mmc 0:1 0x41000000 zImage; "
      "load mmc 0:1 0x41800000 sun8i-v3s-licheepi-zero-dock.dtb; "
      "bootz 0x41000000 - 0x41800000;"
      #define CONFIG_BOOTARGS "console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0"
       3.675032] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01 00:00:10 UTC (10)
      [    3.689357] vcc3v0: disabling
      [    3.698156] vcc5v0: disabling
      [    3.706831] usb0-vbus: disabling
      [    3.715700] ALSA device list:
      [    3.724235]   #0: Dummy 1
      [    3.732362]   #1: Loopback 1
      [    3.740717]   #2: H3 Audio Codec
      [    3.749433]   #3: allwinner,hdmi
      [    3.758774] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
      [    3.771879] Please append a correct "root=" boot option; here are the available partitions:
      [    3.785900] b300        15558144 mmcblk1
      [    3.785905]  driver: mmcblk
      [    3.803880]   b301           32768 mmcblk1p1 23a83b10-01
      [    3.803883]
      [    3.821749]   b302         8347648 mmcblk1p2 23a83b10-02
      [    3.821751]
      [    3.839477] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    3.853331] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.111-gec36a7d5-dirty #2
      [    3.866478] Hardware name: sun8i
      [    3.875354] [<c02287fc>] (unwind_backtrace) from [<c0225398>] (show_stack+0x10/0x14)
      [    3.888844] [<c0225398>] (show_stack) from [<c0a1ba3c>] (dump_stack+0x94/0xa8)
      [    3.901829] [<c0a1ba3c>] (dump_stack) from [<c0240dd0>] (panic+0xdc/0x254)
      [    3.914427] [<c0240dd0>] (panic) from [<c1001228>] (mount_block_root+0x18c/0x25c)
      [    3.927671] [<c1001228>] (mount_block_root) from [<c1001414>] (mount_root+0x11c/0x124)
      [    3.941372] [<c1001414>] (mount_root) from [<c1001574>] (prepare_namespace+0x158/0x19c)
      [    3.955171] [<c1001574>] (prepare_namespace) from [<c1000ef8>] (kernel_init_freeable+0x254/0x264)
      [    3.969889] [<c1000ef8>] (kernel_init_freeable) from [<c0a2ef4c>] (kernel_init+0x8/0x114)
      [    3.983968] [<c0a2ef4c>] (kernel_init) from [<c0222058>] (ret_from_fork+0x14/0x3c)
      [    3.997512] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [   61.924973] BUG: workqueue lockup - pool cpus=0 node=0 flags=0x0 nice=0 stuck for 58s!
      [   61.939007] BUG: workqueue lockup - pool cpus=0-3 flags=0x4 nice=0 stuck for 53s!
      [   61.952577] Showing busy workqueues and worker pools:
      [   61.963669] workqueue events: flags=0x0
      [   61.973520]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=4/256
      [   61.985570]     in-flight: 109:sun4i_usb_phy0_id_vbus_det_scan
      [   61.997440]     pending: vmstat_shepherd, dbs_work_handler, output_poll_execute
      [   62.010863] workqueue events_unbound: flags=0x2
      [   62.021482]   pwq 8: cpus=0-3 flags=0x4 nice=0 active=1/512
      [   62.033209]     pending: flush_to_ldisc
      [   62.043164] workqueue events_freezable: flags=0x4
      [   62.053982]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
      [   62.066135]     pending: thermal_zone_device_check
      [   62.077051] workqueue events_power_efficient: flags=0x80
      [   62.088487]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=5/256
      [   62.100621]     pending: fb_flashcursor, crda_timeout_work, neigh_periodic_work, do_cache_clean, neigh_periodic_work
      [   62.117467] workqueue mm_percpu_wq: flags=0x8
      [   62.128095]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
      [   62.140422]     pending: vmstat_update
      [   62.150518] workqueue pm: flags=0x4
      [   62.160221]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
      [   62.172399]     pending: pm_runtime_work
      [   62.182514] workqueue dm_bufio_cache: flags=0x8
      [   62.193151]   pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/256
      [   62.205299]     pending: work_fn
      [   62.214627] pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=58s workers=5 idle: 29 132 3 108
        awwwwa LV 8 最后由 编辑
        /dev/mmcblk1p2
          aaabbb222 LV 4 @awwwwa 最后由 编辑
